-V2 gives way too high bitrate!?!
masterridley
post Mar 29 2010, 16:48
I use dbpoweramp and I encode flac tracks to LAME 3.98r -V2. Usually this results in ~170 to ~220 kbps files (close to 192kbps CBR quality)
Well, not so for 2 As I Lay Dying albums that I have (think REALLY LOUD metal). When I encode those I get 230-270 kbps and of course the resulting files are quite big.
My question is: is this a bug or completely natural?
Furthermore (if it's not a bug), isn't it just better to encode in 192kbps and get a smaller file, since that's the quality I was going for anyway?
Cheers
robert
post Mar 31 2010, 14:25
LAME developer
global gain: is the global quantization step size (value range 0 - 255)
scale factor per band: amount how much to reduce the global quantization step size for this band, (value range different per bands, ie sfb0: 0-15)
    ifqstep = (scalefac_scale == 0) ? 2 : 4;
    for (sfb = 0; sfb < psymax; ++sfb)
        quantization_stepsize = global_gain - ((scalefac[sfb] + (preflag ? pretab[sfb] : 0)) * ifqstep) + subblock_gain[window[sfb]] * 8);
This post has been edited by robert: Mar 31 2010, 14:35
- masterridley   -V2 gives way too high bitrate!?!   Mar 29 2010, 16:48
- - dv1989   Natural. VBR targets quality, not bitrate. Loud me...   Mar 29 2010, 16:52
|- - dsimcha   QUOTE (dv1989 @ Mar 29 2010, 11:52) Natur...   Mar 29 2010, 16:56
- - [JAZ]   metal (being loud and "noisy"*) kicks on...   Mar 29 2010, 17:06
- - masterridley   Damn! That's what I suspected too (compres...   Mar 29 2010, 17:07
- - robert   You could update to LAME 3.98.4, as previous 3.98 ...   Mar 29 2010, 17:13
- - pdq   QUOTE (masterridley @ Mar 29 2010, 11:48)...   Mar 29 2010, 17:14
- - dv1989   QUOTE (pdq)If you really want the best quality whi...   Mar 29 2010, 17:24
- - masterridley   QUOTE (JAZ)Two ways to workaround (workaround not ...   Mar 29 2010, 17:26
- - greynol   -Y does not cut content above 16k; it is not a low...   Mar 29 2010, 17:43
- - lvqcl   QUOTE Regarding -Y, doesn't it kick in with -V...   Mar 29 2010, 18:06
- - Aleron Ives   I hate to continue discussion about -Y since it se...   Mar 30 2010, 04:59
|- - greynol   QUOTE (Aleron Ives @ Mar 29 2010, 20:59) ...   Mar 30 2010, 05:20
|- - Aleron Ives   QUOTE (greynol @ Mar 29 2010, 20:20) QUOT...   Mar 30 2010, 05:48
- - shadowking   I suggest not to fiddle with -Y . If you want a lo...   Mar 30 2010, 11:10
|- - Aleron Ives   QUOTE (shadowking @ Mar 30 2010, 02:10) I...   Mar 30 2010, 23:38
- - [JAZ]   I am preparing to put this on the wiki (but my use...   Mar 30 2010, 12:03
- - benski   very short version: -Y switch makes LAME not encod...   Mar 30 2010, 17:35
- - greynol   It was not too long and is well worth reading, ben...   Mar 30 2010, 17:42
|- - benski   QUOTE (greynol @ Mar 30 2010, 11:42) It w...   Mar 30 2010, 17:44
- - greynol   I hope you caught my edits above since I think you...   Mar 30 2010, 17:55
- - [JAZ]   I would like an answer from robert, or someone tha...   Mar 31 2010, 10:25
|- - Aleron Ives   QUOTE ([JAZ] @ Mar 31 2010, 02:25...   Mar 31 2010, 10:53
|- - robert   QUOTE ([JAZ] @ Mar 31 2010, 11:25...   Mar 31 2010, 12:33
- - shadowking   -Y is still 'experimental'. It was never ...   Mar 31 2010, 11:52
|- - Aleron Ives   I would like to thank robert for explaining the co...   Mar 31 2010, 23:58
- - [JAZ]   Thanks robert. I've used your explanations as ...   Mar 31 2010, 13:16
- - Ajax   The original poster "masterridley" (a ne...   Mar 31 2010, 14:16
- - robert   global gain: is the global quantization step size ...   Mar 31 2010, 14:25
- - pdq   @[JAZ] You might also point out that for older fo...   Mar 31 2010, 14:47
- - shadowking   We should not be recommending or documenting -Y un...   Mar 31 2010, 14:53
- - dv1989   QUOTE (Knowledgebase)LAME Y SWITH Surely I needn...   Mar 31 2010, 15:04
- - [JAZ]   DOH! I saw something strange in that, but i d...   Mar 31 2010, 20:45
- - dv1989   The spelling was one thing. Also, it may not matte...   Mar 31 2010, 21:09
- - shadowking   This is still going back to my point. Users don...   Apr 1 2010, 10:49
|- - Aleron Ives   QUOTE (shadowking @ Apr 1 2010, 02:49) Th...   Apr 1 2010, 11:18
|- - greynol   QUOTE (shadowking @ Apr 1 2010, 02:49) Us...   Apr 1 2010, 18:28
- - [JAZ]   Robert, can you comment on this line of the articl...   Apr 1 2010, 11:22
- - robert   QUOTE If global gain is zero, resolution will need...   Apr 1 2010, 11:37
- - [JAZ]   Talk about failing to read... I didn't ful...   Apr 1 2010, 13:39
RSS Lo-Fi Version Time is now: 2nd August 2015 - 12:41
