vorbis-tools 1.4.0, libvorbis 1.3.1, and libao 1.0.0 coordinated relea, March 26, 2010 Xiph's news
forart.eu
post Mar 26 2010, 10:07
libao 1.0.0 released
libVorbis 1.3.1 released
vorbis-tools 1.4.0 released
Xiph.Org announces the release of libao-1.0.0, libvorbis-1.3.1 and vorbis-tools-1.4.0. This is a coordinated update of the audio libraries and tools to deploy improved surround-sound support across the libraries and toolchain.
libao improvements
  • AO returned to active development
  • Added surround channel mapping API and capability
  • Updated all drivers on modern installs
  • New config file options
  • Driver options may be specified in config file
  • Support for MacOSX updated to 10.5 and later
  • Build in WMM driver rather than using dlopen()
  • Added Roar Audio driver
  • Added OpenBSD SNDIO driver
  • Workaround for ESD non-4096 byte write bug
  • Workaround aRts server crash bug
  • Workaround for VIA82xx click/crackle bugs under ALSA
  • Remove dead/unused drivers (solaris, alasa05, mmsound)
  • Numerous patches from multiple downstreams
libvorbis improvements
libVorbis 1.3.0 was briefly available as an unreleased staging snapshot. This official release bumps the version number to 1.3.1 to avoid any possible confusion.
  • Optimized/coupled surround support for 5.1 encoding at 44.1/48kHz
  • Added encoder control call to disable channel coupling
  • Corrected an overflow bug in very low-bitrate encoding on 32 bit machines that caused inflated bitrates
  • Numerous API hardening, leak and build fixes
  • Correct bug in 22kHz compand setup that could cause a crash
  • Correct bug in 16kHz codebooks that could cause unstable pure tones at high bitrates
vorbis-tools improvements
vorbis-tools 1.4.0 is the first official release of vorbis-tools since 1.2.x. 1.3.x was never offered as an official snapshot, though various versions were widely deployed as patch-sets by distributions.
  • Implement corrected channel mappings for all input and playback file types
  • Correct an possible infinite loop in WAV input reading code when header is corrupt
  • Implement "disable_coupling" option for oggenc
  • Fix Ctrl-C lockup bug in ogg123
  • ogg123 directory playback in sorted order
  • Add WAVEFORMATEXTENSIBLE support
  • More translations
  • Add '-' as stdin/out filename in vcut
  • Add -lnetwork check for socket in configure
  • Remove 'extra' F parameter from ogg123 remote output
  • Numerous code and build fixes
Downloads
The libao 1.0.0 release is available from http://downloads.xiph.org/releases/ao/
The libvorbis 1.3.1 and vorbis-tools 1.4.0 releases are available from http://downloads.xiph.org/releases/vorbis/
Happy hacking!
Monty
Xiph.Org
This post has been edited by greynol: Mar 26 2010, 23:06
Reason for edit: Removed post icon.
robert
post Apr 20 2010, 11:26
LAME developer
At what point in the input data stream does the termination happen? At 0x7fffffff ? Some signed int problem maybe?
6 channels at 48 kHz sample rate, each sample 3 bytes (24 bits) : round about at 41.42 minutes ?
6 channels at 48 kHz sample rate, each sample 2 bytes (16 bits) : round about at 62.13 minutes ?
- forart.eu   vorbis-tools 1.4.0, libvorbis 1.3.1, and libao 1.0.0 coordinated relea   Mar 26 2010, 10:07
- - john33   libogg 1.2.0 is also part of this release. I...   Mar 26 2010, 10:10
|- - john33   QUOTE (john33 @ Mar 26 2010, 09:10) I...   Mar 26 2010, 18:46
- - forart.eu   Yep, was a yesterday release... john33, time for ...   Mar 26 2010, 10:42
|- - john33   QUOTE (forart.eu @ Mar 26 2010, 09:42) Ye...   Mar 26 2010, 12:46
- - HotshotGG   Sweet I wonder if the Ubuntu team has made a x86_6...   Mar 26 2010, 17:17
- - john33   I'm afraid these may not be completed until to...   Mar 26 2010, 22:47
|- - nycjv321   does this version of libvorbis incorporate the lat...   Mar 26 2010, 23:05
- - viktor   what changes are you making? will you try to get t...   Mar 26 2010, 23:04
- - HotshotGG   QUOTE does this version of libvorbis incorporate t...   Mar 26 2010, 23:32
- - john33   OK, there is a full set of compiles now on Rarewar...   Mar 27 2010, 20:11
|- - forart.eu   QUOTE (john33 @ Mar 27 2010, 20:11) OK, t...   Mar 28 2010, 00:50
- - viktor   QUOTE (john33 @ Mar 27 2010, 20:11) OK, t...   Mar 27 2010, 22:06
- - Dukers   Good to see Xiph projects alive again. I'm loo...   Mar 28 2010, 00:34
- - callmeace   Thanks for the windows builds Is there going to...   Mar 28 2010, 01:19
- - tebasuna51   The windows binaries from Rarewares have many prob...   Mar 28 2010, 19:59
- - john33   Actually, it's the source download that hasn...   Mar 28 2010, 20:21
|- - tebasuna51   QUOTE (john33 @ Mar 28 2010, 21:21) Actua...   Mar 29 2010, 03:37
|- - john33   QUOTE (tebasuna51 @ Mar 29 2010, 02:37) Q...   Mar 29 2010, 09:25
|- - xiphmont   QUOTE (john33 @ Mar 29 2010, 04:25) I kno...   Mar 30 2010, 01:39
|- - john33   QUOTE (xiphmont @ Mar 30 2010, 00:39) ......   Mar 30 2010, 07:41
- - john33   Just to add to the 64 bit conundrum, the 64 bit co...   Mar 29 2010, 14:24
- - callmeace   Oggdec download file says v197 , but on rarewares ...   Mar 29 2010, 22:02
|- - john33   QUOTE (callmeace @ Mar 29 2010, 21:02) Og...   Mar 29 2010, 22:27
- - HotshotGG   I was able to successfully build the new vorbis-to...   Mar 29 2010, 23:27
- - felix26591   How does libvorbis 1.3.1 compare to aotuv b5.7???   Mar 30 2010, 01:56
|- - Zarggg   QUOTE (felix26591 @ Mar 29 2010, 20:56) H...   Mar 30 2010, 22:09
- - icedtea   xiphmont is aotuv still going to be merged? Last I...   Mar 30 2010, 04:03
|- - quadamage   QUOTE (icedtea @ Mar 30 2010, 11:03) xiph...   Mar 30 2010, 07:08
- - gameplaya15143   oggenc2 -q 0 --advanced-encode-option lowpass_freq...   Mar 30 2010, 05:42
- - john33   oggenc2 has been bumped to V2.86 to reflect the ne...   Mar 30 2010, 15:35
|- - Emre   QUOTE (john33 @ Mar 30 2010, 17:35) oggen...   Mar 30 2010, 20:46
|- - john33   QUOTE (Emre @ Mar 30 2010, 19:46) .... Pi...   Mar 31 2010, 09:38
|- - Emre   QUOTE (john33 @ Mar 31 2010, 11:38) ...te...   Mar 31 2010, 15:44
|- - tebasuna51   QUOTE (john33 @ Mar 31 2010, 10:38) I...   Mar 31 2010, 20:12
- - HotshotGG   QUOTE Seconding this question. Also, unless I...   Mar 30 2010, 23:11
- - Jalan   Encoding failed in foobar2000 v1.0.1 for me as wel...   Mar 31 2010, 20:56
- - sauvage78   Same crash here, with generic build+Sempron 3000+ ...   Apr 3 2010, 03:50
- - Dandruff   I can confirm the crashes too: QUOTE (Dandruff ...   Apr 4 2010, 20:35
- - keicar   Same crashes here. See http://www.hydrogenaudio.or...   Apr 10 2010, 22:48
- - john33   Apologies for the delay, but I've been on vaca...   Apr 15 2010, 15:59
- - Dandruff   Thanks John. Working fine now!   Apr 15 2010, 16:59
- - zanuda   oggenc2-87-1.3.1 foobar2000 v1.0.2.1 windowsXP QU...   Apr 15 2010, 17:52
|- - john33   QUOTE (zanuda @ Apr 15 2010, 17:52) oggen...   Apr 15 2010, 19:03
|- - john33   QUOTE (john33 @ Apr 15 2010, 19:03) QUOTE...   Apr 15 2010, 19:27
|- - tebasuna51   QUOTE (john33 @ Apr 15 2010, 20:03) QUOTE...   Apr 19 2010, 20:02
- - robert   Could be something else, but where does -q5,000000...   Apr 15 2010, 18:33
|- - Dandruff   QUOTE (robert @ Apr 15 2010, 19:33) Could...   Apr 15 2010, 18:41
- - robert   So, foobar writes localized text into the command ...   Apr 15 2010, 18:49
|- - Dandruff   QUOTE (robert @ Apr 15 2010, 19:49) So, f...   Apr 15 2010, 19:17
- - sauvage78   In my case the fix seems to work. (Edit: I only te...   Apr 15 2010, 18:51
|- - Dandruff   QUOTE (sauvage78 @ Apr 15 2010, 19:51) In...   Apr 15 2010, 19:20
- - zanuda   I tried convert 6 channel .ac3 file to .flac Resul...   Apr 15 2010, 22:25
- - john33   Sorry, I confirm that directly converting the 6 ch...   Apr 15 2010, 22:52
- - john33   Thanks for the suggestion, I'll give it a try ...   Apr 19 2010, 21:58
- - john33   I tried this just now and I'm afraid that I ge...   Apr 20 2010, 10:42
- - robert   At what point in the input data stream does the te...   Apr 20 2010, 11:26
|- - john33   QUOTE (robert @ Apr 20 2010, 11:26) At wh...   Apr 20 2010, 13:48
- - tebasuna51   The 1:02:08 is the limit 0xFFFFFFFF for a wav 48KH...   Apr 20 2010, 14:44
- - john33   Thanks for your patience. My basic error was tha...   Apr 20 2010, 15:36
- - rt87   aoTuV post-beta5.7 [20100516] (for tester) Releas...   May 17 2010, 06:33
- - HotshotGG   Sweet! Thanks for the update I will have to te...   May 17 2010, 17:55
- - Zarggg   Yay! Can't wait for a new oggenc to go on ...   May 19 2010, 16:09
- - towolf   QUOTE (HotshotGG @ May 17 2010, 17:55) Sw...   May 19 2010, 22:04
- - Lumar   Hello i'm new in the forum so... i'll talk...   Aug 22 2010, 19:20
- - forart.eu   QUOTE (Lumar @ Aug 22 2010, 20:20) Hello ...   Aug 23 2010, 08:51
RSS Lo-Fi Version Time is now: 30th March 2015 - 06:08
