Does Replay gain work differtly in Media monkey, Foobar and Media Monkey given 2 differnt Results
jimmanningjr
post Sep 3 2010, 02:57
Hey Anyone,
For the past 2 years I have been using Media Monkey to Organize and play my music collection which is now about 42,000 tracks about 75% of my collection has Replay gain Values....I am making the switch over to Foobar2000 and was about to replay gain the other 25% with it (Foobar) when I discovered that for the same album I was getting 2 different values...and it is making me wonder does Media Monkey use a different algorithm or is there something I am overlooking...both are set to tag by ALBUM with the track value put in there also. Here are my results: blink.gif
Miles Davis /Jack Johnson Soundtrack/ crying.gif crying.gif
Trk1 Right Off -FOOBAR--Album Gain -1.97db Trk Gain -2.49db
Trk 2 Yesternow-FOOBAR Album Gain -1.97db Trk Gain -0.87db
Trk 1 Right Off Media monkey--Album Vol=-7.9db Trk Vol= -8.4db
Trk 2 Yesternow Media Monkey--Album Vol= -7.9db Trk Vol= - 6.8db
Could someone shed some light on this for me.
Thank You
greynol
post Sep 4 2010, 17:45
There is REPLAYGAIN_REFERENCE_LEVEL which was initiated by Josh Coalson.
http://www.hydrogenaudio.org/forums/index....showtopic=46245
David touched upon this just yesterday saying it was a bad idea:
http://www.hydrogenaudio.org/forums/index....st&p=721226
I have to agree. Notat, by using numbers against your ad-hoc reference, it is you who has broken replaygain.
Take this from someone who normalizes everything to 92dB prior to encoding. If you were to scan my collection you would see that my album gain would be -3dB. Playing these albums back in a RG-compliant player would bring the level down so they play at the standard reference of 89dB. If you wish to use something else you use a preamp setting. If you're worried about clipping with dynamic music, use the option that gives you clipping prevention. If your player doesn't provide these options then request that they get added or find one that does.
More links on the matter:
http://www.hydrogenaudio.org/forums/index....showtopic=67823
http://www.hydrogenaudio.org/forums/index....showtopic=76562
My take on this discussion is that MM has been unknowingly configured to give a different result, MM has a broken implementation (which I doubt), or apples are being compared with oranges because of different masterings or possible differences in HDCD decoding (as krabapple is alluding).
This post has been edited by greynol: Sep 4 2010, 18:22
Notat
post Sep 6 2010, 03:16
QUOTE (greynol @ Sep 4 2010, 10:45) *
MediaMonkey does not have a preamp setting. MediaMonkey does have clipping prevention. I'd like not to have to use clipping prevention because my understanding is that it lowers the gain of a track to prevent clipping. The tracks subject to this will not clip but they will be played at a noticeably lower level.
I guess I was trying to work around lack of a preamp setting by setting a different target volume. It does seem to work. What I don't understand about your comments is that if I have broken RG by using a non-standard target, why allow the target adjustable. MM is not the only application that allows you to adjust this. MM help system does not explain this setting and I don't see anything authoritative on the issue on the MM forms.
Can someone explain what this configuration does exactly?
- jimmanningjr   Does Replay gain work differtly in Media monkey   Sep 3 2010, 02:57
- - klonuo   perhaps your MM target level is set on 89-6 dB Ed...   Sep 3 2010, 03:06
|- - jimmanningjr   QUOTE (klonuo @ Sep 2 2010, 22:06) perhap...   Sep 3 2010, 06:20
- - 2Bdecided   It certainly looks like a 6dB offset you're se...   Sep 3 2010, 10:43
- - krabapple   QUOTE (jimmanningjr @ Sep 2 2010, 21:57) ...   Sep 4 2010, 04:27
- - Notat   I've seen this too and was wondering if it is ...   Sep 4 2010, 17:34
- - greynol   There is REPLAYGAIN_REFERENCE_LEVEL which was init...   Sep 4 2010, 17:45
|- - jimmanningjr   QUOTE (greynol @ Sep 4 2010, 12:45) There...   Sep 4 2010, 20:15
|- - Notat   QUOTE (greynol @ Sep 4 2010, 10:45) Notat...   Sep 6 2010, 03:16
|- - greynol   QUOTE (Notat @ Sep 5 2010, 19:16) I'd...   Sep 6 2010, 04:36
||- - Notat   QUOTE (greynol @ Sep 5 2010, 21:36) QUOTE...   Sep 6 2010, 22:49
|- - Teknojnky   QUOTE (Notat @ Sep 5 2010, 20:16) MediaMo...   Sep 7 2010, 16:48
|- - Notat   QUOTE (Teknojnky @ Sep 7 2010, 09:48) QUO...   Sep 8 2010, 02:40
- - Alex B   Assuming you want to have universally compatible r...   Sep 5 2010, 19:36
- - 2Bdecided   I've downloaded Media Monkey for the first tim...   Sep 6 2010, 11:02
|- - Notat   QUOTE (2Bdecided @ Sep 6 2010, 04:02) So,...   Sep 6 2010, 23:02
|- - chrisjj   QUOTE (2Bdecided @ Sep 6 2010, 11:02) MM ...   Sep 8 2010, 02:50
|- - 2Bdecided   QUOTE (chrisjj @ Sep 8 2010, 02:50) QUOTE...   Sep 8 2010, 07:38
|- - chrisjj   QUOTE (2Bdecided @ Sep 8 2010, 07:38) If ...   Sep 9 2010, 00:54
- - 2Bdecided   Notat, Maybe I didn't make it clear, so let m...   Sep 7 2010, 09:37
|- - Notat   Thanks for the clarification. What is throwing me ...   Sep 7 2010, 15:59
|- - 2Bdecided   QUOTE (Notat @ Sep 7 2010, 15:59) when I ...   Sep 7 2010, 16:45
|- - chrisjj   QUOTE (Notat @ Sep 7 2010, 15:59) What is...   Sep 8 2010, 02:47
- - greynol   Can we have an update to the site so that this doe...   Sep 8 2010, 07:51
- - 2Bdecided   Not from me. It either needs to stay as it is (an...   Sep 8 2010, 10:28
- - 2Bdecided   It was a proposed standard in July 2001. I think ...   Sep 9 2010, 11:13
|- - chrisjj   Thanks David for that explanation. QUOTE (2Bdecid...   Sep 9 2010, 12:05
|- - chrisjj   QUOTE (chrisjj @ Sep 9 2010, 12:05) QUOTE...   Sep 10 2010, 01:26
- - 2Bdecided   Well, maybe somebody can do that. http://www.yout...   Sep 9 2010, 12:55
|- - chrisjj   Agreed, but still if people want to take this forw...   Sep 9 2010, 13:05
|- - jimmanningjr   QUOTE (2Bdecided @ Sep 9 2010, 07:55) Wel...   Sep 14 2010, 00:43
- - load97   I had to register here to say thank as well! I...   Oct 13 2010, 08:30
- - 2Bdecided   QUOTE (load97 @ Oct 13 2010, 08:30) ... c...   Oct 13 2010, 10:27
RSS Lo-Fi Version Time is now: 4th August 2015 - 20:32
