MP3s generated with dbpoweramp not gapless
dancrocker
post Jan 15 2010, 23:58
I hope this is the right forum and that this topic hasn't been beaten to death. I apologize if I'm wrong on either of these. I searched but didn't find the answer I was looking for. Of course, the amount of info here is a bit overwhelming smile.gif
I used dbpoweramp to rip to FLAC, then generate 320kbit CBR MP3s. ITunes plays them gaplessly as does foobar2000. However, my iPod (5th generation) does not. There's a teeny "gap" (more like a glitch). My iPhone 3G doesn't play them gaplessly either although the "gap" is more like a click. Meanwhile, MP3s generated by iTunes play on the iPod perfectly.
I know, years ago, there was a lot of noise about apple not supporting gapless. But, I thought this was all resolved. Certainly, it appears to work fine if the MP3s are encoded with iTunes.
Is this a well-known problem? I found some other posts that seemed to say that LAME encoded MP3s (which is what dbpoweramp uses) play gaplessly on iPods. So, I'm puzzled as to while I'm having this trouble. I'd appreciate any help or suggestions.
kornchild2002
post Jan 20 2010, 20:49
As I have said, iTunes scans my Lame mp3 files during the import process. I can even take iTunes mp3 or iTunes AAC files from one computer, copy them to another, and iTunes on that system will scan for gapless playback. The scanning always occurs regardless of the encoder or ripper. I also don't think that iTunes stores the gapless playback information in a separate file, I know this. Many of us (on a different set of forums) have been observing iTunes' behavior for years. It stores non-embedded album artwork, gapless playback information, playlists, ratings, and various other aspects all in a separate file from the lossy files. There is something wrong if iTunes is not scanning your files for gapless playback. Seeing anything regarding volume means that you have Sound Check enabled.
The first step would be to disable Sound Check, delete the files from your iTunes library, restart iTunes, and import the files back in. Gapless tag/medata or not, iTunes will still scan the files. I suggest that you delete all of the problematic tracks from your iTunes library, restart iTunes, and then add them again. You should see the "scanning for gapless playback" message when importing over 15 files.
greynol
post Jan 20 2010, 20:55
QUOTE (kornchild2002 @ Jan 20 2010, 11:49) *
So which is it?
This post has been edited by greynol: Jan 20 2010, 20:55
kornchild2002
post Jan 20 2010, 22:13
QUOTE (greynol @ Jan 20 2010, 12:55) *
So which is it?
It is both. My first statement is poorly worded. I should have said "I know that iTunes stores gapless playback information in a separate file." I was trying to show that dan's statement of "some people think" should have actually been "people know." So basically I was saying that I don't "think" iTunes stores all of that information in a separate file, I know that iTunes stores that information in a separate file. Bad wording on my part, sorry about that.
- dancrocker   MP3s generated with dbpoweramp not gapless   Jan 15 2010, 23:58
- - kornchild2002   I have thousands of Lame mp3 files on my 120GB iPo...   Jan 16 2010, 00:08
|- - dancrocker   QUOTE (kornchild2002 @ Jan 15 2010, 18:08...   Jan 16 2010, 00:16
|- - kornchild2002   QUOTE (dancrocker @ Jan 15 2010, 16:16) I...   Jan 16 2010, 03:21
|- - dancrocker   QUOTE (kornchild2002 @ Jan 15 2010, 21:21...   Jan 16 2010, 18:30
|- - maggior   QUOTE (dancrocker @ Jan 16 2010, 13:30) T...   Jan 19 2010, 21:15
|- - garym   QUOTE (maggior @ Jan 19 2010, 15:15) I...   Jan 19 2010, 21:22
|- - dancrocker   QUOTE (maggior @ Jan 19 2010, 15:15) QUOT...   Jan 20 2010, 04:53
|- - lukpac   QUOTE (dancrocker @ Jan 19 2010, 21:53) I...   Jul 11 2012, 20:15
|- - lukpac   Bump?   Oct 15 2013, 03:20
- - Teknojnky   its the 'force iso compatibility' option. ...   Jan 16 2010, 00:35
|- - dancrocker   QUOTE (Teknojnky @ Jan 15 2010, 18:35) it...   Jan 16 2010, 00:38
- - maggior   Are you using a paid for version of dbPowerAmp or ...   Jan 16 2010, 03:37
|- - dancrocker   QUOTE (maggior @ Jan 15 2010, 21:37) Are ...   Jan 16 2010, 18:34
|- - garym   Do you have replaygain turned on (or SOUNDCHECK in...   Jan 16 2010, 20:07
|- - dancrocker   QUOTE (garym @ Jan 16 2010, 14:07) Do you...   Jan 16 2010, 23:41
- - spoon   >dbPowerAmp or the free version? The free versi...   Jan 16 2010, 11:35
|- - dancrocker   QUOTE (spoon @ Jan 16 2010, 05:35) >db...   Jan 16 2010, 18:25
|- - maggior   QUOTE (spoon @ Jan 16 2010, 06:35) >db...   Jan 19 2010, 21:04
- - kornchild2002   Would you be willing to upload a 30 second sample ...   Jan 17 2010, 03:37
|- - dancrocker   QUOTE (kornchild2002 @ Jan 16 2010, 21:37...   Jan 17 2010, 06:43
- - kornchild2002   We could determine if the gap is really an issue o...   Jan 17 2010, 08:33
|- - dancrocker   QUOTE (kornchild2002 @ Jan 17 2010, 02:33...   Jan 18 2010, 05:08
|- - 2Bdecided   QUOTE (kornchild2002 @ Jan 17 2010, 07:33...   Jan 18 2010, 10:39
|- - garym   can't help here but just to note that I have 1...   Jan 18 2010, 15:18
|- - kornchild2002   QUOTE (2Bdecided @ Jan 18 2010, 02:39) I ...   Jan 18 2010, 17:33
|- - 2Bdecided   QUOTE (kornchild2002 @ Jan 18 2010, 16:33...   Jan 19 2010, 07:51
|- - DonP   QUOTE (kornchild2002 @ Jan 18 2010, 11:33...   Jan 19 2010, 13:41
|- - kornchild2002   QUOTE (DonP @ Jan 19 2010, 05:41) Less th...   Jan 19 2010, 15:45
|- - DonP   QUOTE (kornchild2002 @ Jan 19 2010, 09:45...   Jan 19 2010, 16:35
|- - kornchild2002   QUOTE (DonP @ Jan 19 2010, 08:35) OK... l...   Jan 19 2010, 19:08
|- - garym   for the record, my mp3 files that work properly (g...   Jan 19 2010, 20:53
- - kornchild2002   Well, figuring out if you were being too picky wou...   Jan 18 2010, 05:13
|- - dancrocker   QUOTE (kornchild2002 @ Jan 17 2010, 23:13...   Jan 18 2010, 23:47
|- - garym   QUOTE (dancrocker @ Jan 18 2010, 17:47) A...   Jan 18 2010, 23:53
|- - dancrocker   QUOTE (garym @ Jan 18 2010, 17:53) QUOTE ...   Jan 19 2010, 01:00
|- - garym   I recall that you said you are creating "320k...   Jan 19 2010, 01:08
- - spoon   On one of the tracks which has problems: Re-Rip t...   Jan 18 2010, 17:56
|- - dancrocker   QUOTE (spoon @ Jan 18 2010, 11:56) On one...   Jan 19 2010, 01:49
|- - dancrocker   QUOTE (dancrocker @ Jan 18 2010, 19:49) Q...   Jan 19 2010, 02:27
- - Case   Little off topic but I can't let kornchild2002...   Jan 18 2010, 20:03
- - greynol   If the tracks are protected by copyright, then yes...   Jan 19 2010, 01:57
- - kornchild2002   Well, just to try to further help you, I have trie...   Jan 19 2010, 02:47
|- - dancrocker   QUOTE (kornchild2002 @ Jan 18 2010, 20:47...   Jan 19 2010, 03:26
|- - kornchild2002   QUOTE (dancrocker @ Jan 18 2010, 19:26) T...   Jan 19 2010, 06:01
- - dancrocker   I decided to play around with the command line ver...   Jan 19 2010, 05:11
- - greynol   The --nogap option is really old and pretty much u...   Jan 19 2010, 06:31
|- - dancrocker   QUOTE (greynol @ Jan 19 2010, 00:31) The ...   Jan 19 2010, 07:37
|- - robert   @dancrocker Do you add tags like APE or an additio...   Jan 19 2010, 13:37
||- - dancrocker   QUOTE (robert @ Jan 19 2010, 07:37) @danc...   Jan 20 2010, 04:36
|- - DonP   QUOTE (dancrocker @ Jan 19 2010, 01:37) I...   Jan 19 2010, 13:44
|- - greynol   QUOTE (DonP @ Jan 19 2010, 04:44) The opt...   Jan 19 2010, 16:42
- - greynol   Nope, though I have no idea what the problem is wi...   Jan 19 2010, 07:40
- - spoon   I might be wrong but I am sure that iTunes determi...   Jan 19 2010, 10:07
|- - greynol   QUOTE (spoon @ Jan 19 2010, 02:07) I migh...   Oct 15 2013, 13:56
|- - lukpac   QUOTE (greynol @ Oct 15 2013, 06:56) I ha...   Oct 15 2013, 14:02
- - kornchild2002   As I have said, iTunes scans my Lame mp3 files dur...   Jan 20 2010, 20:49
|- - greynol   QUOTE (kornchild2002 @ Jan 20 2010, 11:49...   Jan 20 2010, 20:55
|- - garym   QUOTE (greynol @ Jan 20 2010, 14:55) QUOT...   Jan 20 2010, 21:15
|- - kornchild2002   QUOTE (greynol @ Jan 20 2010, 12:55) So w...   Jan 20 2010, 22:13
|- - dancrocker   QUOTE (kornchild2002 @ Jan 20 2010, 16:13...   Jan 20 2010, 23:22
- - kornchild2002   Just make sure that you aren't playing music w...   Jan 20 2010, 23:37
|- - dancrocker   QUOTE (kornchild2002 @ Jan 20 2010, 17:37...   Jan 21 2010, 17:42
- - kornchild2002   Not necessarily. For example, back when the Nero ...   Jan 21 2010, 18:52
|- - dancrocker   QUOTE (kornchild2002 @ Jan 21 2010, 12:52...   Jan 21 2010, 20:02
|- - dancrocker   QUOTE (dancrocker @ Jan 21 2010, 14:02) Q...   Jan 24 2010, 01:20
- - kornchild2002   Ooops, I didn't see your reply. Did you delet...   Jan 27 2010, 17:31
|- - dancrocker   QUOTE (kornchild2002 @ Jan 27 2010, 11:31...   Feb 1 2010, 20:15
- - greynol   The gapless information used by the iPod is not wh...   Feb 1 2010, 20:20
- - kornchild2002   Right. In my experience, it helps to delete the s...   Feb 1 2010, 23:52
- - probedb   Create a new thread, you're bumping a thread t...   Oct 15 2013, 13:33
- - greynol   Bumping is better than creating a new thread. Ple...   Oct 15 2013, 13:50
- - greynol   Restarting iTunes initiates the scan. It happens e...   Oct 15 2013, 14:05
RSS Lo-Fi Version Time is now: 2nd September 2015 - 06:31
