9 Pages V  « < 3 4 5 6 7 > »
Closed TopicStart new topic
lame 3.98.4, 3.99 alpha, 32- and 64-bit builds
lvqcl
post Jan 26 2011, 17:33
Post #101
QUOTE (Steve Forte Rio)
The difference between them was a small digital 1-bit noise.
Really? Usually differences are much bigger.
tsnr (bakerweb.biz)
tsnr is not bakerweb.biz.
This post has been edited by lvqcl: Jan 26 2011, 17:35
alter4
post Jan 31 2011, 21:51
Post #102
QUOTE (Steve Forte Rio @ Jan 14 2011, 15:21) *
3.99a contains the new VBR mode which enables with --vbr-new key. In other modes the result will be the same as for lame 3.98.4
Ha! AFAIK --vbr-new, which enabled a superior VBR mode in LAME 3.97 and some previous versions, is no longer needed with LAME 3.98 as it is now the default VBR mode
see Lame Wiki
This post has been edited by alter4: Jan 31 2011, 21:51
IgorC
post Jan 31 2011, 21:56
Post #103
It's vbr new 2.0
This post has been edited by IgorC: Jan 31 2011, 21:56
http://listening-test.coresv.net/results.htm
john33
post Jan 31 2011, 22:22
Post #104
xcLame and OggDropXPd Developer
QUOTE (Steve Forte Rio @ Jan 26 2011, 16:01) *
QUOTE (john33 @ Jan 17 2011, 09:44) *
QUOTE (Steve Forte Rio @ Jan 15 2011, 12:25) *
So, now I must ask: which is the best? Of course, in terms of quality
That question has been asked many times before and to the best of my knowledge no one has yet been able reliably to differentiate between the outputs from the encoders compiled with different compilers. So it's safe to say that you can use whichever takes your fancy. wink.gif
I asked the same question about different bitstream of 320 CBR encoded with two compiles. The difference between them was a small digital 1-bit noise. These could be the results of some processing optimizations.
But here we have different bitrates, and I think this is very strange and must affect quality.
Again:
john33 build - 191 kbps
tsnr (bakerweb.biz) - 185 kbps
lvqcl - 185 kbps
Sorry, but again, you may be able to see a difference, but can you hear one? The difference is only of any consequence if you can discern it accurately and repeatedly via blind listening tests.
John
Fishman0919
post Feb 7 2011, 23:15
Post #105
Does anyone know why this is not working anymore?
http://lame.cvs.sourceforge.net/viewvc/lam...tar.gz?view=tar
It will download a file but it is 0 bytes in size.
EDIT: Seems it's not work for some other programs as well.
This post has been edited by Fishman0919: Feb 7 2011, 23:18
lvqcl
post Feb 7 2011, 23:21
Post #106
http://www.hydrogenaudio.org/forums/index....st&p=741978
Fishman0919
post Feb 7 2011, 23:22
Post #107
QUOTE (lvqcl @ Feb 7 2011, 15:21) *
Thank You
obones
post Feb 12 2011, 19:54
Post #108
Hello,
I have Vegas Pro in 64bit version installed under Windows 7 x64 and I would like to use the lame codec inside it. I believe this is what lame64.acm is for but I can't find a way to install it properly.
I believe there should be a .inf file with it that would tell windows how to install it but it's not there.
Can any of you give me instructions for installing the acm file under Windows 7 64 bits ?
I have had a look at the rarewares website, but it does not seem to offer any x64 ACM build. There are instructions as to how to install under Win7 x64, but it's to install the x86 version that would then not be accessible to x64 applications
Thank you for your help
tsnr
post Feb 18 2011, 19:52
Post #109
LAME 3.99 alpha 12 (13 Feb 2011) - cvs snapshot
download (mediafire)
Changelog:
- make vbr_mt the default vbr mode
- new mono encoding switches:
-ml encodes left channel only
-mr encodes right channel only
- small fixes for compiler warnings
(vbrquantize.c) bug fix, out of bounds memory write
- reintroduction of fast encoding mode (-q7 / -f) (vbr_mt / vbr_mtrh)
- minor fix for sfb21 encoding (vbr_mt / vbr_mrth)
- small tunings
Win32:
lame.exe - the command line encoder, used from the Windows command shell
lame_enc.dll - LAME encoding library, generally used with CD rippers, etc
lame.acm - windows acm codec
libmp3lame.dll
x64:
lame64.exe
lame_enc64.dll
lame64.acm
libmp3lame64.dll
Bundle compiled with Intel Compiler XE 12.0
LAME MP3 Encoders (download homepage)
obones
post Feb 18 2011, 22:17
Post #110
I tried the x64 ACM codec as it includes an INF file this time but it crashes Vegas Pro so it seems it is not working.
Does anyone have any idea?
IgorC
post Feb 19 2011, 23:40
Post #111
Interesting. Now last alpha preserves frequencies up to 22 Khz (V0).
Enig123
post Feb 20 2011, 06:17
Post #112
What is vbr_mt exactly? And why it was set as default instead of the former vbr_new?
Larson
post Feb 20 2011, 08:39
Post #113
QUOTE (Enig123 @ Feb 20 2011, 06:17) *
If I've understood well, until the previous alpha to access the new vbr mode (vbr new 2.0 some have called it) you had to make the command "-VX --vbr-new" otherwise it worked with the older and regular vbr. Now as far as I've seen it is enabled by default, tested with dbpoweramp.
Fishman0919
post Feb 21 2011, 07:36
Post #114
QUOTE (Enig123 @ Feb 19 2011, 21:17) *
What is vbr_mt exactly? = a vbr routine build into Lame
The old vbr new was "--vbr-mtrh" (I assume by Mark Taylor and Robert Hegemann) ... now the new vbr new is "--vbr-mt" (I'm assumming by Mark Taylor)... There's also a "--vbr-rh" (assumming by Robert Hegemann) which I beleave is the vbr-old routine
EDIT: So it's still "-Vx --vbr-new or just -Vx" in the comandline.... it just routes to the vbr mt routine in Lame instead of vbr mtrh
This post has been edited by Fishman0919: Feb 21 2011, 08:33
Aleron Ives
post Feb 21 2011, 07:54
Post #115
QUOTE (Larson @ Feb 20 2011, 00:39) *
I think that is correct, although the way you said it might still be confusing, since "the older and regular vbr" is not --vbr-old. To be clear, the "old" VBR mode that used to be default in LAME 3.97 and previous versions (vbr-rh) was deprecated for the "new" VBR mode in LAME 3.98. The "new" VBR mode is vbr-mtrh. Because the new VBR mode was made default in LAME 3.98, using the --vbr-new switch didn't actually do anything, since --vbr-new (vbr-mtrh) was the default VBR mode.
In LAME 3.99, the developers began to work on more VBR improvements, so they made the --vbr-new switch enable those improvements. As of the latest alpha, the --vbr-new switch is no longer needed, and running in VBR mode will use the new encoding method by default (vbr-mt). What I don't know is whether this vbr-mt mode is the same vbr-mt that was deprecated around 2002 in favour of vbr-mtrh, or if this vbr-mt is just vbr-mtrh + improvements.
If I've gotten everything completely muddled, feel free to just delete this post so as to not confuse people further, haha.
robert
post Feb 22 2011, 20:58
Post #116
LAME developer
@Fisman0919: your guess about people involved in developing different variations of LAME's vbr code is correct.
There is some internal API enumeration of different VBR modes: vbr_rh, vbr_mt, vbr_mtrh
The command line switches to select one of those are: --vbr-old (vbr_rh), --vbr-mtrh and --vbr-new (vbr_mt)
It's been a long time, since the original vbr_mt code was discarded in favour of vbr_mtrh. The recent discrimination of vbr_mt and vbr_mtrh was only there to make experimentation easier for me. Now both modes do exactly the same again.
With 3.99 alpha 13 I'm starting to re-use some of the latest VBR code tunings in CBR/ABR.
alter4
post Feb 23 2011, 11:17
Post #117
@Robert
Sorry for a little bit off-top, but When do you plan to come into 3.99beta stage?
john33
post Feb 23 2011, 12:03
Post #118
John
robert
post Feb 23 2011, 21:46
Post #119
LAME developer
QUOTE (alter4 @ Feb 23 2011, 11:17) *
@Robert
Probably in March...
Fishman0919
post Feb 24 2011, 17:40
Post #120
I noticed that alpha 13 is not inserting the Lame Header??
robert
post Feb 24 2011, 18:10
Post #121
LAME developer
Just checked john33's compiled binary, the header is there.
Do you do anything special? How do you call LAME? How do you determine the existence of the header?
This post has been edited by robert: Feb 24 2011, 18:20
Fishman0919
post Feb 24 2011, 18:33
Post #122
QUOTE (robert @ Feb 24 2011, 09:10) *
Both with Foobar2000 "-S --noreplaygain -V 2 - %d" and command line "lame.exe --noreplaygain -V 2 test.wav test.mp3"
In Foobar2000, it's not showing the ver of Lame used to encoder and EncSpot is showing Gogo 3.0 as encoder with the Lame Header showing just Xing Tag
This post has been edited by Fishman0919: Feb 24 2011, 18:39
robert
post Feb 24 2011, 18:36
Post #123
LAME developer
It seems, Foobar2000 assumes the "Encoder short VersionString" has to start with LAME.
This post has been edited by robert: Feb 24 2011, 18:47
alter4
post Feb 25 2011, 12:32
Post #124
QUOTE (robert @ Feb 23 2011, 22:46) *
@Robert
Thank you Robert.
Fishman0919
post Feb 27 2011, 19:32
Post #125
Lame 3.99a14 is up... LINK -"http://www.mediafire.com/?7iva5wwo7ld4wr6"
This post has been edited by Fishman0919: Feb 27 2011, 20:12
RSS Lo-Fi Version Time is now: 31st January 2015 - 17:10
