APT-X
slenpree
post Jan 27 2010, 12:16
see www.aptx.com
this company really annoys me because although they claim APT-X to be so great (near lossless @ 128kbps) there is little evidence to support this claim due to their proprietary nature and hardware focus. Their main codec seems to be common in hardware ISDN codecs due to low delay which suggests low complexity.
All in all I would like to give these folks a chance, they might have some very intelegent (and expensive) sound scientists backing the project. It's come the time where I would like to do some blind listening tests with this codec because with all the focus on MP3 ( and even AAC ) I doubt I will be blown away when comparing it a 128kbps MP3.
However I can't find an APT-X software codec for foobar, or at all. With all the game codec packs for foobar I was quite suprised not to see APT-X as it's been about for quite a while. Perhaps I'm just not looking hard enough and need to use the chinese google. If anyone could save my alot of time and point out the foo_input_aptx component that would be greatly appreciated.
Kind Regards,
Jonathan
skamp
post Jan 29 2010, 07:30
dtrainor: do you know of any Bluetooth emitter + receiver set that makes use of apt-X, where the emitter can be plugged into a 1/8" jack (regular audio output) and where a pair of wired headphones can be plugged into the receiver?
I was looking into apt-X after I found out just how much SBC sucked but couldn't find a practical solution.
dtrainor
post Jan 29 2010, 11:31
QUOTE (skamp @ Jan 29 2010, 06:30) *
That's a good question. I believe that Sennheiser produced (or is the process of producing) an apt-X Bluetooth emitter that plugs into a 1/8" jack that is compatible with their apt-X Bluetooth headphones (PX 210 BT and PXC 310 BT, currently). However I don't seem to be able to find any online availability for this emitter and their website only mentions the iPod and USB versions. AFAIK there isn't an apt-X Bluetooth receiver with a conventional headphone socket currently available. However, we are working directly with a company on a product that will have this capability. It's probably a few months away from commercial release.
Regards,
David
atlantic
post Jun 27 2011, 15:05
QUOTE (dtrainor @ Jan 29 2010, 11:31) *
Regards,
David
Hi David,
Can you tell more about this apt-X Bluetooth receiver with a conventional headphone socket? Has it been released by now?
I'm looking for an apt-X Bluetooth capable receiver that could be used with my mobile audio setup (audio fed from mobile phone to IEMs). The receiver would have to be battery powered and relatively lightweight. The upcoming Nokia N9 transmits apt-X Bluetooth.
Best Regards,
atlantic
dtrainor
post Jul 13 2011, 11:15
QUOTE (atlantic @ Jun 27 2011, 14:05) *
Regards,
David
Hi David,
Best Regards,
atlantic
Atlantic,
There have been a few Bluetooth receivers released with apt-X capability that connect to conventional audio equipment using RCA phono / 3.5 mm jack. One is the QED uplay mentioned by Pri3st in a previous post. Another is the Chordette Gem from Chord Electronics
http://www.chordelectronics.co.uk/products-info.asp?id=53
Note that neither of these receivers are battery-powered nor do they have a direct headphone out, so I guess they're still not exactly what you wanted for your original application.
Regards,
David
- slenpree   APT-X   Jan 27 2010, 12:16
- - smack   Look at the documents available at the download se...   Jan 27 2010, 16:18
- - slenpree   thanks for pointing me in the right direction smac...   Jan 27 2010, 16:58
|- - smack   QUOTE (slenpree @ Jan 27 2010, 16:58) Doe...   Jan 27 2010, 17:23
- - dtrainor   As someone who works for APTX, hopefully I can she...   Jan 27 2010, 17:17
|- - pdq   QUOTE (dtrainor @ Jan 27 2010, 12:17) For...   Jan 27 2010, 18:45
|- - Woodinville   QUOTE (dtrainor @ Jan 27 2010, 08:17) sma...   Jan 27 2010, 20:32
|- - lbbrhzn   QUOTE (Woodinville @ Jan 27 2010, 20:32) ...   Oct 1 2010, 16:20
|- - saratoga   QUOTE (lbbrhzn @ Oct 1 2010, 11:20) QUOTE...   Oct 1 2010, 16:30
- - slenpree   thanks smack, i'll give that a go later and re...   Jan 27 2010, 19:08
|- - dtrainor   QUOTE (slenpree @ Jan 27 2010, 18:08) Con...   Jan 27 2010, 23:01
||- - smallicoat   QUOTE (dtrainor @ Jan 27 2010, 14:01) QUO...   Sep 9 2010, 22:09
||- - lbbrhzn   QUOTE (dtrainor @ Jan 27 2010, 23:01) QUO...   Oct 1 2010, 16:25
|- - smack   QUOTE (slenpree @ Jan 27 2010, 19:08) UPD...   Jan 28 2010, 09:53
|- - dtrainor   QUOTE (smack @ Jan 28 2010, 08:53) No, a ...   Jan 28 2010, 11:20
- - Garf   Sounds like the area in which CELT is competing, t...   Jan 27 2010, 20:54
|- - dtrainor   QUOTE (Garf @ Jan 27 2010, 19:54) Sounds ...   Jan 27 2010, 23:10
- - skamp   dtrainor: do you know of any Bluetooth emitter + r...   Jan 29 2010, 07:30
|- - dtrainor   QUOTE (skamp @ Jan 29 2010, 06:30) dtrain...   Jan 29 2010, 11:31
|- - skamp   QUOTE (dtrainor @ Jan 29 2010, 11:31) How...   Jan 29 2010, 17:26
||- - dtrainor   QUOTE (skamp @ Jan 29 2010, 16:26) Thanks...   Jan 29 2010, 20:46
|- - atlantic   QUOTE (dtrainor @ Jan 29 2010, 11:31) AFA...   Jun 27 2011, 15:05
|- - dtrainor   QUOTE (atlantic @ Jun 27 2011, 14:05) QUO...   Jul 13 2011, 11:15
- - jmvalin   As far as I understand (but I could be wrong), the...   Feb 23 2010, 00:16
|- - slenpree   QUOTE (jmvalin @ Feb 22 2010, 23:16) As f...   Jul 11 2010, 23:19
- - smartfinder   Hi all, I like the codecs long ago, I would like t...   Jun 19 2010, 21:38
- - Pri3st   This is the only receiver that I have found. It ha...   Jun 27 2011, 15:35
- - Serge Smirnoff   I wonder if there any possibility to save decoded ...   Jul 8 2013, 13:12
- - beng   Hi, Could someone please answer this one: the Sams...   Sep 20 2013, 10:20
|- - beng   QUOTE (beng @ Sep 20 2013, 11:20) Hi, Cou...   Oct 1 2013, 21:18
- - saratoga   If you want to hack ROMs, XDA would be a better pl...   Oct 2 2013, 00:33
RSS Lo-Fi Version Time is now: 30th March 2015 - 10:50
