Call for capable people to do a comparison of rippers
Jan S.
post Jul 26 2010, 00:13
Group: Admin
Hi.
Over the years and recently (here and here) there have been many discussions and questions about the differences between different cd rippers. New rippers with secure ripping facilities (dbpoweramp, CUEtools, foobar etc) have emerged in recent years and it is now difficult to judge compared to some years ago when the only answer was EAC.
For this reason I thought it could be very good to have a page at the wiki trying to explain in a concise form what the differences are. I was imagining a table with features like we have done for the Lossless format comparison but probably also additional text is required.
I do not consider myself close to competent to try to do this but I have tried to setup a starting point for such a page here: http://wiki.hydrogenaudio.org/index.php?ti...n_of_CD_rippers
I hope the capable people here will invest some time into this so as to save time repeating these points. Please post your thoughts on this idea: how best to organize?, what to put in the table?, which programs are relevant?, what other issues need to be explain in text?, etc.
Some more links:
wikipedias list of rippers: http://en.wikipedia.org/wiki/CD_ripper
Kind of comparison here for secure ripping features: http://wiki.hydrogenaudio.org/index.php?title=Secure_ripping
greynol
post Jul 27 2010, 00:36
"Capable of disabling C2" needs to be removed.
"Use of C2" needs to be reworded as "C2 pointers used to detect errors" and "C2 pointers used during re-reads" needs to be added; or wording to that effect.
AccurateRip1 and AccurateRip2 should just be merged to be AccurateRip, unless spoon suggests otherwise.
There's also a distinction to be made between supporting CUE sheets and gap detection (foobar2000 does not support CUE sheets to the level that EAC/CUETools does).
You might want to get rid of secure ripping features, unless you better define what you expect to have placed there.
FUA support should be added.
dBpoweramp has some other ripping features, such as an attempt to detect interpolation in order to help drop consistent errors, though I don't feel it has been demonstrated as being useful for a wide enough range of drives (one could make the same argument for FUA as well). I also don't think we should create a chart that is heavily skewed based on a list of features belonging to just one ripping program. Still, any type of feature/technology that makes a clear difference in performance should be listed.
We should also consider if something like "Accurate Stream" is worth mentioning. If it is mentioned, I would prefer more generic terminology. "Accurate Stream" seems more like a marketing catch phrase which I have never seen anywhere but on EAC. If anyone actually knows the history of this phrase, please share.
This post has been edited by greynol: Jul 27 2010, 00:50
DR figures too, of course.
greynol
post Jul 28 2010, 00:34
Noting a recent addition made by Eli, I'd like to quote myself:
QUOTE (greynol @ Jul 26 2010, 16:36) *
Perhaps we have some objective 3rd-party statistics demonstrating how often someone is expected to derive a benefit from PerfectMeta?
Unless there are some objections, I'd like to remove the row and add a footnote to the metadata entry for dBpoweramp. I think the same should be done for the CUETool DB with a footnote added to its entry in the AccurateRip row. Perhaps the row be renamed to something that describes what the two services do.
I also think that the (natively) part be removed from the artwork and that the entries be done in a similar fashion as the metadata. Entries designed in such a way as to limit information should be avoided.
This post has been edited by greynol: Jul 28 2010, 00:44
Eli
post Jul 28 2010, 01:16
How many rippers have to support a feature? 2+, 3+? What about using C2 in re-reads? Only 2 rippers?
The feature of CTDB is exclusive to one ripper. I wish it wasn't. Its open to any other rippers to add support. Its an important enough feature in my mind (no other feature can actually correct unrecoverable data) to warrant its own row. Other developers should add support and get a yes in their row as well.
Comparison of meta-data is exclusive to one ripper, I wish it wasn't. Any developer could implement a version of PerfectMeta (under a non-TM name). I don't have any statistics and no one would consider me objective anyway, but I argue that its important enough of a feature to warrant its own row. Its current implementation in dBpoweramp is to skewed to AMG results, however it is still very useful, and much better then anything else anyone is offering.
QUOTE (greynol)
I have an objection with footnote 4 since it implies that dBpoweramp is the only current ripper that can check your rips against different pressings, especially considering that it isn't even the first ripper to be able to do this.
Footnote 4 is correct in that dBpoweramp is the only current ripper to support AR2. But you are also correct in that others support checking against different pressings. Does it warrant 3 rows; accuraterip support, cross pressing checks, and accuraterip 2 support? That would be most accurate, but also somewhat combersome.
This post has been edited by Eli: Jul 28 2010, 01:18
http://forum.dbpoweramp.com/showthread.php?t=21072
- Jan S.   Call for capable people to do a comparison of rippers   Jul 26 2010, 00:13
- - willow   I'm having the impression that novadays CD dri...   Jul 26 2010, 12:38
- - Jan S.   Did you account for offset and difference in heade...   Jul 26 2010, 13:26
- - Jan S.   I have filled some of the table but at this point ...   Jul 27 2010, 00:22
- - greynol   "Capable of disabling C2" needs to be re...   Jul 27 2010, 00:36
|- - greynol   Noting a recent addition made by Eli, I'd like...   Jul 28 2010, 00:34
|- - Eli   QUOTE (greynol @ Jul 26 2010, 16:36) I al...   Jul 28 2010, 01:16
- - Jan S.   * AR2 dropped and footnote added * dropped dppower...   Jul 27 2010, 01:01
- - greynol   I would think that anything hitting that chart sho...   Jul 27 2010, 01:10
- - greynol   When you tell EAC that your drive has Accurate Str...   Jul 27 2010, 01:18
- - greynol   I've made quite a few updates. Please review ...   Jul 27 2010, 07:22
- - spoon   HTOA has been supported since dBpoweramp R13 (it i...   Jul 27 2010, 10:14
|- - greynol   QUOTE (spoon @ Jul 27 2010, 02:14) Accura...   Jul 27 2010, 16:07
- - stevenmmm   MusicBee supports many of the ripping features lis...   Jul 27 2010, 11:42
|- - Jan S.   I have reorganized the table and added info. QUOT...   Jul 27 2010, 14:36
|- - greynol   QUOTE (Jan S. @ Jul 27 2010, 06:36) you a...   Jul 27 2010, 16:09
- - greynol   Careful about post-processing. With at least dBpo...   Jul 27 2010, 16:14
- - spoon   QUOTE Is the table correct now with regards to dbp...   Jul 27 2010, 16:20
- - greynol   From my understanding it wasn't a blanket chec...   Jul 27 2010, 16:28
- - spoon   It suggests that both CRCs are calculated, for eve...   Jul 27 2010, 20:16
- - greynol   I don't see how you can say that. It's pr...   Jul 27 2010, 20:24
- - spoon   >offset is largely determined through mathemati...   Jul 27 2010, 20:27
- - greynol   I just want to make sure that you realize that the...   Jul 27 2010, 20:42
- - spoon   The code suggests that all effective CRCs for +-5 ...   Jul 27 2010, 21:07
- - greynol   That seems to be the most plausible explanation; a...   Jul 27 2010, 21:25
- - spoon   >I don't understand why you would say it we...   Jul 27 2010, 21:42
- - greynol   I don't see how it could be when the two metho...   Jul 27 2010, 21:50
- - spoon   A bad collision is like playing the lottery, the m...   Jul 27 2010, 22:06
- - greynol   Duh, I get it now. Thanks spoon! CUETools do...   Jul 27 2010, 23:37
- - greynol   I'm starting to think that just specifying Win...   Jul 27 2010, 23:51
- - greynol   I have an objection with footnote 4 since it impli...   Jul 28 2010, 00:37
- - greynol   I think there is a way to generalize rows that and...   Jul 28 2010, 02:45
|- - Eli   QUOTE (greynol @ Jul 27 2010, 21:45) dBpo...   Jul 28 2010, 04:03
|- - greynol   QUOTE (Eli @ Jul 27 2010, 20:03) I'm ...   Jul 28 2010, 04:19
|- - Eli   QUOTE (greynol @ Jul 27 2010, 23:19) QUOT...   Jul 28 2010, 22:33
- - greynol   Maybe Jan feels differently, but I thought it a go...   Jul 28 2010, 04:18
- - Jan S.   Why is over-reading in the cache column?Why does ...   Jul 29 2010, 00:15
|- - greynol   QUOTE (Jan S. @ Jul 28 2010, 16:15) Why i...   Jul 29 2010, 01:57
|- - Jan S.   QUOTE (greynol @ Jul 29 2010, 02:57) QUOT...   Jul 29 2010, 23:56
|- - greynol   QUOTE (Jan S. @ Jul 29 2010, 15:56) So we...   Jul 30 2010, 01:06
||- - mjb2006   QUOTE (greynol @ Jul 29 2010, 18:06) QUOT...   Jul 30 2010, 10:41
|- - greynol   QUOTE (Jan S. @ Jul 29 2010, 15:56) C2 p...   Jul 30 2010, 01:13
- - Jan S.   I have implemented some of suggested changes. Befo...   Jul 30 2010, 14:16
- - greynol   I think adding a row about AR results across multi...   Jul 30 2010, 19:07
|- - Jan S.   QUOTE (greynol @ Jul 30 2010, 20:07) I th...   Jul 30 2010, 19:24
- - Jan S.   FYI I found this in XLD changelog:QUOTE Added opti...   Jul 30 2010, 19:11
- - greynol   Thanks Jan. I will edit the table accordingly to ...   Jul 30 2010, 19:21
- - greynol   The argument boils down to how likely a ripping er...   Jul 30 2010, 19:51
- - greynol   fb2k entry updated and other minor edits. I put N...   Jul 30 2010, 21:28
- - spoon   CDex should be added to the table, it is still wid...   Jul 30 2010, 22:00
- - greynol   >not a theory it is a fact You're right sp...   Jul 30 2010, 22:16
|- - Jan S.   QUOTE (greynol @ Jul 30 2010, 23:16) ...   Jul 30 2010, 22:32
- - greynol   I won't shed a tear to see it gone, but it lic...   Jul 30 2010, 22:39
|- - Jan S.   QUOTE (greynol @ Jul 30 2010, 23:39) I wo...   Jul 30 2010, 22:51
- - Pepzhez   There is no proprietary method of cache defeat in ...   Jul 30 2010, 23:10
- - greynol   Items that are left blank or are vague are in need...   Jul 31 2010, 00:52
- - Pepzhez   Filling in the gaps for XLD -- Image as single fi...   Jul 31 2010, 04:58
|- - Jan S.   QUOTE (Pepzhez @ Jul 31 2010, 05:58) Fill...   Jul 31 2010, 11:18
- - Porcus   One year and a half gone since this discussion, th...   Feb 15 2012, 11:10
- - Porcus   Considering the knowledgebase is open for edit ......   Oct 7 2012, 10:11
- - Porcus   * MediaMonkey version 4 claims secure ripping, and...   Jan 7 2015, 09:40
RSS Lo-Fi Version Time is now: 30th January 2015 - 18:10
