foo_playlist_organizer (aka foo_plorg), A component to organize your playlists in a treeview
NEMO7538
post May 3 2010, 17:12
I am happy to release a new component that let you organize your playlists in a treeview control.
With foo_playlist_organizer (aka foo_plorg), you will be able to create folders and hierarchies to arrange and categorize your playlists. All current functions are available by drag & drop or right click on items in the panel.
It can be downloaded here and is compatible with both DUI and CUI.
Please check this page for help and additional information.
This post has been edited by NEMO7538: Dec 25 2011, 22:41
Reason for edit: fixed link.
NEMO7538
post May 9 2010, 18:46
QUOTE (icedtea @ May 8 2010, 12:38) *
but the themed mode on windows 7 is still not working i.e. skinned selection frame
Also just a suggestion wouldn't it be better to move all preferences to the preferences page instead of the context menu?
I may look at supporting the theme .. but not in a near future.
Regarding the preferences, some are left in the context menu in case you want to have several instances and they are specific to each instance, while those from the preferences page are global.
QUOTE (metal_termite @ May 9 2010, 12:41) *
Why does the foo_plorg panel flicker twice really fast each time a playlist is selected? It seems to happen only sometimes when "Activate on single click" is disabled, but every time when it is enabled.
Is this happening to anyone else?
I will investigate at some point in time.
QUOTE (smkk @ May 9 2010, 17:52) *
Thanks for the updates. Just wondering if this red-dotted line is intentional.
I see ... it will be fixed in the next version. In the meantime, you can just set black & white as custom colors, the red should disappear.
This post has been edited by NEMO7538: May 9 2010, 18:47
- NEMO7538   foo_playlist_organizer (aka foo_plorg)   May 3 2010, 17:12
- - 2E7AH   controls (nodes) doesn't follow system (vista/...   May 3 2010, 17:40
|- - metal_termite   QUOTE (NEMO7538 @ May 3 2010, 15:05) foo_...   May 5 2010, 10:01
|- - NEMO7538   QUOTE (metal_termite @ May 5 2010, 11:01)...   May 5 2010, 11:41
|- - LXtreme   QUOTE (NEMO7538 @ May 5 2010, 12:41) QUOT...   May 5 2010, 15:08
|- - metal_termite   QUOTE (NEMO7538 @ May 5 2010, 06:41) QUOT...   May 6 2010, 01:09
- - icedtea   The click region is only limited to the playlist n...   May 3 2010, 19:06
- - muzack   awesome! Thank you!   May 3 2010, 19:46
- - garbanzo.bean   yes! i've been waiting for a component lik...   May 3 2010, 19:53
- - NEMO7538   QUOTE (icedtea @ May 3 2010, 20:06) The c...   May 3 2010, 20:05
- - icedtea   I meant ------------------------- | Playlist ---...   May 3 2010, 20:26
- - NEMO7538   ok, thanks. It used to work here .. I will fix for...   May 3 2010, 20:34
- - Sixth Street   This looks very promising. Can it be developed to...   May 3 2010, 20:35
- - Mar2zz   Very nice. waited long for a component like this. ...   May 3 2010, 21:17
- - Nemphael   Finally, I've waited for this for quite some t...   May 3 2010, 21:57
- - LXtreme   QUOTE (NEMO7538 @ May 3 2010, 18:12) I am...   May 3 2010, 22:06
- - SpaceAgeHero   Thank you! I was also waiting for something s...   May 3 2010, 23:15
- - Nemphael   I noticed something when changing between two pane...   May 3 2010, 23:43
- - Robertina   I have more than seventy playlists at the moment. ...   May 4 2010, 01:19
|- - DustMagnet   QUOTE (Robertina @ May 3 2010, 16:19) thi...   May 4 2010, 05:38
- - smkk   Thanks alot for this component, been waiting for y...   May 4 2010, 05:26
- - gob   Looks good so far, i like the idea. A few suggest...   May 4 2010, 07:21
- - NEMO7538   Thanks everyone for the test. I have updated the t...   May 4 2010, 08:58
- - watercolor   There is some requests. Playlist name area is not...   May 4 2010, 15:53
- - NEMO7538   QUOTE (icedtea @ May 3 2010, 21:26) -----...   May 4 2010, 22:28
- - exxecutor   Thank you for this great component! A decent p...   May 4 2010, 23:55
- - smkk   Thanks for the new version, now just missing drag ...   May 5 2010, 00:05
- - Robertina   Thank you for the update, "Enter" works ...   May 5 2010, 03:20
- - Wooops   Great! I was looking forward for this as well....   May 5 2010, 04:07
- - muzack   the treeview of album list in foobar2000 is also n...   May 5 2010, 14:52
- - marc2003   nope. album list just needs updating as well. open...   May 5 2010, 14:56
- - Nemphael   Whenever I right-click somewhere in the Playlist O...   May 5 2010, 16:05
|- - metal_termite   QUOTE (Nemphael @ May 5 2010, 11:05) When...   May 6 2010, 01:56
- - NEMO7538   QUOTE (Sixth Street @ May 3 2010, 21:35) ...   May 6 2010, 20:13
|- - LXtreme   QUOTE (NEMO7538 @ May 6 2010, 21:13) QUOT...   May 6 2010, 22:03
|- - Robertina   QUOTE (LXtreme @ May 6 2010, 10:03) Fooba...   May 6 2010, 22:40
- - Nemphael   You can see the problem in action here: http://www...   May 6 2010, 20:53
- - exxecutor   QUOTE (LXtreme @ May 6 2010, 23:03) BTW: ...   May 6 2010, 22:12
- - NEMO7538   QUOTE (Nemphael @ May 6 2010, 21:53) You ...   May 6 2010, 23:36
|- - Robertina   QUOTE (NEMO7538 @ May 6 2010, 11:36) Well...   May 7 2010, 01:14
|- - LXtreme   QUOTE (NEMO7538 @ May 7 2010, 00:36) This...   May 7 2010, 06:51
|- - NEMO7538   QUOTE (LXtreme @ May 7 2010, 07:51) QUOTE...   May 7 2010, 07:36
|- - LXtreme   QUOTE (NEMO7538 @ May 7 2010, 08:36) Thos...   May 7 2010, 09:06
|- - NEMO7538   I see ... it will be fixed in the next version.   May 7 2010, 09:24
- - icedtea   Bug http://imgur.com/B4WFw.png And the Win7/Vista ...   May 7 2010, 04:22
- - garbanzo.bean   Bug: i have CUI element colours set to custom, bu...   May 7 2010, 08:32
- - NEMO7538   QUOTE (icedtea @ May 7 2010, 05:22) Bug h...   May 7 2010, 16:07
- - icedtea   Another rendering bug http://imgur.com/BZFEg.png ...   May 8 2010, 05:18
- - NEMO7538   This should be fixed now in the new version. Pleas...   May 8 2010, 08:49
- - icedtea   The color of preferences window isn't the same...   May 8 2010, 09:08
- - NEMO7538   QUOTE (icedtea @ May 8 2010, 10:08) The c...   May 8 2010, 09:36
- - icedtea   yup it is all fixed now thanks but the themed mode...   May 8 2010, 11:38
- - metal_termite   Why does the foo_plorg panel flicker twice really ...   May 9 2010, 11:41
- - smkk   Thanks for the updates. Just wondering if this red...   May 9 2010, 16:52
- - NEMO7538   QUOTE (icedtea @ May 8 2010, 12:38) but t...   May 9 2010, 18:46
- - NEMO7538   BTW, I have uploaded Version 0.9 which fixes the r...   May 10 2010, 07:25
- - jano   I've seen in the forums that Foobar, unlike It...   May 11 2010, 02:16
|- - NEMO7538   QUOTE (metal_termite @ May 9 2010, 12:41)...   May 12 2010, 07:42
- - metal_termite   Here's an idea for a cosmetic feature in the t...   May 12 2010, 17:10
- - NEMO7538   QUOTE (metal_termite @ May 9 2010, 12:41)...   May 14 2010, 23:55
|- - metal_termite   QUOTE (NEMO7538 @ May 14 2010, 18:55) The...   May 15 2010, 14:57
- - smkk   I love you. Thanks for your work on this great com...   May 15 2010, 00:33
- - exxecutor   Agreed! Now foo_plorg has everything what the ...   May 15 2010, 00:59
- - icedtea   when selecting an item it seems that a border is d...   May 15 2010, 06:33
- - Squeller   Thanks for this useful plugin. Please help me see,...   May 17 2010, 17:56
|- - NEMO7538   QUOTE (Squeller @ May 17 2010, 18:56) Tha...   May 17 2010, 20:44
- - icedtea   I have encountered another bug Using CUI+PLORG+Fil...   May 18 2010, 12:19
|- - NEMO7538   QUOTE (icedtea @ May 18 2010, 13:19) I ha...   May 19 2010, 08:22
|- - NEMO7538   QUOTE (icedtea @ May 18 2010, 13:19) ... ...   May 20 2010, 21:27
- - laite   Hi, and sorry if this has been answered before, bu...   May 19 2010, 10:44
|- - muzack   QUOTE (laite @ May 19 2010, 03:44) Hi, an...   May 19 2010, 11:06
- - garbanzo.bean   ooh i missed the big jump to 1.0 this component is...   May 19 2010, 11:54
- - smkk   One tiny feature request: When dropping files from...   May 19 2010, 12:47
- - icedtea   Yes that bug is still fixed thanks Still want to ...   May 21 2010, 04:39
- - laite   It seems that everytime I close and start foobar, ...   May 22 2010, 12:24
- - NEMO7538   QUOTE (smkk @ May 19 2010, 13:47) One tin...   May 22 2010, 13:32
|- - laite   QUOTE (NEMO7538 @ May 22 2010, 14:32) A ...   May 22 2010, 13:44
- - NEMO7538   Do you have any message in the console?   May 22 2010, 19:06
|- - laite   QUOTE (NEMO7538 @ May 22 2010, 20:06) Do ...   May 22 2010, 19:19
- - NEMO7538   I see ... try to remove the panel from your config...   May 22 2010, 20:19
|- - laite   QUOTE (NEMO7538 @ May 22 2010, 21:19) I s...   May 22 2010, 21:13
- - NEMO7538   Well I don't know ... if you are using CUI, t...   May 22 2010, 21:28
- - ArchCarrier   First of all, thanks a lot for this nice piece of ...   May 28 2010, 15:15
|- - NEMO7538   QUOTE (ArchCarrier @ May 28 2010, 16:15) ...   May 29 2010, 11:20
|- - ArchCarrier   QUOTE (NEMO7538 @ May 29 2010, 12:20) You...   May 29 2010, 11:48
- - garbanzo.bean   if i'm interpreting you correctly, you're ...   May 29 2010, 12:01
- - ArchCarrier   Sir, you have made my weekend! I was not aware...   May 30 2010, 10:13
- - mobyduck   I might be doing something wrong, but keyboard sho...   Jun 6 2010, 08:56
|- - NEMO7538   QUOTE (mobyduck @ Jun 6 2010, 09:56) I mi...   Jun 6 2010, 10:26
- - Quadro313   Hey there. I believe my question might be a bit d...   Jun 16 2010, 13:29
|- - NEMO7538   I'm afraid there is a limitation of the SDK wh...   Jun 16 2010, 15:51
- - frnk   Thanks for this great component! This is exact...   Jul 11 2010, 11:17
- - grimes   I get this message in console on foobar2000 startu...   Jul 18 2010, 20:52
|- - NEMO7538   QUOTE (grimes @ Jul 18 2010, 21:52) ... P...   Aug 21 2010, 10:12
- - grimes   Thanks for the fix, Captain Nemo! I still get...   Aug 21 2010, 10:59
|- - NEMO7538   QUOTE (grimes @ Aug 21 2010, 11:59) I sti...   Aug 21 2010, 11:14
- - tg2k3   i love you   Aug 21 2010, 12:47
|- - tg2k3   btw, is it part of your roadmap to display the cat...   Aug 21 2010, 13:09
|- - NEMO7538   QUOTE (tg2k3 @ Aug 21 2010, 14:09) btw, i...   Aug 21 2010, 14:34
- - hejiamei   QUOTE (NEMO7538 @ May 3 2010, 17:12) I am...   Aug 22 2010, 03:55
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 27th May 2015 - 21:10
