Lyricsgrabber2 Feedback & Discussion
Qudeid
post Aug 7 2010, 20:57
A message from the forum staff:
As for May 2011, this component is the #1 source of third party component crashes, with 241 reports this month so far. Install it at your own risk.
Current Version: 0.5.5.2 beta
Introduction:
foo_lyricsgrabber2 is a plugin originally developed by T.P.Wang (unfortunately not maintained for a long time). It is designed to download lyrics from the web for specified songs.
Instructions:
Right-Click a song and choose in the menu "Lyrics Grabber" the provider to download the lyrics from.
Requirements:
Foobar 1.0 or later is supported.
For earlier versions please use the original lyricsgrabber you can find here.
Important: Do not install both foo_lyricsgrabber and foo_lyricsgrabber2 at the same time. Those two will crash foobar! Only install one of them.
Changelog:
0.5.5.2 beta:
- Fixed self inflicted bug
0.5.5.1 beta:
- Maintenance
0.5.5.0 beta:
- Added Leo's Lyrics to the providers
0.5.0.0 beta:
- merged foo_lyricsgrabber2.dll and foo_grabber_python.dll together
- few changes to better support Foobar2000 1.1 Installation/Update feature
- from now on available through the official components website (and thus updateable)
0.4.5.2 beta:
- foo_lyricsgrabber2
- aesthetic fix for DarkLyrics
0.4.5.1 beta:
- fixed LyrDB truncated lyrics problem (Text encoding problem)
0.4.5.0 beta:
- Added new option to enable title formatting for the Lyrics Tag (example in the preferences) after request of ximmox and Tedgo
- Fixed finally Googleluck problems and therefore Darklyrics
0.4.1.4 beta:
- fixed Darklyrics (not finding some songs of an album where it found songs)
0.4.1.3 beta:
- fixed LyricWiki again...
0.4.1.2 beta:
- fixed LyricWiki (problem when looking for a Song that is instrumental)
- got rid of some unnessecary linebreaks at the end of the lyrics (hopefully)
0.4.1.1 beta:
- fixed LyrDb
- fixed AZLyrics (hopefully)
0.4.1.0 beta:
- changed LyricWiki access to real website instead of the edit page
- added googleluck function to curl wrapper
- changed darklyrics to get to the right website using google's "I'm feeling lucky"
0.4.0.1 beta:
- fixed LyrDB again (hopefully really fixed!)
- fixed lyricwiki (Title caps)
0.4.0.0 beta:
- fixed Empty Album Tag in Darklyrics
- changed lyrDB search method --> fixed lyrDB not finding some songs (hopefully)
- Added LyricWiki
0.3.6.1 beta:
- foo_lyircsgrabber2
- fixed "search all" function
0.3.6.0 beta:
- fixed Darklyrics
- sort context menu
- foo_grabber_python
- corrected "Install.txt"
- renamed Python to Scripts in contextmenu and preferences
0.3.5.2 beta:
- fixed AZ Lyrics provider
0.3.5.1 beta:
- fixed progressbar behaviour
0.3.5.0 beta:
- foo_lyricsgrabber2:
- fixed in config windows quite to quiet
- added Darklyrics to the providers
- added AZ Lyrics to the providers
- added LyrDB
- removed lyricsplugin until a fix is known
- adjusted processbar for "search all"-function
- Added support for multi value Artist tags
- Added configuration page to preferences
- Removed some typos
- Moved configuration to preferences
- foo_grabber_python:
- changed system path to foobar2000 profile
0.3.2.0 alpha:
- Context Menu isn't in the legacy commands section anymore
- Added "Search All" to the Context Menu to provide a one-click method to search all built-in providers
- Compiled against the new SDK (05/21/2010)
License:
As the original, this will be released under the MIT License
Credits:
Obviously many thanks to T.P.Wang the initiator for this great plugin!
libcurl - Copyright 1998 - 2008, Daniel Stenberg
Python - Copyright 1990-2010, Python Software Foundation
DEELX Regular Expression Engine - Copyright 2006 RegExLab.com, 史寿伟 (sswater shi)
Download:
Google Code
Components Page
This post has been edited by Peter: May 26 2011, 10:21
Hitchhiker427
post Aug 9 2010, 21:35
I just wanted to point out a small bug. I'm not sure how you're querying AZ Lyrics, but it's reporting "Failed" for tracks whose lyrics are present in that database. Additionally, if I use the built-in AZ Lyrics it reports "Failed", but if I use my python AZ Lyrics script, it works fine.
Here's how I've been accessing that database:
# -*- coding: utf-8 -*-
import encodings.utf_8
import urllib
from xml.dom import minidom
from grabber import LyricProviderBase
class AZLyrics(LyricProviderBase):
    def GetName(self):
        return "A-Z Lyrics"
    def GetVersion(self):
        return "1"
    def GetURL(self):
        return "http://www.azlyrics.com"
    def Query(self, handles, status, abort):
        result = []
        for handle in handles:
            status.Advance()
            if abort.Aborting():
                return result
            artist = handle.Format("[%artist%]")
            title = handle.Format("[%title%]")
            try:
                string = urllib.urlopen("http://search.azlyrics.com/search.php?q=%s+%s" % (urllib.quote(artist), urllib.quote(title))).read()
                result_start = string.find("<b>1.</b>")
                url_start = string.find("<a href=\"", result_start) + 9
                url_end = string.find("\"", url_start)
                url = string[url_start:url_end]
                lyrics_string = urllib.urlopen(url).read()
                lyrics_string = lyrics_string[lyrics_string.find("<!-- END OF RINGTONE 1 -->") + 26:lyrics_string.find("<!-- RINGTONE 2 -->")]
                lyric = lyrics_string[lyrics_string.find("<br>") + 15:lyrics_string.find("<br><br><br><br>") - 1]
                lyric = lyric.replace("<br />","")
                result.append(lyric)
            except Exception, e:
                traceback.print_exc(file=sys.stdout)
                result.append('')
                continue
        return result
if __name__ == "__main__":
    LyricProviderInstance = AZLyrics()
I'm not sure what the differences are, but I felt it's worth mentioning.
This post has been edited by Hitchhiker427: Aug 9 2010, 21:37
- Qudeid   Lyricsgrabber2 Feedback & Discussion   Aug 7 2010, 20:57
- - grimes   Awesome!!! Works great. grabber2 and p...   Aug 7 2010, 21:37
|- - Qudeid   QUOTE (grimes @ Aug 7 2010, 21:37) Awesom...   Aug 7 2010, 21:41
- - q-stankovic   After downloading and installing pythongrabber i c...   Aug 7 2010, 22:18
|- - Qudeid   QUOTE (q-stankovic @ Aug 7 2010, 22...   Aug 7 2010, 22:20
- - The Link   I use the latest beta (beta 2) of foobar2000 1.1 a...   Aug 7 2010, 22:27
|- - Qudeid   QUOTE (The Link @ Aug 7 2010, 22:27) I us...   Aug 7 2010, 22:33
- - q-stankovic   QUOTE (Qudeid @ Aug 7 2010, 23:20) Did yo...   Aug 7 2010, 22:33
- - The Link   Never used an older version of this component.   Aug 7 2010, 22:34
- - q-stankovic   It is the latest lyricsgrabber dll wich lets fooba...   Aug 7 2010, 22:41
- - Qudeid   @stankovic: strange... I'll look into that to...   Aug 7 2010, 22:42
- - q-stankovic   I combined the python stuff with lyricgrabber vers...   Aug 7 2010, 22:48
- - The Link   Rearranging the files and folder solved the proble...   Aug 7 2010, 23:17
- - Qudeid   @ Stankovic: You're probably missing the pyth...   Aug 7 2010, 23:25
|- - The Link   QUOTE @ The Link: You mean the python25.dll into t...   Aug 7 2010, 23:30
|- - Qudeid   QUOTE (The Link @ Aug 7 2010, 23:30) QUOT...   Aug 7 2010, 23:33
|- - The Link   QUOTE (Qudeid @ Aug 8 2010, 00:33) Where ...   Aug 8 2010, 00:04
- - q-stankovic   Oh sorry, the crash was my fault! I had the...   Aug 7 2010, 23:39
- - grimes   Can confirm www.lyricsvip.com occurrence with lyri...   Aug 7 2010, 23:47
- - kode54   %appdata% already points to the roaming profile fo...   Aug 8 2010, 00:22
- - Hitchhiker427   Lyrics Plugin changed the URL to further prevent p...   Aug 8 2010, 00:36
- - fragment   Hi! I downloaded your version as the previous...   Aug 8 2010, 06:51
- - wolfsong   Is it possible to add a setting to handle multiple...   Aug 8 2010, 07:41
- - Qudeid   Many replies.. Hehe.. @ The Link: I think I hav...   Aug 8 2010, 08:20
|- - wolfsong   QUOTE (Qudeid @ Aug 8 2010, 02:20) @wolfs...   Aug 8 2010, 17:57
- - Hitchhiker427   I find moving the pygrabber folder to the profile ...   Aug 8 2010, 09:28
- - grimes   QUOTE (Qudeid @ Aug 8 2010, 09:20) I thin...   Aug 8 2010, 10:16
- - Qudeid   @Hitchhiker: I see.. well it didn't seem to b...   Aug 8 2010, 13:29
- - Qudeid   I see. Is that some kind of convention that multip...   Aug 8 2010, 18:02
|- - wolfsong   QUOTE (Qudeid @ Aug 8 2010, 12:02) I see....   Aug 8 2010, 18:35
- - Qudeid   That's an intresting idea. I will test it that...   Aug 8 2010, 18:45
|- - fbuser   QUOTE (Qudeid @ Aug 8 2010, 18:45) That...   Aug 8 2010, 19:21
- - marc2003   have a look at $meta_num http://wiki.hydroge...   Aug 8 2010, 19:09
|- - Qudeid   QUOTE (marc2003 @ Aug 8 2010, 20:09) have...   Aug 8 2010, 19:19
- - Qudeid   Thank you. That is exactly what I tried and found ...   Aug 8 2010, 19:26
- - Qudeid   Hi Folks, I have a quick question for you... Wha...   Aug 9 2010, 11:46
|- - wolfsong   QUOTE (Qudeid @ Aug 9 2010, 05:46) What d...   Aug 9 2010, 18:08
- - TomBarlow   I'd say preferences only, since the configurat...   Aug 9 2010, 12:40
|- - Qudeid   QUOTE (TomBarlow @ Aug 9 2010, 13:40) I...   Aug 9 2010, 12:58
- - q-stankovic   Agreed, foobar preferences.   Aug 9 2010, 18:28
- - Qudeid   Very well. Done The newest release is up and can...   Aug 9 2010, 18:56
- - icedtea   http://www.lyricsplugin.com/winamp03/plugi...;titl...   Aug 9 2010, 19:13
|- - Qudeid   QUOTE (icedtea @ Aug 9 2010, 20:13) http:...   Aug 9 2010, 19:16
|- - Hitchhiker427   QUOTE (icedtea @ Aug 9 2010, 13:13) http:...   Aug 9 2010, 19:35
|- - Qudeid   QUOTE (Hitchhiker427 @ Aug 9 2010, 20:35)...   Aug 9 2010, 19:37
- - icedtea   Hmm...I see lyrics in both Firefox and IE :S   Aug 9 2010, 19:23
- - Qudeid   As it seems, this site is very location-based. As ...   Aug 9 2010, 19:26
- - wolfsong   Thanks for the update. Works beautifully!   Aug 9 2010, 19:58
|- - Qudeid   QUOTE (wolfsong @ Aug 9 2010, 20:58) Than...   Aug 9 2010, 20:07
- - Hitchhiker427   Oh yeah, and thanks for the update. There are som...   Aug 9 2010, 20:08
|- - Qudeid   QUOTE (Hitchhiker427 @ Aug 9 2010, 21:08)...   Aug 9 2010, 20:20
- - Hitchhiker427   Well, personally I like the "search all...   Aug 9 2010, 20:35
|- - Qudeid   QUOTE (Hitchhiker427 @ Aug 9 2010, 21:35)...   Aug 9 2010, 20:42
- - icedtea   the time var is unix time and check is some sort o...   Aug 9 2010, 20:43
|- - Qudeid   QUOTE (icedtea @ Aug 9 2010, 21:43) the t...   Aug 9 2010, 20:56
- - Qudeid   I've just fixed a little problem with the prog...   Aug 9 2010, 21:06
- - q-stankovic   QUOTE (Qudeid @ Aug 9 2010, 20:26) Anyway...   Aug 9 2010, 21:08
|- - Qudeid   QUOTE (q-stankovic @ Aug 9 2010, 22...   Aug 9 2010, 21:21
- - q-stankovic   QUOTE (Qudeid @ Aug 9 2010, 22:21) Python...   Aug 9 2010, 21:31
- - Hitchhiker427   I just wanted to point out a small bug. I'm n...   Aug 9 2010, 21:35
|- - Qudeid   @Hitchhiker: I have a little different approach. ...   Aug 9 2010, 21:44
- - fbuser   QUOTE (q-stankovic @ Aug 9 2010, 21...   Aug 9 2010, 21:53
|- - Qudeid   Didn't think it was a python25 issue. But I wo...   Aug 9 2010, 22:01
|- - MuffPotter   QUOTE (Qudeid @ Aug 9 2010, 23:01) Didn...   Aug 10 2010, 08:53
- - q-stankovic   At last, it works! Thanks fbuser! One iss...   Aug 9 2010, 22:09
|- - Qudeid   QUOTE (q-stankovic @ Aug 9 2010, 23...   Aug 9 2010, 22:20
- - q-stankovic   Ok, i went to LyrDb Site to search for albums i ha...   Aug 9 2010, 22:48
|- - cartman(2vd)   I dont know if this is considerable request but i ...   Aug 9 2010, 23:38
|- - Qudeid   QUOTE (cartman(2vd) @ Aug 10 2010, 00...   Aug 10 2010, 09:00
- - Qudeid   @MuffPotter: I've just checked myself. The sy...   Aug 10 2010, 09:38
|- - MuffPotter   QUOTE (Qudeid @ Aug 10 2010, 10:38) @Muff...   Aug 10 2010, 09:48
|- - Qudeid   QUOTE (MuffPotter @ Aug 10 2010, 10:48) Q...   Aug 10 2010, 09:58
|- - MuffPotter   QUOTE (Qudeid @ Aug 10 2010, 10:58) QUOTE...   Aug 10 2010, 10:09
- - Qudeid   Thank you very much. The funny thing is.. I didn...   Aug 10 2010, 10:28
- - Qudeid   Thanks to the admins I can now change the first po...   Aug 10 2010, 12:18
- - lokioki   Darklyrics you say ? I am sold. Foobar also infor...   Aug 10 2010, 15:05
|- - Qudeid   QUOTE (lokioki @ Aug 10 2010, 16:05) Dark...   Aug 10 2010, 15:51
- - q-stankovic   The usage of "Search All" leads always t...   Aug 10 2010, 17:18
- - mousepad   I followed the instructions in the Install.txt but...   Aug 10 2010, 17:24
- - Qudeid   @ stankovic: I'm looking at that error, right...   Aug 10 2010, 18:02
- - Qudeid   Version 0.3.6.1 is up.   Aug 10 2010, 22:16
|- - Decalicatan_Decalicatan   QUOTE (Qudeid @ Aug 10 2010, 23:16) Versi...   Aug 10 2010, 22:35
||- - Qudeid   Where is your pygrabber\system folder? The on...   Aug 10 2010, 22:40
||- - Decalicatan_Decalicatan   QUOTE (Qudeid @ Aug 10 2010, 23:40) Where...   Aug 10 2010, 23:39
|- - cartman(2vd)   QUOTE (Qudeid @ Aug 10 2010, 23:16) But n...   Aug 10 2010, 23:46
- - Jny   Qudeid can you add plyrics script? http://plyrics....   Aug 10 2010, 23:22
- - quomodo   There seems to be a problem with umlauts (, , )...   Aug 11 2010, 06:46
|- - Qudeid   QUOTE (quomodo @ Aug 11 2010, 07:46) Ther...   Aug 11 2010, 08:04
- - lokioki   ohkey, found the .dll ^^   Aug 11 2010, 10:26
- - quomodo   Hmm, I tried a few more tracks and no longer have ...   Aug 11 2010, 20:24
|- - Qudeid   Ah.. I now understand. Yes that could be it. Dark...   Aug 11 2010, 21:36
- - Yurk Yurk   Can I ask why LyricWiki has been removed as a sour...   Aug 12 2010, 00:31
- - Yurk Yurk   Another issue: I just ran the Search All on Bob Dy...   Aug 12 2010, 00:39
- - joelzhao   After millions times test, it works! but there...   Aug 12 2010, 02:30
- - Qudeid   @ Yurk Yurk: While I can not implement why or why...   Aug 12 2010, 08:55
- - Qudeid   @Yurk Yurk: I looked into lyricwiki and found no ...   Aug 12 2010, 11:49
- - icedtea   Edit mode on lyricwiki works http://lyrics.wikia.c...   Aug 12 2010, 11:54
|- - Qudeid   QUOTE (icedtea @ Aug 12 2010, 12:54) Edit...   Aug 12 2010, 12:28
- - Qudeid   New Version is out. fixed that crashing thing wit...   Aug 12 2010, 15:51
- - Nachash   a lot of error:101 No such a entry in the database...   Aug 12 2010, 17:16
3 Pages V   1 2 3 >
RSS Lo-Fi Version Time is now: 29th January 2015 - 08:27
