How to play HTOA in Foobar?
g0a
post Aug 29 2010, 16:19
is there any option / component to detect and display HTOA as a separate track in a file with embedded cue sheet in Foobar? If not, what is commonly done to play HTOA in Foobar? Editing the embedded CUE to make the hidden track a non-hidden one? :)
Thanks a lot
This post has been edited by g0a: Aug 29 2010, 16:20
BrassDude
post Jun 19 2013, 03:46
Foosion: From your comment it looks that the "track list" is generated in one of the core functions of foobar2000 and this can not be modified by an extension/component, right? So maybe the main developers could implement this? I mean in pseudo code this would look pretty simple:
if (Time(T01.I01)-Time(T01.I00) > HTOALimit):
ListTrack(T01.I00,0)
Essentially just a simple if statement. The only new parameter would be the time limit HTOALimit that determines when a hidden track is long enough to be listed as track 0. The ListTrack function (I don't know how this is actually done in foobar2000) takes an index (here T01.I00) and assignes a track number (here 0).
So my guess is this might not be too difficult to implement for the main developers but might be a super-cool new feature smile.gif. Or do I miss something here?
foosion
post Jun 19 2013, 05:31
Group: FB2K Moderator (Donating)
QUOTE (BrassDude @ Jun 19 2013, 03:46) *
Not quite, the code for cue sheet parsing is contained in the SDK itself, more specifically in the foobar2000_sdk_helpers library. This code is compiled into each component that supports cue sheets. So even if this code is changed, every such component needs to be recompiled for the changes to take effect. On the other hand foo_input_std contains the support for cue sheet files and since this comes with the foobar2000 installer, it has to be updated by Peter.
I glanced over the cue sheet code in foobar2000_sdk_helpers and I think the change is not that trivial as you hope it would be. The reason is that the code is based on the design decision that every TRACK in the cue sheet is mapped to a track in foobar2000. Different indexes are represented as meta data in foobar2000 which can be retrieved in title formatting code via the $info() function. Specifically
  • INDEX 01 is available as $info(referenced_offset) if is greater than zero.
  • The difference between INDEX 01 and INDEX 00 is available as $info(pregap) if it is greater than zero.
  • INDEX 02 is available as $info(index 02), INDEX 03 as $info(index 03), etc.
I haven't tested it but it should be like that according to this code from cuesheet_index_list.cpp:
void t_cuesheet_index_list::to_infos(file_info & p_out) const
double base = m_positions[1];
if (base > 0) {
p_out.info_set("referenced_offset",cuesheet_format_index_time(base));
if (m_positions[0] < base)
p_out.info_set("pregap",cuesheet_format_index_time(base - m_positions[0]));
else
p_out.info_remove("pregap");
p_out.info_remove("index 00");
p_out.info_remove("index 01");
for(unsigned n=2;n<count;n++)
char namebuffer[16];
sprintf_s(namebuffer,"index %02u",n);
double position = m_positions[n] - base;
if (position > 0)
p_out.info_set(namebuffer,cuesheet_format_index_time(position));
else
p_out.info_remove(namebuffer);
RSS Lo-Fi Version Time is now: 1st February 2015 - 19:26
