16 Pages V  « < 3 4 5 6 7 > »
foobar2000 DeskBand Controls, Windows deskband (taskbar toolbar) for controlling foobar2000
Nixdagibts
post Sep 11 2011, 14:49
Post #101
Question: Is it just implemented that Foobar2000 Deskband Controls 2 starts and closes automatically with foobar?
magic12kenneth
post Oct 6 2011, 03:01
Post #102
Thanks for this awsome addon. It works perfectly on Windows 7 32bit. I have a feature request. Can you implement the display time to static so it doesn't scroll along with the song title and artist?
Nordfinn
post Oct 6 2011, 06:24
Post #103
QUOTE (White_Shadow @ Sep 10 2011, 17:20) *
I've a little issue with the album art support:
(foobar2000 1.1.7, win7 x64, Deskband_2)
All worked fine just up to the point, where I've multiple album arts for one album. It is an album with 3 Disc and for each disc there is a cover. My album art seach pattern is
(something...)
As foobar searches in that order, it displays the file "album.jpg", when I select the whole album with multiple covers, and "cover_%discnumber%.jpg", when I select a single Track. Only Deskband won't do that. It displays my stub image instead. As I expect that the album art would be loaded via foobar, this seems quite strange to me.
Nordfinn
post Oct 6 2011, 06:34
Post #104
Thanks much for this. Got it going pretty quickly, and works well. Except: I too am having trouble with displaying album art. This is what I have for search pattern for front cover art in default ui preferences:
$ifequal($strcmp($left(%path%,5),http:),1,d:\foobar\radio.jpg,)
Only those that conform to the second line are showing up in DeskBand Controls. That is very few, the way I am set up. Almost all my art is defined by the first line (I have all album .cue files and jpegs named by album in one big Foobar folder).
I am running XP.
Anything to be done about this?
Thanks again,
Nordfinn
This post has been edited by Nordfinn: Oct 6 2011, 06:40
White_Shadow
post Oct 6 2011, 10:46
Post #105
I found the source of my album art issue: It happens (afaik) only, when there are embedded "icon"-Artworks. Deleting them solves the problem for playing mp3s.
Decalicatan_Deca...
post Oct 6 2011, 20:18
Post #106
QUOTE (magic12kenneth @ Oct 6 2011, 04:01) *
That would be great !
This static text zone, whose content would be defined with titleformatting in the preferences could be displayed instead of the seekbar for example.
Decalicatan Decalicatan
Nordfinn
post Oct 7 2011, 04:41
Post #107
Album art problem: Thanks much for this. Glad to have it. Works well, except that I, too, am having trouble displaying album art. The search pattern for cover art in my default UI is as follows:
The only parameter for which DeskBand displays the art is the second, but that is very little of my art the way I am set up. Most all of my jpegs are named by album and are in one big folder with .cue (by album) and .wav files (by album). (Strangely, DeskBand doesn't display the "stub" image for those, but rather an image that I can't identify or track down.)
Anything to be done? Any hints?
I am running XP.
Thanks much,
N.
(The third line search string above, by the way, came from a forum member who was looking to add art to radio streams.)
This post has been edited by Nordfinn: Oct 7 2011, 04:42
eldarien
post Oct 10 2011, 19:32
Post #108
You're welcome. And yes, this can be done - so, maybe in next version smile.gif
This post has been edited by eldarien: Oct 10 2011, 19:32
eldarien
post Oct 11 2011, 21:46
Post #109
QUOTE (Nordfinn @ Oct 7 2011, 06:41) *
I double-checked my code - everything is correct. This is limitation of foobar2000 API - it does not support configurable paths in album art exposed to plugins. Paths are hard-coded in foobar itself and there are two of them: "folder.jpg" and "cover.jpg". So, if you name your file folder.jpg or cover.jpg it will display in deskband. Nothing I can do here, sorry.
Possible solution is to embed album art inside media files, as this feature is present since foobar2000 v1.1.7
This post has been edited by eldarien: Oct 11 2011, 22:03
Nordfinn
post Oct 12 2011, 04:17
Post #110
Thanks very much for checking and for the cogent explanation.
N.
Scorpius666
post Dec 21 2011, 18:55
Post #111
This deskband works great but it has a really annoying bug that makes me crazy.
It's easy to reproduce: Create a playlist of shoutcast radio stations (like 5). Play the first one and then press the Next button in the deskband quickly several times. It *always* crashes.
The only workaround is to click Next, wait for the next shoutcast radio to get ready and start playing, and then press Next again, and so on until you get to the station you wanna listen to. It's a pain when you have a playlist of 20 stations and you just don't want to open the main foobar window.
It doesn't happen using the Next/Prev buttons of the foobar window, just with the deskbands.
It also doesn't happen with a normal playlist, it has to be internet radio stations.
Illegal operation:
Code: AA67913Ch, flags: 00000001h, address: 752BB9BCh
Bug check
Call path:
entry=>app_mainloop=>main_thread_callback::callback_run=>on_playback_new_track
This post has been edited by Scorpius666: Dec 21 2011, 18:57
eldarien
post Dec 24 2011, 12:17
Post #112
Hi Scorpius666. Thanks for the report, I will try to fix this issues.
_stranger_
post Dec 24 2011, 20:26
Post #113
Thank you for this excellent plugin!
However, sometimes it crashes foobar when i harass volume bar, but not often smile.gif
one suggestion:
- add saving/loading presets (drop-down list with save and load buttons instead of current preset buttons would be nice)
Regards
Scorpius666
post Dec 26 2011, 19:24
Post #114
QUOTE (eldarien @ Dec 24 2011, 07:17) *
Wow! That's great news!
I stopped using WinAMP and MediaMonkey just because this deskband exists for foobar. That should get you an idea of how awesome this deskband is!
eldarien
post Jan 3 2012, 22:55
Post #115
Happy new year to everyone!
Here's version 0.3 of Deskband Controls.
New stuff:
- new trackbars, more "media-player" style
- static text with title formatting support
- configuration presets
- fixed crush when user performs many frequent actions (changing volume, proceeding to next track a few times, etc.)
Download Deskband Controls
eldarien
post Jan 4 2012, 07:44
Post #116
Download Deskband Controls (Link 2)
adam777
post Jan 4 2012, 08:57
Post #117
Thanks for the new version.
Did you try to contact Peter about adding the component to the official repository?
This post has been edited by adam777: Jan 4 2012, 08:58
eldarien
post Jan 4 2012, 10:34
Post #118
Decalicatan_Deca...
post Jan 4 2012, 23:37
Post #119
Thanks again for your component, and the new stuffs are really great smile.gif
kraut
post Jan 5 2012, 07:17
Post #120
I downloaded the upgrade and loaded in the component panel,but now I cannot get it to work. The layout controls are all srewed up.
Even removing the new version and loading the previous one will not remedy the situation.
Help please.
I did unregister the old version, and registered the new on. Deskband shows up in the toolbar menu, but selecting it will not have it show up in the toolbar.
This post has been edited by kraut: Jan 5 2012, 07:58
eldarien
post Jan 5 2012, 08:08
Post #121
Hi kraut. Make sure that you updated both foobar plugin (foo_deskband_controls.dll) and deskband (deskband_controls.dll). Both must be uninstalled first (plugin must be removed from foobar). Note that explorer.exe should be restarted after you unregister deskband dll (you can kill it in task manager, then run it again from File - New Task...) You can also try to remove plugin configuration file (located at C:\Users\%USERNAME%\AppData\Roaming\foobar2000\configuration\foo_deskband_controls.dll.cfg). Then install new version, run foobar and open deskband panel (deskband is almost invisible when foobar is not opened). In configuration dialog select appropriate preset, click Load and then Apply.
This post has been edited by eldarien: Jan 5 2012, 08:14
kraut
post Jan 6 2012, 02:57
Post #122
Thanks, works now. Looks and works great. Excelllent plugin - should be part or foobar essentials.
_stranger_
post Jan 7 2012, 12:45
Post #123
QUOTE (eldarien @ Jan 3 2012, 23:55) *
New stuff:
Outstanding!
Thank you.
Scorpius666
post Jan 9 2012, 18:30
Post #124
QUOTE (eldarien @ Jan 3 2012, 17:55) *
New stuff:
Excellent!!! Thank you very much.
There's something I noticed: There's no width for Text1/Text2, that means the text always has to be at the right of the deskband. I can't put the text on the left and (let's say) the volume bar at the right of it because it creates a mess. Here's an example:
With a Width field for Text1 we would solve that, don't you think?
All the presets have Text1 at the right of the deskband so nobody notices it. Maybe I'm picky, but I think I got used to have the Text2 (the time) at the right of Text1 sad.gif
This post has been edited by Scorpius666: Jan 9 2012, 18:33
eldarien
post Jan 9 2012, 18:52
Post #125
QUOTE (Scorpius666 @ Jan 9 2012, 19:30) *
Yeah, that was by design from the start. I'll add width to both text strings, no problems smile.gif
RSS Lo-Fi Version Time is now: 24th May 2015 - 19:36
