18 Pages V  « < 11 12 13 14 15 > »
qtaacenc: a command-line QuickTime AAC encoder for Windows
dB
post Sep 3 2011, 15:58
Post #301
QUOTE (DARcode @ Sep 3 2011, 13:59) *
QUOTE (lvqcl @ Sep 3 2011, 11:49) *
About portability: according to procmon.exe, qtaacenc loads the following DLLs:
but only 4 of them (CoreAudioToolbox.dll, CoreGraphics.dll, CoreVideo.dll, QTCF.dll) can be loaded from qtaacenc.exe folder.
Anything can be done qtaacenc side please?
QUOTE (lvqcl @ Sep 3 2011, 16:06) *
QuickTime DLLs require MSVC 2005 redist installed. Adding msvcp80.dll and msvcr80.dll to qtaacenc folder doesn't work. Any way to override it?
nao
post Sep 3 2011, 16:42
Post #302
I guess the DLL path is resolved from the registry values (InstallDir, QTSysDir, QTComponentsDir, etc) in
  • HKEY_LOCAL_MACHINE\SOFTWARE\Apple Inc.\Apple Application Support
  • HKEY_LOCAL_MACHINE\SOFTWARE\Apple Computer, Inc.\QuickTime
QUOTE (lvqcl @ Sep 3 2011, 23:06) *
They are SxS (side-by-side) DLL. I'm not sure but maybe .manifest file will do.
lvqcl
post Sep 3 2011, 16:53
Post #303
It seems that portable QT AAC encoding is possible. All you need is:
* modified qtaacenc.exe
* msvcr100.dll (for qtaacenc.exe)
* msvcr80.dll, msvcp80.dll, Microsoft.VC80.CRT.manifest (for QT)
testing...
b66pak
post Sep 3 2011, 17:10
Post #304
QUOTE (lvqcl @ Sep 2 2011, 20:38) *
I wonder is it possible to add --remix option (similar to 'remix' effect in SoX) to qtaacenc / qaac itself? unsure.gif
qaac's dev just did it...
_
Boulder
post Sep 3 2011, 18:43
Post #305
QUOTE (DARcode @ Sep 3 2011, 14:59) *
QUOTE (Boulder @ Sep 3 2011, 13:16) *
So which version of the coreaudiotoolbox.dll should I use to avoid any fatal problems? I'm usually encoding stereo material at TVBR Q60-80 (not that it matters much since there's only three steps in bitrate level, it seems).
Probs can't be considered fatal, anyway with that target quality you are well above the bit rates (namely 80-96-112 Kbps) at which the QuickTime CoreAudioToolbox.dll library previous to version 7.6.9 have the lowpass bug, therefore if you prefer like IgorC and me higher bit rates at the same quality level you can safely use CoreAudioToolbox.dll v7.9.3.0.
Does this bug occur always at those bitrates? I do see them from time to time, especially when encoding a stereo file which is actually dual mono.
DARcode
post Sep 3 2011, 18:47
Post #306
Group: Members (Donating)
QUOTE (lvqcl @ Sep 3 2011, 17:53) *
testing...
You coming up with the modded qtaacenc yourself?
QUOTE (Boulder @ Sep 3 2011, 19:43) *
Seems so, my 3 tests posted here confirm it, but you can test yourself of course.
WavPack 4.75.0 -b384hx6cmv/qaac 2.49 -V 100
lvqcl
post Sep 3 2011, 18:55
Post #307
Anyone want to test QT portable encoder?
1. Download and install QuickTime 7.7.
2. Download archive from http://www.multiupload.com/U2CTT7YOD0. It contains modified versions of qtaacenc and qaac.
3. Unpack it to some folder.
4. Go to this folder and click on runme.cmd. It will copy all necessary files from QuickTime folders.
5. Delete runme.cmd (it's not necessary anymore), delete "(src)" folder (it contains source files).
6. Uninstall QuickTime.
7. Try to encode files with qtaacenc or qaac.
This post has been edited by lvqcl: Sep 5 2011, 16:52
b66pak
post Sep 3 2011, 20:06
Post #308
i had to add:
copy "%ProgramFiles%\Common Files\Apple\Apple Application Support\icudt40.dll" .\
copy "%ProgramFiles%\Common Files\Apple\Apple Application Support\icuin40.dll" .\
copy "%ProgramFiles%\Common Files\Apple\Apple Application Support\icuuc40.dll" .\
to the runme.cmd to make it work for me...
_
lvqcl
post Sep 3 2011, 20:13
Post #309
I use QuickTime 7.7, and it doesn't have icudt40.dll, only icudt46.dll. Probably different versions of QuickTime require different set of files. Not a big surprise though.
And thanks for testing.
b66pak
post Sep 3 2011, 20:33
Post #310
may be this will cover all the versions...
copy "%ProgramFiles%\Common Files\Apple\Apple Application Support\icu*.dll" .\
copy "%ProgramFiles%\Common Files\Apple\Apple Application Support\lib*.dll" .\
_
dispatcher7007
post Sep 3 2011, 21:55
Post #311
I tried to use qtaacenc.exe operated by foobar2000, just like explained here, but it doesnt want to work properly. QT 7.7 is installed.
When encoding a 6channel .dts (fb2k-dts-plugin installed), it starts encoding, runs for a while, and then crashes (repeatedly at the same point, the produced file is playable) with the following error:
1 out of 1 tracks converted with major problems.
Source: "path\to\foo.dts"
  An error occurred while writing to file (The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters) : "path\to\bar.m4a"
  Additional information:
  Encoder stream format: 48000Hz / 6ch / 24bps
  Command line: "path\to\qtaacenc.exe" --tvbr 100 --highest - "bar.m4a"
  Working folder: Path\to\folder
  Conversion failed: The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters
@writing error: Theres plenty of HDD-Space on a sane disk.
When using NeroAACenc.exe, things work out fine, so the source is supposedly okay...
Anybody got a hint for me?
Greets,
dis
lvqcl
post Sep 3 2011, 22:01
Post #312
1. add --ignorelength option and try again.
2. About multichannel encoding:
http://www.hydrogenaudio.org/forums/index....st&p=768029
http://www.hydrogenaudio.org/forums/index....st&p=768093
lvqcl
post Sep 3 2011, 22:49
Post #313
It seems that I was wrong about samplerates:
Encoding to --cvbr 64 kbps: iTunes and qtaacenc create 32kHz .m4a file, while qaac preserve 44.1 kHz.
Encoding to --tvbr 46: the same difference between qaac and qtaacenc.
dispatcher7007
post Sep 4 2011, 08:33
Post #314
--ingnorelength resolves the crash! Thanks!
Still I`m a bit confused about this "channel mapping issue".
On MediaInfo both give me the same result: "Front: L C R, Side: L R, LFE" Is that internally screwed up?
I don't have the possibilities to test it right now, because my laptop is 2.0, and I don't know any software for that.
greets, Dis
lvqcl
post Sep 4 2011, 08:40
Post #315
Spectrogram in foobar2000. Right-click - Channels - Unchanged.
dispatcher7007
post Sep 4 2011, 09:13
Post #316
well, that doesnt seem messed up... Its a speech only scene without music, so LFE is dead there...
dts orig left vs qtaac right
johnb
post Sep 4 2011, 17:41
Post #317
QUOTE (lvqcl @ Sep 3 2011, 22:49) *
Just for my understanding: when going to low bitrates with a lowpass of 15.7kHz, why would you want to keep a sample rate of 44.1 kHz.? Is the downsampling buggy?
subinbar
post Sep 5 2011, 01:32
Post #318
QUOTE (DARcode @ Sep 2 2011, 11:23) *
QUOTE (johnb @ Sep 2 2011, 12:18) *
Sorry, but I am confused:
Which dll respectively which encoder versions do we want:
Using QuickTime 7.7.0 (LC-AAC encoder 1.7.2, HE-AAC encoder 1.2.1) == dll 7.9.3.0
or
Using QuickTime 7.7.0 (LC-AAC encoder 1.7.1, HE-AAC encoder 1.2.0) == dll 7.9.3.3
Depends on the quality level you want to use, if you go for a bit rate unaffected by the lowpass bug like I'm doing you may prefer the earlier version of the DLL with the higher version of the encoders which produce higher bit rates, see IgorC's clarifications.
If you could clarify - which versions produce the higher bitrate files, and which versions produces the lower bitrate files? And about how much bitrate difference is there between the two?
Currently I use 7.9.3 for Multichannel (because of channels bug on newer versions) and 7.9.7.7 for stereo (because of earlier versions's lowpass bug).
DARcode
post Sep 5 2011, 10:53
Post #319
QUOTE (johnb @ Sep 4 2011, 18:41) *
I'd be interested in knowing too, I simply wanted to know how to keep this encoder's behavior consistent with it's siblings.
QUOTE (lvqcl @ Sep 3 2011, 19:55) *
Anyone want to test QT portable encoder?[...]
Worked perfectly copying the necessary from a QT 7.7 installation and then using your qtaacenc on a QT-less system, thank you!
nao would you be OK with integrating the necessary code by lvql into the official build?
QUOTE (subinbar @ Sep 5 2011, 02:32) *
Didn't wanna take the time to take a look just two pages back eh?
As advised by IgorC and confirmed by my MediaInfo copy/paste's CoreAudioToolbox library v7.9.3.0 produces higher bit rates.
This post has been edited by DARcode: Sep 5 2011, 11:09
subinbar
post Sep 5 2011, 11:06
Post #320
QUOTE (DARcode @ Sep 5 2011, 10:53) *
thanks, I missed that. Looks like around 5-10% higher bitrate.
dB
post Sep 5 2011, 16:17
Post #321
2. Download archive from http://www.multiupload.com/-----.
db1989
post Sep 5 2011, 16:24
Post #322
Yes, because it was edited out:
This post has been edited by lvqcl: Today, 15:51
Perhaps it is out of date, but you would have to wait for a reply from lvqcl.
lvqcl
post Sep 5 2011, 16:55
Post #323
I found serious bug in my code. New version is uploaded, link in post #307 updated.
dB
post Sep 5 2011, 17:01
Post #324
QUOTE (lvqcl @ Sep 5 2011, 17:55) *
radio42
post Sep 6 2011, 15:15
Post #325
Any chance to add support for STDOUT to qtaacenc (i.e. specify '-' as the output file)?
This might be useful if you want to 'stream' ACC to a network...e.g. a SHOUTcast server...
Would that be possible with QT - or is it only possible to set QT to a physical outout file?
RSS Lo-Fi Version Time is now: 1st September 2015 - 19:49
