Tracking Force Suggestions for Stanton 500.v3 Cartridge?, DJ cart with range of 2 - 5 grams. Using for hi-fi play
Tracking Force for Stanton 500.v3 (2 - 5g Range)
You cannot see the results of the poll until you have voted. Please login and cast your vote to see the results of this poll.
Total Votes: 19
Guests cannot vote
Knowzy
post Jul 8 2010, 07:07
Supposing I've got a brand new Stanton T.92 USB turntable and I'm getting ready to produce some samples.
It comes with a pre-mounted (and presumably pre-aligned) Stanton 500.v3 cartridge. As a DJ cartridge, it has a wide range- 2 to 5 grams- and no specific recommendation within.
The tonearm is balanced and the counterweight dial zeroed. What tracking force do you think I should set?
Normally the consensus is to set the tracking force near the top of the range and I'm inclined to use 4.5 grams.
However, as a DJ cartridge, the top of the range is designed to ensure stability amidst violent scratching motions, which I won't be doing. Maybe 4.5 is overkill for trackability.
So, I'm throwing the question open to HA to see if we can't come to an agreement before I began sampling.
Balanced and Awaiting a Tracking Force Figure
This post has been edited by Knowzy: Jul 8 2010, 07:09
botface
post Jul 27 2010, 09:34
What you're describing can often be the result of incorrect bias. Is the mistracking always in both channels or just one? If it's just one channel or sometimes both and sometimes just one it points to a bias problem - especially as you don't seem to have any trouble tracking the test in the centre of the record.
Knowzy
post Jul 27 2010, 16:45
QUOTE (botface @ Jul 27 2010, 01:34) *
Funny you should mention that. I was playing with anti-skate adjustment last night and found that the component responsible for it (a spring?) may be sticky.
I was playing the innermost track and adjusting the bias wildly to see if it had any effect. From 7 to 0 and back to 7. The mistracking continued unabated.
Then, out of the blue, the mistracking stopped. I can now play all three tracks without hearing mistracking and it doesn't matter where I set the anti-skate.
I think you might be on to something!
The +16dB track still mistracks, though.
In other news, I broke out the tracking force scale and found the counterweight to be unreliable.
Here are the readings I got:
  • Counterweight dial: .5 grams, scale: .43 grams (underweight)
  • Counterweight dial: 2 grams, scale: 2.12 grams (overweight)
  • Counterweight dial: 5 grams, scale: 5.35 grams (overweight)
Assuming I can get bias working correctly, perhaps I should set it to the figure on the scale rather than the dial.
Snackcakes
post Sep 20 2011, 18:46
I have the same table. this is some great info.
This post has been edited by db1989: Sep 20 2011, 21:36
Reason for edit: deleting pointless fullquote of prior post
- Knowzy   Tracking Force Suggestions for Stanton 500.v3 Cartridge?   Jul 8 2010, 07:07
- - Axon   Would it be too snarky of an answer to say that th...   Jul 8 2010, 21:50
|- - Knowzy   Before I say too much more, I should disclose that...   Jul 8 2010, 22:28
- - Knowzy   I posed this question to Stanton's tech suppor...   Jul 9 2010, 00:04
|- - Canar   QUOTE (Knowzy @ Jul 8 2010, 18:04) The cu...   Jul 9 2010, 00:50
- - RonaldDumsfeld   The real answer is to experiment and find out for ...   Jul 9 2010, 04:07
- - botface   Don't you have a test record? If not I'd s...   Jul 9 2010, 09:01
|- - Arnold B. Krueger   QUOTE (botface @ Jul 9 2010, 04:01) Don...   Jul 9 2010, 11:41
|- - Knowzy   QUOTE (Arnold B. Krueger @ Jul 9 2010, 03...   Jul 9 2010, 18:26
|- - botface   Aren't those tracks for setting bias? I have H...   Jul 9 2010, 19:09
|- - Knowzy   QUOTE (botface @ Jul 9 2010, 11:09) Aren...   Jul 10 2010, 07:07
- - Knowzy   Using the +15dB track, I tested down to 2.25g and ...   Jul 12 2010, 01:09
|- - botface   I can hear mistracking in the right channel of the...   Jul 12 2010, 09:57
|- - Knowzy   QUOTE (botface @ Jul 12 2010, 01:57) I ca...   Jul 12 2010, 22:47
|- - 2Bdecided   QUOTE (Knowzy @ Jul 12 2010, 22:47) Axon ...   Jul 13 2010, 14:04
- - 2Bdecided   Yes, it's important to remember that once the ...   Jul 12 2010, 13:07
- - botface   QUOTE If you can hear mistracking then clearly I d...   Jul 13 2010, 09:00
- - Knowzy   QUOTE (botface @ Jul 13 2010, 01:00) If y...   Jul 13 2010, 18:11
- - Knowzy   The Short Version I found my tracking force: 4 gra...   Jul 14 2010, 06:20
|- - cliveb   QUOTE (Knowzy @ Jul 14 2010, 06:20) Then ...   Jul 14 2010, 11:02
|- - Knowzy   QUOTE (cliveb @ Jul 14 2010, 03:02) envir...   Jul 15 2010, 16:16
- - Knowzy   I'm now using 5 grams of tracking force (the t...   Jul 26 2010, 22:48
- - botface   What you're describing can often be the result...   Jul 27 2010, 09:34
|- - Knowzy   QUOTE (botface @ Jul 27 2010, 01:34) What...   Jul 27 2010, 16:45
|- - Snackcakes   I have the same table. this is some great info.   Sep 20 2011, 18:46
- - Glenn Gundlach   When I worked in stereo stores, I recommended usin...   Sep 20 2011, 23:08
- - Defkon 1   sorry Im very new to this forum and I can't se...   Dec 14 2013, 05:26
RSS Lo-Fi Version Time is now: 30th July 2015 - 09:53
