Tracking Force Suggestions for Stanton 500.v3 Cartridge?, DJ cart with range of 2 - 5 grams. Using for hi-fi play
Tracking Force for Stanton 500.v3 (2 - 5g Range)
You cannot see the results of the poll until you have voted. Please login and cast your vote to see the results of this poll.
Total Votes: 19
Guests cannot vote
Knowzy
post Jul 8 2010, 07:07
Supposing I've got a brand new Stanton T.92 USB turntable and I'm getting ready to produce some samples.
It comes with a pre-mounted (and presumably pre-aligned) Stanton 500.v3 cartridge. As a DJ cartridge, it has a wide range- 2 to 5 grams- and no specific recommendation within.
The tonearm is balanced and the counterweight dial zeroed. What tracking force do you think I should set?
Normally the consensus is to set the tracking force near the top of the range and I'm inclined to use 4.5 grams.
However, as a DJ cartridge, the top of the range is designed to ensure stability amidst violent scratching motions, which I won't be doing. Maybe 4.5 is overkill for trackability.
So, I'm throwing the question open to HA to see if we can't come to an agreement before I began sampling.
Balanced and Awaiting a Tracking Force Figure
This post has been edited by Knowzy: Jul 8 2010, 07:09
Axon
post Jul 8 2010, 21:50
Group: Members (Donating)
Would it be too snarky of an answer to say that the preferrable tracking force of a Stanton 500 is preferrably 2-4 kilograms? gun2.gif
Sorry, I bought one as a backup once upon a time, and it managed to achieve a ~40hz tonearm resonance on my SL-1200. If low compliance is how DJ cartridges achieve "slammin' bass" then I am kinda scared. Not as scared as using a ceramic cart though.
If you wanted a serious answer, IIRC, I'd probably track it at 3g by default, unless it started jumping grooves.
Knowzy
post Jul 8 2010, 22:28
Before I say too much more, I should disclose that Stanton sent me this turntable free so that I could review it. I paid for the previous four turntables I reviewed out of my pocket.
I don't plan on that fact to affect my opinion of it and I expect you all call me on it if you believe that to be the case.
QUOTE (Axon @ Jul 8 2010, 13:50) *
The proof will be in the listening/analysis.
The turntable is clearly better constructed than the $100 turntables I've been testing. But, as I advise readers in my guide, it is a DJ turntable, which is a musical instrument first and foremost.
Thanks, that's two votes for 3g and one for 5g.
Since you replied, do you mind showing your work a bit?
In particular, is your general tracking force philosophy to use as little as you can get away with or, like I hear most often, to set the tracking for at or near the top of the range to avoid mistracking at all costs?
- Knowzy   Tracking Force Suggestions for Stanton 500.v3 Cartridge?   Jul 8 2010, 07:07
- - Axon   Would it be too snarky of an answer to say that th...   Jul 8 2010, 21:50
|- - Knowzy   Before I say too much more, I should disclose that...   Jul 8 2010, 22:28
- - Knowzy   I posed this question to Stanton's tech suppor...   Jul 9 2010, 00:04
|- - Canar   QUOTE (Knowzy @ Jul 8 2010, 18:04) The cu...   Jul 9 2010, 00:50
- - RonaldDumsfeld   The real answer is to experiment and find out for ...   Jul 9 2010, 04:07
- - botface   Don't you have a test record? If not I'd s...   Jul 9 2010, 09:01
|- - Arnold B. Krueger   QUOTE (botface @ Jul 9 2010, 04:01) Don...   Jul 9 2010, 11:41
|- - Knowzy   QUOTE (Arnold B. Krueger @ Jul 9 2010, 03...   Jul 9 2010, 18:26
|- - botface   Aren't those tracks for setting bias? I have H...   Jul 9 2010, 19:09
|- - Knowzy   QUOTE (botface @ Jul 9 2010, 11:09) Aren...   Jul 10 2010, 07:07
- - Knowzy   Using the +15dB track, I tested down to 2.25g and ...   Jul 12 2010, 01:09
|- - botface   I can hear mistracking in the right channel of the...   Jul 12 2010, 09:57
|- - Knowzy   QUOTE (botface @ Jul 12 2010, 01:57) I ca...   Jul 12 2010, 22:47
|- - 2Bdecided   QUOTE (Knowzy @ Jul 12 2010, 22:47) Axon ...   Jul 13 2010, 14:04
- - 2Bdecided   Yes, it's important to remember that once the ...   Jul 12 2010, 13:07
- - botface   QUOTE If you can hear mistracking then clearly I d...   Jul 13 2010, 09:00
- - Knowzy   QUOTE (botface @ Jul 13 2010, 01:00) If y...   Jul 13 2010, 18:11
- - Knowzy   The Short Version I found my tracking force: 4 gra...   Jul 14 2010, 06:20
|- - cliveb   QUOTE (Knowzy @ Jul 14 2010, 06:20) Then ...   Jul 14 2010, 11:02
|- - Knowzy   QUOTE (cliveb @ Jul 14 2010, 03:02) envir...   Jul 15 2010, 16:16
- - Knowzy   I'm now using 5 grams of tracking force (the t...   Jul 26 2010, 22:48
- - botface   What you're describing can often be the result...   Jul 27 2010, 09:34
|- - Knowzy   QUOTE (botface @ Jul 27 2010, 01:34) What...   Jul 27 2010, 16:45
|- - Snackcakes   I have the same table. this is some great info.   Sep 20 2011, 18:46
- - Glenn Gundlach   When I worked in stereo stores, I recommended usin...   Sep 20 2011, 23:08
- - Defkon 1   sorry Im very new to this forum and I can't se...   Dec 14 2013, 05:26
RSS Lo-Fi Version Time is now: 29th August 2015 - 14:37
