Small Pop between tracks using Lame VBR- V-0
andrew22690
post Jul 3 2010, 20:43
I am ripping with EAC and encoding with Lame, (version 3.98). 99% of the time I get a perfect transition between tracks that are suppose to be gapless (I.E Pink floyd albums) but I have a few tracks that have a very very small tick or pop from one track to the next. EAC said copy was 100% perfect. I am using Foobar for P.C playback.
As i said it is not between every track just the odd one or two. Does anyone have any ideas? I have tried various releases of lame and EAC the Glitch is always in the same spot it and is not showing up in the WAV file, only the encoded Lame file
Case
post Jul 30 2010, 11:16
Group: Developer (Donating)
I decided to try Andavari's idea of short fading and it seems to work quite wonderfully. Pcutmp3 gives perfect gapless mp3 playback in foobar2000 but the files don't work properly on my portable players (iPods and Clip+).
I made a DSP component for foobar that automatically fades the beginning and end of tracks to silence and it gives me glitchless transition on all problem tracks I have tried so far. If you wish to try download Fake Gapless DSP.
- andrew22690   Small Pop between tracks using Lame VBR- V-0   Jul 3 2010, 20:43
- - greynol   Gapless playback without pops/clicks/etc. with los...   Jul 3 2010, 20:47
|- - andrew22690   QUOTE (greynol @ Jul 3 2010, 21:47) Gaple...   Jul 4 2010, 15:05
||- - trout   QUOTE (andrew22690 @ Jul 3 2010, 15:43) ....   Jul 18 2010, 18:19
||- - dv1989   QUOTE (trout @ Jul 18 2010, 18:19) QUOTE ...   Jul 18 2010, 18:58
||- - andrew22690   QUOTE (dv1989 @ Jul 18 2010, 19:58) QUOTE...   Jul 20 2010, 03:48
||- - andrew22690   QUOTE (andrew22690 @ Jul 20 2010, 04:48) ...   Jul 20 2010, 04:00
|||- - pdq   QUOTE (andrew22690 @ Jul 19 2010, 23:00) ...   Jul 20 2010, 04:07
|||- - dv1989   QUOTE (andrew22690 @ Jul 20 2010, 04:48) ...   Jul 20 2010, 11:29
|||- - greynol   QUOTE (dv1989 @ Jul 20 2010, 03:29) the s...   Jul 20 2010, 16:45
|||- - dv1989   QUOTE (greynol @ Jul 20 2010, 16:45) QUOT...   Jul 20 2010, 18:19
||- - pdq   QUOTE (andrew22690 @ Jul 19 2010, 22:48) ...   Jul 20 2010, 04:04
||- - Aleron Ives   QUOTE (andrew22690 @ Jul 19 2010, 19:48) ...   Jul 20 2010, 04:07
|- - googlebot   QUOTE (greynol @ Jul 3 2010, 21:47) Gaple...   Jul 20 2010, 19:26
|- - greynol   QUOTE (googlebot @ Jul 20 2010, 11:26) Th...   Jul 20 2010, 19:30
|- - googlebot   QUOTE (greynol @ Jul 20 2010, 20:30) Gapl...   Jul 21 2010, 02:48
|- - greynol   QUOTE (googlebot @ Jul 20 2010, 18:48) Fo...   Jul 21 2010, 07:27
|- - googlebot   QUOTE (greynol @ Jul 21 2010, 08:27) We a...   Jul 21 2010, 10:10
- - andrew22690   QUOTE (greynol @ Jul 3 2010, 21:47) Gaple...   Jul 3 2010, 21:42
- - Canar   If you rip it to a single file with cuesheet, then...   Jul 4 2010, 03:14
|- - 2Bdecided   QUOTE (Canar @ Jul 4 2010, 03:14) If you ...   Jul 21 2010, 16:52
- - greynol   I missed the part about the wave files being ok. ...   Jul 4 2010, 20:48
|- - mixminus1   With fb2k, yes, and since that's what the OP i...   Jul 4 2010, 23:35
|- - Canar   QUOTE (mixminus1 @ Jul 4 2010, 17:35) How...   Jul 9 2010, 00:47
|- - andrew22690   [/quote]pcutmp3 does it perfectly, as it duplicate...   Jul 9 2010, 19:41
- - Diow   It's the gap detection go in EAC to: EAC --...   Jul 5 2010, 03:25
|- - andrew22690   QUOTE (Diow @ Jul 5 2010, 04:25) It's...   Jul 5 2010, 15:00
|- - greynol   QUOTE (Diow @ Jul 4 2010, 19:25) It's...   Jul 6 2010, 06:17
|- - andrew22690   QUOTE (greynol @ Jul 6 2010, 06:17) QUOTE...   Jul 6 2010, 14:37
|- - pdq   QUOTE (andrew22690 @ Jul 6 2010, 09:37) Q...   Jul 6 2010, 14:51
|- - andrew22690   QUOTE (pdq @ Jul 6 2010, 14:51) QUOTE (an...   Jul 8 2010, 15:26
|- - pdq   QUOTE (andrew22690 @ Jul 8 2010, 10:26) I...   Jul 8 2010, 15:37
|- - Corsair   QUOTE (pdq @ Jul 8 2010, 16:37) QUOTE (an...   Jul 8 2010, 21:35
- - greynol   QUOTE (andrew22690 @ Jul 8 2010, 07:26) I...   Jul 8 2010, 18:04
- - andrew22690   New Command line CODE-V0 --add-id3v2 --pad-id3v2...   Jul 19 2010, 06:06
- - Glenn Gundlach   QUOTE (andrew22690 @ Jul 3 2010, 11:43) S...   Jul 19 2010, 06:18
- - dv1989   But such a DC offset caused click would occur betw...   Jul 19 2010, 10:31
|- - andrew22690   QUOTE (dv1989 @ Jul 19 2010, 11:31) andre...   Jul 20 2010, 03:52
|- - Glenn Gundlach   QUOTE (dv1989 @ Jul 19 2010, 01:31) But s...   Jul 20 2010, 06:22
- - greynol   We're talking about consecutive tracks ripped ...   Jul 20 2010, 06:42
- - robert   Andrew, do you use the latest LAME release, versio...   Jul 20 2010, 10:32
|- - andrew22690   QUOTE (robert @ Jul 20 2010, 11:32) Andre...   Jul 20 2010, 20:25
|- - trout   QUOTE (andrew22690 @ Jul 20 2010, 15:25) ...   Jul 20 2010, 22:49
- - Alex B   It would be nice to have the samples available as ...   Jul 20 2010, 17:49
- - Case   These are not original poster's samples but th...   Jul 20 2010, 18:50
|- - Alex B   QUOTE (Case @ Jul 20 2010, 20:50) These a...   Jul 21 2010, 13:30
- - greynol   QUOTE (andrew22690 @ Jul 20 2010, 12:25) ...   Jul 20 2010, 20:26
- - greynol   I was thinking he found some article discouraging ...   Jul 20 2010, 22:59
|- - andrew22690   Here is the link to the wiki. http://wiki.hydroge...   Jul 20 2010, 23:34
- - greynol   Ok, so it would seem you need to read Trout's ...   Jul 20 2010, 23:55
|- - andrew22690   Thank's Greynol now I get it.   Jul 21 2010, 02:21
- - Diow   Sorry by the mistake I missed the part "the G...   Jul 21 2010, 03:22
- - Andavari   Like the example provided by Case in this post wha...   Jul 21 2010, 05:57
- - Case   They do produce a click. Listen again more closely...   Jul 21 2010, 14:51
|- - greynol   QUOTE (Case @ Jul 21 2010, 06:51) They do...   Jul 21 2010, 17:31
|- - greynol   QUOTE (Case @ Jul 21 2010, 06:51) They do...   Jul 21 2010, 21:32
|- - Alex B   QUOTE (greynol @ Jul 21 2010, 19:31) QUOT...   Jul 30 2010, 12:04
- - andrew22690   QUOTE (andrew22690 @ Jul 3 2010, 21:43) S...   Jul 21 2010, 16:20
|- - andrew22690   Just finished encoding some of my problem tracks w...   Jul 21 2010, 21:14
|- - andrew22690   These were on my own encoded files. Could be that ...   Jul 21 2010, 21:42
- - Case   I decided to try Andavari's idea of short fadi...   Jul 30 2010, 11:16
|- - Alex B   QUOTE (Case @ Jul 30 2010, 13:16) I made ...   Jul 30 2010, 12:27
|- - 2Bdecided   QUOTE (Case @ Jul 30 2010, 11:16) Pcutmp3...   Sep 6 2010, 11:26
- - Case   Here's 10 second clips of tracks that produce ...   Jul 30 2010, 15:08
|- - Matt08642   QUOTE (Case @ Jul 30 2010, 10:08) Here...   Sep 4 2010, 08:56
|- - Slipstreem   QUOTE (Matt08642 @ Sep 4 2010, 08:56) ......   Sep 4 2010, 12:42
||- - Aleron Ives   QUOTE (Slipstreem @ Sep 4 2010, 04:42) QU...   Sep 5 2010, 00:15
|- - Case   QUOTE (Matt08642 @ Sep 4 2010, 10:56) I d...   Sep 5 2010, 14:00
- - dv1989   Or just the common misconception that VBR quality ...   Sep 5 2010, 00:45
|- - Slipstreem   QUOTE (dv1989 @ Sep 5 2010, 00:45) (often...   Sep 5 2010, 01:29
|- - greynol   QUOTE (Slipstreem @ Sep 4 2010, 17:29) Ma...   Sep 5 2010, 02:40
- - dv1989   I wasn't implicating foobar2000. Or any appli...   Sep 5 2010, 01:34
|- - pdq   QUOTE (dv1989 @ Sep 4 2010, 20:34) I wasn...   Sep 5 2010, 01:53
- - dv1989   I suppose I should have anticipated that, especial...   Sep 5 2010, 02:00
- - Matt08642   I meant 320, the V0320 thing was a typo. Basicall...   Sep 5 2010, 11:14
|- - andrew22690   QUOTE (Matt08642 @ Sep 5 2010, 12:14) I m...   Sep 5 2010, 19:57
- - greynol   Maybe this is too much work, but has anyone tried ...   Sep 5 2010, 20:45
|- - 2Bdecided   QUOTE (greynol @ Sep 5 2010, 20:45) Maybe...   Sep 6 2010, 11:32
|- - Alex B   QUOTE (2Bdecided @ Sep 6 2010, 13:32) QUO...   Sep 6 2010, 13:10
- - alexeysp   Here is the transition point of the above posted s...   Sep 6 2010, 19:39
- - /mnt   I've tried out the samples with LAME 3.98.4 at...   Sep 6 2010, 22:29
RSS Lo-Fi Version Time is now: 1st March 2015 - 04:40
