foobar2000 DeskBand Controls, Windows deskband (taskbar toolbar) for controlling foobar2000
eldarien
post Jan 27 2010, 22:46
Hi everybody!
This is foobar2000 Deskband Controls plugin. You can see what it does from screenshots below.
Current version is 1.1.2. Bugreports and suggestions are very welcome.
Changelog:
October 8 2014
* Version 1.1.2
- Fix for taskbar not appearing in auto-hide mode when cursor is placed over deskband controls
October 2 2014
* Version 1.1.1
- Fix crush for some album art data
April 10 2014
* Version 1.1
- Default button colorization color set to transparent (a bug when at first start buttons were black)
- Fix a crush when using alpha channel in floating window background color. Use Opacity setting instead.
- Fix text not drawing in WindowsXP
+ Album Art Preserve aspect ratio option
+ Added link to hydrogenaudio forum topic in foobar plugin about window
+ Hide trackbar borders option
+ Trackbars background color support
Settings window screenshots:
http://img109.imageshack.us/img109/968/exxl.png
http://img10.imageshack.us/img10/6131/vesd.png
http://img10.imageshack.us/img10/5352/es5n.png
http://img689.imageshack.us/img689/5272/ud0x.png
http://img202.imageshack.us/img202/40/4rbd.png
http://img22.imageshack.us/img22/8287/svjt.png
Supported operating systems are Windows XP, Vista, Windows 7, Windows 8 and 8.1.
Please read readme.txt for install instructions.
Download: https://dl.dropboxusercontent.com/u/374593/...ControlsNET.zip
Oh, and if you think that your setup is awesome - feel free to save it as profile and share with us! (Profiles are saved in %AppData%\DeskbandControls\Profiles folder)
This post has been edited by eldarien: Oct 8 2014, 19:28
Reason for edit: adding mirrored link as per post #210
eldarien
post Jan 28 2010, 16:23
QUOTE (Pickaxe @ Jan 28 2010, 10:53) *
can you also make a side-by-side version (buttons on the left, track info on the right) for people who use small icons for the taskbar?
Yes
QUOTE (garbanzo.bean @ Jan 28 2010, 13:20) *
scrolling text
open/close with foobar
button to show foobar
[paused] notification
also might be nice also to have a buttons-only version.
Technically all this is possible, but for some features (like cover art) there must be separate part as a foobar plugin. Maybe I will be able to remove foo_winamp_spam from dependencies in this case...
QUOTE (Squeller @ Jan 28 2010, 16:37) *
Thanks. Can I limit it's width? A user defined tagz string would be nice.
Minimum width is hardcoded to 200px. It will be configurable in next versions.
What do you mean by "tagz"? Is this foobar title formatting tags, like %artist%?
Anyway, you can chage string format in foo_winamp_spam settings.
- eldarien   foobar2000 DeskBand Controls   Jan 27 2010, 22:46
- - Andreasvb   Can't seem to get it to work in Windows 7 x64....   Jan 28 2010, 00:08
- - Helgi   Thank you. I don't think it needs a seek bar ...   Jan 28 2010, 00:41
- - Andreasvb   @Helgi No, what would that have anything do to wit...   Jan 28 2010, 01:00
- - Keesface   I like it. Couple of improvements (if possible): ...   Jan 28 2010, 01:18
- - Helgi   QUOTE (Andreasvb @ Jan 28 2010, 00:00) @H...   Jan 28 2010, 02:07
- - odyssey   I would love to use such thing like this - Problem...   Jan 28 2010, 02:20
- - Andreasvb   It would surprise me if it would be required for i...   Jan 28 2010, 02:20
- - RavenSoft   running x64 here with foo_vis_shpeck and foo_winam...   Jan 28 2010, 03:04
- - eldarien   QUOTE (Andreasvb @ Jan 28 2010, 02:00) It...   Jan 28 2010, 07:37
|- - cerAmik   Your component looks promising. I support all the...   Jan 28 2010, 17:18
- - Pickaxe   Just a request for the next version: can you also ...   Jan 28 2010, 09:53
|- - garbanzo.bean   very cool. working great for me in x86. i have n...   Jan 28 2010, 12:20
- - Squeller   Thanks. Can I limit it's width? A user defined...   Jan 28 2010, 15:37
- - eldarien   QUOTE (Pickaxe @ Jan 28 2010, 10:53) can ...   Jan 28 2010, 16:23
- - RavenSoft   any updates to this plug-in? hope you haven't ...   Feb 2 2010, 03:58
- - eldarien   QUOTE (RavenSoft @ Feb 2 2010, 04:58) any...   Feb 2 2010, 08:11
- - Pickaxe   If you don't mind, can you also make a version...   Feb 2 2010, 19:59
- - DonnieBrasco   Hi, I`m new in this forum I have two simpl...   Feb 3 2010, 13:19
- - eldarien   QUOTE (Pickaxe @ Feb 2 2010, 20:59) If yo...   Feb 3 2010, 13:43
- - DonnieBrasco   Great! I'll wait the new version! Than...   Feb 3 2010, 14:21
- - eldarien   New build is available. Download it here. Changelo...   Feb 10 2010, 22:35
- - Keesface   Nice, thanks. I managed to install it in one go an...   Feb 10 2010, 23:51
- - cerAmik   Great! Keep up the good work. With an autohid...   Feb 11 2010, 03:01
- - TomBarlow   I have found that explorer crashes if you change t...   Feb 11 2010, 09:47
- - eldarien   QUOTE (TomBarlow @ Feb 11 2010, 10:47) I ...   Feb 11 2010, 10:55
|- - TomBarlow   QUOTE (eldarien @ Feb 11 2010, 09:55) Thi...   Feb 11 2010, 16:45
- - DonnieBrasco   It does not work... I put the ini file in the C:...   Feb 12 2010, 09:16
- - eldarien   QUOTE (DonnieBrasco @ Feb 12 2010, 10:16)...   Feb 12 2010, 11:00
- - DonnieBrasco   Already done, but it does not work... I created th...   Feb 12 2010, 11:17
- - Andreasvb   It should be loaded from the foobar2000's conf...   Feb 12 2010, 11:20
- - TomBarlow   It should be [Options] instead of [Options-] or Op...   Feb 12 2010, 11:26
- - DonnieBrasco   Thanks, but [Options], [Options-] or Options- is t...   Feb 12 2010, 11:57
- - Pickaxe   Okay this new update is much better. I am enjoying...   Feb 13 2010, 16:49
- - abernauer   Looking forward to using this - it looks great. I...   Feb 17 2010, 06:47
- - eldarien   QUOTE (abernauer @ Feb 17 2010, 07:47) Wh...   Feb 17 2010, 07:45
|- - abernauer   QUOTE (eldarien @ Feb 16 2010, 22:45) QUO...   Feb 18 2010, 07:52
- - Fractal_Mortality   Anyway to currently remap the controls? I prefer t...   Feb 17 2010, 19:01
- - Keesface   I can't get my settings changed at all... i us...   Feb 18 2010, 01:06
- - eldarien   QUOTE (Keesface @ Feb 18 2010, 02:06) I c...   Feb 18 2010, 07:42
|- - Keesface   QUOTE (eldarien @ Feb 18 2010, 07:42) QUO...   Feb 18 2010, 13:02
- - eldarien   QUOTE (Keesface @ Feb 18 2010, 14:02) The...   Feb 18 2010, 15:26
|- - Keesface   QUOTE (eldarien @ Feb 18 2010, 15:26) QUO...   Feb 18 2010, 15:48
- - DonnieBrasco   What do you think about a different color for the ...   Feb 24 2010, 16:29
- - Audionut   Any eta and a 64bit compatible version?   Mar 7 2010, 04:15
|- - adam777   QUOTE (Audionut @ Mar 6 2010, 22:15) Any ...   Mar 9 2010, 13:42
|- - goldenfingaz   QUOTE (adam777 @ Mar 9 2010, 07:42) QUOTE...   Mar 9 2010, 21:35
- - servimo   This is my Deskband.ini file, it is on "%appd...   Mar 7 2010, 19:38
- - shevchenic   Seems a very nice component~ But i am running on 6...   Mar 10 2010, 19:19
- - eldarien   Hey guys! Here is x64 version (link is the sam...   Mar 10 2010, 21:40
|- - shevchenic   QUOTE (eldarien @ Mar 10 2010, 12:40) Hey...   Mar 11 2010, 08:07
- - netvalker   When I try to register the library, this error pop...   Mar 10 2010, 22:25
|- - eldarien   QUOTE (netvalker @ Mar 10 2010, 23:25) Wh...   Mar 10 2010, 22:30
|- - netvalker   I must be tired. A wonderful plugin. Regards.   Mar 10 2010, 22:43
- - adam777   Hi eldarien, First of all, great work on the x64 v...   Mar 11 2010, 11:00
|- - IvoP123   QUOTE (adam777 @ Mar 11 2010, 11:00) The ...   Mar 11 2010, 11:48
- - BrutuZ   Ok people, i spent a little time making a installe...   Mar 13 2010, 03:05
|- - adam777   QUOTE (BrutuZ @ Mar 12 2010, 21:05) Ok pe...   Mar 17 2010, 19:23
|- - BrutuZ   QUOTE (adam777 @ Mar 17 2010, 15:23) Perh...   Apr 2 2010, 00:29
- - proneax   Great plugin -- this really makes foobar usable fo...   Mar 17 2010, 15:04
- - Shaun1   Can the toolbar be set to open and close along wit...   Apr 1 2010, 23:38
- - BrutuZ   Ok, i added the .zip thingy, now if you have a fil...   Apr 2 2010, 01:39
- - veenone   great plugin BrutuZ! I really like it!   Apr 2 2010, 04:03
|- - BrutuZ   QUOTE (veenone @ Apr 2 2010, 00:03) great...   Apr 2 2010, 06:13
- - fusen   definitely should add a seekbar   Apr 2 2010, 04:29
- - neothe0ne   Is it possible to configure what buttons show up? ...   Apr 3 2010, 23:29
- - BrutuZ   QUOTE (fusen @ Apr 2 2010, 00:29) definit...   Apr 4 2010, 00:17
- - Fractal_Mortality   Any plans on further updating this? I'd really...   Apr 20 2010, 23:13
- - Shaun1   Would really love some updates on this as well, lo...   Apr 21 2010, 06:59
- - BrutuZ   QUOTE (Shaun1 @ Apr 21 2010, 02:59) 2) Th...   Apr 21 2010, 08:12
|- - Shaun1   Sorry, I forgot to mention I'm using XP which ...   Apr 21 2010, 10:51
- - einfallslos   QUOTE (Shaun1 @ Apr 21 2010, 07:59) 1) Mo...   Apr 21 2010, 10:05
|- - Shaun1   I understand that, just saying it would be nice if...   Apr 21 2010, 10:53
- - herojoker   Perhaps code from foo_title could be reused to mak...   Apr 21 2010, 22:59
- - DarkJedii   Any updates? I would hate to see such a wonderful ...   Aug 31 2010, 22:25
- - proneax   still loving this plugin, but I"m pretty sure...   May 12 2011, 06:10
- - eldarien   Hi. Is anyone still interested in this plugin? I a...   Jun 27 2011, 09:22
- - adam777   I would love to see a new version. I can't rem...   Jun 28 2011, 08:36
- - eldarien   Hello everybody. I just finished a new version. Pl...   Jul 12 2011, 23:15
|- - Sandrine   QUOTE (eldarien @ Jul 13 2011, 00:15) Hel...   Jul 13 2011, 08:28
- - adam777   Thank you very much for the new version. A few iss...   Jul 13 2011, 21:42
|- - Sandrine   QUOTE (adam777 @ Jul 13 2011, 22:42) - Af...   Jul 13 2011, 23:57
- - lumaan   Love it   Jul 14 2011, 00:40
- - kraut   Excellent plugin. With the WM popup display you ha...   Jul 14 2011, 01:53
- - eldarien   QUOTE (adam777 @ Jul 13 2011, 22:42) - My...   Jul 14 2011, 07:18
- - adam777   QUOTE (Sandrine @ Jul 13 2011, 16:57) QUO...   Jul 14 2011, 08:01
- - eldarien   QUOTE (adam777 @ Jul 14 2011, 09:01) One ...   Jul 14 2011, 08:51
- - adam777   Hello eldarien, Here's the sample with Hebrew ...   Jul 17 2011, 10:37
- - eldarien   Here is version 0.2.1. Yay! ** Known issue...   Jul 19 2011, 20:52
- - adam777   Wow! 0.2.1 works beautifully, automatic scr...   Jul 20 2011, 08:10
- - aeidein   Great work! Suggestions: * Custom text / pl...   Jul 22 2011, 20:57
|- - adam777   QUOTE (aeidein @ Jul 22 2011, 14:57) Grea...   Jul 23 2011, 11:16
|- - aeidein   QUOTE (adam777 @ Jul 23 2011, 05:16) QUOT...   Jul 25 2011, 17:30
- - eldarien   My server may be offline quite often (it's hom...   Jul 22 2011, 21:17
- - vaga8ondxwr   I have taskbar on the side so my configuration nee...   Jul 24 2011, 06:51
- - Rarn   Great component! It'd be nice if you coul...   Jul 26 2011, 22:00
- - VortX   Awesome! I had been searching for something l...   Aug 24 2011, 12:15
- - adam777   Does anyone have the ZIP file of the latest versio...   Aug 25 2011, 08:23
|- - adam777   QUOTE (adam777 @ Aug 25 2011, 01:23) Does...   Aug 25 2011, 13:51
- - White_Shadow   I've a little issue with the album art support...   Sep 10 2011, 22:20
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 29th May 2015 - 18:30
