foo_dsp_effect, A effect array for FB2K
mudlord
post Oct 26 2010, 10:42
Group: Developer (Donating)
Current builds available here.
Bugtracker : http://bugs.mudlord.info/index.php?project...ex&switch=1
Source code: http://svn.mudlord.info/foobar2000/foo_dsp_effect/
Includes the following effects:
  • Pitch Shift
  • Tempo Shift
  • Playback Rate Shift
  • Dynamics Compressor
  • Echo
  • Phaser
  • Reverb
  • WahWah
  • IIR Filter, which includes the following effects:
    • Bandpass Filter (CSG & ZPG)
    • Bass Boost (boosts bass frequencies which are specifically selected.)
    • High Shelf Filter
    • Low Shelf Filter
    • Notch Filter
    • Parametric EQ (single band)
    • Resonant Highpass Filter
    • Resonant Lowpass Filter
    • Allpass Filter
    • RIAA Phono De-emphasis Filter
    • CD De-emphasis Filter
Change log:
  • 2011-08-11- Version 0.9.2:
    • Fixed conversion crashes in SoundTouch based DSPs.
    • Increased frequency range of IIR DSP.
  • 2011-06-21- Version 0.9.1:
    • Fixed crashes in rate/tempo DSPs.
  • 2011-06-20- Version 0.9:
    • Added a rate modification DSP. Added finer grained control to the Pitch DSP.
  • 2011-04-30- Version 0.8:
    • Added tempo and pitch modification DSPs.
  • 2011-02-10 - Version 0.7.1:
    • Fixed the realtime de-emphasis post processor to be on par with SoX. Made clear distinctions between the phono and CD de-emphasis filters in the IIR filter dialog. Many thanks to Sandrine for his testing.
  • 2011-02-10 - Version 0.7:
    • Added a realtime CD de-emphasis decode post processor. The tag "PRE_EMPHASIS" must be used on content which is supported by FB2Ks decode processor services, for this to work. Pre-emphasis can be signified in your media with the values "1" or "0".
  • 2011-01-28 - Version 0.6.2:
    • Added a RIAA de-emphasis filter.
    • Recompiled with MSVC10.
  • 2011-01-10 - Version 0.6.1:
    • Fixed minor bug that crept into last release.
  • 2011-01-10 - Version 0.6:
    • Fixed various user interface bugs that crept into the last release.
    • Merged the Bass Boost DSP into the IIR filter class and user interface, where it belongs.
  • 2011-01-08 - Version 0.5:
    • Added Garf's dynamic compressor, ported from foobar2000 0.8.3.
    • Added allpass filters.
    • Added a new bandpass filter mode.
    • Added new IIR filter DSP to house the various IIR-related filter effects.
  • 2010-12-14 - Version 0.4:
    • Added notch and high/low shelf filters
    • Increased range of parametric EQ
  • 2010-12-13 - Version 0.3:
    • Added bandpass/resonant highpass/lowpass filters
    • Added a parametric EQ
  • 2010-11-03 - Version 0.2:
    • Increased parameter ranges for Phaser and WahWah effects.
    • Truncated display values for Phaser and WahWah effects to 1 decimal place.
  • Version 0.1:
    • Initial release.
This post has been edited by mudlord: Jun 24 2015, 04:48
Attached File(s)
Attached File  foo_dsp_effect_noemph.zip ( 120.25K ) Number of downloads: 47
romor
post Oct 29 2010, 01:22
are you talking about foo_dsp_loudspeakereq?
source code is there and author chased to replies
This post has been edited by romor: Oct 29 2010, 01:23
scripts: http://goo.gl/M1qVLQ
- mudlord   foo_dsp_effect   Oct 26 2010, 10:42
- - romor   Thanks Very creative name BTW (note to users of ...   Oct 26 2010, 14:51
- - mudlord   Thankyou. Already got some ideas for what to add ...   Oct 29 2010, 00:58
- - romor   are you talking about foo_dsp_loudspeakereq? sourc...   Oct 29 2010, 01:22
- - mudlord   Yes, I am. It uses the same filter design, except...   Oct 29 2010, 01:42
- - sola   Reverb, that's great! Thank you!   Oct 29 2010, 13:34
- - klez   PLEASE implement a configurable subsonic Filter wi...   Oct 29 2010, 16:47
- - mudlord   Suppose so. Should have added a highpass filter in...   Oct 31 2010, 02:09
- - NullString   Thanks! I have a question regarding " (bo...   Oct 31 2010, 22:19
- - mudlord   You just set the frequency to one that works for t...   Nov 1 2010, 00:58
- - mudlord   Mainly wanted to get 0.2 out since I didn't li...   Nov 3 2010, 11:30
- - touccer   Any news about Loudspeaker EQ rewriting?   Nov 25 2010, 22:47
- - mudlord   What is stopping the end user from useing that DSP...   Nov 26 2010, 03:57
- - mudlord   I had a second look at implementing the loudspeake...   Dec 13 2010, 06:41
|- - touccer   QUOTE (mudlord @ Dec 13 2010, 06:41) I ha...   Dec 13 2010, 16:46
|- - mudlord   QUOTE (touccer @ Dec 13 2010, 09:46) QUOT...   Dec 14 2010, 03:52
- - mudlord   New version 0.3: * Added bandpass/resonant highpa...   Dec 13 2010, 13:24
- - romor   Thanks for new filters, mudlord I added ~100Hz h...   Dec 13 2010, 18:19
- - mudlord   Well, I mainly did this filters just to mess aroun...   Dec 14 2010, 03:51
|- - romor   QUOTE (mudlord @ Dec 14 2010, 03:51) Well...   Dec 14 2010, 04:49
- - Takaji   Thanks for the interesting component, mudlord!   Dec 14 2010, 04:15
- - mudlord   Ah, thanks for clarifying. Well the resonant filte...   Dec 14 2010, 05:45
- - mudlord   New version 0.4: * Added notch and high/low shel...   Dec 14 2010, 11:20
|- - touccer   QUOTE (mudlord @ Dec 14 2010, 11:20) New ...   Dec 14 2010, 13:15
- - mudlord   Sorry touccer, you were right. Try the download a...   Dec 14 2010, 13:33
|- - touccer   QUOTE (mudlord @ Dec 14 2010, 13:33) Sorr...   Dec 14 2010, 13:54
|- - touccer   QUOTE (touccer @ Dec 14 2010, 13:54) QUOT...   Dec 15 2010, 13:05
- - jmccrohan   Setting quality to 0 causes an infinite loop in mo...   Dec 19 2010, 00:09
- - mudlord   Known issue. When it will be fixed: Never. Quite a...   Dec 19 2010, 10:20
- - mudlord   0.5 released   Jan 8 2011, 19:46
|- - touccer   Can you extend Parametric EQ frequency range to 0-...   Jan 10 2011, 01:38
- - notwa   Uhhh, something's not right here. Nothing se...   Jan 9 2011, 04:06
- - mudlord   Yes, thats already fixed for the next version. I h...   Jan 9 2011, 05:03
- - mudlord   Done   Jan 10 2011, 05:31
|- - touccer   QUOTE (mudlord @ Jan 10 2011, 05:31) Done...   Jan 10 2011, 12:34
- - notwa   Two things. How does the bass booster work? Is it ...   Jan 11 2011, 00:45
- - mudlord   touccer, fixed for next version. QUOTE How does t...   Jan 11 2011, 05:46
|- - touccer   QUOTE (mudlord @ Jan 11 2011, 05:46) touc...   Jan 11 2011, 13:52
- - mudlord   Woah, sorry about that! Will fix in a couple o...   Jan 11 2011, 14:39
- - Sunhillow   Hi mudlord, thank you so much for this plugin...   Jan 28 2011, 17:06
- - Sandrine   Thank you very much for this useful plugin! I...   Feb 4 2011, 22:15
|- - GeSomeone   QUOTE (Sandrine @ Feb 4 2011, 23:15) ... ...   Feb 7 2011, 22:48
- - mudlord   Sounds interesting, to say the least. Know any n...   Feb 7 2011, 08:03
|- - Sandrine   QUOTE (mudlord @ Feb 7 2011, 08:03) Sound...   Feb 7 2011, 13:36
- - mudlord   Thanks, the test material is good enough quality t...   Feb 7 2011, 18:09
- - fieryflare   I've installed the Dll, but I don't see an...   Feb 7 2011, 22:29
- - mudlord   Not really. You can still make a metadb_handle p...   Feb 8 2011, 04:59
- - tpijag   QUOTE (fieryflare @ Feb 7 2011, 15:29) I...   Feb 8 2011, 05:16
- - kode54   And as a decode postprocessor service, it may retr...   Feb 8 2011, 07:44
|- - GeSomeone   QUOTE (kode54 @ Feb 8 2011, 08:44) And as...   Feb 9 2011, 12:06
- - mudlord   Yep, started adding this as a extra decode post pr...   Feb 8 2011, 12:26
|- - Sandrine   QUOTE (mudlord @ Feb 8 2011, 12:26) Yep, ...   Feb 9 2011, 11:07
- - mudlord   What fields did you tag your files with (for preem...   Feb 9 2011, 11:09
|- - Sandrine   QUOTE (mudlord @ Feb 9 2011, 11:09) What ...   Feb 9 2011, 11:51
- - mudlord   That is the main problem I am grappling with. Mayb...   Feb 10 2011, 10:24
- - mudlord   There its added. Already got complaints that the ...   Feb 10 2011, 11:37
- - lvqcl   Hello mudlord, I have a couple of questions about ...   Feb 10 2011, 16:46
- - mudlord   1. Yes, I will correct it. 2. Formulas were from a...   Feb 10 2011, 22:34
|- - lvqcl   QUOTE (mudlord @ Feb 11 2011, 00:34) 1. Y...   Feb 10 2011, 23:25
- - mudlord   Yeh, I have to agree. Found it works well regardle...   Feb 10 2011, 23:31
- - Sandrine   I'm having the darnedest problem with the de-e...   Feb 11 2011, 19:42
|- - mudlord   QUOTE (Sandrine @ Feb 11 2011, 12:42) I...   Feb 12 2011, 01:45
||- - Sandrine   QUOTE (mudlord @ Feb 12 2011, 01:45) Yes,...   Feb 12 2011, 11:08
|- - Sandrine   QUOTE (Sandrine @ Feb 11 2011, 19:42) I...   Feb 15 2011, 19:29
- - mudlord   Too bad. Component's been discontinued anywa...   Feb 12 2011, 12:23
|- - Sandrine   QUOTE (mudlord @ Feb 12 2011, 12:23) Too ...   Feb 12 2011, 16:54
- - Sunhillow   A great pity this wonderful component has been dis...   Feb 12 2011, 20:16
- - dv1989   Considering other recent and now Recycle Bin-d pos...   Feb 12 2011, 20:22
- - luk3Z   This is funny what I write but I don't know ho...   Feb 19 2011, 21:38
- - mudlord   Preset loading works here @Sandrine: so its a foo...   Feb 20 2011, 00:56
|- - luk3Z   QUOTE (mudlord @ Feb 20 2011, 01:56) Pres...   Feb 20 2011, 10:41
- - mudlord   since I am no longer able to edit posts due to ins...   Feb 20 2011, 02:36
- - luk3Z   I can't edit my previous post anymore, so I pu...   Feb 22 2011, 12:41
- - mudlord   Strange, tried your presets in the standard EQ and...   Feb 24 2011, 09:20
- - .halverhahn   Oooooh... a dream come true: On the fly CD de-emph...   Feb 24 2011, 17:25
- - mudlord   I will fix up the filter dialog for the CD deemph ...   Feb 25 2011, 01:01
- - mudlord   done, updated.   Mar 19 2011, 02:23
- - henrimichel   About foo_dsp_effect 0.7.3 I hope the percentage s...   Mar 19 2011, 14:15
- - mudlord   I found that modding Q factors for those filters m...   Mar 19 2011, 21:46
- - henrimichel   In fact,I realize that no modification can be hear...   Mar 19 2011, 23:30
- - mudlord   Fixed in 0.7.4. Enjoy your gain control in high s...   Mar 20 2011, 00:17
|- - Eclipsed Moon   QUOTE (mudlord @ Mar 19 2011, 18:17) Fixe...   Mar 20 2011, 01:37
- - mudlord   That wasn't the issue, since that is not even ...   Mar 20 2011, 01:39
|- - Eclipsed Moon   QUOTE (mudlord @ Mar 19 2011, 19:39) That...   Mar 20 2011, 19:44
- - henrimichel   Awesome ! Thank you so much for your lightspee...   Mar 20 2011, 03:08
- - mudlord   Well thats awfully good to know. You keep doing th...   Mar 21 2011, 09:52
- - geoslake   Hi Mudlord, thanks for your plugins Im trying to ...   Mar 21 2011, 13:11
- - mudlord   Personally I hardly use the dynamics compressor. ...   Mar 21 2011, 14:15
- - mudlord   Updated to 0.8 http://mudlord.emuxhaven.net/crap/...   Apr 30 2011, 08:30
- - geoslake   thanks   Apr 30 2011, 11:18
- - q-stankovic   Thanks! Time to remove acropolis' compone...   Apr 30 2011, 14:13
- - Thundik81   QUOTE (mudlord @ Apr 30 2011, 00:30) Upda...   Apr 30 2011, 15:32
- - mudlord   Because each sub DSP instance is instance and thre...   Apr 30 2011, 15:46
- - jaro1   Seems "GNU GPL fuckers" problem is gone,...   Apr 30 2011, 16:12
- - Thundik81   QUOTE (mudlord @ Apr 30 2011, 07:46) Beca...   Apr 30 2011, 16:55
- - Gnx   is it possible to add cents resolution (0.35 semit...   Jun 19 2011, 17:45
- - mudlord   Indeed, that is planned in the pipeline. Maybe nex...   Jun 19 2011, 21:03
- - q-stankovic   I have a reproducible crash: when in playback rate...   Jun 21 2011, 17:57
- - mudlord   Thanks, acquiring the crash logs now. EDIT: I see...   Jun 21 2011, 18:27
- - JooKBoX   Hey Mudlord..... I've been having a major prob...   Jun 27 2011, 08:32
3 Pages V   1 2 3 >
RSS Lo-Fi Version Time is now: 3rd July 2015 - 12:33
