foovert, Uploads, Feedback, Bug reports, etc
/mnt
post Feb 20 2010, 01:52
foovert
A clean and simple theme for Columns UI.
Album layout:
Singles layout:
ABX layout:
Status pane:
Codec album list view:
Features:
- A clean and simple layout.
- Designed for Albums.
- NG Grouping.
- A big collection of columns.
- Capable of using different display headers for single tracks while viewing albums at the same time.
- Multiple layouts such as: Album view, Singles view and ABX view.
- Configurable.
- User friendly.
- Useful album list views such as codec browsor.
- Low software requirements.
- Low CPU usage.
Changes from 1.4
- NEW mini play counter display (off by default).
- NEW status bar layout (based on ColumnsUI default layout).
- NEW basic status plane layout (off by default).
- NEW tag checking scripts for displaying disc numbers and hybrid view.
- NEW "by source" album list view.
- NEW columns "Bit Depth", "BPM" and "Source".
- FIXED problems with albums that use discnumbers for users that don't use %totaldiscs%.
- FIXED "by encoding" album list view.
- FIXED "Encoding" column on ABX layout.
- Improvements have been made to the colour scheme.
- NG Group and playlist index is now in dark blue.
- All text now displays in white if selected.
- Tagging requirements for the default "foovert.fcl" theme is now very low.
- "Default" playlist now has its own statistic columns (Ratings, Last Played, etc).
- Updated codec / hardware id list for "System" column and status bar display.
- Updated sort column scripts.
- AAC files that is in LC codec profile will display as AAC-LC on codec display.
- Album Gain display on status bar will display Track Gain if an Album Gain tag is not present.
- Status bar now displays bit depth.
- Small adjustments have been made to the fonts (Column titles).
- Adjustments have been made with column sizes.
- Cleaned up the Status bar layout, that was messy from the beta version.
- Disabled Artist and Album display on main window title display.
- Moved play indicator from "#" column to "Title" on Singles view and to "Filename" on ABX layout.
- Moved all rgb formats are moved to the configureation section.
- Moved total disc checker away from Tracknumber display script.
- Added playing status for the status bar.
- Added a option to disable the playing status on the status bar.
- Added a option to enable and disable total discs checker (off by default).
- Added option to change NG Group title and play index text colour.
- Added option to change rated ratings colour.
- Rewritten Codec display.
- Replaced album checker switch with a tag check script.
- Replaced disc number check switch that was introduced from 1.5 Beta, with a tag check script.
- Removed "by album artist / date" album list view.
Install
First open foobar2000 with the Columns UI interface. Make sure that you have your current setup with grouping and artwork enabled,
a quick and way to do this is to select "Groups (with artwork)" on the Quick setup window.
After the grouping with artwork is enabled, you will need to go to File > Preferences > Columns UI > Main (Tab)
and then click on Import. Which will let you to browse for the foovert.fcl file.
After the fcl theme is loaded, you will need to add a NG Group. Which can be done by going to
File > Preferences > Display > Columns UI > Playlist View, then click on the Grouping and
replace the format with this:
$if2(%album artist%,Unknown Artist) - ['['%date%']' ]$if2($replace(%album%,' (',$rgb(106,137,196)' (',')',')'$rgb(),' [',$rgb(106,137,196)' [',']',']'$rgb()),Untitled Album)
And also set the playlist filters to "Show only on playlists" and the fill the filter box with this:
*single*;*shuffle*;*-s-*;*-abx-*;*--hidden--*
Download
foovert 1.5
The attachment contains a foovert.fcl (1.5) file and a custom version of foovert 1.5 (foovert mnt-19.02.10.fcl).
This post has been edited by /mnt: Feb 20 2010, 02:07
Attached File(s)
"I never thought I'd see this much candy in one mission!"
kazary
post Feb 4 2011, 17:16
Hi, thanks for the theme. I have some doubts. In Columns UI > Playlist View> Groupping , i put this, right?
http://img59.imageshack.us/img59/7967/74120468.jpg
I put in Title Format Script
///////// Custom NG Group format script /////////
///////// By /mnt /////////
// NG Group rgb
$puts(rgb_group,$rgb(42,85,170))
$puts(rgb_contrast,$rgb(255,255,255))
// NG Group format
$get(rgb_group)
$replace(
$if($or(%album%,%album artist%),
$if2(%album artist%,Unknown Artist)' - '['['$year(%date%)'] ']
$if2(%album%,Untitled Album),
$if2(%url%,$directory(%path%,1))),' - [',' - [',' - (',' - (',
' (',$blend($get(rgb_group),$get(rgb_contrast),1,3)' (',')',')'$get(rgb_group),
' [',$blend($get(rgb_group),$get(rgb_contrast),1,3)' [',']',']'$get(rgb_group))
It looks like this: http://img707.imageshack.us/img707/8205/23733177.jpg
In notes.txt say this:
-- Sort
[$replace($swapprefix(%album artist%),",,'',)|][%date%|][$replace($swapprefix(%album%),",,'',)|][%discnumber%|][%tracknumber%|]%path_sort%
-- Filename (Music folder)
$if2($replace(%album artist%,?,,:,,*,,",''''),Unknown Artist)\$if2($replace(%album%,?,,:,,*,,",''''),Unnamed Album)\[$ifgreater(%totaldiscs%,1,%discnumber%.,)]%tracknumber%. $replace(%title%,?,,:,,*,,",'''')[ '('$replace(%track artist%,?,,:,,*,,",'''')')']
But where i put this?
/mnt
post Feb 5 2011, 16:41
QUOTE (kazary @ Feb 4 2011, 17:16) *
It seems to be correct. It looks like it is something to do with the default sorting on foobar2000 or missing tracks.
Also be aware that NG Groups is now case sensitive on newer versions of columnsui.
-- Sort
Most of scripts on the notes text are my custom scripts that i use on foobar2000.
The sort script is very useful for sorting music as Artist by year and album. If you wish to use it you can copy and pasted the sort script onto: File > Preferences > Shell Intergration > Sort Incomming files by (text box):.
Also you will need to set the Album list view to use the core setting by checking "Apply core sort setting to added items", which is located at File > Preferences > Album List Panel > Advanced (Tab).
- /mnt   foovert   Feb 20 2010, 01:52
- - /mnt   foovert 2 New style and updated colour scheme: ...   Apr 2 2010, 20:54
- - /mnt   Customization To customize foovert, you will need...   Apr 10 2010, 21:56
- - johnsonlaw   The second album some how shows differently compar...   Apr 11 2010, 05:20
|- - /mnt   QUOTE (johnsonlaw @ Apr 11 2010, 05:20) T...   Apr 11 2010, 12:48
|- - ineluki   QUOTE (/mnt @ Apr 11 2010, 12:48) QUOTE (...   Jun 9 2011, 12:25
|- - /mnt   QUOTE (ineluki @ Jun 9 2011, 12:25) QUOTE...   Jun 13 2011, 20:05
- - kazary   Hi, thanks for the theme. I have some doubts. In C...   Feb 4 2011, 17:16
|- - /mnt   QUOTE (kazary @ Feb 4 2011, 17:16) Hi, th...   Feb 5 2011, 16:41
- - kazary   Thanks for the reply. I'm a novice I want to ...   Feb 5 2011, 17:56
|- - /mnt   QUOTE (kazary @ Feb 5 2011, 17:56) Thanks...   Feb 5 2011, 19:27
|- - spuuunit   Hi, how have you gotten Track Gain and File Size t...   Feb 13 2011, 21:37
- - jb347   This is great..thanks for uploading!   Mar 19 2011, 02:34
- - /mnt   foovert 2.2 (Beta) Changes - NEW systy notifict...   Apr 16 2011, 19:47
- - Antioch   Hey, nice theme. I've been looking for a clean...   Apr 19 2011, 06:55
|- - /mnt   QUOTE (Antioch @ Apr 19 2011, 06:55) It l...   Apr 26 2011, 22:10
- - /mnt   Final version of foovert 2.2 is now aviliable from...   Apr 29 2011, 19:31
- - crypt   Hi there. Loving your skin! Sadly I still hav...   May 19 2011, 23:12
|- - /mnt   QUOTE (crypt @ May 19 2011, 23:12) Hi the...   May 20 2011, 02:07
|- - crypt   QUOTE (/mnt @ May 20 2011, 02:07) Artwork...   May 20 2011, 17:30
- - silkcut   Hey /mnt. Thanks so much for the theme! It...   Jul 27 2011, 18:15
- - /mnt   @silkcut 1. You can edit the Album / Artist colum...   Jul 27 2011, 23:08
- - silkcut   Thanks /mnt. I made the changes you suggested in ...   Aug 3 2011, 22:42
|- - /mnt   QUOTE (silkcut @ Aug 3 2011, 22:42) Thank...   Aug 8 2011, 15:19
- - ainz   @ /mnt This is a very good foobar config. I'v...   Dec 20 2011, 00:02
- - Jagt   I'm completely new to Foobar and I've been...   Dec 11 2012, 10:08
- - Jagt   QUOTE (Jagt @ Dec 11 2012, 10:08) I'm...   Dec 22 2012, 00:34
|- - silkcut   QUOTE (Jagt @ Dec 21 2012, 17:34) QUOTE (...   Dec 22 2012, 00:48
- - Jagt   QUOTE (silkcut @ Dec 22 2012, 00:48) e to...   Dec 22 2012, 01:53
- - Jagt   To make things easier, here's a screenshot of ...   Dec 22 2012, 12:16
- - someguru20   It depends where/view you are trying to change the...   Feb 11 2013, 09:32
- - /mnt   To make the Album List view obey the incoming sort...   Feb 11 2013, 23:12
- - /mnt   Anyway its been a while since i released a new ver...   Feb 11 2013, 23:24
- - illwill916   When do you think version 3 final will be out?   May 5 2013, 01:42
|- - /mnt   QUOTE (illwill916 @ May 5 2013, 01:42) Wh...   May 22 2013, 22:48
- - /mnt   foovert 3 is now released, which can be downloade...   Jun 29 2013, 23:48
- - Lowdjo   Thanx a lot... I discoverted Foovert this winter, ...   Jul 18 2013, 12:15
- - Frecktel   Hey /mnt, Thanks again for a great setup. Keep co...   Jul 23 2013, 12:46
- - gir404   Great setup. My only issue is that some albums do...   Apr 9 2014, 04:00
|- - /mnt   QUOTE (gir404 @ Apr 9 2014, 04:00) Great ...   Apr 14 2014, 10:28
- - gir404   I found only 7 offending albums in my entire libra...   Apr 18 2014, 16:36
- - gir404   I can't find the edit button, but the last par...   Apr 19 2014, 20:20
- - /mnt   @ gir404 Thanks for information on your affected ...   Apr 21 2014, 18:10
- - gir404   Thank you for the fix! If I'm using a thi...   Apr 21 2014, 20:09
RSS Lo-Fi Version Time is now: 30th July 2015 - 03:44
