44.1 vs 88.2 ABX report at AES
2Bdecided
post Jul 16 2010, 17:07
ReplayGain developer
Here:
http://www.aes.org/events/128/papers/?ID=2252
P18-6 Sampling Rate Discrimination: 44.1 kHz vs. 88.2 kHz—Amandine Pras, Catherine Guastavino, McGill University - Montreal, Quebec, Canada
It is currently common practice for sound engineers to record digital music using high-resolution formats, and then down sample the files to 44.1 kHz for commercial release. This study aims at investigating whether listeners can perceive differences between musical files recorded at 44.1 kHz and 88.2 kHz with the same analog chain and type of AD-converter. Sixteen expert listeners were asked to compare 3 versions (44.1 kHz, 88.2 kHz, and the 88.2 kHz version down-sampled to 44.1 kHz) of 5 musical excerpts in a blind ABX task. Overall, participants were able to discriminate between files recorded at 88.2 kHz and their 44.1 kHz down-sampled version. Furthermore, for the orchestral excerpt, they were able to discriminate between files recorded at 88.2 kHz and files recorded at 44.1 kHz.
Convention Paper 8101
Was anyone at the presentation? Has anyone bought the paper?
Dologan
post Jul 16 2010, 18:18
Group: Members (Donating)
Interesting. The fact that the discrimination was mostly limited to the downsampled version would seem to indicate that any audibility issues are with the downsampling procedure rather than the sampling rate itself. There is, however, the case of the orchestral music...
Searching for the paper I also found that the same authors have published a test comparing CD-quality vs MP3:
QUOTE (http://www.aes.org/e-lib/browse.cfm?elib=15074)
Subjective Evaluation of MP3 Compression for Different Musical Genres
Mp3 compression is commonly used to reduce the size of digital music files but introduces a number of potentially audible artifacts, especially at low bitrates. We investigated whether listeners prefer CD quality to mp3 files at various bitrates (96 kb/s to 320 kb/s), and whether this preference is affected by musical genre. Thirteen trained listeners completed an A/B comparison task judging CD quality and compressed files. Listeners significantly preferred CD quality to mp3 files up to 192 kb/s for all musical genres. In addition, we observed a significant effect of expertise (sound engineers vs. musicians) and musical genres (electric v.s acoustic music).
Again, frustratingly little information given about the details of the test...
C.R.Helmrich
post Jul 16 2010, 19:33
http://coltrane.music.mcgill.ca/MAQ/experiments contains the PowerPoint presentation of the MP3-vs.-CD talk.
(Edit after reading: quite interesting results, but nothing new really, and the results for musicians should be treated with care since there were only 4 of them.)
Chris
This post has been edited by C.R.Helmrich: Jul 16 2010, 19:52
Dologan
post Jul 16 2010, 20:30
QUOTE (C.R.Helmrich @ Jul 16 2010, 19:33) *
Hey, thanks for the link. I tried finding something, but failed.
I guess I'll post a few of the details and observations here so that people don't need to go to the PDF to check them:
- Trained listeners were 9 sound engineers and 4 musicians of age ~28 (SD 5.6 yr)
- LAME used, unknown version. 96, 128, 192, 256 and 320. Alas, no VBR it seems. Pity.
- Genres: Pop, Metal/Rock, "Contemporary", Classical, Opera. <10sec excerpt.
- HQ speaker setup (not headphones). Wonder if it would have made much difference?
- 150 randomized trials (per excerpt? overall? not clear). Pairwise A/B. Testers asked to "prefer" one or the other and then the overall % tested for statistical significance.
- For 256 and 320 preference was 50/50 (so not significant). For 192, 128 and 96 it was 60/40, 75/25 and 80/20, respectively (significant).
- Sound engineers were more likely to prefer the higher quality version than musicians. Electric genres (pop/metal) were more frequently preferred in their HQ version than acoustic ones.
- Order of problems cited in decreasing frequency were: high freq artefacts, general distortion, transient artefacts, stereo image, dynamic range, reverb, background noise.
- No correlation between listening habits and performance.
- In the conclusion it is stated that trained listeners can not discriminate between CD quality and mp3 compression at 256-320 kb/s, while expert listeners could. Not sure who these "expert listeners" are supposed to be, but probably the test subjects from a referenced paper (Sutherland 2007?) who reportedly could do so even at 320.
I suppose that the results aren't very surprising, really. If VBR had been used, I imagine the threshold bitrate would likely end up being around those obtained by V2, supporting its status as "best value" setting.
- 2Bdecided   44.1 vs 88.2 ABX report at AES   Jul 16 2010, 17:07
- - Dologan   Interesting. The fact that the discrimination was ...   Jul 16 2010, 18:18
|- - C.R.Helmrich   http://coltrane.music.mcgill.ca/MAQ/experiments co...   Jul 16 2010, 19:33
|- - Dologan   QUOTE (C.R.Helmrich @ Jul 16 2010, 19:33)...   Jul 16 2010, 20:30
- - Arnold B. Krueger   QUOTE (2Bdecided @ Jul 16 2010, 12:07) He...   Jul 16 2010, 19:45
|- - pbelkner   QUOTE (Arnold B. Krueger @ Jul 16 2010, 20...   Jul 16 2010, 20:01
||- - Dologan   QUOTE (pbelkner @ Jul 16 2010, 20:01) QUO...   Jul 16 2010, 20:03
||- - pbelkner   QUOTE (Dologan @ Jul 16 2010, 21:03) but ...   Jul 16 2010, 20:19
||- - benski   Yes, exactly. It is cheaper to design a 192kHz DA...   Jul 16 2010, 20:47
||- - Arnold B. Krueger   QUOTE (Dologan @ Jul 16 2010, 15:03) QUOT...   Jul 16 2010, 23:21
|- - C.R.Helmrich   QUOTE Overall, participants were able to discrimin...   Jul 16 2010, 20:25
|- - pbelkner   QUOTE (C.R.Helmrich @ Jul 16 2010, 21:25)...   Jul 16 2010, 20:59
- - krabapple   1) I suggest this thread be focused on the 44.1 v...   Jul 16 2010, 22:23
|- - WernerO   QUOTE (krabapple @ Jul 16 2010, 23:23) Th...   Aug 11 2010, 13:51
|- - mzil   QUOTE (krabapple @ Jul 16 2010, 17:23) 2)...   Jul 22 2012, 02:47
|- - C.R.Helmrich   Sorry for bumping this thread, but I thought the f...   Mar 8 2014, 01:21
|- - [JAZ]   QUOTE (C.R.Helmrich @ Mar 8 2014, 01:21) ...   Mar 8 2014, 18:38
- - googlebot   Why upsample? 99.9% of all DACs oversample anyway....   Jul 16 2010, 22:25
|- - Arnold B. Krueger   QUOTE (googlebot @ Jul 16 2010, 17:25) Wh...   Jul 16 2010, 23:47
|- - benski   QUOTE (Arnold B. Krueger @ Jul 16 2010, 18...   Jul 17 2010, 03:12
||- - Arnold B. Krueger   QUOTE (benski @ Jul 16 2010, 22:12) QUOTE...   Jul 17 2010, 06:39
||- - greynol   QUOTE (Arnold B. Krueger @ Jul 16 2010, 22...   Jul 17 2010, 18:33
||- - Arnold B. Krueger   QUOTE (greynol @ Jul 17 2010, 13:33) QUOT...   Jul 17 2010, 20:35
|- - 2Bdecided   QUOTE (Arnold B. Krueger @ Jul 16 2010, 23...   Jul 21 2010, 13:22
- - Alex B   I think the least incorrect way to compare 88.2 KH...   Jul 16 2010, 22:33
|- - Arnold B. Krueger   QUOTE (Alex B @ Jul 16 2010, 17:33) I thi...   Jul 16 2010, 23:30
|- - Dologan   QUOTE (Alex B @ Jul 16 2010, 22:33) I thi...   Jul 16 2010, 23:40
- - AndyH-ha   It seems that what I wrote in the first part of my...   Jul 17 2010, 09:55
|- - googlebot   AndyH-ha, that might be on purpose. For two lowpas...   Jul 17 2010, 10:49
- - googlebot   I think the 88.2 vs. downsampled 44.1 test had at ...   Jul 17 2010, 16:39
- - greynol   QUOTE (Arnold B. Krueger @ Jul 17 2010, 12...   Jul 17 2010, 20:48
|- - Arnold B. Krueger   QUOTE (greynol @ Jul 17 2010, 15:48) QUOT...   Jul 17 2010, 23:04
- - AndyH-ha   I also may not know what I'm talking about, bu...   Jul 17 2010, 22:02
- - greynol   The reason for oversampling in old CD players is a...   Jul 17 2010, 22:13
|- - Arnold B. Krueger   QUOTE (greynol @ Jul 17 2010, 17:13) The ...   Jul 17 2010, 23:14
- - greynol   I'm taking issue with what I thought was a bla...   Jul 17 2010, 23:27
|- - Arnold B. Krueger   QUOTE (greynol @ Jul 17 2010, 18:27) I...   Jul 18 2010, 01:52
|- - greynol   QUOTE (Arnold B. Krueger @ Jul 17 2010, 17...   Jul 19 2010, 00:56
- - amandinepras   Thanks all for your interest in our paper, I recei...   Jul 19 2010, 00:52
|- - Arnold B. Krueger   QUOTE (amandinepras @ Jul 18 2010, 19:52)...   Jul 19 2010, 03:35
|- - Arnold B. Krueger   QUOTE (amandinepras @ Jul 18 2010, 19:52)...   Jul 19 2010, 11:35
||- - 2Bdecided   QUOTE (Arnold B. Krueger @ Jul 19 2010, 11...   Jul 21 2010, 13:20
||- - Kees de Visser   QUOTE (2Bdecided @ Jul 21 2010, 14:20) QU...   Jul 23 2010, 09:26
|- - Arnold B. Krueger   QUOTE (amandinepras @ Jul 18 2010, 19:52)...   Jul 19 2010, 11:48
||- - googlebot   QUOTE (Arnold B. Krueger @ Jul 19 2010, 12...   Jul 19 2010, 12:19
|||- - Arnold B. Krueger   QUOTE (googlebot @ Jul 19 2010, 07:19) QU...   Jul 19 2010, 14:33
||- - krabapple   QUOTE (Arnold B. Krueger @ Jul 19 2010, 06...   Jul 19 2010, 14:08
|- - Notat   QUOTE (amandinepras @ Jul 18 2010, 17:52)...   Jul 21 2010, 04:08
|- - hciman77   QUOTE (amandinepras @ Jul 18 2010, 19:52)...   Jul 28 2010, 15:18
- - Pio2001   Thanks for joining the discussion, Amandine. Your...   Jul 19 2010, 12:31
|- - 2Bdecided   QUOTE (Pio2001 @ Jul 19 2010, 12:31) I se...   Jul 21 2010, 13:13
- - googlebot   The study shows at least the intent of objectivity...   Jul 19 2010, 16:28
|- - Arnold B. Krueger   QUOTE (googlebot @ Jul 19 2010, 11:28) [l...   Jul 19 2010, 19:11
|- - Soap   QUOTE (Arnold B. Krueger @ Jul 19 2010, 14...   Jul 19 2010, 20:24
|- - Soap   QUOTE (Arnold B. Krueger @ Jul 19 2010, 14...   Jul 19 2010, 23:07
- - Juha   QUOTE Doesn't anybody else see a problem with ...   Jul 19 2010, 19:25
- - googlebot   The manufacturer's specs for the FF 800. Unwei...   Jul 19 2010, 20:22
|- - Arnold B. Krueger   QUOTE (googlebot @ Jul 19 2010, 15:22) Th...   Jul 19 2010, 21:26
- - Cavaille   Forgive me to interrupt this discussion about the ...   Jul 20 2010, 08:40
|- - Arnold B. Krueger   QUOTE (Cavaille @ Jul 20 2010, 03:40) Arn...   Jul 20 2010, 13:13
|- - Arnold B. Krueger   QUOTE (Arnold B. Krueger @ Jul 20 2010, 08...   Jul 20 2010, 19:30
||- - Pio2001   QUOTE (Arnold B. Krueger @ Jul 20 2010, 20...   Jul 20 2010, 22:36
|||- - Arnold B. Krueger   QUOTE (Pio2001 @ Jul 20 2010, 17:36) QUOT...   Jul 20 2010, 23:57
||- - C.R.Helmrich   QUOTE (Arnold B. Krueger @ Jul 20 2010, 20...   Jul 20 2010, 22:53
|- - 2Bdecided   QUOTE (Arnold B. Krueger @ Jul 20 2010, 13...   Jul 21 2010, 13:25
|- - WernerO   QUOTE (Arnold B. Krueger @ Jul 20 2010, 14...   Aug 2 2010, 08:19
|- - Arnold B. Krueger   QUOTE (WernerO @ Aug 2 2010, 03:19) QUOTE...   Aug 2 2010, 11:56
- - Pio2001   The strange thing is that there are ABX results wi...   Jul 21 2010, 12:16
|- - hciman77   QUOTE (Pio2001 @ Jul 21 2010, 07:16) The ...   Jul 27 2010, 22:56
- - googlebot   The fact, that the study's authors have regist...   Jul 23 2010, 10:55
|- - Pio2001   QUOTE (googlebot @ Jul 23 2010, 11:55) co...   Jul 24 2010, 13:58
- - krabapple   Sheesh, it's only been four days. They may ac...   Jul 23 2010, 19:20
- - googlebot   In dubio pro reo is generally a good principle. Bu...   Jul 26 2010, 19:43
|- - hciman77   QUOTE (googlebot @ Jul 26 2010, 14:43) In...   Jul 26 2010, 21:05
- - hciman77   I read the full paper and I think there may be som...   Jul 26 2010, 19:48
|- - Arnold B. Krueger   QUOTE (hciman77 @ Jul 26 2010, 14:48) I r...   Jul 27 2010, 13:16
||- - 2Bdecided   QUOTE (Arnold B. Krueger @ Jul 27 2010, 13...   Jul 27 2010, 22:45
|- - Pio2001   QUOTE (hciman77 @ Jul 26 2010, 20:48) Thi...   Jul 28 2010, 11:39
|- - Arnold B. Krueger   QUOTE (Pio2001 @ Jul 28 2010, 06:39) QUOT...   Jul 28 2010, 13:52
|- - AndyH-ha   QUOTE (Arnold B. Krueger @ Jul 28 2010, 04...   Jul 28 2010, 22:42
|- - Arnold B. Krueger   QUOTE (AndyH-ha @ Jul 28 2010, 17:42...   Jul 29 2010, 13:04
|- - 2Bdecided   QUOTE (AndyH-ha @ Jul 28 2010, 22:42...   Jul 29 2010, 22:11
|- - SebastianG   QUOTE (2Bdecided @ Jul 29 2010, 22:11) bu...   Jul 30 2010, 09:55
|- - Arnold B. Krueger   QUOTE (2Bdecided @ Jul 29 2010, 17:11) I ...   Jul 30 2010, 12:26
- - lvqcl   Audition 1.5: 44.1 -> 96 kHz resampling, Qualit...   Jul 30 2010, 11:42
- - C.R.Helmrich   I finally found time to read the entire paper. It...   Aug 9 2010, 21:41
- - 2Bdecided   I think before you pull out one positive result an...   Aug 9 2010, 22:44
|- - C.R.Helmrich   QUOTE (2Bdecided @ Aug 9 2010, 23:44) I t...   Aug 10 2010, 01:37
- - Pio2001   I finaly got the article. Actually, they say somet...   Aug 9 2010, 23:33
- - Pio2001   The unknown thing is the origin of the p values. I...   Aug 10 2010, 12:33
- - lrossouw   Did they test for difference (Check if you can tel...   Sep 8 2010, 09:39
- - Mach-X   I am going to loosely quote a well known poster he...   Mar 8 2014, 08:08
|- - Arnold B. Krueger   QUOTE (Mach-X @ Mar 8 2014, 03:08) I...   Mar 10 2014, 12:58
- - bandpass   TEAC -- slight COI perhaps? Guessing their method...   Mar 8 2014, 09:06
- - WernerO   Perhaps. Another weakness is their apparent use o...   Mar 11 2014, 08:04
|- - Arnold B. Krueger   QUOTE (WernerO @ Mar 11 2014, 03:04) Perh...   Mar 11 2014, 13:44
||- - Kees de Visser   QUOTE (Arnold B. Krueger @ Mar 11 2014, 13...   Mar 11 2014, 14:28
|- - C.R.Helmrich   QUOTE (WernerO @ Mar 11 2014, 08:04) Anot...   Mar 11 2014, 23:55
- - Wombat   QUOTE (Kees de Visser @ Mar 11 2014, 14:2...   Mar 11 2014, 15:51
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 23rd May 2015 - 16:55
