samples where aps or ape has a problem
2Bdecided
post Mar 24 2003, 17:01
ReplayGain developer
I'm sure this has been asked before, but I can't find it, and it's not in the FAQ (it should be - please!)
On which samples is --alt-preset extreme audibly better than --alt-preset standard.
On which samples is --alt-preset insane audibly better than --alt-preset extreme.
On which samples is --alt-preset insane not transparent?
Gabriel
post Apr 4 2003, 11:20
LAME developer
David, would you try adding --athtype 0 to preset 128?
This could be a workaround against the source of the problem.
My idea is:
Gpsycho estimates tonality up to cwlimit (around 8kHz by default). Upper freqs are all considered to be noise sounds and not tonal sounds. As noise is generating more masking, upper freqs have more masking than lower freqs.
If I'm not wrong, Nspsytune is computing tonality up to the higher relevant part (sfb20?), so higher freqs have less masking than with Gpsycho.
Athtype 0 would increase the masking for the higher freqs. This is obviously not the right solution. Imo the right thing to do would be to have non linear spreading for Nspsytune.
- 2Bdecided   samples where aps or ape has a problem   Mar 24 2003, 17:01
- - Wombat   There are some, http://www.hydrogenaudio.org/foru...   Mar 24 2003, 18:40
- - Pio2001   QUOTE (2Bdecided @ Mar 24 2003 - 07:01 PM)On ...   Mar 24 2003, 22:11
- - KikeG   For me, the trumpets.wav sample sounds much more t...   Mar 24 2003, 23:12
- - 2Bdecided   Thank you all for your responses. I went hunting a...   Mar 25 2003, 17:25
- - Pio2001   QUOTE (2Bdecided @ Mar 25 2003 - 07:25 PM)bad...   Mar 25 2003, 20:50
- - guruboolez   --alt-preset VBR are suffering with harpsichord. E...   Mar 25 2003, 21:11
- - 2Bdecided   guruboolez - thank you - you're right! W...   Mar 26 2003, 11:58
- - 2Bdecided   QUOTE (Pio2001 @ Mar 25 2003 - 07:50 PM)The p...   Mar 26 2003, 11:59
- - guruboolez   · Jump is a song from Van Halen (1984 album, but n...   Mar 26 2003, 12:03
- - 2Bdecided   Reading about the 3.94 alphas, I followed this sug...   Mar 26 2003, 16:57
- - 2Bdecided   At the risk of being a saddo who just bumps his ow...   Mar 27 2003, 11:10
- - KikeG   QUOTE (guruboolez @ Mar 25 2003 - 09:11 PM)In...   Mar 27 2003, 11:56
- - Dibrom   QUOTE (2Bdecided @ Mar 25 2003 - 09:25 AM)P.S...   Mar 27 2003, 12:02
- - Dibrom   QUOTE (2Bdecided @ Mar 26 2003 - 08:57 AM)aps...   Mar 27 2003, 12:07
- - 2Bdecided   Thank you.   Mar 27 2003, 13:25
- - 2Bdecided   To settle aps -Z vs ape -Z vs api in my own mind, ...   Mar 27 2003, 14:01
- - 2Bdecided   ?   Mar 28 2003, 11:27
- - CiTay   Hmm, --aps -Z files aren't really that much bi...   Mar 28 2003, 12:40
- - 2Bdecided   ? Sorry to bump again, but it's kind of impor...   Mar 31 2003, 11:16
- - DickD   I was searching for info on how -Z worked and foun...   Mar 31 2003, 17:14
- - KikeG   IIRC, JohnV said that there's no problem in us...   Apr 1 2003, 10:05
- - 2Bdecided   JohnV did say exactly that, but Dibrom said ...   Apr 1 2003, 10:24
- - 2Bdecided   ? With the many tests samples I've been try...   Apr 3 2003, 15:52
- - JohnV   It has been said many times that Gpsycho has often...   Apr 3 2003, 17:57
- - Dibrom   QUOTE (2Bdecided @ Apr 1 2003 - 02:24 AM)So m...   Apr 3 2003, 18:17
- - DickD   Just guessing (sorry!) but perhaps -Z could ma...   Apr 3 2003, 20:15
- - 2Bdecided   QUOTE (JohnV @ Apr 3 2003 - 04:57 PM)It has b...   Apr 4 2003, 10:53
- - 2Bdecided   QUOTE (Dibrom @ Apr 3 2003 - 05:17 PM)The poi...   Apr 4 2003, 11:11
- - Gabriel   David, would you try adding --athtype 0 to preset ...   Apr 4 2003, 11:20
- - Wombat   I use aps -Z for a long time now. I donīt encode m...   Apr 4 2003, 11:27
- - JohnV   QUOTE (2Bdecided @ Apr 4 2003 - 01:11 PM)You ...   Apr 4 2003, 12:43
- - CiTay   Okay, i changed the List of recommended LAME setti...   Apr 4 2003, 15:16
- - 2Bdecided   QUOTE (Gabriel @ Apr 4 2003 - 10:20 AM)David,...   Apr 4 2003, 16:25
- - 2Bdecided   JohnV - thanks for that long explanation. It would...   Apr 4 2003, 16:31
- - ff123   2BDecided, Thanks for that list of samples. I...   Apr 4 2003, 16:50
- - user   --alt-preset fast standard / extreme ? dev0: ...   Apr 11 2003, 14:02
- - Frank Klemm   QUOTE (JohnV @ Apr 4 2003 - 01:43 PM)Yes, usi...   Apr 11 2003, 15:41
- - 2Bdecided   QUOTE (user @ Apr 11 2003 - 01:02 PM)--alt-pr...   Apr 11 2003, 16:30
RSS Lo-Fi Version Time is now: 26th January 2015 - 05:44
