Speexenc crushing
Anakunda
post Sep 29 2010, 11:42
Greetings,
need convert some audio files to SPX. Used the free binaries from speex.org, particulary speexenc.exe 1.2b3.
I use this string for fb2k converter:
--vbr --quality 8 - %d
I believe there's nothing bad on it.
But suddenly conversin crashes. Error report here:
1 out of 1 tracks converted with major problems.
Source: "E:\xfer\01 - Jambory.mp3"
  An error occurred while writing to file (The encoder has terminated prematurely with code -1073741819 (0xC0000005); please re-check parameters) : "C:\Users\Anakunda\AppData\Local\Temp\01 - Jambory.spx"
Additional information:
Encoder stream format: 44100Hz / 2ch / 16bps
Command line: "D:\media\speex\speexenc.exe" --vbr --quality 8 - "01 - Jambory.spx"
Working folder: C:\Users\Anakunda\AppData\Local\Temp\
  Conversion failed: The encoder has terminated prematurely with code -1073741819 (0xC0000005); please re-check parameters
speexenc does start, at least to print commandline help, just no conversion
Using Win7/x64
This post has been edited by Anakunda: Sep 29 2010, 11:42
Speech
post Jun 8 2011, 00:22
I'm trying to convert audio files with speexenc.exe. Its basic syntax is extremely simply:
speexenc.exe inputfilename.wav outputfilename.spx
However, when I define a conversion preset, I see that you can only define the output file name (%d); you can't define the input file name.
I would get the following error with the option %d:
Source: "D:\My documents\test.wav"
  An error occurred while writing to file (The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters) : "D:\My documents\test.spx"
  Encoder stream format: 16000Hz / 1ch / 24bps
  Command line: "C:\Program Files (x86)\foobar2000\speexenc.exe" "test.spx"
  Working folder: D:\My documents\
  Conversion failed: The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters
I would get the following error with the option %s %d:
  An error occurred while finalizing the encoding process (Object not found) : "D:\My documents\test.spx"
  Conversion failed: Object not found
This would be extremely basic, but I didn't find any information in the manual: where is the input file with default parameters like these ("-S --noreplaygain -V 2 - %d")? Or, how do you define where the input file would be placed in the command line?
Mon blog: http://piratefurieux.wordpress.com
klonuo
post Jun 8 2011, 01:24
QUOTE (Speech @ Jun 8 2011, 01:22) *
It's in last dash, as pipe which speexenc does not understand so you have to use temp file %s
It's in Destination section in converter
edit: Destination section is for output file of course. For input file you don't have to worry about it (foobar uses %temp% folder)
This post has been edited by klonuo: Jun 8 2011, 01:36
RSS Lo-Fi Version Time is now: 4th September 2015 - 09:19
