GXLame - Low-bitrate MP3 encoder., Dedicated thread for discussion.
The Sheep of DEA...
post Apr 23 2010, 20:06
This is a snapshot of my work on "GXLame." GXLame is an MP3 encoder based off of LAME v3.98.4 and v3.99b0 which has been heavily optimized for high-quality, low-bitrate VBR encoding. It is similar in concept to other popular encoders at these bitrates such as some AAC codecs, Vorbis mods, and so forth at bitrates down to 56kbps. This codec does not rely on aggressive lowpassing or resampling to acheive these low bitrates, and the quality aims to be acceptable at much lower bitrates than have come to be expected of the standard. Here's a rough idea of what to expect:
On a continuous scale from V 0 (lowest bitrate) to V 100 (highest quality), with V20 as the default:
V100: 256kbps
V90: 224kbps
V80: 185kbps
V70: 162kbps
V60: 146kbps
V50: 128kbps
V40: 112kbps
V30: 96kbps
V20: 85kbps
V10: 74kbps
V0: 64kbps (actually 56kbps @ 32KHz; auto resampling to 32Khz takes place at V5 and below)
The range 0-35 is where the most tuning took place. The codec accepts input from stdin and can be used in foobar2000 (and many other audio rippers/managers/converters) by following any of the guides for LAME, but with a different commandline. For instance, one can easily import CD audio into foobar2000 and convert the tracks with the simple commandline: GXLame-t5.3 -S - %d
For greatly increased encoding speed, add "-f". To target a different quality level, add "-Vx" ('x' here means a number like 30, which would produce average bitrates somewhat close to 96kbps according to the above table).
GXLame 32bits version GXLame-t5 (9 Aug 2011)
This version contains debugging options.
usage: GXLame [options] <infile> [outfile]
    <infile> and/or <outfile> can be "-", which means stdin/stdout.
RECOMMENDED:
    GXLame input.wav output.mp3
OPTIONS:
    -b bitrate      (Not recommended) set the bitrate, default 85 kbps
    -h              highest quality, but slower (not recommended).
    -f              fast mode, slightly lower quality (but still very good)
    -V n            quality setting for VBR.  default n = 20 (near 85 kbps)
                    100 = highest quality, biggest files. 0 = smallest files
    --preset type   type must be "medium", "standard", "extreme", "insane",
                    or a value for an average desired bitrate and depending
                    on the value specified, appropriate quality settings will
                    be used.
                    "--preset help" gives more info on these
    --priority type  sets the process priority
                     0,1 = Low priority
                     2   = normal priority
                     3,4 = High priority
    --longhelp      full list of options
    --license       print License information
This is an early test release. Although some great progress is being made, it is not completely tuned, stable, or optimized. Then again, codecs never are and probably never will be. I want to gather user feedback, so use this puppy to compress whatever audio you will. Please note that lossy transcoding is an especially bad idea with GXLame. It relies so heavily on the psymodel and noise shaping that any artifacts present in the original--even inaudible ones in a transparent encode--may rebound here with a great vengeance. Particular culprits are transient smearing and additional high frequency distortion. If you must transcode, at least resample to a different frequency first (for instance, add "--resample 48" to the commandline when re-compressing/transcoding standard CD audio).
Grab a look at the changelog and older versions in the uploads thread here. Be sure to provide your opinions, discussions, impressions, test results, and whatever other witty banter you might deem applicable in this thread!
Right now, go forth and test it on your music, soundtracks, speech tracks (for speech, I recommend GXLame -V0 -mm --resample 16) -- I'm looking for tests for any regressions that might have been introduced in t5.3 since t5.2.
This post has been edited by The Sheep of DEATH: Sep 1 2011, 03:41
Attached File(s)
Copy Restriction, Annulment, & Protection = C.R.A.P. -Supacon
njsain
post Oct 31 2012, 17:52
Is the source available for GXLame? I would like to compile it for use on my computer running the Ubuntu 12.04 OS.
- The Sheep of DEATH   GXLame - Low-bitrate MP3 encoder.   Apr 23 2010, 20:06
- - Canar   Fascinating. How easily backported are your change...   Apr 23 2010, 20:29
|- - The Sheep of DEATH   QUOTE (Canar @ Apr 23 2010, 14:29) Fascin...   Apr 23 2010, 20:57
- - dv1989   QUOTE (The Sheep of DEATH @ Apr 23 2010, 20...   Apr 23 2010, 23:28
|- - The Sheep of DEATH   QUOTE (dv1989 @ Apr 23 2010, 17:28) Not n...   Apr 24 2010, 07:29
- - gaekwad2   Quick impression: Less warbling and distortion tha...   Apr 24 2010, 15:33
- - [JAZ]   I don't pretend to be rude but... Do you hav...   Apr 24 2010, 16:24
|- - The Sheep of DEATH   QUOTE ([JAZ] @ Apr 24 2010, 10:24...   Apr 24 2010, 22:53
|- - gaekwad2   QUOTE (The Sheep of DEATH @ Apr 24 2010, 23...   Apr 25 2010, 01:26
- - Canar   I have to disagree [JAZ]. The results speak for th...   Apr 24 2010, 19:31
- - shadowking   There biggest problem will be low volume , solo/ja...   Apr 25 2010, 02:48
|- - The Sheep of DEATH   QUOTE (shadowking @ Apr 24 2010, 20:48) T...   Apr 25 2010, 22:14
|- - gaekwad2   QUOTE (The Sheep of DEATH @ Apr 25 2010, 23...   Apr 26 2010, 02:04
|- - The Sheep of DEATH   In response to the samples I received so far! ...   Apr 27 2010, 14:18
- - stereotype   QUOTE (The Sheep of DEATH @ Apr 23 2010, 13...   Apr 25 2010, 02:54
- - [JAZ]   @Stereotype: in GXLame, 0..35 is the low bitrate r...   Apr 25 2010, 12:28
- - Steve Forte Rio   very interesting project. Hopefully it is backward...   Apr 25 2010, 19:57
- - Canar   Nice! I'm tempted to try hack-in support f...   Apr 27 2010, 15:24
|- - The Sheep of DEATH   QUOTE (Canar @ Apr 27 2010, 09:24) Nice...   Apr 29 2010, 02:11
- - gaekwad2   The noise is greatly reduced in t2, now the bigges...   Apr 30 2010, 13:03
|- - Soap   QUOTE (gaekwad2 @ Apr 30 2010, 08:03) The...   Apr 30 2010, 13:06
|- - [JAZ]   QUOTE (Soap @ Apr 30 2010, 14:06) Why are...   Apr 30 2010, 19:41
- - Canar   I do intend to do a bit of listening testing on th...   Apr 30 2010, 16:26
- - The Sheep of DEATH   From yesterday: QUOTE GXLame-t3. Changelog: - Sli...   Apr 30 2010, 21:44
- - lvqcl   I noticed that gxlame doesn't like quiet sampl...   May 1 2010, 11:09
|- - The Sheep of DEATH   QUOTE (lvqcl @ May 1 2010, 05:09) I notic...   May 1 2010, 19:40
- - lvqcl   Bitrate vs quality settings for LAME 3.98.4, LAME ...   May 1 2010, 18:50
|- - dv1989   QUOTE (lvqcl @ May 1 2010, 18:50) LAME 3....   May 1 2010, 21:16
- - lvqcl   QUOTE (The Sheep of DEATH)Could you direct me to t...   May 1 2010, 20:05
- - lvqcl   QUOTE Does this version have a different default V...   May 2 2010, 08:26
- - dv1989   Thanks for the answer! I wonder how it'll ...   May 2 2010, 11:55
- - lvqcl   QUOTE (dv1989)I wonder how it'll compare in li...   May 2 2010, 20:36
- - Aleron Ives   Forgive my ignorance, but if the VBR new in 3.98 h...   May 3 2010, 01:24
- - Steve Forte Rio   Sorry, but were I can download LAME 3.99 alpha 6 e...   May 3 2010, 11:56
- - dv1989   Google's first result for "LAME 3.99a6...   May 3 2010, 12:15
- - Steve Forte Rio   Oh, thank you)   May 3 2010, 12:20
- - lvqcl   current version is alpha 7 vbr-new behavior was t...   May 3 2010, 13:21
|- - The Sheep of DEATH   QUOTE (lvqcl @ May 3 2010, 07:21) current...   May 9 2010, 10:57
- - lvqcl   Killer samples for GXLame-t4 -V 30: mama_original...   May 21 2010, 18:43
- - The Sheep of DEATH   Hi. So I see vorbis got another new release recent...   May 5 2011, 06:22
- - IgorC   Thank You, Nice to see new version. It looks good...   May 6 2011, 07:40
|- - The Sheep of DEATH   QUOTE (IgorC @ May 6 2011, 01:40) Thank Y...   May 7 2011, 09:11
- - The Sheep of DEATH   Just for the record (in case I'm not around fo...   Aug 15 2011, 20:10
|- - holmus   QUOTE (The Sheep of DEATH @ Aug 15 2011, 19...   Aug 19 2011, 15:44
|- - C.R.Helmrich   I'm also interested in the performance of the ...   Aug 20 2011, 13:55
|- - moozooh   QUOTE (C.R.Helmrich @ Aug 20 2011, 16:55)...   Aug 20 2011, 18:14
- - IgorC   After conducting the last public test I've und...   Aug 21 2011, 23:23
- - moozooh   Ah, I erroneously assumed C.R.Helmrich was asking ...   Aug 23 2011, 13:46
- - IgorC   Short test. 10 first samples from last public tes...   Sep 1 2011, 05:50
|- - The Sheep of DEATH   Excellent, this is what I was looking for! Tha...   Sep 1 2011, 20:49
|- - IgorC   QUOTE (The Sheep of DEATH @ Sep 1 2011, 16...   Sep 2 2011, 02:44
|- - lvqcl   QUOTE (The Sheep of DEATH @ Sep 1 2011, 23...   Sep 3 2011, 09:13
- - IgorC   Another short test. 10 samples from the last publi...   Sep 3 2011, 09:50
- - lvqcl   I thought that ABR is still preferrable for LAME a...   Sep 3 2011, 10:45
- - IgorC   You're right. ABR is recommended for LAME at l...   Sep 3 2011, 11:20
|- - The Sheep of DEATH   QUOTE (IgorC @ Sep 3 2011, 05:20) You...   Sep 3 2011, 21:55
|- - lvqcl   QUOTE (The Sheep of DEATH @ Sep 4 2011, 00...   Sep 3 2011, 22:39
|- - IgorC   QUOTE (The Sheep of DEATH @ Sep 3 2011, 17...   Sep 3 2011, 22:53
|- - The Sheep of DEATH   Ahaha, thanks. I was thinking of V20, in the middl...   Sep 4 2011, 04:40
|- - lvqcl   QUOTE (The Sheep of DEATH @ Sep 4 2011, 07...   Sep 4 2011, 06:27
|- - The Sheep of DEATH   QUOTE (lvqcl @ Sep 4 2011, 00:27) QUOTE (...   Sep 4 2011, 07:49
|- - IgorC   QUOTE (The Sheep of DEATH @ Sep 4 2011, 03...   Sep 4 2011, 08:04
- - darkbyte   Nice encoder. I'm waiting for the lame_enc.dll...   Oct 2 2011, 14:58
- - Yuri   This encoder is great. Sounds really good with h...   Jan 21 2012, 04:16
- - Freya   Firstly respect to you for coming out with such a ...   Mar 15 2012, 10:36
|- - The Sheep of DEATH   QUOTE (Freya @ Mar 15 2012, 04:36) Firstl...   Mar 26 2012, 06:23
- - LithosZA   Are you restricted to 16Kbps? MP3 will blow up at ...   Mar 15 2012, 11:45
|- - Freya   QUOTE (LithosZA @ Mar 15 2012, 10:45) Are...   Mar 15 2012, 12:36
- - LithosZA   QUOTE It has to be .mp3 format I'm afraid, oth...   Mar 15 2012, 14:07
- - njsain   Is the source available for GXLame? I would like t...   Oct 31 2012, 17:52
RSS Lo-Fi Version Time is now: 5th May 2015 - 16:50
