foo_quicksearch, New version of foo_uie_quicksearch
NEMO7538
post Apr 13 2010, 12:49
I am happy to release a new version of the now defunct quicksearch toolbar.
This new version has been made for foobar V1.x and is compatible with both DUI and CUI.
It can be downloaded here and provides with new features such as autoplaylist generation, full customization of the context menu, .... and improved performances.
Please check this page for help and additional information.
It utilizes the Windows Imaging Component which is included in Windows XP SP3 or higher and in .NET 3.0.
The WIC can also be downloaded here separately.
This post has been edited by NEMO7538: Jun 19 2011, 17:23
RogerG
post Apr 20 2010, 16:11
There is a problem with the quick search preferences panel. If I select Quick Search in the foobar prefereces tree, the quick search prefereces appear but they first take the whole window space then the panel is resized. The tree becomes visible again. You might notice this on slow computers only or if you select the quick search tree entry for the first time. It doesn't look good. It is the only component with this kind of behaviour.
Another unusual thing is the statusbar. If I select the search results playlist the time and volume in the right cornor disappear for a short time. You might notice this on slow computers only, too. It doesn't happen if I select normal playlists.
This post has been edited by RogerG: Apr 20 2010, 16:16
Robertina
post Apr 21 2010, 08:17
Group: Banned
QUOTE (RogerG @ Apr 20 2010, 04:11) *
RogerG,
are you using Columns UI? Other than the DUI it adds an area to its statusbar which indicates the read-only status of playlists and therefore it seems to redraw that section of the statusbar with the values for volume, time and write-protection.
I own several computers, on the older (slower) ones, with CUI the behaviour you described occurs with all read-only playlists, including the read-only Quicksearch ones, and it occurs never with unprotected playlists or with the DUI statusbar.
RogerG
post Apr 22 2010, 07:42
QUOTE (Robertina @ Apr 21 2010, 09:17) *
RogerG,
you are right, I use Columns UI. Thank you for the hint!
Robertina
post Apr 22 2010, 08:11
Group: Banned
QUOTE (RogerG @ Apr 21 2010, 19:42) *
I am always glad if I can contribute something useful with my small and simply structured user brain... lalala.gif
- NEMO7538   foo_quicksearch   Apr 13 2010, 12:49
- - Gapkiller   Playing with it right now. Looks good. Thank You.   Apr 13 2010, 13:20
- - Keesface   customization of the context menu, that's awes...   Apr 13 2010, 13:26
- - mystNZ   Hi NEMO7538, thanks for the new release! I am...   Apr 13 2010, 13:53
|- - NEMO7538   QUOTE (mystNZ @ Apr 13 2010, 14:53) Can t...   Apr 13 2010, 14:32
|- - mystNZ   QUOTE (NEMO7538 @ Apr 13 2010, 23:32) I a...   Apr 13 2010, 15:43
|- - kabuki   QUOTE (NEMO7538 @ Apr 13 2010, 15:32) Onl...   Apr 13 2010, 16:10
- - NEMO7538   QUOTE (mystNZ @ Apr 13 2010, 16:43) the s...   Apr 13 2010, 16:13
- - Decalicatan_Decalicatan   Maybe this has been discussed before in a discussi...   Apr 13 2010, 16:25
- - kerpondile   QUOTE (NEMO7538 @ Apr 13 2010, 13:49) I a...   Apr 13 2010, 17:03
|- - NEMO7538   QUOTE (kerpondile @ Apr 13 2010, 18:03) O...   Apr 13 2010, 17:56
|- - kerpondile   QUOTE (NEMO7538 @ Apr 13 2010, 18:56) QUO...   Apr 15 2010, 08:44
- - jeremija   I am having trouble with adding the item to the CU...   Apr 13 2010, 17:51
|- - NEMO7538   QUOTE (jeremija @ Apr 13 2010, 18:51) I a...   Apr 13 2010, 18:49
|- - bwat47   QUOTE (jeremija @ Apr 13 2010, 11:51) I a...   Apr 23 2010, 00:11
- - ojdo   QUOTE (NEMO7538 @ Apr 13 2010, 13:49) Thi...   Apr 13 2010, 19:39
- - kabuki   @NEMO7538 report: i notice that you have replaced ...   Apr 13 2010, 19:45
- - fbuser   QUOTE (ojdo @ Apr 13 2010, 19:39) [*]Bug:...   Apr 13 2010, 20:09
- - NEMO7538   QUOTE (mystNZ @ Apr 13 2010, 14:53) I am ...   Apr 13 2010, 22:34
|- - jeremija   QUOTE (NEMO7538 @ Apr 13 2010, 23:34) QUO...   Apr 14 2010, 08:12
- - Qest   Love it. I've been looking for something like ...   Apr 14 2010, 08:27
- - amors   QUOTE (jeremija @ Apr 13 2010, 18:51) I a...   Apr 14 2010, 09:41
- - NEMO7538   QUOTE (mystNZ @ Apr 13 2010, 14:53) Hi NE...   Apr 14 2010, 10:37
|- - Falstaff   QUOTE (NEMO7538 @ Apr 14 2010, 10:37) QUO...   Apr 14 2010, 16:59
|- - mystNZ   QUOTE (NEMO7538 @ Apr 14 2010, 19:37) Sho...   Apr 15 2010, 14:25
- - Falstaff   Thank you very much NEMO for the new release   Apr 14 2010, 12:01
- - amors   In context menu 'Quicksearch for same'. ...   Apr 14 2010, 13:09
- - xan K   Thank you for this!   Apr 14 2010, 15:44
- - jeremija   If it could only be optional - I would't mind ...   Apr 14 2010, 17:45
|- - Falstaff   QUOTE (jeremija @ Apr 14 2010, 17:45) If ...   Apr 14 2010, 17:56
- - NEMO7538   QUOTE (jeremija @ Apr 14 2010, 18:45) If ...   Apr 14 2010, 19:22
- - Falstaff   thanks a lot   Apr 14 2010, 19:25
- - jeremija   Thank you!   Apr 14 2010, 19:36
- - jgro   Version 1.3 works perfect so far, no problem delet...   Apr 14 2010, 20:55
- - sPeziFisH   By far one of the most useful components ! Thx...   Apr 14 2010, 21:48
- - NEMO7538   Well in fact you don't need to .... It is don...   Apr 15 2010, 09:05
- - RogerG   Thank you for the new version! The improved sp...   Apr 17 2010, 05:08
- - megar   The minute I was lacking foo_quisearch, I found yo...   Apr 17 2010, 14:59
- - NEMO7538   QUOTE (RogerG @ Apr 17 2010, 06:08) ... H...   Apr 17 2010, 19:21
- - Robertina   Thank you, NEMO7538, for this very useful componen...   Apr 18 2010, 23:49
|- - NEMO7538   QUOTE (Robertina @ Apr 19 2010, 00:49) Wi...   Apr 19 2010, 05:19
- - Robertina   NEMO7538, please allow me to make three suggestion...   Apr 19 2010, 01:08
- - Robertina   Thank you for the update and your support. Robert...   Apr 19 2010, 05:23
- - Robertina   I am using foo_quicksearch since a few days now. N...   Apr 20 2010, 08:31
- - RogerG   There is a problem with the quick search preferenc...   Apr 20 2010, 16:11
|- - NEMO7538   QUOTE (RogerG @ Apr 20 2010, 17:11) ...th...   Apr 20 2010, 20:20
|- - Robertina   QUOTE (RogerG @ Apr 20 2010, 04:11) Anoth...   Apr 21 2010, 08:17
|- - RogerG   QUOTE (Robertina @ Apr 21 2010, 09:17) QU...   Apr 22 2010, 07:42
|- - Robertina   QUOTE (RogerG @ Apr 21 2010, 19:42) you a...   Apr 22 2010, 08:11
- - kabuki   hi, anyone having problem with the new syntax to u...   Apr 20 2010, 17:23
|- - Chugfrenzy   QUOTE (kabuki @ Apr 20 2010, 16:23) hi, a...   Apr 20 2010, 19:06
|- - kabuki   QUOTE (Chugfrenzy @ Apr 20 2010, 20:06) ...   Apr 20 2010, 20:09
|- - mystNZ   QUOTE (kabuki @ Apr 21 2010, 05:09) this ...   Apr 21 2010, 08:11
|- - kabuki   QUOTE (mystNZ @ Apr 21 2010, 09:11) QUOTE...   Apr 21 2010, 10:07
- - fbuser   The Add button for Tagz strings in the preferences...   Apr 20 2010, 21:43
|- - NEMO7538   QUOTE (fbuser @ Apr 20 2010, 22:43) The A...   Apr 20 2010, 21:53
|- - fbuser   QUOTE (NEMO7538 @ Apr 20 2010, 21:53) QUO...   Apr 21 2010, 19:17
- - einfallslos   I would love to use an ELplaylist as my media libr...   Apr 21 2010, 10:32
|- - vogliadicane   I really like this component. Would it be possible...   Apr 21 2010, 16:06
||- - NEMO7538   Delete your first playlist 'Default' once ...   Apr 21 2010, 16:22
|- - fbuser   QUOTE (einfallslos @ Apr 21 2010, 10:32) ...   Apr 21 2010, 20:33
- - Robertina   My search pattern %added% DURING LAST 4 HOURS resu...   Apr 21 2010, 16:27
|- - NEMO7538   QUOTE (Robertina @ Apr 21 2010, 17:27) My...   Apr 21 2010, 20:40
|- - fbuser   QUOTE (NEMO7538 @ Apr 21 2010, 20:40) QUO...   Apr 21 2010, 21:04
- - fbuser   I found two other problems: When searching the dat...   Apr 21 2010, 20:49
- - NEMO7538   Thanks fbuser ! I was thinking of something l...   Apr 21 2010, 23:59
|- - Robertina   QUOTE (NEMO7538 @ Apr 21 2010, 11:59) BTW...   Apr 22 2010, 07:07
|- - fbuser   QUOTE (NEMO7538 @ Apr 21 2010, 23:59) I w...   Apr 22 2010, 18:04
|- - NEMO7538   QUOTE (fbuser @ Apr 22 2010, 19:04) Sorry...   Apr 22 2010, 19:52
|- - fbuser   QUOTE (NEMO7538 @ Apr 22 2010, 19:52) Wel...   Apr 22 2010, 20:29
- - Robertina   I discover in this moment the new functionality to...   Apr 22 2010, 12:36
- - u-neeks   Hi, is there any way to display the icon on the ri...   Apr 23 2010, 06:28
- - Robertina   Quick Search inserts a single space between its pl...   Apr 23 2010, 22:21
- - NEMO7538   QUOTE (u-neeks @ Apr 23 2010, 07:28)...   Apr 24 2010, 09:06
- - Robertina   NEMO7538, could you consider to expand the size of...   May 7 2010, 11:35
- - NEMO7538   QUOTE (Robertina @ May 7 2010, 12:35) Cou...   May 8 2010, 11:15
|- - Robertina   QUOTE (NEMO7538 @ May 7 2010, 23:15) QUOT...   May 10 2010, 16:10
- - kerpondile   Would it be possible to define action for "en...   May 8 2010, 12:14
- - NEMO7538   I have added this option to the todo list. BTW I w...   May 8 2010, 13:31
|- - kerpondile   QUOTE (NEMO7538 @ May 8 2010, 14:31) I ha...   May 8 2010, 16:42
- - watercolor   >Please note that the context menu is not avail...   May 8 2010, 18:44
- - NEMO7538   The old version was using only one entry.   May 8 2010, 19:23
|- - Falstaff   Bonjour NEMO, a display issue : white background ...   May 8 2010, 19:45
|- - NEMO7538   QUOTE (Falstaff @ May 8 2010, 20:45) a di...   May 12 2010, 11:18
|- - Falstaff   QUOTE (NEMO7538 @ May 12 2010, 11:18) QUO...   May 12 2010, 11:27
|- - Falstaff   cursor vanishing don't happen on windows XP, o...   May 14 2010, 11:59
- - watercolor   QUOTE (NEMO7538 @ May 9 2010, 03:23) The ...   May 9 2010, 03:12
- - Falstaff   cursor vanishing fixed and flickering too ... my b...   May 14 2010, 17:55
|- - NEMO7538   QUOTE (Falstaff @ May 14 2010, 18:55) cur...   May 14 2010, 18:18
- - WilB   I find that on XP using PSS & $movepanel_...   May 14 2010, 18:20
- - Falstaff   thanx a lot for the fix, i'll try it tomorrow   May 14 2010, 21:57
- - Falstaff   ok, v1.9 tested, no more flickering at all, but st...   May 15 2010, 14:21
- - NEMO7538   I'm sorry but I cannot reproduce this behavior...   May 15 2010, 16:13
- - Emcee   [Request] Direct access to the history via drop-do...   May 19 2010, 14:36
- - ayuyaia   Could not get this to work. With foobar 1.0.2 (por...   May 21 2010, 00:30
|- - NEMO7538   QUOTE (ayuyaia @ May 21 2010, 01:30) Coul...   May 21 2010, 06:18
- - ayuyaia   Yes, I just reinstalled the latest version (dated ...   May 21 2010, 10:12
- - ArianneG   Hello. Just tried to download the component using ...   May 21 2010, 11:38
- - NEMO7538   QUOTE (ayuyaia @ May 21 2010, 11:12) Yes,...   May 21 2010, 12:44
- - biatche   anybody mind mirroring the latest version to rapid...   May 21 2010, 15:20
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 26th April 2015 - 04:29
