Tiny encoder in lossy mode sounds differnent to wavpack, Tiny encoder lossy mode analysis
cram
post Feb 24 2010, 10:52
I have been running some tests on the performance of the wavpack algorithm for low bit rates and sample rates using the command line versions of the software.
e.g. wavpack -b24 file.wav file.wv
These have been performed at 16k sample rate and 11k sample rate as my application requires big reduction in the data file size. The command line algorithm states that 24 is the most compression available (although i have noticed that tiny encoder can go lower).
On the whole i have been pretty impressed with the lossy mode of the algorithm and found some suitable settings for my application.
My target hardware however requires fixed point maths so I have now implemented the tiny encoder 4.40 to perform the compression.
The issue that i have discovered is this version of the algorithm does not sound the same. There are additional distortion products when using the Tiny encoder which are not present on the command line version of wavpack.
I have tried using v4.40 of the command line version in case it was a version issue but this seems to perform as well as the latest wavpack version.
I have tried the command line version of Tiny encoder 4.40 and this does also have the distortion products which leads me to believe that they are specific to the implementation.
e.g. tinypack -b2.0 file.wav file.wv (at 16kHz)
My concern is that the lack of resolution (or dynamic range) forced by a fixed point implementation has led to a compromise of the algorithm's performance.
1) has anyone else encountered this issue?
2) Is it just a known issue that the fixed point Tiny Encoder does not function as well as the floating point version?
3) Does anyone have any ideas in which areas the discrepancy in the algorithms performance could be occurring and if modification of the source code could improve the issues.
Any comments or suggestions would be much appreciated.
many thanks
bryant
post Feb 26 2010, 05:41
WavPack Developer
Group: Developer (Donating)
There is no difference between the tiny encoder and the regular encoder with respect to floating-point math; both use only integers except perhaps for very infrequent operations (like a few per block).
However, there are two differences that could affect quality. The first is the “extra” mode that can dramatically improve encoding quality in some circumstances. This is only available in the command-line version, but unless you had specifically enabled this with the “-x” option, you would not be getting it.
The other difference is in noise shaping. The tiny encoder has by default no noise shaping, so the quantization noise is always flat. In the command-line encoder the default is for dynamic noise shaping, which can improve encoding quality significantly. To disable noise shaping in the command-line version (to see if this is the difference) try adding the option “-s0”. Both versions can provide fixed noise shaping, so you might try “-s-0.5” in the tiny encoder and see if that improves things (the same option in the standard encoder should result in identical results between the two encoders). This fixed noise shaping moves the noise up or down in frequency, so you can tweak this value depending on whether the artifacts you are hearing are high or low in frequency.
If it turns out that dynamic noise shaping is the factor that is making a big difference for your application, we can discuss adding that to the tiny encoder. It does not require much extra CPU or code size, but it cannot work in the hybrid lossless mode (which I assume you are not using). Without actually looking into it, I think it would be fairly trivial to do (...famous last words).
Another thing to try is the “-h” switch (which also works identically in both encoders). This requires somewhat more CPU for both encoding and decoding, but will also improve quality.
Please let me know if there’s anything else I can do to help you with getting WavPack working for your application.
David
RSS Lo-Fi Version Time is now: 22nd May 2015 - 12:51
