TagBox Tag Editing Plugin, UI Element
Arash
post May 26 2010, 08:48
Hello Everybody,
I needed something like this but couldn't find any so I wrote it myself!
It is something like an editable "properties" window in a UI element with "quick tagger" like features and a little more.
Here is more info and download link.
Arash
post Aug 10 2010, 20:05
QUOTE (q-stankovic @ Aug 10 2010, 17:36) *
We are not talking about the field which requires at least one letter to open the popupmenu but the content of dropdown box.
Any chance to see 2E7AH's idea implemented.
Now I see what you're talking about. I like the idea myself as I told 2E7AH but making such thing is not easy I need to have a lot of free time to code something like that. Hope I can find it soon.
QUOTE (stefle @ Aug 10 2010, 19:09) *
Why not launch window directly from "TagBox" entry? No need for a submenu.
Because of my laziness smile.gif There used to be some other submenus which I moved to TagBox window's right-click menu. I'll make it a single item eventually.
ooops thats my local address, this is the correct url: http://arash.dejkam.com/software/tagbox/
This post has been edited by autumn: Aug 10 2010, 20:07
stefle
post Aug 11 2010, 11:18
Can't find version 1.71.
Check box "active" doesn't work.
Captions in configuration window are truncated on my system. Probably a DPI setting issue. (I have 115 instead of default 96 DPI.)
QUOTE (autumn @ Aug 10 2010, 20:05) *
Now I see what you're talking about. I like the idea myself as I told 2E7AH but making such thing is not easy [...]
What about this, no redesign of dropdown box needed, just a behaviour change of fields which are multivalue and autocomplete:
1. Type first letters of desired value in tag field
2. Select value from popping up autocomplete list
3. Type semicolon (or click a button)
4. Again type first letters of additional value
5. Again autocomplete list is launched
6. Select another value
I miss something like that in foobar core.
Some remarks on the documentation:
• Pressing Enter applies the changes.
When selecting item from autocomplete list no Enter needed.
• Pressing Ctrl+Enter or Ctrl+Down when only one track is selected applies the change and moves the selection to next track in play list.
Ctrl+Down doesn't work with autocomplete fields. Ctrl+Enter should be recommended.
• There is a context menu (tracks' right click menu) option to set track number to track's index in current selection.
The phrase "tracks' right click menu" is misleading.
• Right-Click any tag's label to access more options like "Auto Track Number", "Correct Capitalization" or "Filename -> Tag" functions.
Should be merged with previous instruction.
• You can enter an alternative tag for auto-complete to for example have a custom "guitar player" tag but get the list of suggestions from the "artist" tag.
I wouldn't use it, cause it's a core feature ("+"-seperated fields in Preferences › Advanced › Display › Autocomplete fields)
___________________
QUOTE (q-stankovic @ Aug 7 2010, 18:33) *
Maybe it is a good idea to let it look like selection properties. Means: no grid view but alternate colors and column headers - that seems more friendly to me.
Agreed.
This post has been edited by stefle: Aug 11 2010, 11:54
Arash
post Aug 11 2010, 15:03
QUOTE (stefle @ Aug 11 2010, 11:18) *
here: http://arash.dejkam.com/software/tagbox/
Are you sure? Note that this feature is supposed to work only when you use a predefined value. (doesn't work when using auto-complete).
Actually there is no such menu item anymore, removed it from documentation.
I wouldn't use it, cause it's a core feature ("+"-seperated fields in Preferences Advanced Display Autocomplete fields)
I was not aware of that advanced setting at all before Yirkha's last post in this topic. I'll remove this feature later.
- autumn   TagBox Tag Editing Plugin   May 26 2010, 08:48
- - Neonphytismo   QUOTE (autumn @ May 26 2010, 15:48) Hello...   May 26 2010, 09:42
- - 2E7AH   because I guess it's DUI element and not CUI p...   May 26 2010, 09:52
|- - autumn   QUOTE (2E7AH @ May 26 2010, 09:52) some i...   May 26 2010, 10:47
|- - 2E7AH   QUOTE (autumn @ May 26 2010, 11:47) I don...   May 26 2010, 10:59
|- - autumn   QUOTE (2E7AH @ May 26 2010, 10:59) Couldn...   May 26 2010, 11:53
|- - 2E7AH   QUOTE (autumn @ May 26 2010, 12:53) BTW I...   May 26 2010, 13:50
- - 2E7AH   yeah, I was thinking about spacing generaly becaus...   May 26 2010, 12:12
- - Falstaff   download link doesn't work for me "requ...   May 26 2010, 13:06
|- - autumn   QUOTE (Falstaff @ May 26 2010, 13:06) dow...   May 26 2010, 13:28
- - muzack   Hey, thanks for this great plugin! It's mo...   May 26 2010, 13:26
- - q-stankovic   QUOTE (2E7AH @ May 26 2010, 13:12) yeah, ...   May 26 2010, 17:50
- - LXtreme   Good idea and great work! Thanks a lot :-) Ju...   May 26 2010, 20:38
- - foosion   Have you hardcoded the line height in pixels? At l...   May 26 2010, 21:54
|- - kabuki   hello do you plan to make it compatible to CUI asw...   May 26 2010, 22:35
- - autumn   Well! When developing this plugin I needed to ...   May 27 2010, 10:17
- - 2E7AH   it's fine now and CUI isn't redundant of...   May 27 2010, 11:03
- - lyh   Many people are useing CUI,I never use DUI.But als...   May 27 2010, 11:16
- - watercolor   Great job. Are there plan that adding foobar2000 c...   May 27 2010, 13:24
- - autumn   Hello Everybody, Thanks for all your suggestions ...   Jun 20 2010, 11:29
- - autumn   About the CUI panel, since I don't use CUI mys...   Jun 20 2010, 11:42
- - SoulMan   Hello, This plug-in is one of the ones I was wait...   Jul 18 2010, 15:21
- - Yirkha   Regarding autocomplete, you can use fb2k's lib...   Jul 18 2010, 23:20
- - autumn   @SoulMan: I think I'll add the "launch th...   Jul 20 2010, 09:37
- - SoulMan   Hello, Thank you a lot   Jul 23 2010, 14:10
- - autumn   Hello Everyone, Here comes version 0.150, comment...   Aug 2 2010, 12:39
|- - Yirkha   QUOTE (autumn @ Aug 2 2010, 13:39) @muzac...   Aug 2 2010, 16:11
- - watercolor   I want to use this in cui panel.   Aug 2 2010, 13:12
- - Andreasvb   It says it's missing some file. The file is a...   Aug 2 2010, 13:44
- - autumn   My development environment is somewhat different f...   Aug 2 2010, 14:22
- - marc2003   not working for me either. i'm running windows...   Aug 2 2010, 14:42
- - muzack   keyboard shortcuts doesn't interfere anymore. ...   Aug 2 2010, 15:31
|- - autumn   QUOTE (muzack @ Aug 2 2010, 15:31) keyboa...   Aug 2 2010, 16:57
|- - muzack   QUOTE (autumn @ Aug 2 2010, 17:57) QUOTE ...   Aug 2 2010, 17:37
- - autumn   Those with missing file problem please try the new...   Aug 2 2010, 15:39
- - marc2003   new version works on XP and windows 7. however, ...   Aug 2 2010, 16:09
- - autumn   QUOTE (marc2003 @ Aug 2 2010, 16:09) new ...   Aug 2 2010, 16:48
|- - marc2003   QUOTE (autumn @ Aug 2 2010, 16:48) That...   Aug 2 2010, 16:50
- - autumn   Version 0.170 released: TagBox Download Page new...   Aug 7 2010, 15:43
|- - muzack   QUOTE (autumn @ Aug 7 2010, 16:43) Versio...   Aug 7 2010, 16:54
- - q-stankovic   Thank you for the update! There is a fundemen...   Aug 7 2010, 16:48
|- - autumn   QUOTE (q-stankovic @ Aug 7 2010, 16...   Aug 7 2010, 18:02
- - q-stankovic   QUOTE (autumn @ Aug 7 2010, 19:02) But I ...   Aug 7 2010, 18:33
|- - autumn   QUOTE (q-stankovic @ Aug 7 2010, 18...   Aug 7 2010, 19:09
- - stefle   Thanks for your nice component! "active...   Aug 9 2010, 14:37
|- - autumn   QUOTE (stefle @ Aug 9 2010, 14:37) ...   Aug 10 2010, 16:55
|- - stefle   QUOTE (autumn @ Aug 10 2010, 16:55) QUOTE...   Aug 10 2010, 19:09
- - wolfsong   I tried to edit the values in the ratings preset a...   Aug 9 2010, 20:51
|- - autumn   QUOTE (wolfsong @ Aug 9 2010, 20:51) I tr...   Aug 10 2010, 16:57
|- - wolfsong   QUOTE (autumn @ Aug 10 2010, 10:57) QUOTE...   Aug 10 2010, 17:25
- - autumn   Just a few changes, If you're not using the st...   Aug 10 2010, 16:47
- - q-stankovic   QUOTE (autumn @ Aug 10 2010, 17:55) QUOTE...   Aug 10 2010, 17:36
|- - stefle   QUOTE (q-stankovic @ Aug 10 2010, 17...   Aug 10 2010, 19:18
- - autumn   QUOTE (q-stankovic @ Aug 10 2010, 17...   Aug 10 2010, 20:05
|- - stefle   Can't find version 1.71. Check box "activ...   Aug 11 2010, 11:18
|- - autumn   QUOTE (stefle @ Aug 11 2010, 11:18) Can...   Aug 11 2010, 15:03
|- - stefle   QUOTE (autumn @ Aug 11 2010, 15:03) QUOTE...   Aug 11 2010, 16:51
|- - autumn   QUOTE (stefle @ Aug 11 2010, 16:51) Defin...   Aug 11 2010, 17:25
|- - stefle   QUOTE (autumn @ Aug 11 2010, 17:25) Yes y...   Aug 11 2010, 17:58
|- - wolfsong   QUOTE (autumn @ Aug 11 2010, 11:25) Yes y...   Aug 11 2010, 19:28
- - q-stankovic   Autumn, i hope you don't feel annoyed to hear ...   Aug 10 2010, 20:33
|- - autumn   QUOTE (q-stankovic @ Aug 10 2010, 20...   Aug 10 2010, 21:17
- - autumn   version 0.172: Fixed the "immediately apply...   Aug 12 2010, 10:35
- - stefle   Thanks. Tried to prefdefine my 1217 %performer% v...   Aug 12 2010, 17:34
|- - autumn   QUOTE (stefle @ Aug 12 2010, 17:34) Tried...   Aug 13 2010, 01:33
- - autumn   Here comes a major upgrade, a lot of things have c...   Sep 18 2010, 16:14
- - q-stankovic   So much thanks!   Sep 18 2010, 16:29
- - q-stankovic   I did some testing and here are some smaller issue...   Sep 18 2010, 19:48
|- - autumn   QUOTE (q-stankovic @ Sep 18 2010, 20...   Sep 19 2010, 10:14
|- - Yirkha   QUOTE (autumn @ Sep 19 2010, 11:14) QUOTE...   Sep 24 2010, 11:55
- - SpaceAgeHero   I just discovered this component and wanted to exp...   Sep 21 2010, 23:07
- - watercolor   "Values Currently in Databse" typo? An...   Sep 24 2010, 10:47
- - Zelphar   it seems that the rating can not recognize by play...   Sep 24 2010, 18:44
- - q-stankovic   Zelphar, that's how it should work. TagBox wri...   Sep 24 2010, 19:06
- - Arash   QUOTE (watercolor @ Sep 24 2010, 10:47) ...   Sep 25 2010, 16:25
- - Yirkha   Maybe. Don't be afraid, try stuff like this fi...   Sep 25 2010, 16:52
|- - Arash   QUOTE (Yirkha @ Sep 25 2010, 16:52) Don...   Sep 27 2010, 16:42
- - Zelphar   I think use playback statistics' database bett...   Sep 26 2010, 11:57
- - q-stankovic   QUOTE (Zelphar @ Sep 26 2010, 12:57) ... ...   Sep 26 2010, 12:34
- - Arash   Version 0.205 * TagBox window updates itself ...   Oct 6 2010, 12:44
- - herojoker   It would be nice if there was an option to show ce...   Oct 7 2010, 09:11
- - Sandrine   Nice component! Please consider using the wind...   Oct 10 2010, 13:13
|- - Arash   QUOTE (Sandrine @ Oct 10 2010, 13:13) Ple...   Oct 10 2010, 14:32
|- - Sandrine   QUOTE (Arash @ Oct 10 2010, 15:32) QUOTE ...   Oct 11 2010, 17:00
|- - Arash   QUOTE (Sandrine @ Oct 11 2010, 17:00) QUO...   Oct 12 2010, 11:29
|- - Sandrine   QUOTE (Arash @ Oct 12 2010, 12:29) QUOTE ...   Oct 12 2010, 12:18
|- - Arash   QUOTE (Sandrine @ Oct 12 2010, 12:18) 7 x...   Oct 12 2010, 12:50
|- - Sandrine   QUOTE (Arash @ Oct 12 2010, 13:50) QUOTE ...   Oct 12 2010, 16:18
|- - Arash   QUOTE (Sandrine @ Oct 12 2010, 16:18) Jus...   Oct 13 2010, 11:22
- - q-stankovic   A small request concerning the tag behaviour: If ...   Oct 10 2010, 15:34
|- - Arash   QUOTE (q-stankovic @ Oct 10 2010, 15...   Oct 11 2010, 12:43
- - q-stankovic   QUOTE (Arash @ Oct 11 2010, 13:43) I may ...   Oct 11 2010, 16:44
- - Arash   0.207 * "Done" button in the drop-d...   Oct 15 2010, 12:45
- - Sandrine   Thanks, I got my sanity back now   Oct 15 2010, 15:05
- - q-stankovic   Hello Arash! Due to the design of the prefere...   Oct 16 2010, 18:13
|- - Arash   QUOTE (q-stankovic @ Oct 16 2010, 18...   Oct 16 2010, 18:59
- - q-stankovic   QUOTE (Arash @ Oct 16 2010, 19:59) ... bu...   Oct 16 2010, 20:33
|- - Arash   QUOTE (q-stankovic @ Oct 16 2010, 20...   Oct 17 2010, 10:40
- - ruebe   hi! i really like your component, but i have ...   Oct 17 2010, 10:07
- - Arash   QUOTE (ruebe @ Oct 17 2010, 10:07) 1. a m...   Oct 17 2010, 10:54
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 4th August 2015 - 20:32
