Have you ever regretted ABXing?, How has it changed your feelings about your stuff?
BearcatSandor
post Nov 3 2010, 21:30
By "stuff" i mean equipment and music?
Have you ever ABXed something and found yourself not enjoying it as much as you did now that you know it's not all you thought it to be? Has the opposite ever happened to you?
I don't have the set up to ABX sound files yet (i'm a Linux user and both options seem to be dead). After participating in this forum for only a few days and reading of others experiences with 24-bit vs 16-bit music i'm now looking at my 24-bit collection of DVD-As, SACDs and 24-bit Studio Master downloads and thinking "..Damn it?" with a bit of confusion. I don't feel as secure with them anymore. I thought i had the 'best' sound i could get which is always a goal for folks like me.
Conversely, i might enjoy my redbook CDs more now as i won't be thinking "well they aren't 24-bit :"( " and i might not be hearing deficits that aren't really there.
I'm not sure how to feel about that.
I'm sure i'm not the only one here who's gone though this. Some of you started out as 'audiofools' too, right? How did you deal with this?
In a sense i'm kinda feeling "No, i don't want to look up ABX testing for loudspeakers. I waited 10 years for just the right pair to come to me and i really don't want to know that my $2.5k Anthony Gallo Acoustic Reference 3.1s are 'the same' as a pair of BestBuy specials." That's a bit of an exaggeration given how different speakers can be ...at least i think it is.
I'm uncertain. Honestly, i think i'm changing quickly and looking for support.
So how did you deal when the ABXing didn't work out how how you hoped it might?
edit: Brought it back on-topic a bit.
This post has been edited by BearcatSandor: Nov 3 2010, 21:59
Music lover and recovering high end audiophile
greynol
post Nov 5 2010, 00:41
While that may be, this forum requires different criteria from those who claim they can perceive an audible difference.
NB that I am not suggesting that you are making such claims.
Perhaps I missed it somewhere, but when you're talking about peak amplitudes, is this including the ambient noise of the listening area or not? It most certainly makes a difference!
Josh358
post Nov 5 2010, 01:19
QUOTE (greynol @ Nov 4 2010, 18:41) *
I hope I'm not violating the rules of the forum. I came directly to this thread after seeing a post on another forum and these are my first posts here. In any case, no, I'm not making any personal claims. I've never heard noise from a fully digital 16 bit recording played at natural levels, either at home or in the studio, though I'm intrigued enough that when I get my system set up again (it's in the attic while my listening room is renovated) I may try a calibrated experiment. I was just referring to the Meyer-Moran results.
Surprisingly, to me, anyway, Fielder found that the noise of a quiet home listening room was below the threshold of hearing, and that the noise in an average room wasn't far enough above it to mask noise in a recording:
"The level of typical listening-room noise is assessed by two further studies. The first of these, by this author, examines 10 home listening rooms to produce an average noise curve, while the second, by Cohen and Fielder, examines 27 home listening rooms and produces minimum, maximum, and average noise spectra. Since both studies produce similar averages for home listening-room noise, Fig. 6 shows the minimum, average, and maximum noise spectrum levels from only the second study.
"Fig. 6 shows that the average noise spectrum of the home listening rooms surveyed possesses noise levels above 400 Hz that are no higher than 10 dB above the hearing threshold criterion. This, combined with the fact that the listener is able to employ directional clues, means that generally the home listening-room noise has no effect on reducing the dynamic-range requirements. Examination of the minimum noise levels for each one- third-octave frequency point shows that the most quiet home playback conditions have extremely low noise levels in the frequency bands above 2 kHz, critical to the detection of white noise. In this frequency region the lowest room noise situations are at least 10 dB below the hearing acuity curve."
http://www.zainea.com/Dynamic%20range.htm
On the other hand, according to Meyer and Moran, "The background noise level in [the room used for the ABX comparisons] is lower than that in most urban listening rooms: 19 dBA."
http://www.bostonaudiosociety.org/explanation.htm
So strictly speaking, their result seems to be applicable only to the quietest listening rooms.
Arnold B. Kruege...
post Nov 5 2010, 17:50
QUOTE (Josh358 @ Nov 4 2010, 20:19) *
There seems to be a critical missing paragraph in the Fielder paper. It might be titled "Noise in recording Environments".
The paper as presented usecontains an unstated assumption that appears to me to be something like: "The dynamic range requirement for musical playback is irrelevant to noise in the space where the music is recorded."
IME, the space in which the recording is made is actually the weakest link. Large spaces are very expensive to make really quiet, and then you go and spoil the whole thing by putting performers into it. If you add an audience, then its close micing or lotsa noise, mostly both.
I see the Fielder paper as being a justification for HDCD, which we now know failed in the marketplace. IME the reason why is that due to the relatively high levels of noise in spaces used for recording, HDCD like SACD and DVD-A is a solution looking for a problem. It appears that SACD and DVD-A have also failed or are in the later stages of failing in the marketplace.
- BearcatSandor   Have you ever regretted ABXing?   Nov 3 2010, 21:30
- - dv1989   QUOTE (BearcatSandor @ Nov 3 2010, 20:30)...   Nov 3 2010, 21:39
|- - BearcatSandor   QUOTE (dv1989 @ Nov 3 2010, 14:39) At the...   Nov 3 2010, 21:45
|- - greynol   QUOTE (BearcatSandor @ Nov 3 2010, 13:45)...   Nov 3 2010, 22:04
|- - dv1989   QUOTE (BearcatSandor @ Nov 3 2010, 20:45)...   Nov 3 2010, 22:17
- - greynol   If it's any consolation, the most common advic...   Nov 3 2010, 21:48
- - mixminus1   Oh, I don't think you should regret buying the...   Nov 3 2010, 22:20
|- - BearcatSandor   QUOTE (mixminus1 @ Nov 3 2010, 15:20) Oh,...   Nov 3 2010, 22:32
||- - mixminus1   QUOTE (BearcatSandor @ Nov 3 2010, 14:32)...   Nov 3 2010, 22:48
|- - Northpack   QUOTE (mixminus1 @ Nov 3 2010, 22:20) I...   Nov 3 2010, 22:39
- - greynol   That's funny, I was thinking the opposite: th...   Nov 3 2010, 22:51
|- - mixminus1   Oh, then you'd positively LOVE these. >:D ...   Nov 3 2010, 23:14
- - mixminus1   ...and now attempting to at least get myself back ...   Nov 3 2010, 23:45
- - Roseval   QUOTE (BearcatSandor @ Nov 3 2010, 22:30)...   Nov 4 2010, 00:22
|- - odigg   I think I had two simultaneous feelings after I st...   Nov 4 2010, 01:29
- - Josh358   QUOTE (BearcatSandor @ Nov 3 2010, 15:30)...   Nov 4 2010, 19:23
|- - greynol   QUOTE (Josh358 @ Nov 4 2010, 11:23) An ex...   Nov 4 2010, 20:54
||- - Josh358   QUOTE (greynol @ Nov 4 2010, 14:54) QUOTE...   Nov 5 2010, 00:18
||- - 2Bdecided   QUOTE (Josh358 @ Nov 5 2010, 00:18) a sys...   Nov 5 2010, 01:08
||- - Josh358   QUOTE (2Bdecided @ Nov 4 2010, 19:08) Tha...   Nov 5 2010, 01:46
||- - 2Bdecided   QUOTE (Josh358 @ Nov 5 2010, 01:46) I...   Nov 5 2010, 08:44
||- - Josh358   QUOTE (2Bdecided @ Nov 5 2010, 02:44) ......   Nov 5 2010, 17:38
|- - Porcus   QUOTE (Josh358 @ Nov 4 2010, 19:23) Thoug...   Nov 23 2010, 14:40
- - hlloyge   Personally, my aac's are now around 160 kbit V...   Nov 4 2010, 21:54
- - greynol   While that may be, this forum requires different c...   Nov 5 2010, 00:41
|- - Josh358   QUOTE (greynol @ Nov 4 2010, 18:41) While...   Nov 5 2010, 01:19
|- - Arnold B. Krueger   QUOTE (Josh358 @ Nov 4 2010, 20:19) Surpr...   Nov 5 2010, 17:50
|- - Josh358   QUOTE (Arnold B. Krueger @ Nov 5 2010, 11...   Nov 5 2010, 22:46
||- - Arnold B. Krueger   QUOTE (Josh358 @ Nov 5 2010, 16:46) QUOTE...   Nov 8 2010, 14:00
||- - Josh358   QUOTE (Arnold B. Krueger @ Nov 8 2010, 08...   Nov 8 2010, 17:28
|||- - Arnold B. Krueger   QUOTE (Josh358 @ Nov 8 2010, 11:28) QUOTE...   Nov 8 2010, 20:11
|||- - Josh358   QUOTE (Arnold B. Krueger @ Nov 8 2010, 14...   Nov 9 2010, 01:05
|||- - Arnold B. Krueger   QUOTE (Josh358 @ Nov 8 2010, 19:05) I ass...   Nov 9 2010, 13:48
|||- - Josh358   QUOTE (Arnold B. Krueger @ Nov 9 2010, 07...   Nov 9 2010, 23:52
|||- - Engelsstaub   QUOTE (Josh358 @ Nov 9 2010, 17:52) Inter...   Nov 10 2010, 07:27
||||- - Josh358   QUOTE (Engelsstaub @ Nov 10 2010, 01:27) ...   Nov 10 2010, 17:20
||||- - BearcatSandor   QUOTE (Josh358 @ Nov 10 2010, 09:20) QUOT...   Nov 10 2010, 18:00
||||- - Josh358   QUOTE (BearcatSandor @ Nov 10 2010, 12:00...   Nov 10 2010, 18:54
|||- - Arnold B. Krueger   QUOTE (Josh358 @ Nov 9 2010, 17:52) Of co...   Nov 10 2010, 14:19
|||- - Arnold B. Krueger   QUOTE (Josh358 @ Nov 9 2010, 17:52) Inter...   Nov 10 2010, 15:00
|||- - Josh358   QUOTE (Arnold B. Krueger @ Nov 10 2010, 09...   Nov 10 2010, 18:49
||- - krabapple   QUOTE (Arnold B. Krueger @ Nov 8 2010, 08...   Nov 17 2010, 18:19
|- - krabapple   QUOTE I see the Fielder paper as being a justifica...   Nov 17 2010, 18:15
- - DigitalMan   Interesting OP Did ABX after ripping to LAME 256kb...   Nov 5 2010, 02:06
- - Canar   I have never regretted ABXing. Double-blind testin...   Nov 5 2010, 02:20
- - BearcatSandor   I appreciate all of these posts. I'm still de-...   Nov 5 2010, 03:00
|- - Josh358   QUOTE (BearcatSandor @ Nov 4 2010, 21:00)...   Nov 5 2010, 03:51
|- - greynol   QUOTE (BearcatSandor @ Nov 4 2010, 19:00)...   Nov 5 2010, 04:23
|- - Engelsstaub   QUOTE (BearcatSandor @ Nov 4 2010, 21:00)...   Nov 5 2010, 07:13
||- - knutinh   QUOTE (Engelsstaub @ Nov 5 2010, 07:13) I...   Nov 5 2010, 08:20
||- - Engelsstaub   QUOTE (knutinh @ Nov 5 2010, 02:20) QUOTE...   Nov 6 2010, 06:29
||- - dv1989   QUOTE (Engelsstaub @ Nov 6 2010, 05:29) I...   Nov 6 2010, 11:10
||- - googlebot   QUOTE (dv1989 @ Nov 6 2010, 12:10) What y...   Nov 6 2010, 11:39
|- - dv1989   QUOTE (BearcatSandor @ Nov 5 2010, 02:00)...   Nov 5 2010, 23:53
- - greynol   No worries. I think the fear that transcoding is ...   Nov 5 2010, 07:42
|- - Josh358   QUOTE (greynol @ Nov 5 2010, 01:42) No wo...   Nov 5 2010, 17:32
|- - greynol   QUOTE (Josh358 @ Nov 5 2010, 09:32) Has a...   Nov 5 2010, 18:34
|- - Josh358   QUOTE (greynol @ Nov 5 2010, 12:34) QUOTE...   Nov 5 2010, 22:00
|- - greynol   QUOTE (Josh358 @ Nov 5 2010, 14:00) Which...   Nov 6 2010, 21:07
|- - Josh358   QUOTE (greynol @ Nov 6 2010, 15:07) QUOTE...   Nov 6 2010, 23:50
|- - Arnold B. Krueger   QUOTE (Josh358 @ Nov 6 2010, 17:50) Elect...   Nov 8 2010, 14:17
|- - Josh358   QUOTE (Arnold B. Krueger @ Nov 8 2010, 08...   Nov 8 2010, 19:32
- - simonh   I wonder whether lossy will formats distributed ov...   Nov 5 2010, 08:52
- - Takla   The only damage I've caused by abx testing has...   Nov 5 2010, 16:07
- - DigitalMan   After a humbling fail on ABX with MP3 at 192kbp/s ...   Nov 6 2010, 05:33
- - dv1989   Yeah, I may have overgeneralised. I think I meant...   Nov 6 2010, 11:56
- - Meeko   Never regretted learning that my hearing isn't...   Nov 11 2010, 15:18
- - Onebeforezod   The weird thing for me was that I really could tel...   Nov 25 2010, 02:36
|- - greynol   QUOTE (Onebeforezod @ Nov 24 2010, 17:36)...   Nov 25 2010, 02:42
|- - Onebeforezod   QUOTE (greynol @ Nov 24 2010, 17:42) QUOT...   Nov 26 2010, 10:37
- - analog scott   QUOTE (greynol @ Nov 25 2010, 03:42) QUOT...   Nov 25 2010, 20:55
|- - Arnold B. Krueger   QUOTE (analog scott @ Nov 25 2010, 14:55)...   Nov 25 2010, 22:38
- - greynol   Your ABX report saying you can tell the difference...   Nov 27 2010, 03:22
|- - mjb2006   QUOTE (greynol @ Nov 26 2010, 19:22) Your...   Nov 29 2010, 22:53
- - Wombat   QUOTE (greynol @ Nov 27 2010, 04:22) Your...   Nov 27 2010, 03:29
- - BearcatSandor   QUOTE (Wombat @ Nov 26 2010, 19:29) QUOTE...   Nov 29 2010, 21:50
RSS Lo-Fi Version Time is now: 28th August 2015 - 14:17
