"Band on the Run" unlimited remaster, "retains the dynamic range of the original master recording"
2Bdecided
post Nov 10 2010, 11:22
ReplayGain developer
The anti "loudness race" trend continues...
HIGH RESOLUTION DETAILS
The audio industry has seen many technical innovations since Band on the Run was first released on vinyl in 1973, the most notable being digital recording. However, with the introduction of CD came two advances, “de-noising” and “peak limiting” which have become increasingly unpopular within certain areas of the music industry and amongst audiophiles.
De-noising was introduced to remove the inherent sound, or hiss, associated with analogue tape. The amount of processing used to remove tape noise can be varied, but when used excessively, many believe that it also has a detrimental effect on elements of the musical sound.
Peak limiting is a process that increases the loudness of music. It is achieved by holding the loudest peaks down and raising the overall level of the music. Much depends on the amount of limiting applied, but at its most extreme the result can be a serious reduction in the dynamic range and often audible distortion.
The release of The Beatles’ remasters in 2009 saw a marked change in attitudes towards these issues, where both noise reduction and limiting were used sparingly with the aim of representing the master tapes more accurately. Such is the case with the newly remastered CD of Band on the Run: tape noise reduction has scarcely been used and the degree of limiting is subtle. In addition digital technology has advanced with the ability now to offer recordings in 24 bit/96kHz. The high resolution version is being made available via download and is being offered in two formats: limited, which is comparable in volume to the remastered CD, and un-limited, which in comparison with the limited version will sound quieter, but retain the dynamic range of the original master recording.
Allan Rouse Abbey Road Studios
They're "only" charging an extra 3 / $5 above the comparable "CD" download, though you have no option but to pay for the 9 extra bonus tracks if you want hi-res.
If you just want the normal album, you're paying double to get hi-res (limited or unlimited version).
9-track "CD" download: 6 / $9
18-track "CD" download: 10 / $15
Hi-Res download: 13 / $20
Both Hi-Res downloads: 23 / $36
From here:
http://www.paulmccartney.com/bandontherun/
P.S. I haven't heard it. It's a shame it's not on Spotify! (The recent John Lennon releases are).
This post has been edited by 2Bdecided: Nov 10 2010, 12:15
C.R.Helmrich
post Nov 14 2010, 16:39
I'd probably take the limited version, because that's limiting how it should be done: subtle. When you compare the spectrograms in this post, you can see that the spectral content is almost identical in the limited and unlimited versions. There is a tiny bit more high-frequency content in the limited version, which is probably distortion due to the limiter, and three clipped transients (vertical lines), but the purple color of these added spectral components tells us that they are of very high frequency, very low level, and thus most likely inaudible. For comparison I delay- and volume-aligned the two versions from the upload thread by removing the first 231 samples of the unlimited version and amplifying the limited version by 0.69. The waveforms and spectra of the two versions are then so similar that I didn't bother trying to ABX them.
Thanks a lot for uploading the samples! Gave me a lot of insight. If every label would master its songs like the limited version of BOTR, there would be no loudness war.
Chris
P.S.: The 22-kHz line is weird. Probably not dither since its frequency varies and doesn't make sense. Maybe interference during A/D conversion of the tape.
This post has been edited by C.R.Helmrich: Nov 14 2010, 16:47
2Bdecided
post Nov 15 2010, 13:41
QUOTE (C.R.Helmrich @ Nov 14 2010, 15:39) *
As far as I can see, in the samples here...
http://www.hydrogenaudio.org/forums/index....c=84945&hl=
...there's 1 peak of a few (12?) samples that's been reduced by about 0.5dB (sample 966828), and everything else is virtually identical. Even concentrating on that peak, I can't hear the difference. I wouldn't expect to be able to!
If only more "limiting" was like this!
I assume in the loudest parts of the album there are more squashed the peaks, and so it might become audible.
btw, it's interesting just A/B-ing the tracks without level matching. The level difference is obvious, but I bet 90% of people would also claim the louder track is brighter - probably better over all, as well as louder. Whereas once they're level matched, they sound identical. I wonder how many people have done listening tests biassed in this way?
Arnold B. Kruege...
post Nov 15 2010, 14:26
QUOTE (2Bdecided @ Nov 15 2010, 07:41) *
This is one of the secrets to how to sell audio gear. Match levels by ear, which results in a random mismatch of about a dB or a few dB. Then present both alternatives along with a aales pitch about why one is obviously better.
Works just about every time!
People go into audio stores, whether brick-and-motar or web, with money to spend. To them, success is defined as actually making a decision and spending their money. All the sales people have to do is play along with them and help them complete their agenda. It seems almost cruel to confuse them with the relevant facts. ;-)
- 2Bdecided   "Band on the Run" unlimited remaster   Nov 10 2010, 11:22
- - Notat   I don't see this as something to complain abou...   Nov 10 2010, 15:30
|- - 2Bdecided   QUOTE (Notat @ Nov 10 2010, 14:30) I don...   Nov 11 2010, 11:19
- - AndyH-ha   It's hard to see how the selling prices are re...   Nov 10 2010, 22:19
|- - dhromed   QUOTE (AndyH-ha @ Nov 10 2010, 22:19...   Nov 10 2010, 22:29
|- - Soap   QUOTE (AndyH-ha @ Nov 10 2010, 16:19...   Nov 10 2010, 22:32
- - AndyH-ha   I don't question a sellers right to price his ...   Nov 10 2010, 22:39
- - Canar   While your point is very valid, Andy, Notat's ...   Nov 10 2010, 23:02
- - greynol   I understand the concept, but I don't think it...   Nov 10 2010, 23:08
|- - DVDdoug   QUOTE (greynol @ Nov 10 2010, 14:08) I do...   Nov 10 2010, 23:33
|- - Porcus   QUOTE (greynol @ Nov 10 2010, 23:08) I un...   Nov 15 2010, 05:03
|- - greynol   QUOTE (Porcus @ Nov 14 2010, 20:03) On th...   Nov 15 2010, 10:13
- - mixminus1   Also, if I'm reading the website correctly, on...   Nov 10 2010, 23:26
- - Teknojnky   I have to agree with greynol, this simply re-enfor...   Nov 10 2010, 23:26
- - Fandango   I'm wondering how this can actually turn the t...   Nov 10 2010, 23:56
|- - Josh358   QUOTE (Fandango @ Nov 10 2010, 17:56) I...   Nov 11 2010, 00:50
- - BearcatSandor   Also, the $30 price will further encourage pe...   Nov 11 2010, 02:27
- - JSW   I actually did pay $20 for the 24/96 "un...   Nov 11 2010, 02:35
|- - 2Bdecided   QUOTE (JSW @ Nov 11 2010, 01:35) I actual...   Nov 11 2010, 11:33
- - Meeko   Wow...talk about choices. I'm not positive an...   Nov 11 2010, 14:46
- - zipr   What a confusing mess of a page that is! I won...   Nov 11 2010, 15:06
- - ramicio   I procured the unlimited version. Sounds nice. I...   Nov 11 2010, 16:33
- - BearcatSandor   There's something i don't get about this t...   Nov 11 2010, 16:52
|- - Josh358   QUOTE (BearcatSandor @ Nov 11 2010, 10:52...   Nov 11 2010, 23:30
|- - Arnold B. Krueger   QUOTE (BearcatSandor @ Nov 11 2010, 10:52...   Nov 12 2010, 15:22
|- - BearcatSandor   QUOTE (Arnold B. Krueger @ Nov 12 2010, 07...   Nov 12 2010, 17:21
|- - greynol   QUOTE (BearcatSandor @ Nov 12 2010, 08:21...   Nov 13 2010, 00:33
- - 2Bdecided   I agree. All of which makes it surprising that th...   Nov 12 2010, 11:04
|- - Josh358   QUOTE (2Bdecided @ Nov 12 2010, 05:04) I ...   Nov 12 2010, 19:48
- - Brand   I really like seeing major labels openly mention t...   Nov 12 2010, 13:19
- - ron spencer   I bought this...sounds nice. Price is good given ...   Nov 12 2010, 15:49
- - Wombat   I know this recording from back in the 70s and won...   Nov 12 2010, 16:15
|- - Josh358   QUOTE (Wombat @ Nov 12 2010, 10:15) I kno...   Nov 12 2010, 19:56
- - Wombat   QUOTE (Josh358 @ Nov 12 2010, 20:56) I su...   Nov 12 2010, 20:06
- - Batman321   I bought it, very nice sound. I converted these ...   Nov 12 2010, 20:25
- - jimmanningjr   I just got my hands on these 96/24 files of BOTR. ...   Nov 13 2010, 04:19
|- - Canar   QUOTE (jimmanningjr @ Nov 12 2010, 23:19)...   Nov 13 2010, 21:08
- - Brand   I got my hands on those as well (both limited and ...   Nov 13 2010, 21:06
- - jimmanningjr   Nice and Short Thanks   Nov 13 2010, 21:27
|- - Canar   QUOTE (jimmanningjr @ Nov 13 2010, 16:27)...   Nov 13 2010, 21:41
|- - jimmanningjr   You know I have had my doubts...that 16 bit was go...   Nov 13 2010, 23:04
|- - Josh358   QUOTE (jimmanningjr @ Nov 13 2010, 17:04)...   Nov 15 2010, 01:51
- - emte   I, unfortunately, must agree with the post above. ...   Nov 13 2010, 23:43
|- - jimmanningjr   Wondering if with the proper playback equipment if...   Nov 14 2010, 06:48
- - krabapple   You shouldn't expect an audible difference due...   Nov 14 2010, 08:52
- - greynol   I am not so sure that sensitivity/acuity to bit-de...   Nov 14 2010, 09:19
- - emte   I'm 22 and I have never noticed any audible di...   Nov 14 2010, 10:41
- - Brand   IMO there's no way there could be an audible d...   Nov 14 2010, 11:48
- - C.R.Helmrich   I'd probably take the limited version, because...   Nov 14 2010, 16:39
|- - 2Bdecided   QUOTE (C.R.Helmrich @ Nov 14 2010, 15:39)...   Nov 15 2010, 13:41
|- - Arnold B. Krueger   QUOTE (2Bdecided @ Nov 15 2010, 07:41) bt...   Nov 15 2010, 14:26
- - greynol   It's quite possible that the differences heard...   Nov 15 2010, 02:09
|- - Josh358   QUOTE (greynol @ Nov 14 2010, 20:09) It...   Nov 15 2010, 19:19
- - greynol   Certainly, which is why have foobar2000 configured...   Nov 15 2010, 19:22
RSS Lo-Fi Version Time is now: 31st March 2015 - 08:12
