TagBox Tag Editing Plugin, UI Element
Arash
post May 26 2010, 08:48
Hello Everybody,
I needed something like this but couldn't find any so I wrote it myself!
It is something like an editable "properties" window in a UI element with "quick tagger" like features and a little more.
Here is more info and download link.
q-stankovic
post Oct 11 2010, 16:44
QUOTE (Arash @ Oct 11 2010, 13:43) *
I may even be able to allow on the fly changing of the behavior using a small drop-down menu
I think that would be over the top and is not worth the whole effort you would have to put in that. Generally we have setted senseful options in the preferences: rating has replace as tagbehaviour and that is somehow selfevident. Also other fields are evident. I just thought about a simple reminder for other fields where it is not clear. As there are many possibilities to override the behaviour (clear all tags in drop down box or using field itself ...) i think it is not necessary to make it more complex than needed.
This post has been edited by q-stankovic: Oct 11 2010, 16:45
- autumn   TagBox Tag Editing Plugin   May 26 2010, 08:48
- - Neonphytismo   QUOTE (autumn @ May 26 2010, 15:48) Hello...   May 26 2010, 09:42
- - 2E7AH   because I guess it's DUI element and not CUI p...   May 26 2010, 09:52
|- - autumn   QUOTE (2E7AH @ May 26 2010, 09:52) some i...   May 26 2010, 10:47
|- - 2E7AH   QUOTE (autumn @ May 26 2010, 11:47) I don...   May 26 2010, 10:59
|- - autumn   QUOTE (2E7AH @ May 26 2010, 10:59) Couldn...   May 26 2010, 11:53
|- - 2E7AH   QUOTE (autumn @ May 26 2010, 12:53) BTW I...   May 26 2010, 13:50
- - 2E7AH   yeah, I was thinking about spacing generaly becaus...   May 26 2010, 12:12
- - Falstaff   download link doesn't work for me "requ...   May 26 2010, 13:06
|- - autumn   QUOTE (Falstaff @ May 26 2010, 13:06) dow...   May 26 2010, 13:28
- - muzack   Hey, thanks for this great plugin! It's mo...   May 26 2010, 13:26
- - q-stankovic   QUOTE (2E7AH @ May 26 2010, 13:12) yeah, ...   May 26 2010, 17:50
- - LXtreme   Good idea and great work! Thanks a lot :-) Ju...   May 26 2010, 20:38
- - foosion   Have you hardcoded the line height in pixels? At l...   May 26 2010, 21:54
|- - kabuki   hello do you plan to make it compatible to CUI asw...   May 26 2010, 22:35
- - autumn   Well! When developing this plugin I needed to ...   May 27 2010, 10:17
- - 2E7AH   it's fine now and CUI isn't redundant of...   May 27 2010, 11:03
- - lyh   Many people are useing CUI,I never use DUI.But als...   May 27 2010, 11:16
- - watercolor   Great job. Are there plan that adding foobar2000 c...   May 27 2010, 13:24
- - autumn   Hello Everybody, Thanks for all your suggestions ...   Jun 20 2010, 11:29
- - autumn   About the CUI panel, since I don't use CUI mys...   Jun 20 2010, 11:42
- - SoulMan   Hello, This plug-in is one of the ones I was wait...   Jul 18 2010, 15:21
- - Yirkha   Regarding autocomplete, you can use fb2k's lib...   Jul 18 2010, 23:20
- - autumn   @SoulMan: I think I'll add the "launch th...   Jul 20 2010, 09:37
- - SoulMan   Hello, Thank you a lot   Jul 23 2010, 14:10
- - autumn   Hello Everyone, Here comes version 0.150, comment...   Aug 2 2010, 12:39
|- - Yirkha   QUOTE (autumn @ Aug 2 2010, 13:39) @muzac...   Aug 2 2010, 16:11
- - watercolor   I want to use this in cui panel.   Aug 2 2010, 13:12
- - Andreasvb   It says it's missing some file. The file is a...   Aug 2 2010, 13:44
- - autumn   My development environment is somewhat different f...   Aug 2 2010, 14:22
- - marc2003   not working for me either. i'm running windows...   Aug 2 2010, 14:42
- - muzack   keyboard shortcuts doesn't interfere anymore. ...   Aug 2 2010, 15:31
|- - autumn   QUOTE (muzack @ Aug 2 2010, 15:31) keyboa...   Aug 2 2010, 16:57
|- - muzack   QUOTE (autumn @ Aug 2 2010, 17:57) QUOTE ...   Aug 2 2010, 17:37
- - autumn   Those with missing file problem please try the new...   Aug 2 2010, 15:39
- - marc2003   new version works on XP and windows 7. however, ...   Aug 2 2010, 16:09
- - autumn   QUOTE (marc2003 @ Aug 2 2010, 16:09) new ...   Aug 2 2010, 16:48
|- - marc2003   QUOTE (autumn @ Aug 2 2010, 16:48) That...   Aug 2 2010, 16:50
- - autumn   Version 0.170 released: TagBox Download Page new...   Aug 7 2010, 15:43
|- - muzack   QUOTE (autumn @ Aug 7 2010, 16:43) Versio...   Aug 7 2010, 16:54
- - q-stankovic   Thank you for the update! There is a fundemen...   Aug 7 2010, 16:48
|- - autumn   QUOTE (q-stankovic @ Aug 7 2010, 16...   Aug 7 2010, 18:02
- - q-stankovic   QUOTE (autumn @ Aug 7 2010, 19:02) But I ...   Aug 7 2010, 18:33
|- - autumn   QUOTE (q-stankovic @ Aug 7 2010, 18...   Aug 7 2010, 19:09
- - stefle   Thanks for your nice component! "active...   Aug 9 2010, 14:37
|- - autumn   QUOTE (stefle @ Aug 9 2010, 14:37) ...   Aug 10 2010, 16:55
|- - stefle   QUOTE (autumn @ Aug 10 2010, 16:55) QUOTE...   Aug 10 2010, 19:09
- - wolfsong   I tried to edit the values in the ratings preset a...   Aug 9 2010, 20:51
|- - autumn   QUOTE (wolfsong @ Aug 9 2010, 20:51) I tr...   Aug 10 2010, 16:57
|- - wolfsong   QUOTE (autumn @ Aug 10 2010, 10:57) QUOTE...   Aug 10 2010, 17:25
- - autumn   Just a few changes, If you're not using the st...   Aug 10 2010, 16:47
- - q-stankovic   QUOTE (autumn @ Aug 10 2010, 17:55) QUOTE...   Aug 10 2010, 17:36
|- - stefle   QUOTE (q-stankovic @ Aug 10 2010, 17...   Aug 10 2010, 19:18
- - autumn   QUOTE (q-stankovic @ Aug 10 2010, 17...   Aug 10 2010, 20:05
|- - stefle   Can't find version 1.71. Check box "activ...   Aug 11 2010, 11:18
|- - autumn   QUOTE (stefle @ Aug 11 2010, 11:18) Can...   Aug 11 2010, 15:03
|- - stefle   QUOTE (autumn @ Aug 11 2010, 15:03) QUOTE...   Aug 11 2010, 16:51
|- - autumn   QUOTE (stefle @ Aug 11 2010, 16:51) Defin...   Aug 11 2010, 17:25
|- - stefle   QUOTE (autumn @ Aug 11 2010, 17:25) Yes y...   Aug 11 2010, 17:58
|- - wolfsong   QUOTE (autumn @ Aug 11 2010, 11:25) Yes y...   Aug 11 2010, 19:28
- - q-stankovic   Autumn, i hope you don't feel annoyed to hear ...   Aug 10 2010, 20:33
|- - autumn   QUOTE (q-stankovic @ Aug 10 2010, 20...   Aug 10 2010, 21:17
- - autumn   version 0.172: Fixed the "immediately apply...   Aug 12 2010, 10:35
- - stefle   Thanks. Tried to prefdefine my 1217 %performer% v...   Aug 12 2010, 17:34
|- - autumn   QUOTE (stefle @ Aug 12 2010, 17:34) Tried...   Aug 13 2010, 01:33
- - autumn   Here comes a major upgrade, a lot of things have c...   Sep 18 2010, 16:14
- - q-stankovic   So much thanks!   Sep 18 2010, 16:29
- - q-stankovic   I did some testing and here are some smaller issue...   Sep 18 2010, 19:48
|- - autumn   QUOTE (q-stankovic @ Sep 18 2010, 20...   Sep 19 2010, 10:14
|- - Yirkha   QUOTE (autumn @ Sep 19 2010, 11:14) QUOTE...   Sep 24 2010, 11:55
- - SpaceAgeHero   I just discovered this component and wanted to exp...   Sep 21 2010, 23:07
- - watercolor   "Values Currently in Databse" typo? An...   Sep 24 2010, 10:47
- - Zelphar   it seems that the rating can not recognize by play...   Sep 24 2010, 18:44
- - q-stankovic   Zelphar, that's how it should work. TagBox wri...   Sep 24 2010, 19:06
- - Arash   QUOTE (watercolor @ Sep 24 2010, 10:47) ...   Sep 25 2010, 16:25
- - Yirkha   Maybe. Don't be afraid, try stuff like this fi...   Sep 25 2010, 16:52
|- - Arash   QUOTE (Yirkha @ Sep 25 2010, 16:52) Don...   Sep 27 2010, 16:42
- - Zelphar   I think use playback statistics' database bett...   Sep 26 2010, 11:57
- - q-stankovic   QUOTE (Zelphar @ Sep 26 2010, 12:57) ... ...   Sep 26 2010, 12:34
- - Arash   Version 0.205 * TagBox window updates itself ...   Oct 6 2010, 12:44
- - herojoker   It would be nice if there was an option to show ce...   Oct 7 2010, 09:11
- - Sandrine   Nice component! Please consider using the wind...   Oct 10 2010, 13:13
|- - Arash   QUOTE (Sandrine @ Oct 10 2010, 13:13) Ple...   Oct 10 2010, 14:32
|- - Sandrine   QUOTE (Arash @ Oct 10 2010, 15:32) QUOTE ...   Oct 11 2010, 17:00
|- - Arash   QUOTE (Sandrine @ Oct 11 2010, 17:00) QUO...   Oct 12 2010, 11:29
|- - Sandrine   QUOTE (Arash @ Oct 12 2010, 12:29) QUOTE ...   Oct 12 2010, 12:18
|- - Arash   QUOTE (Sandrine @ Oct 12 2010, 12:18) 7 x...   Oct 12 2010, 12:50
|- - Sandrine   QUOTE (Arash @ Oct 12 2010, 13:50) QUOTE ...   Oct 12 2010, 16:18
|- - Arash   QUOTE (Sandrine @ Oct 12 2010, 16:18) Jus...   Oct 13 2010, 11:22
- - q-stankovic   A small request concerning the tag behaviour: If ...   Oct 10 2010, 15:34
|- - Arash   QUOTE (q-stankovic @ Oct 10 2010, 15...   Oct 11 2010, 12:43
- - q-stankovic   QUOTE (Arash @ Oct 11 2010, 13:43) I may ...   Oct 11 2010, 16:44
- - Arash   0.207 * "Done" button in the drop-d...   Oct 15 2010, 12:45
- - Sandrine   Thanks, I got my sanity back now   Oct 15 2010, 15:05
- - q-stankovic   Hello Arash! Due to the design of the prefere...   Oct 16 2010, 18:13
|- - Arash   QUOTE (q-stankovic @ Oct 16 2010, 18...   Oct 16 2010, 18:59
- - q-stankovic   QUOTE (Arash @ Oct 16 2010, 19:59) ... bu...   Oct 16 2010, 20:33
|- - Arash   QUOTE (q-stankovic @ Oct 16 2010, 20...   Oct 17 2010, 10:40
- - ruebe   hi! i really like your component, but i have ...   Oct 17 2010, 10:07
- - Arash   QUOTE (ruebe @ Oct 17 2010, 10:07) 1. a m...   Oct 17 2010, 10:54
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 28th July 2015 - 16:51
