FFSoX Player 0.1 Initial Release
pbelkner
post Jun 13 2010, 14:47
FFSoX Player is a Winamp (http://www.winamp.com/) plug-in based on the FFmpeg (http://www.ffmpeg.org/) and SoX (http://sox.sourceforge.net/) libraries. Using FFmepg almost all multimedia files may be played, including but by far not restricted to H.264 and VP8. Audiophile sound processing is provided using high quality 32 bit SoX algorithms and dithering.
Home: http://in-ffsox.sourceforge.net/
Project: http://sourceforge.net/projects/in-ffsox/
Download: http://sourceforge.net/projects/in-ffsox/files/
Antonski
post Aug 29 2010, 23:11
Thank you for your work, now Musepack playback is fine. However, tags and RG are still not recognized (or at least not displayed).
Please, see below what I mean.
BTW, I don't use ASIO4ALL, just your input plugin with latest ffmpeg shared libs. I don't believe this could be the reason, but I might be wrong?
pbelkner
post Aug 30 2010, 10:13
QUOTE (Antonski @ Aug 30 2010, 00:11) *
Unfortunately this seems to be true for SV8 because currently FFmpeg seems not to support tags for SV8. Hopefully a FFmpeg devolper will pick up some day.
According to my tests tags should work for SV7.
Antonski
post Aug 30 2010, 23:28
QUOTE (pbelkner @ Aug 30 2010, 12:13) *
Well, not really:
But even if the tags reading is not implemented by ffmpeg, the RG is not stored in tags. For Musepack RG is stored in the file header.
Anyhow, I understand that all these issues are probably due to the incomplete ffmpeg implementation, so it is not in your power to fix them.
Thanks and good luck.
pbelkner
post Aug 31 2010, 08:02
QUOTE (Antonski @ Aug 31 2010, 00:28) *
The plug-in has a hidden feature to work around missing tags or missing tag implementations. I've created it mainly to RG various video formats which doesn't provide RG at all. Maybe it helps also in your case.
The feature consists in providing a file "folder.csv" for each folder containing multi media files you want to "pseudo" tag. The file "folder.csv" has the following format:
The first line is a header listing tabulator separated the tags. Currently the haeder has to list the following tags exactly in the given order separated by tabulator:
  1. file
  2. artist
  3. album
  4. year
  5. track
  6. title
  7. comment
  8. genre
  9. replaygain_track_gain
  10. replaygain_album_gain
  11. albumartist
  12. composer
  13. publisher
  14. disc
  15. bpm
The following lines have to list the corresponding values for each file to be pseudo tagged, possibly empty, separated by tabulators.
The following script demonstrate how to pseudo tag Musepack SV8:
#!/bin/sh
IFS="
# run wavegain analysis and store result into ${table} for later use.
table=`wavegain -a *.wav 2>&1|tr "\t" " "`
# define pattern for album related values.
pat1=""
pat1="${pat1}^[ ]*Recommended Album Gain:[ ]*"    # eat white
pat1="${pat1}\([^ ]*\)"                            # col #1: gain
pat1="${pat1}[ ]*dB[ ]*Scale:[ ]*"                # eat white
pat1="${pat1}\([^ ]*\)"                            # col #2: scale
pat1="${pat1}.*$"                                # eat white
album_gain=`echo "${table}"|sed -n "s/${pat1}/\1/p"`
echo "album gain: ${album_gain} dB"
# define pattern for track related values.
pat2=""
pat2="${pat2}^[ ]*"                                # eat white
pat2="${pat2}\([^ |]*\)"                        # col #1: gain
pat2="${pat2}[ ]*dB[ ]*|[ ]*"                    # eat white
pat2="${pat2}\([^ |]*\)"                        # col #2: peak
pat2="${pat2}[ ]*|[ ]*"                            # eat white
pat2="${pat2}\([^ |]*\)"                        # col #3: scale
pat2="${pat2}\([^ |]*\)"                        # col #4: new peak
pat2="${pat2}\([^ |]*\)"                        # col #5: left dc offset
pat2="${pat2}\([^ |]*\)"                        # col #6: right dc offset
pat2="${pat2}\([^ |]*\)"                        # col #7: track
pat2="${pat2}.*$"                                # eat white
# create "folder.csv" and write header to it.
header="file"
header="${header}\tartist"
header="${header}\talbum"
header="${header}\tyear"
header="${header}\ttrack"
header="${header}\ttitle"
header="${header}\tcomment"
header="${header}\tgenre"
header="${header}\treplaygain_track_gain"
header="${header}\treplaygain_album_gain"
header="${header}\talbumartist"
header="${header}\tcomposer"
header="${header}\tpublisher"
header="${header}\tdisc"
header="${header}\tbpm"
echo -e "${header}" > folder.csv
# for each track ...
for track in `echo "${table}"|sed -n "s/${pat2}/\7/p"`; do
  # get current track gain.
  track_gain=`echo "${table}"|grep "${track}"|sed -n "s/${pat2}/\1/p"`
  echo "track: ${track}, track gain: ${track_gain} dB"
  # encode current track.
  mpcenc --overwrite ${track}
  # append a row corresponding to current track into "folder.csv"
  row="`basename ${track} .wav`.mpc"        # file
  row="${row}\t"                            # artist
  row="${row}\t"                            # album
  row="${row}\t"                            # year
  row="${row}\t"                            # track
  row="${row}\t"                            # title
  row="${row}\t"                            # comment
  row="${row}\t"                            # genre
  row="${row}\t${track_gain} dB"            # replaygain_track_gain
  row="${row}\t${album_gain} dB"            # replaygain_album_gain
  row="${row}\t"                            # albumartist
  row="${row}\t"                            # composer
  row="${row}\t"                            # publisher
  row="${row}\t"                            # disc
  row="${row}\t"                            # bpm
  echo -e "${row}" >> folder.csv
done
This post has been edited by pbelkner: Aug 31 2010, 08:05
- pbelkner   FFSoX Player 0.1 Initial Release   Jun 13 2010, 14:47
- - b66pak   thanks a lot... _   Jun 13 2010, 18:27
- - pbelkner   Just released v0.2: http://sourceforge.net/projec...   Jun 27 2010, 17:08
- - pbelkner   Released v0.3 Got a feature request on SourceForg...   Jul 4 2010, 19:27
- - pbelkner   v0.4 released What's new? Enabled seeking (de...   Jul 25 2010, 14:47
- - pbelkner   v0.4.1 released What's new? Support for ...   Aug 8 2010, 14:13
- - ZinCh   works nice, the only thing I didnt like - it is do...   Aug 8 2010, 14:17
|- - pbelkner   QUOTE (ZinCh @ Aug 8 2010, 15:17) it is d...   Aug 8 2010, 16:13
- - ZinCh   my previous message was a inaccurate, it looks lik...   Aug 8 2010, 20:17
|- - pbelkner   QUOTE (ZinCh @ Aug 8 2010, 21:17) I send ...   Aug 9 2010, 10:26
- - kerimcem   dont work flac winamp seek bar...   Aug 8 2010, 23:46
|- - pbelkner   QUOTE (kerimcem @ Aug 9 2010, 00:46) dont...   Aug 9 2010, 10:35
- - pbelkner   v0.4.2 released What's new? Fixed seeking OGG...   Aug 22 2010, 16:31
|- - pbelkner   QUOTE (pbelkner @ Aug 22 2010, 17:31) v0....   Aug 22 2010, 18:52
|- - pbelkner   v0.4.4 released What's new? Changed order of ...   Oct 10 2010, 14:50
- - Antonski   Very interesting project, congratulations! so...   Aug 23 2010, 16:36
|- - pbelkner   QUOTE (Antonski @ Aug 23 2010, 17:36) Ver...   Aug 23 2010, 17:07
- - pbelkner   v0.4.3 released What's new? Fixed reading met...   Aug 28 2010, 12:41
- - Antonski   Thank you for your work, now Musepack playback is ...   Aug 29 2010, 23:11
|- - pbelkner   QUOTE (Antonski @ Aug 30 2010, 00:11) How...   Aug 30 2010, 10:13
|- - Antonski   QUOTE (pbelkner @ Aug 30 2010, 12:13) Acc...   Aug 30 2010, 23:28
|- - pbelkner   QUOTE (Antonski @ Aug 31 2010, 00:28) But...   Aug 31 2010, 06:52
|- - pbelkner   QUOTE (Antonski @ Aug 31 2010, 00:28) Any...   Aug 31 2010, 08:02
- - Antonski   Hello, Tagging Musepack files with RG values is n...   Sep 2 2010, 00:59
|- - pbelkner   Thank you for your support, Antonski. QUOTE (Anto...   Sep 2 2010, 07:43
- - sboistan   Thank you so much for this - it's made a world...   Oct 27 2010, 04:12
|- - pbelkner   Thanks a lot, sboistan. QUOTE (sboistan @ Oc...   Oct 28 2010, 10:19
|- - banan   QUOTE (pbelkner @ Oct 28 2010, 10:19) All...   Apr 10 2012, 12:38
|- - pbelkner   QUOTE (banan @ Apr 10 2012, 12:38) QUOTE ...   Apr 11 2012, 03:56
|- - banan   I see... not as easy as I thought. Anyway, thanks ...   Apr 11 2012, 07:31
|- - chi   QUOTE (pbelkner @ Apr 11 2012, 04:56) Thi...   Apr 12 2012, 23:17
- - sboistan   Both of those features would be great. I haven...   Oct 30 2010, 20:38
|- - pbelkner   QUOTE (sboistan @ Oct 30 2010, 21:38) 1. ...   Oct 30 2010, 21:24
||- - greynol   QUOTE (pbelkner @ Oct 30 2010, 13:24) How...   Oct 30 2010, 21:51
||- - sboistan   QUOTE (pbelkner @ Oct 30 2010, 16:24) How...   Oct 30 2010, 22:40
|- - pbelkner   QUOTE (sboistan @ Oct 30 2010, 21:38) 1. ...   Nov 1 2010, 13:53
- - pbelkner   v0.4.5 released What's new? Fixed mapping tag...   Dec 16 2010, 17:35
- - pbelkner   v0.4.6 releasedhttp://sourceforge.net/projects/in-...   Jan 15 2011, 21:17
|- - pbelkner   v0.4.6.1 releasedhttp://sourceforge.net/projects/i...   Jan 16 2011, 14:05
- - pbelkner   FFmpeg has "bumped" their DLLs: avutil-5...   May 15 2011, 15:56
|- - sboistan   The decoder for mp3 and ac3 files seems to be lock...   May 18 2011, 20:42
|- - pbelkner   QUOTE (sboistan @ May 18 2011, 20:42) The...   May 19 2011, 15:15
- - pbelkner   Version 0.4.6.5 released: Home: http://in-ffsox.so...   Oct 1 2011, 09:44
|- - pbelkner   Version 0.4.6.6 released: Home: http://in-ffsox.so...   Oct 3 2011, 17:55
|- - pbelkner   Version 0.4.6.7 released: Home: http://in-ffsox.so...   Oct 15 2011, 17:23
|- - pbelkner   Version 0.4.7 released: Home: http://in-ffsox.sour...   Feb 11 2012, 12:26
|- - pbelkner   Version 0.4.8 released: Home: http://in-ffsox.sour...   Mar 9 2012, 20:52
- - Antonski   Too bad that tags and RG for Musepack still don...   Oct 16 2011, 01:33
- - kerimcem   hi great plugin my problem mp3 file prefer float ...   Mar 12 2012, 16:15
|- - pbelkner   QUOTE (kerimcem @ Mar 12 2012, 16:15) hi ...   Mar 12 2012, 18:23
|- - kerimcem   QUOTE (pbelkner @ Mar 12 2012, 11:23) QUO...   Mar 12 2012, 18:39
|- - pbelkner   QUOTE (kerimcem @ Mar 12 2012, 18:39) ok ...   Mar 13 2012, 07:47
- - kerimcem   hi ı try aimp http://aimp.ru/ (asio volume b...   Mar 28 2012, 11:45
|- - Dario   QUOTE (kerimcem @ Mar 28 2012, 12:45) hi ...   Mar 28 2012, 14:11
- - elge   Thanks for this great plugin. To me, it sounds be...   Sep 28 2012, 10:53
|- - pbelkner   QUOTE (elge @ Sep 28 2012, 10:53) Thanks ...   Sep 28 2012, 17:56
|- - greynol   QUOTE (pbelkner @ Sep 28 2012, 09:56) QUO...   Sep 28 2012, 18:10
- - pbelkner   Version 0.4.9-2 released: Home: http://in-ffsox.so...   Nov 4 2012, 17:35
- - smeekeven   Monkey's Audio APE files stutter by using FFSo...   Nov 10 2012, 23:38
|- - pbelkner   QUOTE (smeekeven @ Nov 10 2012, 23:38) Si...   Nov 11 2012, 09:34
- - smeekeven   APE stuttering problems SOLVED in FFSoX Player 0.4...   Nov 11 2012, 10:29
|- - pbelkner   QUOTE (smeekeven @ Nov 11 2012, 10:29) Si...   Nov 11 2012, 18:04
- - Polarus   Hi, In my first post here I would like to thank yo...   Nov 12 2012, 22:58
|- - pbelkner   QUOTE (Polarus @ Nov 12 2012, 22:58) Hi, ...   Nov 16 2012, 07:14
|- - pbelkner   QUOTE (Polarus @ Nov 12 2012, 22:58) with...   Nov 19 2012, 17:52
- - Polarus   It would be very nice if you can specify decoder l...   Nov 16 2012, 13:00
|- - pbelkner   v0.5.0 releasedhttp://sourceforge.net/projects/in-...   Nov 25 2012, 16:47
- - pbelkner   Version 0.6.0 released: Home: http://in-ffsox.sour...   Dec 8 2012, 12:41
|- - bandpass   QUOTE (pbelkner @ Dec 8 2012, 11:41) [*]P...   Dec 8 2012, 17:18
|- - pbelkner   QUOTE (bandpass @ Dec 8 2012, 18:18) is t...   Dec 8 2012, 17:48
- - Wombat   QUOTE (pbelkner @ Dec 8 2012, 18:48) QUOT...   Dec 8 2012, 18:00
- - pbelkner   QUOTE (greynol @ Nov 25 2012, 18:45) I th...   Dec 13 2012, 20:09
- - smeekeven   Problems with playback MPC (Musepack) files Thank...   Dec 14 2012, 11:39
|- - greynol   QUOTE (smeekeven @ Dec 14 2012, 02:39) By...   Dec 15 2012, 15:56
- - Willakan   This is a very impressive piece of TOS-8 skirting:...   Dec 14 2012, 18:16
|- - pbelkner   QUOTE (smeekeven @ Dec 14 2012, 12:39) By...   Dec 14 2012, 20:49
- - greynol   AFAICT none of those preferences have any bearing ...   Dec 15 2012, 15:46
|- - bandpass   QUOTE (greynol @ Dec 15 2012, 14:46) AFAI...   Dec 15 2012, 19:16
- - Wombat   Besides that sox doesn´t add noise shaped dither t...   Dec 15 2012, 16:41
|- - pbelkner   QUOTE (Wombat @ Dec 15 2012, 17:41) Besid...   Dec 15 2012, 18:56
- - greynol   I didn't think qualifications against synthesi...   Dec 15 2012, 19:39
|- - bandpass   QUOTE (greynol @ Dec 15 2012, 18:39) I di...   Dec 16 2012, 10:33
|- - greynol   QUOTE (bandpass @ Dec 16 2012, 01:33) The...   Dec 16 2012, 17:09
|- - bandpass   If source and destination rates are both >= 441...   Dec 16 2012, 22:29
- - Wombat   QUOTE (pbelkner @ Dec 15 2012, 19:56) QUO...   Dec 15 2012, 19:52
|- - pbelkner   QUOTE (Wombat @ Dec 15 2012, 20:52) Pronu...   Dec 15 2012, 19:57
- - Wombat   Still i feel insulted by your Straw Man argument. ...   Dec 15 2012, 20:11
|- - pbelkner   QUOTE (Wombat @ Dec 15 2012, 21:11) You a...   Dec 15 2012, 20:35
- - [JAZ]   @pbelkner: To put it on perspective, i'll giv...   Dec 15 2012, 23:27
|- - pbelkner   QUOTE ([JAZ] @ Dec 16 2012, 00:27...   Dec 16 2012, 04:37
- - [JAZ]   Ok, I didn't think about it. How is the repla...   Dec 16 2012, 11:01
|- - pbelkner   QUOTE ([JAZ] @ Dec 16 2012, 12:01...   Dec 16 2012, 15:38
- - smeekeven   Hi Peter Belkner, You know I'm a dedicated us...   Dec 30 2012, 14:40
- - smeekeven   Problems with decoding MP3, APE and MPC files sinc...   Jan 3 2013, 15:38
|- - pbelkner   QUOTE (smeekeven @ Jan 3 2013, 16:38) Hap...   Jan 6 2013, 23:25
- - smeekeven   in_ffsox-0.6.2-ffmpeg works perfectly ! PBel...   Jan 7 2013, 13:24
- - smeekeven   New avcodec-55.dll and avformat-55.dll Zeranoe bui...   Mar 16 2013, 09:53
|- - pbelkner   QUOTE (smeekeven @ Mar 16 2013, 10:53) Ne...   Mar 16 2013, 11:44
- - mjb2006   Peter did end up toning down the docs to just say ...   Dec 8 2013, 06:29
RSS Lo-Fi Version Time is now: 28th January 2015 - 20:18
