44.1 vs 88.2 ABX report at AES
2Bdecided
post Jul 16 2010, 17:07
ReplayGain developer
Here:
http://www.aes.org/events/128/papers/?ID=2252
P18-6 Sampling Rate Discrimination: 44.1 kHz vs. 88.2 kHz—Amandine Pras, Catherine Guastavino, McGill University - Montreal, Quebec, Canada
It is currently common practice for sound engineers to record digital music using high-resolution formats, and then down sample the files to 44.1 kHz for commercial release. This study aims at investigating whether listeners can perceive differences between musical files recorded at 44.1 kHz and 88.2 kHz with the same analog chain and type of AD-converter. Sixteen expert listeners were asked to compare 3 versions (44.1 kHz, 88.2 kHz, and the 88.2 kHz version down-sampled to 44.1 kHz) of 5 musical excerpts in a blind ABX task. Overall, participants were able to discriminate between files recorded at 88.2 kHz and their 44.1 kHz down-sampled version. Furthermore, for the orchestral excerpt, they were able to discriminate between files recorded at 88.2 kHz and files recorded at 44.1 kHz.
Convention Paper 8101
Was anyone at the presentation? Has anyone bought the paper?
Arnold B. Kruege...
post Jul 16 2010, 19:45
QUOTE (2Bdecided @ Jul 16 2010, 12:07) *
Here:
Some friends from here went to the convention and we discussed a number of the papers last Saturday.
Problems I see with the tests is that they were done rather awkwardly and with the DACs running at different sample rates. Recording with parallel ADCs running at different sample rates introduces more potential for artifacts.
It is easy to show that recording and playing at different sample rates sounds different if the equipment has artifacts that are associated with different sample rates, which is not uncommon.
The *right* way to do this experiment is to record everything at a high sample rate, and create the low sample rate data by down sampling followed by up sampling. Then, all the hardware runs at the same (high) sample rate and differences due to its failings are minimized.
This post has been edited by Arnold B. Krueger: Jul 16 2010, 19:51
C.R.Helmrich
post Jul 16 2010, 20:25
So this basically means it's more important to make the DAC high-resolution than to make the ADC high-resolution. Interesting. So pbelkner's question is legitimate. Maybe a 88.2-kHz DAC tends to reproduce a 44.1-kHz recording more faithfully than a 44.1-kHz DAC? Assuming a good upsampling algorithm, of course.
Chris
This post has been edited by C.R.Helmrich: Jul 16 2010, 20:27
pbelkner
post Jul 16 2010, 20:59
QUOTE (C.R.Helmrich @ Jul 16 2010, 21:25) *
My preference is to up-sample 44.1 kHz to 88.2 kHz and 48 kHz to 96 kHz, respectively, depending on the original sample rate, i.e. no fixed rate for up-sampling but an integer multiple of the input sample rate.
My preferred algorithms are the ones provided by the SoX library (http://sox.sourceforge.net/).
This post has been edited by pbelkner: Jul 16 2010, 21:16
- 2Bdecided   44.1 vs 88.2 ABX report at AES   Jul 16 2010, 17:07
- - Dologan   Interesting. The fact that the discrimination was ...   Jul 16 2010, 18:18
|- - C.R.Helmrich   http://coltrane.music.mcgill.ca/MAQ/experiments co...   Jul 16 2010, 19:33
|- - Dologan   QUOTE (C.R.Helmrich @ Jul 16 2010, 19:33)...   Jul 16 2010, 20:30
- - Arnold B. Krueger   QUOTE (2Bdecided @ Jul 16 2010, 12:07) He...   Jul 16 2010, 19:45
|- - pbelkner   QUOTE (Arnold B. Krueger @ Jul 16 2010, 20...   Jul 16 2010, 20:01
||- - Dologan   QUOTE (pbelkner @ Jul 16 2010, 20:01) QUO...   Jul 16 2010, 20:03
||- - pbelkner   QUOTE (Dologan @ Jul 16 2010, 21:03) but ...   Jul 16 2010, 20:19
||- - benski   Yes, exactly. It is cheaper to design a 192kHz DA...   Jul 16 2010, 20:47
||- - Arnold B. Krueger   QUOTE (Dologan @ Jul 16 2010, 15:03) QUOT...   Jul 16 2010, 23:21
|- - C.R.Helmrich   QUOTE Overall, participants were able to discrimin...   Jul 16 2010, 20:25
|- - pbelkner   QUOTE (C.R.Helmrich @ Jul 16 2010, 21:25)...   Jul 16 2010, 20:59
- - krabapple   1) I suggest this thread be focused on the 44.1 v...   Jul 16 2010, 22:23
|- - WernerO   QUOTE (krabapple @ Jul 16 2010, 23:23) Th...   Aug 11 2010, 13:51
|- - mzil   QUOTE (krabapple @ Jul 16 2010, 17:23) 2)...   Jul 22 2012, 02:47
|- - C.R.Helmrich   Sorry for bumping this thread, but I thought the f...   Mar 8 2014, 01:21
|- - [JAZ]   QUOTE (C.R.Helmrich @ Mar 8 2014, 01:21) ...   Mar 8 2014, 18:38
- - googlebot   Why upsample? 99.9% of all DACs oversample anyway....   Jul 16 2010, 22:25
|- - Arnold B. Krueger   QUOTE (googlebot @ Jul 16 2010, 17:25) Wh...   Jul 16 2010, 23:47
|- - benski   QUOTE (Arnold B. Krueger @ Jul 16 2010, 18...   Jul 17 2010, 03:12
||- - Arnold B. Krueger   QUOTE (benski @ Jul 16 2010, 22:12) QUOTE...   Jul 17 2010, 06:39
||- - greynol   QUOTE (Arnold B. Krueger @ Jul 16 2010, 22...   Jul 17 2010, 18:33
||- - Arnold B. Krueger   QUOTE (greynol @ Jul 17 2010, 13:33) QUOT...   Jul 17 2010, 20:35
|- - 2Bdecided   QUOTE (Arnold B. Krueger @ Jul 16 2010, 23...   Jul 21 2010, 13:22
- - Alex B   I think the least incorrect way to compare 88.2 KH...   Jul 16 2010, 22:33
|- - Arnold B. Krueger   QUOTE (Alex B @ Jul 16 2010, 17:33) I thi...   Jul 16 2010, 23:30
|- - Dologan   QUOTE (Alex B @ Jul 16 2010, 22:33) I thi...   Jul 16 2010, 23:40
- - AndyH-ha   It seems that what I wrote in the first part of my...   Jul 17 2010, 09:55
|- - googlebot   AndyH-ha, that might be on purpose. For two lowpas...   Jul 17 2010, 10:49
- - googlebot   I think the 88.2 vs. downsampled 44.1 test had at ...   Jul 17 2010, 16:39
- - greynol   QUOTE (Arnold B. Krueger @ Jul 17 2010, 12...   Jul 17 2010, 20:48
|- - Arnold B. Krueger   QUOTE (greynol @ Jul 17 2010, 15:48) QUOT...   Jul 17 2010, 23:04
- - AndyH-ha   I also may not know what I'm talking about, bu...   Jul 17 2010, 22:02
- - greynol   The reason for oversampling in old CD players is a...   Jul 17 2010, 22:13
|- - Arnold B. Krueger   QUOTE (greynol @ Jul 17 2010, 17:13) The ...   Jul 17 2010, 23:14
- - greynol   I'm taking issue with what I thought was a bla...   Jul 17 2010, 23:27
|- - Arnold B. Krueger   QUOTE (greynol @ Jul 17 2010, 18:27) I...   Jul 18 2010, 01:52
|- - greynol   QUOTE (Arnold B. Krueger @ Jul 17 2010, 17...   Jul 19 2010, 00:56
- - amandinepras   Thanks all for your interest in our paper, I recei...   Jul 19 2010, 00:52
|- - Arnold B. Krueger   QUOTE (amandinepras @ Jul 18 2010, 19:52)...   Jul 19 2010, 03:35
|- - Arnold B. Krueger   QUOTE (amandinepras @ Jul 18 2010, 19:52)...   Jul 19 2010, 11:35
||- - 2Bdecided   QUOTE (Arnold B. Krueger @ Jul 19 2010, 11...   Jul 21 2010, 13:20
||- - Kees de Visser   QUOTE (2Bdecided @ Jul 21 2010, 14:20) QU...   Jul 23 2010, 09:26
|- - Arnold B. Krueger   QUOTE (amandinepras @ Jul 18 2010, 19:52)...   Jul 19 2010, 11:48
||- - googlebot   QUOTE (Arnold B. Krueger @ Jul 19 2010, 12...   Jul 19 2010, 12:19
|||- - Arnold B. Krueger   QUOTE (googlebot @ Jul 19 2010, 07:19) QU...   Jul 19 2010, 14:33
||- - krabapple   QUOTE (Arnold B. Krueger @ Jul 19 2010, 06...   Jul 19 2010, 14:08
|- - Notat   QUOTE (amandinepras @ Jul 18 2010, 17:52)...   Jul 21 2010, 04:08
|- - hciman77   QUOTE (amandinepras @ Jul 18 2010, 19:52)...   Jul 28 2010, 15:18
- - Pio2001   Thanks for joining the discussion, Amandine. Your...   Jul 19 2010, 12:31
|- - 2Bdecided   QUOTE (Pio2001 @ Jul 19 2010, 12:31) I se...   Jul 21 2010, 13:13
- - googlebot   The study shows at least the intent of objectivity...   Jul 19 2010, 16:28
|- - Arnold B. Krueger   QUOTE (googlebot @ Jul 19 2010, 11:28) [l...   Jul 19 2010, 19:11
|- - Soap   QUOTE (Arnold B. Krueger @ Jul 19 2010, 14...   Jul 19 2010, 20:24
|- - Soap   QUOTE (Arnold B. Krueger @ Jul 19 2010, 14...   Jul 19 2010, 23:07
- - Juha   QUOTE Doesn't anybody else see a problem with ...   Jul 19 2010, 19:25
- - googlebot   The manufacturer's specs for the FF 800. Unwei...   Jul 19 2010, 20:22
|- - Arnold B. Krueger   QUOTE (googlebot @ Jul 19 2010, 15:22) Th...   Jul 19 2010, 21:26
- - Cavaille   Forgive me to interrupt this discussion about the ...   Jul 20 2010, 08:40
|- - Arnold B. Krueger   QUOTE (Cavaille @ Jul 20 2010, 03:40) Arn...   Jul 20 2010, 13:13
|- - Arnold B. Krueger   QUOTE (Arnold B. Krueger @ Jul 20 2010, 08...   Jul 20 2010, 19:30
||- - Pio2001   QUOTE (Arnold B. Krueger @ Jul 20 2010, 20...   Jul 20 2010, 22:36
|||- - Arnold B. Krueger   QUOTE (Pio2001 @ Jul 20 2010, 17:36) QUOT...   Jul 20 2010, 23:57
||- - C.R.Helmrich   QUOTE (Arnold B. Krueger @ Jul 20 2010, 20...   Jul 20 2010, 22:53
|- - 2Bdecided   QUOTE (Arnold B. Krueger @ Jul 20 2010, 13...   Jul 21 2010, 13:25
|- - WernerO   QUOTE (Arnold B. Krueger @ Jul 20 2010, 14...   Aug 2 2010, 08:19
|- - Arnold B. Krueger   QUOTE (WernerO @ Aug 2 2010, 03:19) QUOTE...   Aug 2 2010, 11:56
- - Pio2001   The strange thing is that there are ABX results wi...   Jul 21 2010, 12:16
|- - hciman77   QUOTE (Pio2001 @ Jul 21 2010, 07:16) The ...   Jul 27 2010, 22:56
- - googlebot   The fact, that the study's authors have regist...   Jul 23 2010, 10:55
|- - Pio2001   QUOTE (googlebot @ Jul 23 2010, 11:55) co...   Jul 24 2010, 13:58
- - krabapple   Sheesh, it's only been four days. They may ac...   Jul 23 2010, 19:20
- - googlebot   In dubio pro reo is generally a good principle. Bu...   Jul 26 2010, 19:43
|- - hciman77   QUOTE (googlebot @ Jul 26 2010, 14:43) In...   Jul 26 2010, 21:05
- - hciman77   I read the full paper and I think there may be som...   Jul 26 2010, 19:48
|- - Arnold B. Krueger   QUOTE (hciman77 @ Jul 26 2010, 14:48) I r...   Jul 27 2010, 13:16
||- - 2Bdecided   QUOTE (Arnold B. Krueger @ Jul 27 2010, 13...   Jul 27 2010, 22:45
|- - Pio2001   QUOTE (hciman77 @ Jul 26 2010, 20:48) Thi...   Jul 28 2010, 11:39
|- - Arnold B. Krueger   QUOTE (Pio2001 @ Jul 28 2010, 06:39) QUOT...   Jul 28 2010, 13:52
|- - AndyH-ha   QUOTE (Arnold B. Krueger @ Jul 28 2010, 04...   Jul 28 2010, 22:42
|- - Arnold B. Krueger   QUOTE (AndyH-ha @ Jul 28 2010, 17:42...   Jul 29 2010, 13:04
|- - 2Bdecided   QUOTE (AndyH-ha @ Jul 28 2010, 22:42...   Jul 29 2010, 22:11
|- - SebastianG   QUOTE (2Bdecided @ Jul 29 2010, 22:11) bu...   Jul 30 2010, 09:55
|- - Arnold B. Krueger   QUOTE (2Bdecided @ Jul 29 2010, 17:11) I ...   Jul 30 2010, 12:26
- - lvqcl   Audition 1.5: 44.1 -> 96 kHz resampling, Qualit...   Jul 30 2010, 11:42
- - C.R.Helmrich   I finally found time to read the entire paper. It...   Aug 9 2010, 21:41
- - 2Bdecided   I think before you pull out one positive result an...   Aug 9 2010, 22:44
|- - C.R.Helmrich   QUOTE (2Bdecided @ Aug 9 2010, 23:44) I t...   Aug 10 2010, 01:37
- - Pio2001   I finaly got the article. Actually, they say somet...   Aug 9 2010, 23:33
- - Pio2001   The unknown thing is the origin of the p values. I...   Aug 10 2010, 12:33
- - lrossouw   Did they test for difference (Check if you can tel...   Sep 8 2010, 09:39
- - Mach-X   I am going to loosely quote a well known poster he...   Mar 8 2014, 08:08
|- - Arnold B. Krueger   QUOTE (Mach-X @ Mar 8 2014, 03:08) I...   Mar 10 2014, 12:58
- - bandpass   TEAC -- slight COI perhaps? Guessing their method...   Mar 8 2014, 09:06
- - WernerO   Perhaps. Another weakness is their apparent use o...   Mar 11 2014, 08:04
|- - Arnold B. Krueger   QUOTE (WernerO @ Mar 11 2014, 03:04) Perh...   Mar 11 2014, 13:44
||- - Kees de Visser   QUOTE (Arnold B. Krueger @ Mar 11 2014, 13...   Mar 11 2014, 14:28
|- - C.R.Helmrich   QUOTE (WernerO @ Mar 11 2014, 08:04) Anot...   Mar 11 2014, 23:55
- - Wombat   QUOTE (Kees de Visser @ Mar 11 2014, 14:2...   Mar 11 2014, 15:51
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 26th May 2015 - 12:50
