samples where aps or ape has a problem
2Bdecided
post Mar 24 2003, 17:01
ReplayGain developer
I'm sure this has been asked before, but I can't find it, and it's not in the FAQ (it should be - please!)
On which samples is --alt-preset extreme audibly better than --alt-preset standard.
On which samples is --alt-preset insane audibly better than --alt-preset extreme.
On which samples is --alt-preset insane not transparent?
2Bdecided
post Apr 4 2003, 10:53
QUOTE (JohnV @ Apr 3 2003 - 04:57 PM)
It has been said many times that Gpsycho has often for example better pre-echo control than plain vanilla nspsytune preset, so I don't know if that's anything new. Many times it has been said that the non-codelevel tweaked presets aren't necessarely always performing better than some other switches with a bunch of samples. The --alt-preset cbr 128 also suffers (although prolly not quite similarly) from the use of noise shaping type 2. Try the samples listed in this thread using --alt-preset cbr 128 -Z although this may not be ideal overall... And since GPsycho uses noise shaping type 1 by default, it performs very well with those samples which fail with ns-type2...
Yes, I know the relative strengths and weaknesses of gpsycho vs nspsytune are very very old news - I remember discussions in the r3mix forum!
Where --alt-preset cbr 128 is worse than -h -b 128, I think it's almost entirely due to nspsytune, since -Z does almost nothing to help. (On a quick check, it sounds like it does something on awe32, but not on the others). And, as you say, adding -Z to ap cbr 128 would probably cause problems elsewhere.
I know you're doing some tweaking, and introducing new presets in the current lame alphas - and also (obviously) that ABR beats CBR - but while the current FAQ recommendations still stand, can the FAQ include alternatives at 128kbps? It might be honest to suggest that FhG is worth a try. Not on a page two links down, but actually there in the list of recomended settings.
- 2Bdecided   samples where aps or ape has a problem   Mar 24 2003, 17:01
- - Wombat   There are some, http://www.hydrogenaudio.org/foru...   Mar 24 2003, 18:40
- - Pio2001   QUOTE (2Bdecided @ Mar 24 2003 - 07:01 PM)On ...   Mar 24 2003, 22:11
- - KikeG   For me, the trumpets.wav sample sounds much more t...   Mar 24 2003, 23:12
- - 2Bdecided   Thank you all for your responses. I went hunting a...   Mar 25 2003, 17:25
- - Pio2001   QUOTE (2Bdecided @ Mar 25 2003 - 07:25 PM)bad...   Mar 25 2003, 20:50
- - guruboolez   --alt-preset VBR are suffering with harpsichord. E...   Mar 25 2003, 21:11
- - 2Bdecided   guruboolez - thank you - you're right! W...   Mar 26 2003, 11:58
- - 2Bdecided   QUOTE (Pio2001 @ Mar 25 2003 - 07:50 PM)The p...   Mar 26 2003, 11:59
- - guruboolez   · Jump is a song from Van Halen (1984 album, but n...   Mar 26 2003, 12:03
- - 2Bdecided   Reading about the 3.94 alphas, I followed this sug...   Mar 26 2003, 16:57
- - 2Bdecided   At the risk of being a saddo who just bumps his ow...   Mar 27 2003, 11:10
- - KikeG   QUOTE (guruboolez @ Mar 25 2003 - 09:11 PM)In...   Mar 27 2003, 11:56
- - Dibrom   QUOTE (2Bdecided @ Mar 25 2003 - 09:25 AM)P.S...   Mar 27 2003, 12:02
- - Dibrom   QUOTE (2Bdecided @ Mar 26 2003 - 08:57 AM)aps...   Mar 27 2003, 12:07
- - 2Bdecided   Thank you.   Mar 27 2003, 13:25
- - 2Bdecided   To settle aps -Z vs ape -Z vs api in my own mind, ...   Mar 27 2003, 14:01
- - 2Bdecided   ?   Mar 28 2003, 11:27
- - CiTay   Hmm, --aps -Z files aren't really that much bi...   Mar 28 2003, 12:40
- - 2Bdecided   ? Sorry to bump again, but it's kind of impor...   Mar 31 2003, 11:16
- - DickD   I was searching for info on how -Z worked and foun...   Mar 31 2003, 17:14
- - KikeG   IIRC, JohnV said that there's no problem in us...   Apr 1 2003, 10:05
- - 2Bdecided   JohnV did say exactly that, but Dibrom said ...   Apr 1 2003, 10:24
- - 2Bdecided   ? With the many tests samples I've been try...   Apr 3 2003, 15:52
- - JohnV   It has been said many times that Gpsycho has often...   Apr 3 2003, 17:57
- - Dibrom   QUOTE (2Bdecided @ Apr 1 2003 - 02:24 AM)So m...   Apr 3 2003, 18:17
- - DickD   Just guessing (sorry!) but perhaps -Z could ma...   Apr 3 2003, 20:15
- - 2Bdecided   QUOTE (JohnV @ Apr 3 2003 - 04:57 PM)It has b...   Apr 4 2003, 10:53
- - 2Bdecided   QUOTE (Dibrom @ Apr 3 2003 - 05:17 PM)The poi...   Apr 4 2003, 11:11
- - Gabriel   David, would you try adding --athtype 0 to preset ...   Apr 4 2003, 11:20
- - Wombat   I use aps -Z for a long time now. I donīt encode m...   Apr 4 2003, 11:27
- - JohnV   QUOTE (2Bdecided @ Apr 4 2003 - 01:11 PM)You ...   Apr 4 2003, 12:43
- - CiTay   Okay, i changed the List of recommended LAME setti...   Apr 4 2003, 15:16
- - 2Bdecided   QUOTE (Gabriel @ Apr 4 2003 - 10:20 AM)David,...   Apr 4 2003, 16:25
- - 2Bdecided   JohnV - thanks for that long explanation. It would...   Apr 4 2003, 16:31
- - ff123   2BDecided, Thanks for that list of samples. I...   Apr 4 2003, 16:50
- - user   --alt-preset fast standard / extreme ? dev0: ...   Apr 11 2003, 14:02
- - Frank Klemm   QUOTE (JohnV @ Apr 4 2003 - 01:43 PM)Yes, usi...   Apr 11 2003, 15:41
- - 2Bdecided   QUOTE (user @ Apr 11 2003 - 01:02 PM)--alt-pr...   Apr 11 2003, 16:30
RSS Lo-Fi Version Time is now: 26th April 2015 - 02:44
