Closed TopicStart new topic
Bug: Notification area icon behaviour in foobar2000 1.0
Dandruff
post Jan 20 2010, 14:49
There's a bug with the Notification area icon in foobar2000 1.0:
My Preferences:
- "Always show notification area icon" disabled
- "Minimize to notification area" enabled
-> start foobar2000
=> Notification area icon visible. Shouln't be visible! Switching to a different application (or just clicking on the Desktop) fixes it. Didn't happen with older versions!
hsn
post Feb 8 2010, 18:14
i want to disable the tray icon and i want to disable "minimize to notification area".
my settings:
- "Minimize to notification area" disabled
but i always get the notification area icon and foobar is always minimized to the tray.
my installation:
- portable Foobar2000 v1.0
- Windows 7 32 bit
This post has been edited by hsn: Feb 8 2010, 18:15
Yirkha
post Feb 15 2010, 11:27
Group: FB2K Moderator
Yes, this will be fixed in the next version.
Dandruff
post Mar 8 2010, 09:43
QUOTE (Dandruff @ Jan 20 2010, 14:49) *
My Preferences:
-> start foobar2000
Not fixed in 1.0.1! Exactly the same behaviour.
Yirkha
post Mar 8 2010, 13:57
Yeah. Not funny.
Dandruff
post Mar 8 2010, 14:56
QUOTE (Yirkha @ Mar 8 2010, 13:57) *
Yeah. Not funny.
postED
post Mar 18 2010, 00:57
Is it a bug in 1.0.1?
1) Minimize to notification area disabled
When I press minimize, working set in process foobar.exe changed from ~10 mb to 4,5 mb (can find in ProcessExplorer)
2) Minimize to notification area enabled
When I press minimize, working set in process foobar.exe still ~10 mb and didn't change
in 0.9.x working set changed always.
Portable 1.0.1, components - foo_run, foo_playcount, foo_input_monkey, foo_uie_wsh_panel_mod. OS - WinXP SP3
This post has been edited by postED: Mar 18 2010, 01:01
Dandruff
post Mar 18 2010, 01:04
QUOTE (postED @ Mar 18 2010, 00:57) *
Confirmed. Indeed strange.
Snowknight26
post Mar 18 2010, 03:17
So the other thread doesn't get lost in the depths of the forums:
Having any child form visible while 'Minimize to notification area' is checked makes it so that when foobar2000 is minimized, the child form stays visible.
nimd4
post Mar 22 2010, 21:06
QUOTE (Dandruff @ Mar 8 2010, 15:56) *
Yeah. Not funny.
Z68A-G43*i7-3770*Ven. 2x4GB 2133MHz*WD 1TB 64MB SATA*Win7 Pro/64
Snowknight26
post Apr 10 2010, 23:41
I guess (hope) most of these will be fixed in 1.0.3?
Dandruff
post Apr 11 2010, 15:31
Issue Post #1 is fixed for me in 1.0.2.1! The working set issue in Post #7 isn't!
kode54
post Apr 11 2010, 19:18
Group: Admin
Reducing the working set when minimizing is a feature that went away with Vista. And the fact that minimizing to the notification area doesn't reduce the working set in XP is because the window isn't actually minimized, but hidden, and the code in XP to reduce the working set seems to be in the default system command handler for minimizing, which is overridden for the minimize to notification area effect.
It would be possible to work around the issue just for XP users, but what is the point? Paging out a few megabytes of memory that aren't relevant to playback alone?
A minor change is going in to change how the window is minimized to the notification area, to fix an issue with hiding child windows such as Preferences or the Playlist Search. This may or may not "fix" the working set reduction "issue" with Windows XP systems.
Dandruff
post Apr 11 2010, 20:19
Ok. I have no problem with that. Just strange that it obviously was working in 0.9 versions. Other applications I've tested still can do it too when minimizing to system tray ...
Dandruff
post Apr 30 2010, 15:46
Post #15
FIXED (1.0.3)
Snowknight26
post May 4 2010, 03:42
Post #16
Fixed at the expense of other issues, yeah. :\
RSS Lo-Fi Version Time is now: 27th May 2015 - 17:13
