8 Pages V  < 1 2 3 4 > »
foo_touchremote - Remote control for iPhone/iPod Touch, [Not my release]
odyssey
post May 2 2010, 16:47
Post #26
QUOTE (z-man @ May 2 2010, 14:50) *
Same problem here. I loaded the plugin for the first time on Friday evening, and it worked perfectly. On Saturday morning the iPhone remote can't find the library. I am using only Bonjour, no iTunes, and have not installed any Windows updates (I have them intentionally disabled). The only variable is that I loaded a large new directory into Foobar's library, but even after reverting to my library's "test config" it's still not working. Very odd indeed.....
Same issue, when it prompts for code but then won't connect?
z-man
post May 2 2010, 16:58
Post #27
QUOTE (odyssey @ May 2 2010, 10:47) *
Exactly. Device pairs just fine, but times out when trying to find library.
odyssey
post May 2 2010, 17:00
Post #28
QUOTE (z-man @ May 2 2010, 16:58) *
What are your device and model? What about firmware?
z-man
post May 2 2010, 17:28
Post #29
QUOTE (odyssey @ May 2 2010, 11:00) *
iPhone 8GB - model # MA712LL
version 3.1.2 (7D11)
Modem Firmware 04.05.04_G
I have also have an iTouch here, I'll try that now to see if there are different results and report back.
z-man
post May 2 2010, 18:19
Post #30
QUOTE (z-man @ May 2 2010, 11:28) *
Interesting....I loaded the plug in with my very small "test library" on the iTouch. It connected right up. When I deleted that library and added a large new one, the plugin ceased to work (pairs with Foobar but can't find library). It seems the bug has to do with adding/changing/deleting directories to the library. I'm out of ideas now, but would really like to make this work......
odyssey
post May 4 2010, 21:49
Post #31
I think the bug is simply some bad configuration or something like that. I just updated foobar2000 core without touching foo_touchremote, and it simply works now.
If it doesn't fix the problem, maybe try to remove (or rename, just in case) the configuration file foo_touchremote.dll.cfg and see if it fixes the problem. Note, that I'm not allowed to recommend this, as it will ultimately blow up your computer and some admin may be responsible blablabla... (yeah, I actually got a warning for that once - TWICE!)
z-man
post May 8 2010, 13:03
Post #32
QUOTE (odyssey @ May 4 2010, 16:49) *
Tried both - no luck. Very odd. Will continue experimenting later today. Would really like to get this to work...
odyssey
post May 8 2010, 13:05
Post #33
Try on a fresh separete portable install.
qedao
post May 9 2010, 11:29
Post #34
Hi guys, Ive been using the plug for quite some time. I got the same problem at found out that if you play ramdom songs with foobar while its trying to connect, it works. I know it sound stupid but it works.
Also a bug? that I dont know how to override is that if you select a playlist that is not "remote selection" then no matter what u select in the remote, the next song will come from the selected list and not from the album you selected in remote.
Any1 found a solution to this?
Seems like the guy doing the development is not updating his page for a while sad.gif
C0mM4NcH3
post May 10 2010, 17:55
Post #35
Hey guys
This tool is just amazing, but i'm stuck at sth.
I can't search for Artists, Songs etc. On the "Remote"-App I just see the "Playlists" and its no problem to play songs of them. But if I click on "Artists" or "Albums" there is a message: "No Songs, You can download songs using iTunes." And so far I can't search my whole library.
Is this just not possible or am I missing something?
Thanks for your help!
C0mM4NcH3
widerock
post May 21 2010, 07:06
Post #36
QUOTE (odyssey @ May 1 2010, 11:17) *
I also only use Bonjour. iTunes has never been near the PC with foobar2000 on. Also Bonjour doesn't seem to be updated - The files are dated 2008-12-12!
Is there any method to use or install Bonjour without iTunes?
Due to some reason, it is not allowed to install and use iTunes in my PC.
If it is possible to use Bonjour without installing iTunes, I'd like to try this amazing features.
Thank you in advance.
sonvolt
post May 21 2010, 12:11
Post #37
QUOTE (widerock @ May 21 2010, 07:06) *
Yes, Just Google Bonjour for Windows and download/install .. Itunes not needed.
This post has been edited by sonvolt: May 21 2010, 12:13
sonvolt
post Jun 22 2010, 12:56
Post #38
If you could update your tracks star ratings via this app i'd buy an Ipod Touch and use it all the time , but having to walk to PC to rate song defeats a lot of its purpose, or can you and I'm missiing something?
This post has been edited by sonvolt: Jun 22 2010, 12:58
odyssey
post Jun 22 2010, 14:03
Post #39
QUOTE (sonvolt @ Jun 22 2010, 12:56) *
I previously asked the developer about this, and he's answer was:
of course, rating will be supported sooner or later, when I'll have some time to make it.
sonvolt
post Jun 22 2010, 14:18
Post #40
QUOTE (odyssey @ Jun 22 2010, 14:03) *
Thanks here's hoping.. : wink.gif
msb1
post Jun 25 2010, 17:29
Post #41
I've been using Foo_touchremote and am very pleased with it. I however have one issue. Searches from my Ipod are case sensitive. ie: searching for "moby" will not show result for "Moby". Does anyone know how to fix this? Thanks.
gob
post Jun 29 2010, 08:15
Post #42
the case sensitive searching looks like it would have to be sorted out on the devs side.
being able to rate songs would be killer!
most of the connection issues seem to happen most often when there are multiple devices connecting.
redmodel
post Jul 7 2010, 18:31
Post #43
Sorry,
I don't know if it's just me, or if it's been posted already. But does anyone know how to add albums to a playlist through the Remote App? I can listen to one album at a time, but I'd prefer to add a bunch to a playlist through the remote.
take care
dts350z
post Sep 7 2010, 00:29
Post #44
FYI I was not able to pair my iPhone 3Gs until I unplugged an apple airport express from my network.
Foobar plugin would ask for my pin, and eventually the dialog would go away, but nothing showing in the paired devices window.
dapost
post Sep 17 2010, 06:51
Post #45
Can someone please point me to directions how to install the foobar iphone remote control? I have already installed itunes and successfully using apple remote. Thanks!
s33m33
post Sep 19 2010, 20:54
Post #46
Working fine on 3GS 3.1.3. Nice plugin. Thanks.
Gets info & albumart from custom directories too, even after restarting app.
Missing lyrics & sort options though.
Fangs404
post Sep 20 2010, 06:09
Post #47
Does the developer know that this component is listed as a broken component (http://www.hydrogenaudio.org/forums/index....showtopic=30719)?
This post has been edited by Fangs404: Sep 20 2010, 06:10
metal_termite
post Sep 28 2010, 21:27
Post #48
Apple updated the Remote app to version 2.0. I updated the app to v2.0 and foo_touchremote no longer seems to function. The foobar2000 library will not appear in the Remote app, even after removing the paired device (in foobar2000) and re-pairing it. Can anyone else confirm this behavior, or is it just a quirk with my setup?
This post has been edited by metal_termite: Sep 28 2010, 21:28
Anomalous
post Sep 28 2010, 22:38
Post #49
The same thing is happening to me with version 2.0, pairing works but that's all.
sonvolt
post Sep 29 2010, 08:12
Post #50
No help to you but thanks for warning, will not update till plugin updated which hopefully it will be. Apple update probably will have some changes for Iphone4/OS4 which plugin can't deal with.
This post has been edited by sonvolt: Sep 29 2010, 08:16
RSS Lo-Fi Version Time is now: 21st April 2015 - 08:15
