Playback Statistics component: version 3.0.1, Discussion, feedback and beta versions
Peter
post Jul 23 2010, 12:48
foobar2000 developer
Group: Admin
Download - version 3.0.1:
http://www.foobar2000.org/components/view/foo_playcount
Documentation:
http://wiki.hydrogenaudio.org/index.php?ti...oo_playcount%29
This component requires foobar2000 v1.1 or newer.
Changes since 3.0:
- No longer attempts to update tags on remote files or streams when playing.
This post has been edited by Peter: Oct 12 2010, 14:43
Canar
post Aug 17 2010, 00:42
Bug report: I have two albums with the same artist and title but different track listings. However, statistics component does not differentiate the two. See:
The first visible column to the right of "Track Information" is the the play counter.
2. Assume good faith.
- Peter   Playback Statistics component: version 3.0.1   Jul 23 2010, 12:48
- - _oao   QUOTE XML backup functionality You can export pla...   Jul 23 2010, 13:34
- - s33m33   Thanks Peter for the hard work. from wiki: QUOTE...   Jul 23 2010, 13:36
- - orchid   Hello Peter, Are there any plans to add options f...   Jul 23 2010, 14:17
- - xan K   WOW, this is awesome! Thank you for the hard w...   Jul 23 2010, 14:58
- - q-stankovic   Thanks Peter, great release! The concept is a...   Jul 23 2010, 18:08
- - _oao   this new Copy/Paste statistics feature is quite ha...   Jul 23 2010, 23:28
- - phool   Losing my playback stats has been one of the reaso...   Jul 24 2010, 07:24
|- - kompot   Some (strange?) behaviour discovered. Documentati...   Jul 24 2010, 08:12
- - Peter   Disc numbers are in fact used (updated the wiki pa...   Jul 24 2010, 08:42
|- - kompot   Actually not only disc numbers differ but track nu...   Jul 24 2010, 10:28
- - Peter   OK, bug found, thanks for reporting. Fixed in bet...   Jul 24 2010, 11:01
- - Gnx   Thanks Peter for all that work. I used foo_quickt...   Jul 24 2010, 18:26
- - Yirkha   Properties   - The characters should be stars, but...   Jul 24 2010, 18:58
- - Gnx   nice Thx   Jul 24 2010, 20:51
- - lwiczek   QUOTE (s33m33 @ Jul 23 2010, 14:36) Thank...   Jul 25 2010, 10:42
|- - xan K   QUOTE (lwiczek @ Jul 25 2010, 05:42) +1 A...   Jul 27 2010, 04:08
- - eradumvelhinho   I don't understand. The same thing happened a ...   Jul 26 2010, 18:35
- - Nemphael   I had some problems - a whole album lost it's ...   Jul 26 2010, 20:36
- - eradumvelhinho   Okay. My problem is solved. It seems that some of ...   Jul 27 2010, 11:17
- - grimes   Where is the Statistics-database stored? Can't...   Jul 27 2010, 11:40
- - Yirkha   QUOTE (Yirkha @ Jul 24 2010, 19:58)   - ...   Jul 27 2010, 14:19
|- - hxkclan   QUOTE (Yirkha @ Jul 27 2010, 14:19) QUOTE...   Jul 30 2010, 23:21
- - Qest   Background: I do not use file tags. I prefer to ke...   Jul 27 2010, 22:27
|- - Case   QUOTE (Qest @ Jul 28 2010, 00:27) Backgro...   Jul 30 2010, 11:43
- - neothe0ne   What happens if you update file tags in foobar2000...   Jul 28 2010, 09:45
- - romor   I used converter to convert one of my library...   Jul 28 2010, 12:43
|- - GeSomeone   QUOTE (romor @ Jul 28 2010, 13:43) I used...   Jul 28 2010, 13:57
- - romor   It is delicate thing, but I would like to consider...   Jul 28 2010, 14:22
- - Nemphael   I rewrote a couple of tags with mp3tags so they...   Jul 29 2010, 17:54
|- - Qest   QUOTE (Nemphael @ Jul 29 2010, 09:54) By ...   Jul 29 2010, 18:14
|- - Snowknight26   QUOTE (Nemphael @ Jul 29 2010, 11:54) I r...   Jul 30 2010, 21:26
- - muzack   What about adding the HOTNESS algorithm in the ne...   Jul 31 2010, 13:29
- - lwiczek   It would be nice if there would be additional fiel...   Aug 1 2010, 08:32
|- - kompot   Feature proposal. Are there any chance of adding ...   Aug 4 2010, 16:37
|- - MordredKLB   This is awesome and leads to a feature request I...   Aug 6 2010, 19:12
- - Sandrine   The functionality of this component looks interest...   Aug 6 2010, 23:54
|- - eradumvelhinho   QUOTE (Sandrine @ Aug 6 2010, 16:54) but ...   Aug 7 2010, 00:28
|- - Sandrine   QUOTE (eradumvelhinho @ Aug 7 2010, 01:28...   Aug 8 2010, 20:29
- - mrinferno   hey peter, thanks really enjoying the new beta of ...   Aug 7 2010, 00:12
- - lvqcl   http://wiki.hydrogenaudio.org/index.php?ti...rmatt...   Aug 7 2010, 00:36
- - JohanDeBock   Great addition, keep up the good work! Nice to...   Aug 7 2010, 12:23
- - fxnaxn   Hey, does anyone know the exact algorithm that is ...   Aug 7 2010, 20:08
- - Nemphael   %first_played% and %last_played% will return dates...   Aug 8 2010, 20:46
|- - Sandrine   QUOTE (Nemphael @ Aug 8 2010, 21:46) %fir...   Aug 8 2010, 20:57
- - Nemphael   Oh, didn't see the part about Masstagger. You ...   Aug 8 2010, 21:06
- - Sandrine   After playing around a bit with this component, he...   Aug 8 2010, 22:18
|- - laite   QUOTE (Sandrine @ Aug 9 2010, 00:18) c) R...   Aug 10 2010, 14:20
- - marc2003   to display stuff in file tags, use $meta. eg ...   Aug 10 2010, 14:29
|- - laite   QUOTE (marc2003 @ Aug 10 2010, 16:29) to ...   Aug 10 2010, 14:36
- - marc2003   i thought $meta worked in queries but having ...   Aug 10 2010, 14:44
|- - KarnEvil9   QUOTE (marc2003 @ Aug 10 2010, 05:44) but...   Aug 10 2010, 17:42
|- - laite   QUOTE (marc2003 @ Aug 10 2010, 16:44) but...   Aug 11 2010, 11:39
- - Nemphael   To use functions like $meta() in Autoplaylist...   Aug 10 2010, 17:49
- - s33m33   Thanks Nemphael for the tip.   Aug 13 2010, 07:36
- - d4kk0n1234   Bug: 2 different tracks with the same tags except...   Aug 13 2010, 14:40
- - klonuo   XML output doesn't have "artist + album +...   Aug 13 2010, 18:46
|- - klonuo   QUOTE (klonuo @ Aug 13 2010, 18:46) Actu...   Aug 14 2010, 12:22
- - Vanishing   Thanks for the great work, I'm a long time foo...   Aug 13 2010, 19:27
|- - mrinferno   Vanishing, Suggest referencing the Wiki article f...   Aug 13 2010, 19:44
- - Vanishing   I understand, and I also read the Wiki. I like the...   Aug 14 2010, 11:27
- - GLiBERN   QUOTE (Vanishing @ Aug 13 2010, 20:27) A ...   Aug 15 2010, 19:29
- - Canar   Bug report: I have two albums with the same artist...   Aug 17 2010, 00:42
|- - copperblue   QUOTE (Canar @ Aug 16 2010, 23:42) Bug re...   Sep 8 2010, 09:33
|- - shakey_snake   QUOTE (copperblue @ Sep 8 2010, 04:33) QU...   Sep 8 2010, 14:57
- - q-stankovic   I like to approve what vanishing already said: it ...   Aug 18 2010, 18:35
|- - bubbleguuum   QUOTE (q-stankovic @ Aug 18 2010, 19...   Aug 18 2010, 20:18
- - q-stankovic   I wouldn't care about that despite the strange...   Aug 18 2010, 20:31
- - bsw11   I can not get the rating to display as a number or...   Aug 24 2010, 02:02
|- - muzack   QUOTE (bsw11 @ Aug 24 2010, 03:02) I can ...   Aug 24 2010, 11:18
|- - bsw11   QUOTE (muzack @ Aug 24 2010, 03:18) QUOTE...   Aug 25 2010, 07:17
|- - muzack   QUOTE (bsw11 @ Aug 25 2010, 08:17) OK tha...   Aug 25 2010, 08:18
- - Xezzy   Playback statistics 3.0 is just brilliant, thank y...   Aug 24 2010, 19:05
- - _oao   QUOTE Playback statistics are now pinned to a comb...   Aug 25 2010, 07:04
- - Sixth Street   So I'm approaching upgrading to 3.0 with some ...   Aug 25 2010, 16:28
- - mystNZ   I am having trouble changing a song's "Ad...   Aug 26 2010, 19:51
- - tpijag   Added date = date added to library. Static. It is ...   Aug 26 2010, 20:14
|- - mystNZ   QUOTE (tpijag @ Aug 27 2010, 06:14) Added...   Aug 26 2010, 20:30
|- - muzack   You can edit the added date in playbackstat this w...   Aug 26 2010, 21:42
|- - GeSomeone   QUOTE (mystNZ @ Aug 26 2010, 21:30) [..]u...   Aug 27 2010, 11:58
- - Zulithe   Is there any way to use this component WITHOUT it ...   Aug 27 2010, 06:24
|- - shakey_snake   It does not modify files by default--you'll ne...   Aug 27 2010, 06:31
- - kruji   QUOTE (Yirkha @ Jul 24 2010, 18:58)   - ...   Aug 28 2010, 12:24
|- - Yirkha   QUOTE (kruji @ Aug 28 2010, 13:24) is ist...   Aug 30 2010, 12:19
- - rend3r   Do I have any chance to get latest foo_playcount f...   Aug 30 2010, 01:27
- - Jubei   Ok. Read this thread several times, but am getting...   Sep 1 2010, 19:19
|- - Robertina   QUOTE (Jubei @ Sep 1 2010, 07:19) What sh...   Sep 1 2010, 21:17
|- - Jubei   Thanks first for the info. I normally have Foobar...   Sep 1 2010, 21:34
|- - Yirkha   QUOTE (Jubei @ Sep 1 2010, 22:34) In the ...   Sep 1 2010, 21:40
- - Jubei   ... so how can I check if the Playback Statistics ...   Sep 1 2010, 21:46
- - Robertina   You can install as many foobar versions as you wan...   Sep 1 2010, 22:14
|- - Jubei   Good idea! To be frank, though, I think my pr...   Sep 1 2010, 22:19
- - Robertina   This is really strange. I can tell you that both %...   Sep 1 2010, 22:28
|- - Jubei   OH MY GOD! RESET SOLVED EVERYTHING!! ...   Sep 1 2010, 22:31
- - Robertina   I am very glad that you have been able to solve th...   Sep 1 2010, 22:54
- - thi3nki3p   Hello, recently I'm starting to listen to shou...   Sep 6 2010, 11:51
- - lrossouw   I'd like to be able to create an xml restore f...   Sep 6 2010, 20:14
- - Copland   My ML is stored on a NAS. I use an identical fooba...   Sep 8 2010, 20:32
- - Yirkha   Do the computers run different OS?   Sep 8 2010, 23:30
- - Copland   QUOTE (Yirkha @ Sep 8 2010, 23:30) Do the...   Sep 9 2010, 09:28
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 6th March 2015 - 18:34
