Topic: Relative path not working? (Read 1867 times) previous topic - next topic
I'm using foobar 1.1 in portable mode. As I moved the map in which foobar is installed, I had to re-add my library. The old library has a relative path, but the new added library shows the full path (including drive letter), although it is on the same drive as foobar.
Do I need to enable some setting, or is this a glitch from the new version?
Thanks for your help!
It seems that relative path does work when the map 'foobar2000' resides in the root directory or in submap of the root directory. If the directory level is higher, it does not create a relative path.
