Playback Statistics component: version 3.0.1, Discussion, feedback and beta versions
Peter
post Jul 23 2010, 12:48
foobar2000 developer
Group: Admin
Download - version 3.0.1:
http://www.foobar2000.org/components/view/foo_playcount
Documentation:
http://wiki.hydrogenaudio.org/index.php?ti...oo_playcount%29
This component requires foobar2000 v1.1 or newer.
Changes since 3.0:
- No longer attempts to update tags on remote files or streams when playing.
This post has been edited by Peter: Oct 12 2010, 14:43
bsw11
post Aug 24 2010, 02:02
I can not get the rating to display as a number or starts. I know its getting set because it show in the song's properties. If I put %rating% it just shows ?. If I put (%rating%) it shows up as blank.
Do I need the foo_rating2 to make it work?
I am running the just released 1.1 but it did not work in the last beta as well for me.
muzack
post Aug 24 2010, 11:18
QUOTE (bsw11 @ Aug 24 2010, 03:02) *
Did you try to "import statistics from file tags" in track context menu?
If you write the rating directly to the file (via masstagger script or wsh panel script) it may not appear in statistics.
Correct me if I am wrong but I am sure that's the way it works.
Btw. I noticed faster File Operation (move files etc) with new Playbackstatistics. Maybe because the stat database doesn't depend on filepaths.
bsw11
post Aug 25 2010, 07:17
QUOTE (muzack @ Aug 24 2010, 03:18) *
OK that worked - but are you telling me that every time I set a rating I also have to do this as well?? That is not nice. Is there a way to fix this and just make it work?
Also I get a ? on all tracks that are not set - can you show me a way to eliminate this?
THANKS!
muzack
post Aug 25 2010, 08:18
QUOTE (bsw11 @ Aug 25 2010, 08:17) *
here are some quirky solutions which depends on how you set the rating:
If you use a masstagger script with keyboardshortcuts (like me) then write the id3 rating tags back to statistic db over the full library. once a week or so.
(select the rootnode in album view and choose "write statistics from file tags")
Or you use keyboardshortcuts and map them to the original Playbackstat rating contextmenu but then no rating tag in files anymore.
If you set Preferences > Advanced > Tools > Playback Statistics > Automatically synchronize file tags with statistics... - then the rating will be written to your tags. But any other stat field will be written too (%last_played% etc.)
Or if you just want to display your rating tag in a playlistcolumn without using the component, then set a column with $meta(rating) instead of %rating%. This will use the filetag.
And if you use something like [%rating%] (square brackets) then the ? symbol disappears.
I think that's all possible ways. Maybe someone have another hint.
- Peter   Playback Statistics component: version 3.0.1   Jul 23 2010, 12:48
- - _oao   QUOTE XML backup functionality You can export pla...   Jul 23 2010, 13:34
- - s33m33   Thanks Peter for the hard work. from wiki: QUOTE...   Jul 23 2010, 13:36
- - orchid   Hello Peter, Are there any plans to add options f...   Jul 23 2010, 14:17
- - xan K   WOW, this is awesome! Thank you for the hard w...   Jul 23 2010, 14:58
- - q-stankovic   Thanks Peter, great release! The concept is a...   Jul 23 2010, 18:08
- - _oao   this new Copy/Paste statistics feature is quite ha...   Jul 23 2010, 23:28
- - phool   Losing my playback stats has been one of the reaso...   Jul 24 2010, 07:24
|- - kompot   Some (strange?) behaviour discovered. Documentati...   Jul 24 2010, 08:12
- - Peter   Disc numbers are in fact used (updated the wiki pa...   Jul 24 2010, 08:42
|- - kompot   Actually not only disc numbers differ but track nu...   Jul 24 2010, 10:28
- - Peter   OK, bug found, thanks for reporting. Fixed in bet...   Jul 24 2010, 11:01
- - Gnx   Thanks Peter for all that work. I used foo_quickt...   Jul 24 2010, 18:26
- - Yirkha   Properties   - The characters should be stars, but...   Jul 24 2010, 18:58
- - Gnx   nice Thx   Jul 24 2010, 20:51
- - lwiczek   QUOTE (s33m33 @ Jul 23 2010, 14:36) Thank...   Jul 25 2010, 10:42
|- - xan K   QUOTE (lwiczek @ Jul 25 2010, 05:42) +1 A...   Jul 27 2010, 04:08
- - eradumvelhinho   I don't understand. The same thing happened a ...   Jul 26 2010, 18:35
- - Nemphael   I had some problems - a whole album lost it's ...   Jul 26 2010, 20:36
- - eradumvelhinho   Okay. My problem is solved. It seems that some of ...   Jul 27 2010, 11:17
- - grimes   Where is the Statistics-database stored? Can't...   Jul 27 2010, 11:40
- - Yirkha   QUOTE (Yirkha @ Jul 24 2010, 19:58)   - ...   Jul 27 2010, 14:19
|- - hxkclan   QUOTE (Yirkha @ Jul 27 2010, 14:19) QUOTE...   Jul 30 2010, 23:21
- - Qest   Background: I do not use file tags. I prefer to ke...   Jul 27 2010, 22:27
|- - Case   QUOTE (Qest @ Jul 28 2010, 00:27) Backgro...   Jul 30 2010, 11:43
- - neothe0ne   What happens if you update file tags in foobar2000...   Jul 28 2010, 09:45
- - romor   I used converter to convert one of my library...   Jul 28 2010, 12:43
|- - GeSomeone   QUOTE (romor @ Jul 28 2010, 13:43) I used...   Jul 28 2010, 13:57
- - romor   It is delicate thing, but I would like to consider...   Jul 28 2010, 14:22
- - Nemphael   I rewrote a couple of tags with mp3tags so they...   Jul 29 2010, 17:54
|- - Qest   QUOTE (Nemphael @ Jul 29 2010, 09:54) By ...   Jul 29 2010, 18:14
|- - Snowknight26   QUOTE (Nemphael @ Jul 29 2010, 11:54) I r...   Jul 30 2010, 21:26
- - muzack   What about adding the HOTNESS algorithm in the ne...   Jul 31 2010, 13:29
- - lwiczek   It would be nice if there would be additional fiel...   Aug 1 2010, 08:32
|- - kompot   Feature proposal. Are there any chance of adding ...   Aug 4 2010, 16:37
|- - MordredKLB   This is awesome and leads to a feature request I...   Aug 6 2010, 19:12
- - Sandrine   The functionality of this component looks interest...   Aug 6 2010, 23:54
|- - eradumvelhinho   QUOTE (Sandrine @ Aug 6 2010, 16:54) but ...   Aug 7 2010, 00:28
|- - Sandrine   QUOTE (eradumvelhinho @ Aug 7 2010, 01:28...   Aug 8 2010, 20:29
- - mrinferno   hey peter, thanks really enjoying the new beta of ...   Aug 7 2010, 00:12
- - lvqcl   http://wiki.hydrogenaudio.org/index.php?ti...rmatt...   Aug 7 2010, 00:36
- - JohanDeBock   Great addition, keep up the good work! Nice to...   Aug 7 2010, 12:23
- - fxnaxn   Hey, does anyone know the exact algorithm that is ...   Aug 7 2010, 20:08
- - Nemphael   %first_played% and %last_played% will return dates...   Aug 8 2010, 20:46
|- - Sandrine   QUOTE (Nemphael @ Aug 8 2010, 21:46) %fir...   Aug 8 2010, 20:57
- - Nemphael   Oh, didn't see the part about Masstagger. You ...   Aug 8 2010, 21:06
- - Sandrine   After playing around a bit with this component, he...   Aug 8 2010, 22:18
|- - laite   QUOTE (Sandrine @ Aug 9 2010, 00:18) c) R...   Aug 10 2010, 14:20
- - marc2003   to display stuff in file tags, use $meta. eg ...   Aug 10 2010, 14:29
|- - laite   QUOTE (marc2003 @ Aug 10 2010, 16:29) to ...   Aug 10 2010, 14:36
- - marc2003   i thought $meta worked in queries but having ...   Aug 10 2010, 14:44
|- - KarnEvil9   QUOTE (marc2003 @ Aug 10 2010, 05:44) but...   Aug 10 2010, 17:42
|- - laite   QUOTE (marc2003 @ Aug 10 2010, 16:44) but...   Aug 11 2010, 11:39
- - Nemphael   To use functions like $meta() in Autoplaylist...   Aug 10 2010, 17:49
- - s33m33   Thanks Nemphael for the tip.   Aug 13 2010, 07:36
- - d4kk0n1234   Bug: 2 different tracks with the same tags except...   Aug 13 2010, 14:40
- - klonuo   XML output doesn't have "artist + album +...   Aug 13 2010, 18:46
|- - klonuo   QUOTE (klonuo @ Aug 13 2010, 18:46) Actu...   Aug 14 2010, 12:22
- - Vanishing   Thanks for the great work, I'm a long time foo...   Aug 13 2010, 19:27
|- - mrinferno   Vanishing, Suggest referencing the Wiki article f...   Aug 13 2010, 19:44
- - Vanishing   I understand, and I also read the Wiki. I like the...   Aug 14 2010, 11:27
- - GLiBERN   QUOTE (Vanishing @ Aug 13 2010, 20:27) A ...   Aug 15 2010, 19:29
- - Canar   Bug report: I have two albums with the same artist...   Aug 17 2010, 00:42
|- - copperblue   QUOTE (Canar @ Aug 16 2010, 23:42) Bug re...   Sep 8 2010, 09:33
|- - shakey_snake   QUOTE (copperblue @ Sep 8 2010, 04:33) QU...   Sep 8 2010, 14:57
- - q-stankovic   I like to approve what vanishing already said: it ...   Aug 18 2010, 18:35
|- - bubbleguuum   QUOTE (q-stankovic @ Aug 18 2010, 19...   Aug 18 2010, 20:18
- - q-stankovic   I wouldn't care about that despite the strange...   Aug 18 2010, 20:31
- - bsw11   I can not get the rating to display as a number or...   Aug 24 2010, 02:02
|- - muzack   QUOTE (bsw11 @ Aug 24 2010, 03:02) I can ...   Aug 24 2010, 11:18
|- - bsw11   QUOTE (muzack @ Aug 24 2010, 03:18) QUOTE...   Aug 25 2010, 07:17
|- - muzack   QUOTE (bsw11 @ Aug 25 2010, 08:17) OK tha...   Aug 25 2010, 08:18
- - Xezzy   Playback statistics 3.0 is just brilliant, thank y...   Aug 24 2010, 19:05
- - _oao   QUOTE Playback statistics are now pinned to a comb...   Aug 25 2010, 07:04
- - Sixth Street   So I'm approaching upgrading to 3.0 with some ...   Aug 25 2010, 16:28
- - mystNZ   I am having trouble changing a song's "Ad...   Aug 26 2010, 19:51
- - tpijag   Added date = date added to library. Static. It is ...   Aug 26 2010, 20:14
|- - mystNZ   QUOTE (tpijag @ Aug 27 2010, 06:14) Added...   Aug 26 2010, 20:30
|- - muzack   You can edit the added date in playbackstat this w...   Aug 26 2010, 21:42
|- - GeSomeone   QUOTE (mystNZ @ Aug 26 2010, 21:30) [..]u...   Aug 27 2010, 11:58
- - Zulithe   Is there any way to use this component WITHOUT it ...   Aug 27 2010, 06:24
|- - shakey_snake   It does not modify files by default--you'll ne...   Aug 27 2010, 06:31
- - kruji   QUOTE (Yirkha @ Jul 24 2010, 18:58)   - ...   Aug 28 2010, 12:24
|- - Yirkha   QUOTE (kruji @ Aug 28 2010, 13:24) is ist...   Aug 30 2010, 12:19
- - rend3r   Do I have any chance to get latest foo_playcount f...   Aug 30 2010, 01:27
- - Jubei   Ok. Read this thread several times, but am getting...   Sep 1 2010, 19:19
|- - Robertina   QUOTE (Jubei @ Sep 1 2010, 07:19) What sh...   Sep 1 2010, 21:17
|- - Jubei   Thanks first for the info. I normally have Foobar...   Sep 1 2010, 21:34
|- - Yirkha   QUOTE (Jubei @ Sep 1 2010, 22:34) In the ...   Sep 1 2010, 21:40
- - Jubei   ... so how can I check if the Playback Statistics ...   Sep 1 2010, 21:46
- - Robertina   You can install as many foobar versions as you wan...   Sep 1 2010, 22:14
|- - Jubei   Good idea! To be frank, though, I think my pr...   Sep 1 2010, 22:19
- - Robertina   This is really strange. I can tell you that both %...   Sep 1 2010, 22:28
|- - Jubei   OH MY GOD! RESET SOLVED EVERYTHING!! ...   Sep 1 2010, 22:31
- - Robertina   I am very glad that you have been able to solve th...   Sep 1 2010, 22:54
- - thi3nki3p   Hello, recently I'm starting to listen to shou...   Sep 6 2010, 11:51
- - lrossouw   I'd like to be able to create an xml restore f...   Sep 6 2010, 20:14
- - Copland   My ML is stored on a NAS. I use an identical fooba...   Sep 8 2010, 20:32
- - Yirkha   Do the computers run different OS?   Sep 8 2010, 23:30
- - Copland   QUOTE (Yirkha @ Sep 8 2010, 23:30) Do the...   Sep 9 2010, 09:28
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 30th January 2015 - 19:11
