FFT Analysis for Dummies
Ethan Winer
post Mar 27 2010, 21:41
Folks,
I'd like to learn more about FFTs. I'm not a math guy, so I imagine I'll never fully understand all the nuances. But I'd like to try anyway. I understand the general concept, that an FFT shows how much energy is present at different frequencies. What I'd like to know is how to set the various parameters such as FFT Size and Overlap, when to use the different types of window smoothing and why, and so forth. Below is a list of settings in the Rightmark FFT analyzer with my associated questions, and hopefully this is a good place to start.
FFT Size: I understand that the higher the number, the better the frequency resolution. So why is this
even adjustable? Why not just use the highest resolution possible automatically?
Zero Padding: This ranges from None through 8x. What does this do?
FFT Overlap: What is this for, and when would you use higher or lower values?
FFT Window: I recognize some of the names, but have no idea when or why one would select these choices.
Kaiser Window beta: I have no idea what this does either.
I noticed that Sound Forge lets you pick the number of slices to show. What are slices and why is more than
one needed to analyze a Wave file?
I realize this is a lot to ask! If anyone knows of a good newbie-level tutorial that explains this in plain English with minimal math, I'd love to see it. Everything I've found through Google starts right in with math that's way over my head.
--Ethan
I believe in Truth, Justice, and the Scientific Method
Woodinville
post Mar 28 2010, 01:00
Ok.
An FFT is a discrete-time, finite length linear algebraic transform. It is orthonormal, which is to say it is a tight frame, or 1 to 1 and onto.
It uses a set of basis vectors that are derived directly from the complex exponential used in the continuous-time, continuous-frequency Fourier Transform.
As a result of the periodic nature of the FFT basis vectors, it is periodic across block boundaries, i.e. it looks like the data repeats to infinity, if you are doing a 2-point fft on two values, say 1 and -1 (yes, that's ridiculous, but it makes the point), the result is the same as calculating the full integral form on the infinite sequence 1 -1 1 -1 1 -1 1 -1 1 -1 ....
Among other things, this means that for signals that are not periodic at a block length, there will be a discontinuity at the ends.
This is why you do windowing, it removes the discontinuity at the ends of the block by windowing the signal to zero.
A window is nothing but the impulse response of a lowpass filter with specific properties.
I have to go shopping. So more later?
Some points, an FFT is not an approximation, nor is it a model. It is a precise transform with a precise inverse, one that obeys power and amplitude conservation both in the time and short-term frequency domain. In this it is actually marginally more precise than the full Fourier Transform, which suffers some zero-power, small amplitude issues, but that only with signals that can not exist in the real world, perhaps outside of astrophysics.
Must go, spouse grumbling.
J. D. (jj) Johnston
Gumboot
post Jan 15 2012, 00:25
QUOTE (Woodinville @ Mar 28 2010, 00:00) *
I take exception to this. An FFT, like anything else, is a model and/or an approximation if it is used as such. Sometimes 3 is an approximation of pi. There's no fantastic mathematical property that can stop something from being used as a very blunt instrument.
- Ethan Winer   FFT Analysis for Dummies   Mar 27 2010, 21:41
- - lvqcl   QUOTE (Ethan Winer @ Mar 27 2010, 23:41) ...   Mar 27 2010, 22:23
|- - Paulhoff   QUOTE (lvqcl @ Mar 27 2010, 17:23) ...   Mar 27 2010, 22:46
- - AndyH-ha   In most music the frequency changes over time. Ver...   Mar 27 2010, 23:36
- - Woodinville   Ok. An FFT is a discrete-time, finite length line...   Mar 28 2010, 01:00
|- - Gumboot   QUOTE (Woodinville @ Mar 28 2010, 00:00) ...   Jan 15 2012, 00:25
|- - Woodinville   QUOTE (Gumboot @ Jan 14 2012, 15:25) QUOT...   Jan 15 2012, 01:26
- - Notat   I'm not a super math dude but I have been read...   Mar 28 2010, 01:55
|- - Woodinville   QUOTE (Notat @ Mar 27 2010, 17:55) The ba...   Mar 28 2010, 05:23
|- - Notat   QUOTE (Woodinville @ Mar 27 2010, 22:23) ...   Mar 28 2010, 14:45
|- - Ethan Winer   Thanks for the advice and links. I thought to Goog...   Mar 28 2010, 16:59
|- - Canar   QUOTE (Notat @ Mar 28 2010, 09:45) Thanks...   Mar 29 2010, 18:35
|- - Woodinville   QUOTE (Notat @ Mar 28 2010, 06:45) QUOTE ...   Mar 30 2010, 00:10
|- - Notat   QUOTE (Woodinville @ Mar 29 2010, 17:10) ...   Mar 30 2010, 03:15
|- - Woodinville   QUOTE (Notat @ Mar 29 2010, 19:15) QUOTE ...   Mar 30 2010, 21:20
- - hellokeith   I had a very informative conversation about transf...   Mar 28 2010, 04:02
|- - Arnold B. Krueger   QUOTE (hellokeith @ Mar 27 2010, 23:02) A...   Mar 28 2010, 04:26
- - honestguv   Ethan, perhaps the best single resource to answer ...   Mar 28 2010, 10:46
- - benski   Answering a bit more than your question asks, for ...   Mar 28 2010, 16:53
|- - Ethan Winer   Okay, I have a few quick questions: In Sound Forg...   Mar 29 2010, 18:16
|- - Arnold B. Krueger   QUOTE (Ethan Winer @ Mar 29 2010, 13:16) ...   Mar 30 2010, 02:14
||- - Ethan Winer   QUOTE (Arnold B. Krueger @ Mar 29 2010, 21...   Mar 30 2010, 21:02
|- - Alexey Lukin   QUOTE (Ethan Winer @ Mar 29 2010, 13:16) ...   Apr 3 2010, 18:52
|- - Ethan Winer   Thanks very much Alexey! Lots for me to digest...   Apr 4 2010, 17:47
- - Woodinville   Note: I generally point at "Fourier Analysis...   Mar 30 2010, 00:13
- - Canar   I say we start with the Z-transform and express ev...   Mar 30 2010, 21:32
|- - Woodinville   QUOTE (Canar @ Mar 30 2010, 13:32) I say ...   Mar 30 2010, 21:50
- - C.R.Helmrich   Back in the days I learned the discrete Fourier tr...   Apr 4 2010, 18:21
|- - Arnold B. Krueger   QUOTE (C.R.Helmrich @ Apr 4 2010, 13:21) ...   Apr 5 2010, 12:21
|- - SebastianG   QUOTE (Arnold B. Krueger @ Apr 5 2010, 12...   Apr 5 2010, 16:39
- - hypervelocity   Hello guys, I'm working on my undergraduate t...   Apr 26 2011, 14:43
|- - Arnold B. Krueger   QUOTE (hypervelocity @ Apr 26 2011, 09:43...   May 2 2011, 13:42
- - pdq   That would depend on the sampling rate of your dat...   Apr 26 2011, 16:16
- - Natalia   Hi guys! I am trying to sort out samples acco...   Jan 12 2012, 08:49
- - xnor   QUOTE (Natalia @ Jan 12 2012, 09:49) I am...   Jan 12 2012, 18:10
- - Natalia   Well, I guess I should've made it clear from t...   Jan 13 2012, 01:49
|- - Woodinville   The irony of this thread being ressurrected is: h...   Jan 13 2012, 02:08
||- - Ethan Winer   QUOTE (Woodinville @ Jan 12 2012, 20:08) ...   Jan 13 2012, 17:48
|||- - Kees de Visser   QUOTE (Ethan Winer @ Jan 13 2012, 18:48) ...   Jan 13 2012, 19:03
||||- - Woodinville   QUOTE (Kees de Visser @ Jan 13 2012, 10:0...   Jan 14 2012, 23:14
|||- - Canar   QUOTE (Ethan Winer @ Jan 13 2012, 08:48) ...   Jan 15 2012, 01:05
||- - Roseval   QUOTE (Woodinville @ Jan 13 2012, 02:08) ...   Feb 1 2012, 23:56
||- - Woodinville   QUOTE (Roseval @ Feb 1 2012, 14:56) QUOTE...   Feb 2 2012, 11:02
|- - C.R.Helmrich   QUOTE (Natalia @ Jan 13 2012, 02:49) I am...   Jan 14 2012, 23:48
- - Natalia   Wish I could attend   Jan 13 2012, 02:55
- - xnor   Natalie, do these stimuli cause spikes every 68 se...   Jan 13 2012, 11:41
- - xnor   QUOTE (Gumboot @ Jan 15 2012, 01:25) I ta...   Jan 15 2012, 00:40
- - Woodinville   Slide deck and octave scripts are up at www.aes.or...   Jan 27 2012, 02:50
|- - neelX   QUOTE (Woodinville @ Jan 27 2012, 03:50) ...   Jan 27 2012, 11:49
|- - Woodinville   QUOTE (neelX @ Jan 27 2012, 02:49) QUOTE ...   Jan 28 2012, 00:13
- - Woodinville   .zip files still fubar. Webmaster pinged.   Jan 28 2012, 05:19
- - Woodinville   .zip fixed.   Jan 28 2012, 11:56
|- - Ethan Winer   QUOTE (Woodinville @ Jan 28 2012, 05:56) ...   Jan 28 2012, 18:50
|- - xnor   The .m files are scripts for GNU Octave, but you c...   Jan 28 2012, 20:01
|- - Ethan Winer   QUOTE (xnor @ Jan 28 2012, 14:01) The .m ...   Jan 29 2012, 19:09
- - Woodinville   So, Ethan, did you run some of the scripts yet? N...   Jan 30 2012, 02:59
|- - Ethan Winer   QUOTE (Woodinville @ Jan 29 2012, 20:59) ...   Jan 30 2012, 18:45
|- - Woodinville   QUOTE (Ethan Winer @ Jan 30 2012, 09:45) ...   Jan 30 2012, 23:59
|- - Ethan Winer   Hey, I watched an FFT tutorial "webinar...   Feb 1 2012, 23:14
|- - xnor   QUOTE (Ethan Winer @ Feb 2 2012, 00:14) I...   Feb 2 2012, 19:37
||- - C.R.Helmrich   Me too. To many people, such a resource will be mo...   Feb 2 2012, 23:14
||- - Roseval   QUOTE (C.R.Helmrich @ Feb 2 2012, 23:14) ...   Feb 2 2012, 23:36
||- - Woodinville   QUOTE (C.R.Helmrich @ Feb 2 2012, 14:14) ...   Feb 6 2012, 06:17
||- - romor   QUOTE (Woodinville @ Feb 6 2012, 07:17) S...   Feb 8 2012, 09:53
||- - Woodinville   QUOTE (romor @ Feb 8 2012, 00:53) QUOTE (...   Feb 9 2012, 03:52
|- - Ethan Winer   QUOTE (Ethan Winer @ Feb 1 2012, 17:14) H...   Feb 28 2012, 18:38
|- - Woodinville   QUOTE (Ethan Winer @ Feb 28 2012, 09:38) ...   Mar 1 2012, 01:01
||- - romor   QUOTE (Woodinville @ Mar 1 2012, 02:01) N...   Mar 1 2012, 15:25
||- - Ethan Winer   QUOTE (Woodinville @ Feb 29 2012, 19:01) ...   Mar 1 2012, 20:03
|- - Arnold B. Krueger   QUOTE (Ethan Winer @ Feb 28 2012, 12:38) ...   Mar 1 2012, 14:00
- - romor   http://www.aes.org/sections/pnw/scripts/   Feb 2 2012, 02:37
|- - Roseval   Thanks   Feb 2 2012, 10:14
- - Speedskater   Were you able to find anyone to make an audio reco...   Feb 2 2012, 15:31
|- - Woodinville   QUOTE (Speedskater @ Feb 2 2012, 06:31) W...   Feb 4 2012, 02:48
|- - Woodinville   QUOTE (Woodinville @ Feb 3 2012, 17:48) Q...   Feb 4 2012, 07:20
- - Woodinville   http://www.aes.org/sections/pnw/pnwrecaps/2012/jj_...   Feb 6 2012, 05:52
- - icstm   thanks for hosting.   Mar 1 2012, 18:43
RSS Lo-Fi Version Time is now: 25th January 2015 - 16:01
