2 Pages V   1 2 >
Merge FLAC files limited to max 2.00GB?, Trying to merge large flac files
SoleBastard
post Oct 2 2010, 18:40
I'm trying to merge 2 large FLAC files of about 1.5GB into 1, the resulting FLAC file should be about 3GB. However I get the following error:
1 out of 2 tracks converted with major problems.
Source: "C:\bigfile1.flac"
Track converted successfully.
Source: "C:\bigfile2.flac"
An error occurred while writing to file (The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters) : "C:\Image.flac"
Additional information:
Encoder stream format: 48000Hz / 2ch / 24bps
Command line: "C:\Foobar2000\flac.exe" -s --ignore-chunk-sizes -8 - -o "Image.flac"
Working folder: C:\
Conversion failed: The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters
The resulting merged image.flac file is cut off at exactly 2.00GB. I've checked both files and they decode fine on their own, and I have the same problem with merging other big flac files too. Hard drive space is sufficient.
As I have many FLAC files >2.00GB its likely not a FLAC limitation but something hardcoded into Foobar2000. Is there any particular reason for this and if not, can this limit please be removed? smile.gif Or does someone have a better idea to merge these files?
(Using Win7 x64, Foobar2000 v1.1, C2D + 8GB RAM, NTFS)
This post has been edited by SoleBastard: Oct 2 2010, 18:43
Andreasvb
post Oct 2 2010, 18:48
Seems to be a limitation in Windows.
See this post, http://www.hydrogenaudio.org/forums/index....st&p=483172
Windows 8.1u3 Pro x64 Media Center // foobar2000 1.3.7
SoleBastard
post Oct 2 2010, 18:54
Well, eac3to has no problem converting DTSHD or TrueHD files into >2GB FLAC files using the reference libFLAC.dll 1.2.1. Thats why I don't think either Windows or FLAC is the problem but rather Foobar2000 itself.
This post has been edited by SoleBastard: Oct 2 2010, 18:56
Andreasvb
post Oct 2 2010, 18:58
Is the flac.exe the same version?
SoleBastard
post Oct 2 2010, 19:05
If you mean if the flac.exe file used by Foobar2000 has the same version as the libFLAC.dll used by eac3to then yes, both are the latest 1.2.1.
Andreasvb
post Oct 2 2010, 19:24
What if you try from cmd?
Then you know if it's foobar2000 or not.
SoleBastard
post Oct 2 2010, 19:46
What do you mean 'from cmd'? I don't know how to do this using flac.exe as I can't seem to find the correct option in 'flac -help'
lvqcl
post Oct 2 2010, 20:19
http://www.hydrogenaudio.org/forums/index....st&p=676123
SoleBastard
post Oct 2 2010, 20:44
Thanks for the link lvqcl (and I apologize for not finding the thread myself).
I just merged the same files using WavPack and this resulted in a nice 2.25GB file that plays fine. So I guess I was wrong by blaming Foobar2000 but its actually the windows build of FLAC 1.2.1. I guess I'll fire up my Ubuntu boot to try merge the FLACs in there.
However, that still doesn't explain why eac3to can make >2GB FLAC files in Windows without any problems. I'll ask the creator of that program how he manages to do that (see here).
This post has been edited by SoleBastard: Oct 2 2010, 20:56
Case
post Oct 2 2010, 22:35
Group: Developer (Donating)
Here's FLAC 1.2.1 modified to work with file sizes larger than 2 GB. The executable is larger than the official binary because it's statically linked MSVC 2010 compile.
Edit: removed attachment.
This post has been edited by Case: Oct 3 2010, 07:56
SoleBastard
post Oct 2 2010, 22:55
Thanks Case, I tried using your flac.exe with Foobar2000 v1.1. However, when the temp file is slightly above 2GB it gives a similar error code as above. To make sure the correct flac.exe is used by Foobar I created a custom convert profile in Foobar and pointed it at your flac.exe. I guess there are some more problems than just the flac.exe file.
As a temporary work-around I merged to big FLAC files into 1 .w64 file with foobar2000. I then converted this .w64 file to flac using eac3to 3.24. Awkward, but it works. smile.gif
This post has been edited by SoleBastard: Oct 2 2010, 23:00
Squeller
post Oct 3 2010, 00:22
I'm also interested in a solution.
QUOTE (jcoalson @ Dec 30 2009, 03:31) *
libFLAC uses the C stdlib for file i/o. even on my XP box with VS 2005, microsoft's stdlib implementation is still limited to 2 GB (i.e. no 64-bit off_t).
I'm reluctant to add win-specific calls to libFLAC just because MS is intentionally sabotaging portability. every other build of flac works with large files.
(source)
kode54
post Oct 3 2010, 00:35
Group: Admin
Microsoft's C standard library has extensions for 64-bit file offsets as of some revision from years ago.
Case
post Oct 3 2010, 08:05
Sorry about that. I didn't test piped encoding for larger than 2 GB files. Input file size check broke when "(long)(-1)" got changed to "(__int64)(-1)". Fixed version attached.
The fix involves defining fseeko as _fseeki64 and ftello as _ftelli64 and changing off_t to __int64.
Edit: attachment removed. More off_t to __int64 changes required. Also stat to _stati64 and fstat to _fstat64.
This post has been edited by Case: Oct 3 2010, 09:58
lvqcl
post Oct 3 2010, 08:52
Post #15
Sorry, output FLAC file is still limited by 2,281,813,291 bytes.
Case
post Oct 3 2010, 10:04
Post #16
It worked for me in a quick test but I should have learned from the first mistake not to be too hasty. If source file was too large the encoded file had no md5 checksum or length info. My original diagnosis of the problem was incorrect.
Now all off_t types are changed to __int64 and remaining 32 bit stuff (stat and fstat) changed to 64 bit versions (_stati64, _fstati64). I can convert 5.61 GB WAV file to ~3 GB FLAC file fine in foobar with pipes but WAV file reader seems to have some issues. Encoding the wav directly from command line reports some incomplete sample error at the end and file lengths don't match in foobar's binary comparator.
This post has been edited by Case: Oct 3 2010, 12:47
SoleBastard
post Oct 3 2010, 10:36
Post #17
Sorry, still doesn't work, same non-descriptive error as above.
lvqcl
post Oct 3 2010, 11:01
Post #18
flac - --ignore-chunk-sizes -o a.flac < image.wav =>
-: WARNING: skipping unknown sub-chunk 'ДвЧв' (use --keep-foreign-metadata to keep)
-: ERROR during read while skipping over unsupported sub-chunk
This post has been edited by lvqcl: Oct 3 2010, 11:01
Case
post Oct 3 2010, 12:49
Post #19
I could dublicate SoleBastard's issue immediately with 24 bit source files and went digging into FLAC's WAV reader. It was designed to only handle 4 GB source files. Attached version no longer has that limit.
SoleBastard
post Oct 3 2010, 13:08
Post #20
Yay, this one seems to work fine! smile.gif I'll double-check if everything is encoded correctly later on but thanks a lot Case! biggrin.gif
lvqcl
post Oct 3 2010, 16:59
Post #21
QUOTE (SoleBastard @ Oct 2 2010, 23:44) *
It's interesting that foobar2000 shows incorrect bitrate of very big wavpack files (> 4 GB?). Winamp and wvunpack -c show the same incorrect bitrate, too.
SoleBastard
post Oct 4 2010, 19:21
Post #22
QUOTE (lvqcl @ Oct 3 2010, 17:59) *
Can confirm here with a 5.3 GB file and the latest WavPack, bitrate is way off (too low). blink.gif
bryant
post Oct 6 2010, 19:01
Post #23
WavPack Developer
QUOTE (SoleBastard @ Oct 4 2010, 11:21) *
It's a known problem that WavPack cannot handle files over 4 GB. It was discussed here in detail (and with some workarounds). Note that this a problem with the decoding library only; there is nothing limiting in the file format (and the files are fine).
I basically got this working last summer (along with handling .CAF files) but I still have not gotten a chance to finish it up and release it, but am hopeful for this year.
David
Squeller
post Oct 7 2010, 17:20
Post #24
Thanks Case, I'll test it soon. I'll merge some single files albums to flacs>2GB.
seanyseansean
post Jan 22 2011, 14:14
Post #25
Group: Members (Donating)
QUOTE (Case @ Oct 3 2010, 12:49) *
Thank you, Case. And nice to see an old name around here too!
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 27th February 2015 - 06:13
