9 Pages V  « < 4 5 6 7 8 > »
CUETools DB
tunetyme
post Apr 22 2011, 20:55
Post #126
I initially thought this program screwed up some my tracks cover art. I've discovered it has deleted my tags. Not on all my files but mostly 1-3 tracks on an album and up to 10 on a given album. Out of 29,000 plus tracks I have to repopulate over 3,500 tracks. Thankfully, I use JRiver Media Center and all the info is stored in an independent database. Because of the cover art problem I have to album by album. This is not good.
USE THIS SOFTWARE WITH GREAT CAUTION!!!!
I would like to help with this software but I need to be sure that it isn't going to damage my tags or files before I run it again. It would also be nice if there was a report or log generated after a run with everything organized by Category (see previous post) and artist. At that point I can at least update my database files to indicate all those that are accurate. This program has tremendous potential. It might be nice if the tags themselves could be updated to indicate that they have been verified by creating a field within the tags.
Tunetyme
Gregory S. Chudo...
post Apr 23 2011, 20:57
Post #127
QUOTE (tunetyme @ Apr 18 2011, 07:33) *
I believe that if you have the ability to correct the errors on a given CD (to minimize size of the DB) it may be possible to address the individual tracks as a subset and correct only those tracks that need to be.
You mean without reencoding the rest of the tracks? In theory that could be done, but i don't think that it would be a very important feature.
But you will still need to read all the other tracks to be able to use the recovery record.
It was suggested several times to make per-track recovery records, but that's impractical, because the size of the database would be multiplied by the number of tracks. Smaller recovery records won't work. And if we could afford to have tens of terabytes of data in the database, i'd prefer to use this space for larger whole-disc recovery records.
CUETools 2.1.4
Gregory S. Chudo...
post Apr 23 2011, 21:11
Post #128
QUOTE (tunetyme @ Apr 21 2011, 17:20) *
The key question is what to do with the info and how do I address the ones that could not be verified?
AccurateRip: disk not present in database, will not submit.
There are two possibilities here:
1) When a popular CD that should be in AR isn't found, that means that CUETools wasn't able to determine AR disc id,
because of the missing pregap or changed order of tracks. Most likely that's because you didn't keep the cue sheet.
There's no general way to fix it. To avoid this problem in the future, you should preserve the cue sheet.
2) CD is ok but not yet in AR database.
You can either wait for it to appear there and resubmit with CUETools, or use a ripper which can submit
directly to CTDB without AR verification.
recently verified: AR: database access error: Unable to connect to the remote server, CTDB: BadRequest.
Internet connection was down, you'll have to resubmit.
synchronization was lost.
That usually means that flac file was truncated. You'll have to rerip it.
AccurateRip: confidence too low, will not submit.
You can either wait until it's confirmed in AR and resubmit with CUETools, or use a ripper which can submit
AR: offset X, rip accurate (X/Y), CTDB: disk not present in database, XY- has been uploaded.
You successfully submitted CD to CTDB.
recently verified: AR: rip accurate (X/Y).
That's probably a bit annoying new feature, which i shouldn't have made on by default.
Turn off the 'Skip recently verified' checkbox. (icon with a clock)
CUEToolsDB: verified OK, confidence 112.
CD is already in CTDB, you don't need to submit it.
AR: rip not accurate (0/2), CTDB: could not be verified, will not submit.
Your rip probably contains errors, but you can't be sure because confidence is low.
CUETools 2.1.4
Gregory S. Chudo...
post Apr 23 2011, 21:17
Post #129
QUOTE (tunetyme @ Apr 22 2011, 22:55) *
CUETools doesn't modify tags by default. And nothing like this have happened before.
You either have turned on the option "Write AccurateRip tags" on verify in advanced settings, or it wasn't CUETools that ate your tags.
If you did turn on this option, and it did screw up your tags, please send me a sample file for which this happens.
CUETools 2.1.4
tunetyme
post Apr 27 2011, 16:52
Post #130
I have selected verify from the drop down menu. Under action I selected verify and submit. Mode all three are checked. I am using flac files. I don't see an advanced or write accurate rip tags option in 2.1.1.
I have been repairing all my tags from JRiver Media Center where all the tag info is stored independently. I assume I can send you info to the address listed on your website. It will take me awhile to sort through my file to see what hasn't been fixed. I think the only thing left is cover art problems.
I am willing to do some testing on a smaller scale. When I first ran this I used a few artist and then ran it on my whole rock database of 2200+ CD's. One thing that would be really helpful is to have a field in the tag that states if it has been verified or not. There could be several different codes to define the status of the album.
Tunetyme
Gregory S. Chudo...
post May 6 2011, 03:43
Post #131
QUOTE (tunetyme @ Apr 27 2011, 19:52) *
Advanced settings are opened when you click a gray cogwheel button in the top-left corner. If you didn't change those settings, then by default tag writing should be off and CUETools just couldn't have eaten your tags.
CUETools saves this info in it's local database, which is a better way IMHO than modifying the files.
This post has been edited by Gregory S. Chudov: May 6 2011, 03:44
CUETools 2.1.4
Gregory S. Chudo...
post May 6 2011, 03:47
Post #132
Thanks to CTDB, i was able to gather some interesting statistics on the use of pregaps:
CUETools 2.1.4
sauvage78
post May 6 2011, 05:11
Post #133
Interesting Yes, Thanks!!!
This post has been edited by sauvage78: May 6 2011, 05:12
CDImage+CUE
Secure [Low/C2/AR(2)]
Flac -4
sauvage78
post May 18 2011, 13:10
Post #134
I guess it doesn't matter much but I noticed CTDB counter is blocked at 50006 since a few days.
CDImage+CUE
Flac -4
Gregory S. Chudo...
post May 22 2011, 00:34
Post #135
Strangely enough, constantly updating this counter was taking too much of servers resources, so i had to partially disable it. It will update about once per day now.
By the way, congratulations everyone on reaching 50k CDs in database!
I moved CTDB to a new hosting to prepare for further database growth, and am working on providing musicbrainz NGS metadata via CTDB.
Here's an example: http://db.cuetools.net/lookup2.php?toc=32:...z=1&fuzzy=0
This post has been edited by Gregory S. Chudov: May 22 2011, 00:35
CUETools 2.1.4
radu
post May 22 2011, 19:50
Post #136
I think that in order for the CTDB to grow it should be supported by EAC, as AR is.
Are there any plans for an EAC plugin?
If no plans, why?
Gregory S. Chudo...
post May 22 2011, 21:07
Post #137
I'm working on it.
This post has been edited by Gregory S. Chudov: May 22 2011, 21:08
CUETools 2.1.4
HotShotFR
post May 24 2011, 00:32
Post #138
QUOTE (Gregory S. Chudov @ May 22 2011, 01:34) *
Speaking of resources, I recently discovered CTDB and decided to check all my rips against AR/CTDB then submit all [AR-reported] error-free ones to CTDB... (that was about ~1000 new discs in a row, ouch). I noticed afterwards that the uploading step failed for about ~5 rips (they did not appear online at db.cuetools.net). Had to do a new submission and it worked. Server overload?
Gregory S. Chudo...
post May 24 2011, 07:03
Post #139
Thanks. Most probably it was caused by me doing some maintainance and development in the background. But it could be server overload.
I guess i will have to set up a dedicated server at some point. The good thing about VDS is that it's cheap smile.gif
CUETools 2.1.4
Gregory S. Chudo...
post May 26 2011, 19:41
Post #140
Great news everyone: EAC V1.0 beta 2 is out, and it supports plugins. You can download it here: http://www.exactaudiocopy.de/en/index.php/...urces/download/
And CTDB plugin here: CUETools.CTDB.EACPlugin.rar
This post has been edited by Gregory S. Chudov: Jun 3 2011, 14:48
CUETools 2.1.4
Porcus
post May 27 2011, 01:13
Post #141
HotShotFR
post May 27 2011, 14:08
Post #142
QUOTE (Gregory S. Chudov @ May 26 2011, 20:41) *
And CTDB plugin here: http://db.cuetools.net/downloads/CUETools.CTDB.EACPlugin.rar
Great news smile.gif But what are we supposed to do with this CTDB plugin?
For instance I extracted the archive contents to my main Cuetools directory (overwriting files from a fresh 2.1.1), yet when verifying any file I get the error message: Exception: Method not found : 'Void CUETools.CTDB.CUEToolsDB.ContactDB(System.String)'
edit: Nevermind. Just figured out there are online instructions at http://db.cuetools.net/plugin.php biggrin.gif
This post has been edited by HotShotFR: May 27 2011, 14:10
zfox
post May 27 2011, 17:41
Post #143
Track 31 accurately ripped (confidence 6) [1278B705] (AR v2)
Track 32 accurately ripped (confidence 6) [26837954] (AR v2)
All tracks accurately ripped
End of status report
---- CUETools DB Plugin V2.1.2
[CTDB TOCID: 17ng1NaZY3cpgsNWrDCX5d2xFZM-] found.
[98d58d47] (3/3) Differs in 20 samples @37:51:39,58:44:55-58:44:56
You can use CUETools to repair this rip.
==== Log checksum CC0459D22AA62E8188551B97513046D1FE68D69AD04EEF36AA7B60991B2BB0BE ====
Hi Greg,
Does the Log Checksum value that was produced by EAC cover the text that was inserted by your plugin?
Gregory S. Chudo...
post May 27 2011, 22:33
Post #144
It should. Plugin itself doesn't modify the log file, it just returns the message to EAC, and EAC inserts it into log file.
CUETools 2.1.4
Gregory S. Chudo...
post Jun 3 2011, 14:52
Post #145
If you had trouble accessing the database for the past hour, that's because i was moving it to a new hosting. CUETools DB is now hosted on Amazon Cloud Services. Database runs on EC2 instance, and parity files are stored in S3. This should guarantee fast access and practically zero downtime.
CUETools 2.1.4
HotShotFR
post Jun 3 2011, 14:57
Post #146
Congrats for the new functionalities and redesign.
(Well done for the new Cuetools website too!)
Gregory S. Chudo...
post Jun 3 2011, 15:03
Post #147
I have to figure out how to further integrate CTDB with Musicbrainz (and possibly Discogs), then i can reuse their search capabilities.
CUETools 2.1.4
Studio 308
post Jun 13 2011, 23:50
Post #148
I only hope that this new method of adding plugins won't ruin EAC trust on some paranoid trackers.
Thanks for addition of this plugin.
Listen to WMRI...
Eli
post Jul 2 2011, 16:04
Post #149
Gregory, would you consider adding support for the CDTOC in meta-data. To many of my discs are not recognized when I try to verify and submit. I have over 5000 securely ripped CDs that I would like to submit to the DB.
The TOC is stored in the meta-data per these specs:
http://forum.dbpoweramp.com/showthread.php?t=16705
http://forum.dbpoweramp.com/showthread.php?t=21072
Porcus
post Jul 3 2011, 22:55
Post #150
QUOTE (Eli @ Jul 2 2011, 17:04) *
... and maybe even dBpoweramp's ACCURATEDISCID tag too? Despite the name, that is the track ID.
RSS Lo-Fi Version Time is now: 27th March 2015 - 07:11
