DTS Audio CDs
duchski2
post Apr 1 2010, 17:53
I searched the web for a definitive answer but still could not find definitive specs for what is called DTS CD i.e. CD encoded with audio in DTS format.
As I understand DTS files are "encapsulated" in wav format so to the CD player thay look like "normal" wav files i.e. 16 bit, 44.1khz etc but then inside the fake wav file is a DTS encoded audio info. Now, what are the specs for the actual DTS stream inside the "wav" file i.e what DTS bit rates, sampling freq. etc are allowed?
GeSomeone
post Apr 13 2010, 17:07
QUOTE (duchski2 @ Apr 4 2010, 09:27) *
Ok. What about the sampling freq, can DTS-CD contain 48,000 Hz files?
It could depend on the (DTS) encoder, but so far I was only able to encode 44.1kHz input files on DTS-CD. When trying 48kHz the playback speed was totally wrong.
QUOTE (andy o @ Apr 4 2010, 17:46) *
The PCM "noise" is stereo 44.1 kHz, but when decoded, the DTS stream will be 5.1-channel 48 kHz. [..] I don't know how this would work for DTS 96/24 streams though, whose bitrates are probably higher.
DTS(WAV) files can be either either 44.1 or 48kHz. AFAIK the DTS-CD (44.1kHz) that can be burned on a CD, can only contain 44.1 kHz payload (see above). You can use 24 bit input however (as you can for making mp3's). The 96/24 extension can only be used in a full bit rate, 1536 kbps, stream and it will have a 48kHz core for backwards compatibility.
BTW the channel layout does not necessarily have to be 5.1. It could also be 5.0, 4.0 or even 2.0 although the last one is hardly ever used (I'm not sure about 4.1).
In theory, there is no difference between theory and practice.
RSS Lo-Fi Version Time is now: 28th July 2015 - 13:12
