foobar2000 DeskBand Controls, Windows deskband (taskbar toolbar) for controlling foobar2000
eldarien
post Jan 27 2010, 22:46
Hi everybody!
This is foobar2000 Deskband Controls plugin. You can see what it does from screenshots below.
Current version is 1.1.2. Bugreports and suggestions are very welcome.
Changelog:
October 8 2014
* Version 1.1.2
- Fix for taskbar not appearing in auto-hide mode when cursor is placed over deskband controls
October 2 2014
* Version 1.1.1
- Fix crush for some album art data
April 10 2014
* Version 1.1
- Default button colorization color set to transparent (a bug when at first start buttons were black)
- Fix a crush when using alpha channel in floating window background color. Use Opacity setting instead.
- Fix text not drawing in WindowsXP
+ Album Art Preserve aspect ratio option
+ Added link to hydrogenaudio forum topic in foobar plugin about window
+ Hide trackbar borders option
+ Trackbars background color support
Settings window screenshots:
http://img109.imageshack.us/img109/968/exxl.png
http://img10.imageshack.us/img10/6131/vesd.png
http://img10.imageshack.us/img10/5352/es5n.png
http://img689.imageshack.us/img689/5272/ud0x.png
http://img202.imageshack.us/img202/40/4rbd.png
http://img22.imageshack.us/img22/8287/svjt.png
Supported operating systems are Windows XP, Vista, Windows 7, Windows 8 and 8.1.
Please read readme.txt for install instructions.
Download: https://dl.dropboxusercontent.com/u/374593/...ControlsNET.zip
Oh, and if you think that your setup is awesome - feel free to save it as profile and share with us! (Profiles are saved in %AppData%\DeskbandControls\Profiles folder)
This post has been edited by eldarien: Oct 8 2014, 19:28
Reason for edit: adding mirrored link as per post #210
eldarien
post Feb 12 2010, 11:00
QUOTE (DonnieBrasco @ Feb 12 2010, 10:16) *
It does not work...
I put the ini file in the C:\Winprog\Foobar2000\Configuration folder (portable mode) and this is my custom ini file:
But the configurations are not loaded, I have always the seekbar and the text.
I deleted the unwanted lines from deskband.ini, is it correct?
Why configurations are not loaded?
It is loaded only from %appdata%/foobar2000/configuration
If this folder does not exists (because of portable mode), create it and it will work.
On win 7 it's here: c:\Users\%UserName%\AppData\Roaming\foobar2000\configuration\
You can run this command in command line to see exact location: echo %appdata%
This post has been edited by eldarien: Feb 12 2010, 11:02
- eldarien   foobar2000 DeskBand Controls   Jan 27 2010, 22:46
- - Andreasvb   Can't seem to get it to work in Windows 7 x64....   Jan 28 2010, 00:08
- - Helgi   Thank you. I don't think it needs a seek bar ...   Jan 28 2010, 00:41
- - Andreasvb   @Helgi No, what would that have anything do to wit...   Jan 28 2010, 01:00
- - Keesface   I like it. Couple of improvements (if possible): ...   Jan 28 2010, 01:18
- - Helgi   QUOTE (Andreasvb @ Jan 28 2010, 00:00) @H...   Jan 28 2010, 02:07
- - odyssey   I would love to use such thing like this - Problem...   Jan 28 2010, 02:20
- - Andreasvb   It would surprise me if it would be required for i...   Jan 28 2010, 02:20
- - RavenSoft   running x64 here with foo_vis_shpeck and foo_winam...   Jan 28 2010, 03:04
- - eldarien   QUOTE (Andreasvb @ Jan 28 2010, 02:00) It...   Jan 28 2010, 07:37
|- - cerAmik   Your component looks promising. I support all the...   Jan 28 2010, 17:18
- - Pickaxe   Just a request for the next version: can you also ...   Jan 28 2010, 09:53
|- - garbanzo.bean   very cool. working great for me in x86. i have n...   Jan 28 2010, 12:20
- - Squeller   Thanks. Can I limit it's width? A user defined...   Jan 28 2010, 15:37
- - eldarien   QUOTE (Pickaxe @ Jan 28 2010, 10:53) can ...   Jan 28 2010, 16:23
- - RavenSoft   any updates to this plug-in? hope you haven't ...   Feb 2 2010, 03:58
- - eldarien   QUOTE (RavenSoft @ Feb 2 2010, 04:58) any...   Feb 2 2010, 08:11
- - Pickaxe   If you don't mind, can you also make a version...   Feb 2 2010, 19:59
- - DonnieBrasco   Hi, I`m new in this forum I have two simpl...   Feb 3 2010, 13:19
- - eldarien   QUOTE (Pickaxe @ Feb 2 2010, 20:59) If yo...   Feb 3 2010, 13:43
- - DonnieBrasco   Great! I'll wait the new version! Than...   Feb 3 2010, 14:21
- - eldarien   New build is available. Download it here. Changelo...   Feb 10 2010, 22:35
- - Keesface   Nice, thanks. I managed to install it in one go an...   Feb 10 2010, 23:51
- - cerAmik   Great! Keep up the good work. With an autohid...   Feb 11 2010, 03:01
- - TomBarlow   I have found that explorer crashes if you change t...   Feb 11 2010, 09:47
- - eldarien   QUOTE (TomBarlow @ Feb 11 2010, 10:47) I ...   Feb 11 2010, 10:55
|- - TomBarlow   QUOTE (eldarien @ Feb 11 2010, 09:55) Thi...   Feb 11 2010, 16:45
- - DonnieBrasco   It does not work... I put the ini file in the C:...   Feb 12 2010, 09:16
- - eldarien   QUOTE (DonnieBrasco @ Feb 12 2010, 10:16)...   Feb 12 2010, 11:00
- - DonnieBrasco   Already done, but it does not work... I created th...   Feb 12 2010, 11:17
- - Andreasvb   It should be loaded from the foobar2000's conf...   Feb 12 2010, 11:20
- - TomBarlow   It should be [Options] instead of [Options-] or Op...   Feb 12 2010, 11:26
- - DonnieBrasco   Thanks, but [Options], [Options-] or Options- is t...   Feb 12 2010, 11:57
- - Pickaxe   Okay this new update is much better. I am enjoying...   Feb 13 2010, 16:49
- - abernauer   Looking forward to using this - it looks great. I...   Feb 17 2010, 06:47
- - eldarien   QUOTE (abernauer @ Feb 17 2010, 07:47) Wh...   Feb 17 2010, 07:45
|- - abernauer   QUOTE (eldarien @ Feb 16 2010, 22:45) QUO...   Feb 18 2010, 07:52
- - Fractal_Mortality   Anyway to currently remap the controls? I prefer t...   Feb 17 2010, 19:01
- - Keesface   I can't get my settings changed at all... i us...   Feb 18 2010, 01:06
- - eldarien   QUOTE (Keesface @ Feb 18 2010, 02:06) I c...   Feb 18 2010, 07:42
|- - Keesface   QUOTE (eldarien @ Feb 18 2010, 07:42) QUO...   Feb 18 2010, 13:02
- - eldarien   QUOTE (Keesface @ Feb 18 2010, 14:02) The...   Feb 18 2010, 15:26
|- - Keesface   QUOTE (eldarien @ Feb 18 2010, 15:26) QUO...   Feb 18 2010, 15:48
- - DonnieBrasco   What do you think about a different color for the ...   Feb 24 2010, 16:29
- - Audionut   Any eta and a 64bit compatible version?   Mar 7 2010, 04:15
|- - adam777   QUOTE (Audionut @ Mar 6 2010, 22:15) Any ...   Mar 9 2010, 13:42
|- - goldenfingaz   QUOTE (adam777 @ Mar 9 2010, 07:42) QUOTE...   Mar 9 2010, 21:35
- - servimo   This is my Deskband.ini file, it is on "%appd...   Mar 7 2010, 19:38
- - shevchenic   Seems a very nice component~ But i am running on 6...   Mar 10 2010, 19:19
- - eldarien   Hey guys! Here is x64 version (link is the sam...   Mar 10 2010, 21:40
|- - shevchenic   QUOTE (eldarien @ Mar 10 2010, 12:40) Hey...   Mar 11 2010, 08:07
- - netvalker   When I try to register the library, this error pop...   Mar 10 2010, 22:25
|- - eldarien   QUOTE (netvalker @ Mar 10 2010, 23:25) Wh...   Mar 10 2010, 22:30
|- - netvalker   I must be tired. A wonderful plugin. Regards.   Mar 10 2010, 22:43
- - adam777   Hi eldarien, First of all, great work on the x64 v...   Mar 11 2010, 11:00
|- - IvoP123   QUOTE (adam777 @ Mar 11 2010, 11:00) The ...   Mar 11 2010, 11:48
- - BrutuZ   Ok people, i spent a little time making a installe...   Mar 13 2010, 03:05
|- - adam777   QUOTE (BrutuZ @ Mar 12 2010, 21:05) Ok pe...   Mar 17 2010, 19:23
|- - BrutuZ   QUOTE (adam777 @ Mar 17 2010, 15:23) Perh...   Apr 2 2010, 00:29
- - proneax   Great plugin -- this really makes foobar usable fo...   Mar 17 2010, 15:04
- - Shaun1   Can the toolbar be set to open and close along wit...   Apr 1 2010, 23:38
- - BrutuZ   Ok, i added the .zip thingy, now if you have a fil...   Apr 2 2010, 01:39
- - veenone   great plugin BrutuZ! I really like it!   Apr 2 2010, 04:03
|- - BrutuZ   QUOTE (veenone @ Apr 2 2010, 00:03) great...   Apr 2 2010, 06:13
- - fusen   definitely should add a seekbar   Apr 2 2010, 04:29
- - neothe0ne   Is it possible to configure what buttons show up? ...   Apr 3 2010, 23:29
- - BrutuZ   QUOTE (fusen @ Apr 2 2010, 00:29) definit...   Apr 4 2010, 00:17
- - Fractal_Mortality   Any plans on further updating this? I'd really...   Apr 20 2010, 23:13
- - Shaun1   Would really love some updates on this as well, lo...   Apr 21 2010, 06:59
- - BrutuZ   QUOTE (Shaun1 @ Apr 21 2010, 02:59) 2) Th...   Apr 21 2010, 08:12
|- - Shaun1   Sorry, I forgot to mention I'm using XP which ...   Apr 21 2010, 10:51
- - einfallslos   QUOTE (Shaun1 @ Apr 21 2010, 07:59) 1) Mo...   Apr 21 2010, 10:05
|- - Shaun1   I understand that, just saying it would be nice if...   Apr 21 2010, 10:53
- - herojoker   Perhaps code from foo_title could be reused to mak...   Apr 21 2010, 22:59
- - DarkJedii   Any updates? I would hate to see such a wonderful ...   Aug 31 2010, 22:25
- - proneax   still loving this plugin, but I"m pretty sure...   May 12 2011, 06:10
- - eldarien   Hi. Is anyone still interested in this plugin? I a...   Jun 27 2011, 09:22
- - adam777   I would love to see a new version. I can't rem...   Jun 28 2011, 08:36
- - eldarien   Hello everybody. I just finished a new version. Pl...   Jul 12 2011, 23:15
|- - Sandrine   QUOTE (eldarien @ Jul 13 2011, 00:15) Hel...   Jul 13 2011, 08:28
- - adam777   Thank you very much for the new version. A few iss...   Jul 13 2011, 21:42
|- - Sandrine   QUOTE (adam777 @ Jul 13 2011, 22:42) - Af...   Jul 13 2011, 23:57
- - lumaan   Love it   Jul 14 2011, 00:40
- - kraut   Excellent plugin. With the WM popup display you ha...   Jul 14 2011, 01:53
- - eldarien   QUOTE (adam777 @ Jul 13 2011, 22:42) - My...   Jul 14 2011, 07:18
- - adam777   QUOTE (Sandrine @ Jul 13 2011, 16:57) QUO...   Jul 14 2011, 08:01
- - eldarien   QUOTE (adam777 @ Jul 14 2011, 09:01) One ...   Jul 14 2011, 08:51
- - adam777   Hello eldarien, Here's the sample with Hebrew ...   Jul 17 2011, 10:37
- - eldarien   Here is version 0.2.1. Yay! ** Known issue...   Jul 19 2011, 20:52
- - adam777   Wow! 0.2.1 works beautifully, automatic scr...   Jul 20 2011, 08:10
- - aeidein   Great work! Suggestions: * Custom text / pl...   Jul 22 2011, 20:57
|- - adam777   QUOTE (aeidein @ Jul 22 2011, 14:57) Grea...   Jul 23 2011, 11:16
|- - aeidein   QUOTE (adam777 @ Jul 23 2011, 05:16) QUOT...   Jul 25 2011, 17:30
- - eldarien   My server may be offline quite often (it's hom...   Jul 22 2011, 21:17
- - vaga8ondxwr   I have taskbar on the side so my configuration nee...   Jul 24 2011, 06:51
- - Rarn   Great component! It'd be nice if you coul...   Jul 26 2011, 22:00
- - VortX   Awesome! I had been searching for something l...   Aug 24 2011, 12:15
- - adam777   Does anyone have the ZIP file of the latest versio...   Aug 25 2011, 08:23
|- - adam777   QUOTE (adam777 @ Aug 25 2011, 01:23) Does...   Aug 25 2011, 13:51
- - White_Shadow   I've a little issue with the album art support...   Sep 10 2011, 22:20
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 28th May 2015 - 06:05
