LAME, CBR, VBR,.... I'm confused!
Immo
post Mar 26 2003, 19:51
Hi!
This is my first post on this board, and the reason why I'm posting is to find an explanation for one particular, interesting issue of LAME MP3 compression...
I took a sample from a live instrumental concert with clear high-frequency sounds. I compressed it with two different settings, using LAME 3.91.
-b 192 -m j -h -q 0 (= 192kbps constant, joint stereo, quality-optimised, max. quality) and
--alt-preset standard, which produced a slightly larger file, the bitrate averaging at 200kbps.
The results were both quite good and I couldn't tell the difference in sound - maybe I lack the equipment.
I performed a spectral frequency analysis on each of the results.
Here's what it looked like:
Let's look at the left image: the frequency meter suggests thet there's a sharp cut at 16kHz. Nevertheless, some sounds are given higher frequencies, but then there is another sharp cut just under 19kHz, above which nothing can be seen.
Now the right image: up to about 16kHz the frequencies are generally preserved. Then they gradually become thinner in a varying manner, depending, i suppose, on their importance. There is no sharp cut below ~19.8kHz.
I do not know much abot audio compression - maybe I'm misunderstanding the whole thing - so I'd like you to ask you first: which picture do you think corresponds to which compression method?
Immo
Oge_user
post Mar 28 2003, 10:52
A/V Moderator
QUOTE (Immo @ Mar 27 2003 - 12:08 PM)
I tried to use Lame 3.93.1 with the same CBR settings:  -b 192 -m j -q 0.
What do we see? In the 3.91 there is no clear cut at 16kHz, as opposed to 3.93.1, where we can distinguish a cut much better.
You used -q 0 for your test, and this setting cause quality problems on Lame.
Maybe you get those unexepted results because of -q 0.
Try to use -q 2 on both Lame 3.91 and 3.93.1 to see if it's the same problem.
[ Commodore 64 Forever...! ]
- Immo   LAME, CBR, VBR,.... I'm confused!   Mar 26 2003, 19:51
- - /\/ephaestous   YOU CANT' SAY SOMETHING SOUNDS BETTER BASED ON...   Mar 26 2003, 19:59
- - ff123   I'd say that --alt-preset standard is the pict...   Mar 26 2003, 20:46
- - evereux   QUOTE (/\/ephaestous @ Mar 26 2003 - 06:...   Mar 26 2003, 21:08
- - Pio2001   The left picture must be alt preset standard, beca...   Mar 26 2003, 21:12
- - outscape   i have to agree with /\/ephaestous on this.. ...   Mar 26 2003, 21:18
- - /\/ephaestous   QUOTE (evereux @ Mar 26 2003 - 03:08 PM)QUOTE...   Mar 26 2003, 21:21
- - Immo   Thanks for the replies, folks. All who guessed, g...   Mar 26 2003, 22:11
- - Andavari   QUOTE (Immo @ Mar 26 2003 - 03:11 PM)The poin...   Mar 26 2003, 22:38
- - [proxima]   QUOTE (Pio2001 @ Mar 26 2003 - 09:12 PM)-h -b...   Mar 26 2003, 23:11
- - LordSyl   Please, don't confuse newbies with those stupi...   Mar 26 2003, 23:54
- - Pio2001   Right, right, It started when I was about to write...   Mar 27 2003, 00:30
- - mithrandir   QUOTE (Immo @ Mar 26 2003 - 04:11 PM)A questi...   Mar 27 2003, 01:43
- - NeoRenegade   I just wanted to point out, Immo, that your comman...   Mar 27 2003, 06:46
- - Immo   Good afternoon, thanks for the tip, NeoRenegade, ...   Mar 27 2003, 13:08
- - Pio2001   QUOTE (Immo @ Mar 27 2003 - 03:08 PM)I suppos...   Mar 27 2003, 14:28
- - Immo   Sorry, you're right! What I meant was th...   Mar 27 2003, 15:12
- - Lev   /\/ephaestous: QUOTE YOU CANT' SAY SOMET...   Mar 27 2003, 17:36
- - Gecko   Immo: VBR isn't about preserving HF content. I...   Mar 27 2003, 17:58
- - Immo   Lev: it gets even more ironic when the author make...   Mar 27 2003, 18:39
- - deej_1977   QUOTE (Pio2001 @ Mar 27 2003 - 03:28 PM)Addin...   Mar 27 2003, 18:47
- - LordSyl   CBR is shit...always. The entire fact of giving th...   Mar 27 2003, 19:30
- - sony666   CBR is not "always shit", plz stay serio...   Mar 28 2003, 01:58
- - NeoRenegade   The lame development team works on the encoder and...   Mar 28 2003, 03:29
- - roman   To Immo About your 1st pictures... Can you think a...   Mar 28 2003, 08:38
- - Oge_user   QUOTE (Immo @ Mar 27 2003 - 12:08 PM)I tried ...   Mar 28 2003, 10:52
- - DigitalDictator   sony666 QUOTE If you plan to use your encodes for...   Mar 28 2003, 11:57
- - Immo   Roman: I guess ti prav explaining how VBR acts ...   Mar 28 2003, 19:12
- - Immo   Oge_user:I just tried it, the results weren't ...   Mar 28 2003, 19:25
- - sony666   QUOTE (DigitalDictator @ Mar 28 2003 - 11:57 ...   Mar 28 2003, 23:48
RSS Lo-Fi Version Time is now: 28th July 2015 - 15:11
