MP3s generated with dbpoweramp not gapless
dancrocker
post Jan 15 2010, 23:58
I hope this is the right forum and that this topic hasn't been beaten to death. I apologize if I'm wrong on either of these. I searched but didn't find the answer I was looking for. Of course, the amount of info here is a bit overwhelming smile.gif
I used dbpoweramp to rip to FLAC, then generate 320kbit CBR MP3s. ITunes plays them gaplessly as does foobar2000. However, my iPod (5th generation) does not. There's a teeny "gap" (more like a glitch). My iPhone 3G doesn't play them gaplessly either although the "gap" is more like a click. Meanwhile, MP3s generated by iTunes play on the iPod perfectly.
I know, years ago, there was a lot of noise about apple not supporting gapless. But, I thought this was all resolved. Certainly, it appears to work fine if the MP3s are encoded with iTunes.
Is this a well-known problem? I found some other posts that seemed to say that LAME encoded MP3s (which is what dbpoweramp uses) play gaplessly on iPods. So, I'm puzzled as to while I'm having this trouble. I'd appreciate any help or suggestions.
kornchild2002
post Jan 18 2010, 05:13
Well, figuring out if you were being too picky would mean that there isn't anything technically wrong with your iPod. As I said, this helped with someone else. The device may not be performing as you like but at least we could determine if it was operating normally.
Try restoring it first, re-syncing the content, and then listening to it again (don't fast forward through the songs). The issue isn't with Lame. I and many others can attest to this. I even have Lame 3.90.3 files that playback gaplessly.
dancrocker
post Jan 18 2010, 23:47
QUOTE (kornchild2002 @ Jan 17 2010, 23:13) *
A question for you and others:
When you say your files play gaplessly, are you saying that the transition between tracks is perfect and flawless? If it isn't, then this is what I'm encountering. If it is, then this is what I'm trying to achieve.
Anyways, I performed the following experiments with the indicated results (some I have done before but I repeated them to confirm):
1. Restore iPod
No improvement in playback
2. Rip and MP3 encode with iTunes
Perfect playback. It's impossible to tell where one track ends and the next begins just by listening. In my opinion, this is the way it should be. There's no good reason, again in my opinion, to settle for anything less.
3. Rip and MP3 encode with MAX
Glitch between tracks
4. Rip to ALAC and MP3 encode with MAX
5. Rip to ALAC and MP3 encode with dbpoweramp
6. Rip to FLAC and MP3 encode with dbpoweramp
In all cases, the MP3s played flawlessly in iTunes but, in the cases indicated, weren't quite right when played with the iPod.
I haven't yet tried the WAV comparison suggestion by someone else, but I will.
Conclusions based on my observations:
-The LAME encoding is working fine and is putting the right data into the file to enable proper gapless playback. I believe this because foobar2000 plays the files perfectly
-iTunes properly interprets the header data and plays the files perfectly
-My iPod either does not properly use the header data or has some other issue with LAME encoded MP3s that prevents them from being played gaplessly
-The iTunes MP3 encoder does something different than LAME in order to allow the iPod to play the files perfectly
At this point, I'm wondering if the issue is not strictly related to gapless, but to some other characteristic of the LAME files.
garym
post Jan 18 2010, 23:53
QUOTE (dancrocker @ Jan 18 2010, 17:47) *
In my case, my LAME mp3 files have a "perfect and flawless" (your words) transition between tracks 99.9% of the time. And I've actually tried hard to detect a glitch in transition, with headphones, etc. I will say that once in a while, I'll get a glitch when transitioning, usually a function of transitioning between a 30 minute song (e.g., grateful dead, dark star) and the following song. But I can go back and play song again and with the same exact songs, the transition is perfect. Then again, once in a while, I get a glitch in the middle of a song. These I chalk up to the ipod reloading its cache or something odd. It is a computer after all and is reading data from a harddrive.
- dancrocker   MP3s generated with dbpoweramp not gapless   Jan 15 2010, 23:58
- - kornchild2002   I have thousands of Lame mp3 files on my 120GB iPo...   Jan 16 2010, 00:08
|- - dancrocker   QUOTE (kornchild2002 @ Jan 15 2010, 18:08...   Jan 16 2010, 00:16
|- - kornchild2002   QUOTE (dancrocker @ Jan 15 2010, 16:16) I...   Jan 16 2010, 03:21
|- - dancrocker   QUOTE (kornchild2002 @ Jan 15 2010, 21:21...   Jan 16 2010, 18:30
|- - maggior   QUOTE (dancrocker @ Jan 16 2010, 13:30) T...   Jan 19 2010, 21:15
|- - garym   QUOTE (maggior @ Jan 19 2010, 15:15) I...   Jan 19 2010, 21:22
|- - dancrocker   QUOTE (maggior @ Jan 19 2010, 15:15) QUOT...   Jan 20 2010, 04:53
|- - lukpac   QUOTE (dancrocker @ Jan 19 2010, 21:53) I...   Jul 11 2012, 20:15
|- - lukpac   Bump?   Oct 15 2013, 03:20
- - Teknojnky   its the 'force iso compatibility' option. ...   Jan 16 2010, 00:35
|- - dancrocker   QUOTE (Teknojnky @ Jan 15 2010, 18:35) it...   Jan 16 2010, 00:38
- - maggior   Are you using a paid for version of dbPowerAmp or ...   Jan 16 2010, 03:37
|- - dancrocker   QUOTE (maggior @ Jan 15 2010, 21:37) Are ...   Jan 16 2010, 18:34
|- - garym   Do you have replaygain turned on (or SOUNDCHECK in...   Jan 16 2010, 20:07
|- - dancrocker   QUOTE (garym @ Jan 16 2010, 14:07) Do you...   Jan 16 2010, 23:41
- - spoon   >dbPowerAmp or the free version? The free versi...   Jan 16 2010, 11:35
|- - dancrocker   QUOTE (spoon @ Jan 16 2010, 05:35) >db...   Jan 16 2010, 18:25
|- - maggior   QUOTE (spoon @ Jan 16 2010, 06:35) >db...   Jan 19 2010, 21:04
- - kornchild2002   Would you be willing to upload a 30 second sample ...   Jan 17 2010, 03:37
|- - dancrocker   QUOTE (kornchild2002 @ Jan 16 2010, 21:37...   Jan 17 2010, 06:43
- - kornchild2002   We could determine if the gap is really an issue o...   Jan 17 2010, 08:33
|- - dancrocker   QUOTE (kornchild2002 @ Jan 17 2010, 02:33...   Jan 18 2010, 05:08
|- - 2Bdecided   QUOTE (kornchild2002 @ Jan 17 2010, 07:33...   Jan 18 2010, 10:39
|- - garym   can't help here but just to note that I have 1...   Jan 18 2010, 15:18
|- - kornchild2002   QUOTE (2Bdecided @ Jan 18 2010, 02:39) I ...   Jan 18 2010, 17:33
|- - 2Bdecided   QUOTE (kornchild2002 @ Jan 18 2010, 16:33...   Jan 19 2010, 07:51
|- - DonP   QUOTE (kornchild2002 @ Jan 18 2010, 11:33...   Jan 19 2010, 13:41
|- - kornchild2002   QUOTE (DonP @ Jan 19 2010, 05:41) Less th...   Jan 19 2010, 15:45
|- - DonP   QUOTE (kornchild2002 @ Jan 19 2010, 09:45...   Jan 19 2010, 16:35
|- - kornchild2002   QUOTE (DonP @ Jan 19 2010, 08:35) OK... l...   Jan 19 2010, 19:08
|- - garym   for the record, my mp3 files that work properly (g...   Jan 19 2010, 20:53
- - kornchild2002   Well, figuring out if you were being too picky wou...   Jan 18 2010, 05:13
|- - dancrocker   QUOTE (kornchild2002 @ Jan 17 2010, 23:13...   Jan 18 2010, 23:47
|- - garym   QUOTE (dancrocker @ Jan 18 2010, 17:47) A...   Jan 18 2010, 23:53
|- - dancrocker   QUOTE (garym @ Jan 18 2010, 17:53) QUOTE ...   Jan 19 2010, 01:00
|- - garym   I recall that you said you are creating "320k...   Jan 19 2010, 01:08
- - spoon   On one of the tracks which has problems: Re-Rip t...   Jan 18 2010, 17:56
|- - dancrocker   QUOTE (spoon @ Jan 18 2010, 11:56) On one...   Jan 19 2010, 01:49
|- - dancrocker   QUOTE (dancrocker @ Jan 18 2010, 19:49) Q...   Jan 19 2010, 02:27
- - Case   Little off topic but I can't let kornchild2002...   Jan 18 2010, 20:03
- - greynol   If the tracks are protected by copyright, then yes...   Jan 19 2010, 01:57
- - kornchild2002   Well, just to try to further help you, I have trie...   Jan 19 2010, 02:47
|- - dancrocker   QUOTE (kornchild2002 @ Jan 18 2010, 20:47...   Jan 19 2010, 03:26
|- - kornchild2002   QUOTE (dancrocker @ Jan 18 2010, 19:26) T...   Jan 19 2010, 06:01
- - dancrocker   I decided to play around with the command line ver...   Jan 19 2010, 05:11
- - greynol   The --nogap option is really old and pretty much u...   Jan 19 2010, 06:31
|- - dancrocker   QUOTE (greynol @ Jan 19 2010, 00:31) The ...   Jan 19 2010, 07:37
|- - robert   @dancrocker Do you add tags like APE or an additio...   Jan 19 2010, 13:37
||- - dancrocker   QUOTE (robert @ Jan 19 2010, 07:37) @danc...   Jan 20 2010, 04:36
|- - DonP   QUOTE (dancrocker @ Jan 19 2010, 01:37) I...   Jan 19 2010, 13:44
|- - greynol   QUOTE (DonP @ Jan 19 2010, 04:44) The opt...   Jan 19 2010, 16:42
- - greynol   Nope, though I have no idea what the problem is wi...   Jan 19 2010, 07:40
- - spoon   I might be wrong but I am sure that iTunes determi...   Jan 19 2010, 10:07
|- - greynol   QUOTE (spoon @ Jan 19 2010, 02:07) I migh...   Oct 15 2013, 13:56
|- - lukpac   QUOTE (greynol @ Oct 15 2013, 06:56) I ha...   Oct 15 2013, 14:02
- - kornchild2002   As I have said, iTunes scans my Lame mp3 files dur...   Jan 20 2010, 20:49
|- - greynol   QUOTE (kornchild2002 @ Jan 20 2010, 11:49...   Jan 20 2010, 20:55
|- - garym   QUOTE (greynol @ Jan 20 2010, 14:55) QUOT...   Jan 20 2010, 21:15
|- - kornchild2002   QUOTE (greynol @ Jan 20 2010, 12:55) So w...   Jan 20 2010, 22:13
|- - dancrocker   QUOTE (kornchild2002 @ Jan 20 2010, 16:13...   Jan 20 2010, 23:22
- - kornchild2002   Just make sure that you aren't playing music w...   Jan 20 2010, 23:37
|- - dancrocker   QUOTE (kornchild2002 @ Jan 20 2010, 17:37...   Jan 21 2010, 17:42
- - kornchild2002   Not necessarily. For example, back when the Nero ...   Jan 21 2010, 18:52
|- - dancrocker   QUOTE (kornchild2002 @ Jan 21 2010, 12:52...   Jan 21 2010, 20:02
|- - dancrocker   QUOTE (dancrocker @ Jan 21 2010, 14:02) Q...   Jan 24 2010, 01:20
- - kornchild2002   Ooops, I didn't see your reply. Did you delet...   Jan 27 2010, 17:31
|- - dancrocker   QUOTE (kornchild2002 @ Jan 27 2010, 11:31...   Feb 1 2010, 20:15
- - greynol   The gapless information used by the iPod is not wh...   Feb 1 2010, 20:20
- - kornchild2002   Right. In my experience, it helps to delete the s...   Feb 1 2010, 23:52
- - probedb   Create a new thread, you're bumping a thread t...   Oct 15 2013, 13:33
- - greynol   Bumping is better than creating a new thread. Ple...   Oct 15 2013, 13:50
- - greynol   Restarting iTunes initiates the scan. It happens e...   Oct 15 2013, 14:05
RSS Lo-Fi Version Time is now: 30th July 2015 - 06:08
