2 Pages V  < 1 2
foo_stopafteralbum.dll, Component
grimes
post Apr 25 2011, 18:37
Post #26
Stop after album 2.4
ADD: (mainmenu) | Playback | Control | Previous playlist after album
ADD: (mainmenu) | Playback | Control | Next playlist after album
ADD: Advanced Preferences | Playback | Stop after album | Previous playlist & play
ADD: Advanced Preferences | Playback | Stop after album | Next playlist & play
Playing the highlighted track of the previous/next playlist (first track, if no track highlighted).
FIX: bugs fixed, code simplifing/pruning
This post has been edited by grimes: Apr 25 2011, 18:44
grimes
post May 2 2011, 16:27
Post #27
Stop after album 2.5
FIX: "Next/Previous playlist & play" now works with "playback follows cursor" disabled
Tip: "stop after current" button in CUI-toolbar
CUI-Button-Toolbar | Button options | Add | Playback/Stop after current
Indicates whether "stop after current" is enabled or not
スラッシュ
post May 2 2011, 16:53
Post #28
Nice work dude! biggrin.gif Perhaps you could include a "skip to next playlist on last in playlist" option? Since you already have stop after last track and next playlist after album, I would guess it's just a matter of combining those two? Just in case I make a playlist with multiple albums (that does happen sometimes...). laugh.gif
Also, it doesn't seem to detect when a new version is out with the updater? Dunno how that works exactly, but just a heads up.
Hmm, is there a discussion thread for this component? I suppose this post should go there... laugh.gif
grimes
post May 2 2011, 16:58
Post #29
Discussion thread:
http://www.hydrogenaudio.org/forums/index....showtopic=83748
I'll reply there.
grimes
post May 2 2011, 19:30
Post #30
Stop after album 2.6
FIX: only once commands in advanced preferences
grimes
post May 3 2011, 15:36
Post #31
Stop after album 2.7
ADD: Menu | Playback | Control | Next playlist after playlist end (ON/OFF)
This post has been edited by grimes: May 3 2011, 15:36
grimes
post May 5 2011, 13:55
Post #32
Stop after album 2.8
ADD: Menu | Playback | Control | Next playlist after playlist end (1st track) (ON/OFF)
ADD: Menu | Playback | Control | Repeat playlist (ON/OFF)
thanks to kode54 for hint.
grimes
post May 25 2011, 16:45
Post #33
Stop after album 2.9
CHG: (mainmenu command) Previous playlist (focused track) -> Previous playlist (1st track)
CHG: (mainmenu command) Stop after albums (1-10) -> Stop after albums once (1-10)
CHG: (mainmenu command) Stop after tracks (1-20) -> Stop after tracks once (1-20)
ADD: (mainmenu command) Timebomb | Timebomb# min, Abort
ADD: (mainmenu command) Alarm | 0.5h - 5h, Alarm# min, Abort
This post has been edited by grimes: May 25 2011, 16:55
grimes
post Jun 4 2011, 11:46
Post #34
Stop after album 3.0
CHG: skipalbum, repeatalbum, etc. improvements
badrocket
post Jun 22 2011, 23:04
Post #35
Thank you so much for this.
grimes
post Oct 23 2011, 18:18
Post #36
Stop after album 3.1
ADD: shorter alarm times (5s-0.5h)
grimes
post Dec 14 2011, 18:38
Post #37
Stop after album 3.2
ADD: Gap tracks submenu: 5s - 1h, track length
grimes
post Dec 18 2011, 12:55
Post #38
Stop after album 3.3
ADD: Gap album submenu: 5s - 1h, track length
FIX: few bugs
grimes
post Dec 21 2011, 13:15
Post #39
Stop after album 3.4
RMV: Next playlist after album (focused track)
RMV: Next playlist (focused track)
CHG: Repeat playlist -> Repeat playlist once
CHG: minor issues
This post has been edited by grimes: Mar 11 2013, 14:11
irbiz7
post Apr 11 2012, 09:11
Post #40
foobar 1.1.11 -> fading -> automatic track change(10000-0) -> gap track - track length is turn on -> track don't change
(visibly seekbar stop in few second before end of track)
grimes
post Apr 11 2012, 10:00
Post #41
This feature means that you have to wait the whole length of the last track before the next track starts.
example: last track length: 5min23sec -> gap is 5min23sec. Keep in mind that there can be very long gaps, be cautious.
track don't change
Can't reproduce. next track starts after length of last track
This only happens here, if i choose "automatic track change - Fade out:10000" and "stop after current" is active.
EDIT: Ok, i think i know now what the problem might be:
There is no fade-in in "gap track" mode. This is easy to explain: there is no automatic track change. It works like this: "stop after current" is set, at end of track a timer is activated, and then next track is started. (so no "automatic track change")
This post has been edited by grimes: Apr 11 2012, 10:21
irbiz7
post Apr 12 2012, 06:21
Post #42
my problem is loud track after gap.
question is can i turn-on fade-in after track gap?
This post has been edited by irbiz7: Apr 12 2012, 06:24
grimes
post Apr 12 2012, 11:45
Post #43
I can't find a way.
Maybe i'am wrong, but there is no option to fade-in on starting track (only "pause and stop" etc.)
EDIT:
I used for starting track after gap:
virtual void playback_control::start ( t_track_command p_command = track_command_play,bool p_paused = false)
-> no fade-in
alternative would be:
void playback_control::play_start (t_track_command p_command = track_command_play,bool p_paused = false)
fade-in?
This post has been edited by grimes: Apr 12 2012, 12:09
grimes
post Mar 11 2013, 14:14
Post #44
Stop after album 3.5
FIX: stop after album for untagged tracknumber/totaltracks
This post has been edited by grimes: Aug 23 2013, 09:35
grimes
post Aug 23 2013, 09:36
Post #45
Stop after album 3.6
ADD: Postgap, Add a pause after the track in seconds (x.xx) defined by tag %postgap%.
Download: see first post
MaCs
post Jan 15 2014, 16:49
Post #46
Would it be possible to select a song in a playlist and do some sort of "stop after this track"?
grimes
post Jan 15 2014, 20:02
Post #47
This is a feature of fbuser's wonderful Playlist attributes. The option is called "Stop after focused track".
MaCs
post Jan 15 2014, 21:56
Post #48
QUOTE (grimes @ Jan 15 2014, 14:02) *
Good, thanks!
w00w000
post Apr 21 2015, 05:50
Post #49
hi, just try 3.6, at first, good idea finally to see that "Repeat (track)" has now priority over stopAA (actually how it logically should be), but when turn "Repeat (track)" off while has stopAA active it just go to the next album after the previous last album track. bummer..
switching back to 3.4
2 Pages V  < 1 2
RSS Lo-Fi Version Time is now: 4th August 2015 - 07:54
