Fraunhofer has begun marketing HD-AAC, ISO MPEG-4 AAC-LC & SLS
rpp3po
post Jan 10 2010, 20:35
Fraunhofer IIS just presented HD-AAC at the Consumer Electronics Show in Las Vegas. It's a hybrid format which can be played back as conventional AAC on legacy devices. HD-AAC capable devices also read the SLS layer and get a lossless reconstruction of the original signal.
More details here.
MPEG-4 SLS is not really news, but Fraunhofer finally seems to be pushing this out to a broader public now. Decoders are supposed to be ready within 12 weeks for literally all current (mobile and stationary) hardware platforms.
Seems to be a great product, I hope Apple picks this up!
It's probably not necessarily better than other hybrid solutions. But it would be nice if it got enough momentum to be implemented into the top line of mobile players and their ecosystems. For example, if you would be able buy HD-AAC in the iTMS and then let it copy just the AAC-LC part to your iPod.
This post has been edited by rpp3po: Jan 10 2010, 22:35
mixminus1
post Jan 10 2010, 20:55
QUOTE (rpp3po @ Jan 10 2010, 11:35) *
...or just buy ALAC files and then have iTunes encode to AAC on-the-fly when you sync your iPod (like it already can do with the shuffle).
This would seem to be the simpler solution as it utilizes an existing format, allows the end user to choose the AAC bitrate, and should also be more efficient from a downloading and storage standpoint (assuming the HD-AAC files would be larger than ALAC due to their hybrid nature).
C.R.Helmrich
post Jan 10 2010, 23:32
QUOTE (mixminus1 @ Jan 10 2010, 21:55) *
I heard/read somewhere that the compression performance of HD-AAC is supposed to be on par with FLAC and similar dedicated lossless coders.
Chris
Garf
post Jan 11 2010, 00:28
Mad Scientist
Group: Admin
QUOTE (C.R.Helmrich @ Jan 10 2010, 23:32) *
Chris
If we don't include speed into the comparison. But yes, compression ratio is OK. One can wonder what the use of MPEG4 ALS is once you have SLS.
MPEG4 SLS (HD-AAC) will win if you need to transcode, because it only needs minimal processing to "slice" the stream to the bitrate you want, and the AAC or AAC+SLS layers are backwards compatible to LC-AAC.
mixminus1
post Jan 11 2010, 16:55
QUOTE (Garf @ Jan 10 2010, 15:28) *
Ah, didn't get that part from the block diagram in the Fraunhofer PDF.
So you can take an HD-AAC file, choose to "slice" it to 256 kb/sec or 128 kb/sec, and either of those resulting files would be playable by any device capable of LC-AAC playback?
rpp3po
post Jan 11 2010, 17:21
Both the HD-AAC and the sliced LC-AAC file can be played back on a legacy device. The LC-AAC portion of the HD-AAC file is only encoded once, though. So you can only slice a new file out at the bitrate that was originally encoded, e. g. 256 kbit/s. For other bitrates you need to re-encode the lossless data.
This post has been edited by rpp3po: Jan 11 2010, 17:22
Garf
post Jan 11 2010, 17:42
Mad Scientist
Group: Admin
QUOTE (rpp3po @ Jan 11 2010, 17:21) *
To clarify, you can only slice out a new file at a higher bitrate than what the LC-AAC part was originally encoded with. So applications of HD-AAC would generally encode the LC-AAC at something lower like 96 or 128kbps, rather than a higher bitrate.
If the LC-AAC part of the file was encoded at 128kbps, you can still slice out a 256kbps HD-AAC file, which would be 128kbps LC-AAC plus 128kbps correction layer. The correction layer is very efficient and the combination could reasonably be compared to a 256kbps LC-AAC file.
The resulting file will play back as a 256kbps file in a HD-AAC player and like 128kbps in a LC-AAC player.
rpp3po
post Jan 11 2010, 19:28
While everything you write is correct, I think we have used different meanings of "slicing out". There are three types of files:
  1. HD-AAC with complete SLS content: lossless
  2. HD-AAC with partial SLS content: high quality lossy.
  3. Plain LC-AAC "sliced" or stripped from a HE-AAC file.
All three can be played back on legacy AAC players without modification. The latter will only access the embedded LC-AAC part, though. While being compatible that means wasting a lot of space, which one could use otherwise on those devices. So you can strip of all HD-content from an HD-AAC file and just upload the plain LC-AAC part to those devices.
Players with real HD-AAC support can play category 1 & 2 files with all features enabled. Category 2 files are a kind of a cross-breed. They are lossy but one can allocate an arbitrary amount of SLS data for higher quality. Up to 100% when they become category 1 files. So the user can choose exactly how much space he is willing to spend.
Personally, if I would be able to chose options myself, I would not go for a <= 128kbit/s LC-AAC base stream, but for about ~192kbit/s, That's my intended rate for mobile use and I don't expect older iPods ever to get updated for HD-AAC. Partial SLS content would be inaccessible for those. I don't expect category 2 to find broad acceptance anyway.
Request this feature here (apple.com) if you want HD-AAC support in iTunes! Apple really pays much attention to customer feedback.
This post has been edited by rpp3po: Jan 11 2010, 19:43
rpp3po
post Jan 11 2010, 20:34
I think, if Fraunhofer wants this to be a success, they must have an unlicensed encoder and decoder out in the wild soon. I don't think that they can otherwise build enough momentum while the technology is still hot. The market is pretty saturated with formats. FLAC has already convinced some bigger labels. And the little extra-scalability-feature won't turn the tide of the world just because they are Fraunhofer and had success once.
Microsoft and Adobe have build monopolies on business facts like that. But I don't have much hope for Fraunhofer. Those institutions usually don't have the organizational structure, where a decision like that can really be made. Scientists are used to having to cover their asses consistently for every step into the unknown. And who would voluntarily take responsibility for a step like that. By contrast for real businesses like MS and Adobe taking risks is routine business.
This post has been edited by rpp3po: Jan 11 2010, 20:37
Garf
post Jan 11 2010, 21:48
Mad Scientist
Group: Admin
QUOTE (rpp3po @ Jan 11 2010, 20:34) *
I'm not sure what you mean by unlicensed, but MPEG 4 SLS is an ISO standard and can be implemented by anyone. No need for Fraunhofer for that. They're just one firm that implemented it, and try to sell their codec which is named HD-AAC. Just like the HE-AAC standard was sold by Coding Technologies as aacPlus.
This standard is probably covered by a boatload of patents, and will for sure be covered by those for LC-AAC. Fraunhofer doesn't have any particular decision power about how they will be licensed.
rpp3po
post Jan 11 2010, 23:41
QUOTE (Garf @ Jan 11 2010, 21:48) *
I'm not going to implement it, are you? I'm talking about their software, a command line encoder and decoder for example, that everyone can play around with. A frontend here, a Foobar wrapper plugin there... Let people play freely with it. Until it doesn't get too commercial you can allow stuff to stay beneath your radar and let it build your momentum. When you have reached sufficient market share, you can still tighten your policies.
This post has been edited by rpp3po: Jan 12 2010, 00:28
Garf
post Jan 11 2010, 23:52
Mad Scientist
Group: Admin
QUOTE (rpp3po @ Jan 11 2010, 23:41) *
If it wasn't patented up the wazoo with royalties asked even for free implementations, that might happen (by me or anyone, for that matter).
As it is now, why bother?
- rpp3po   Fraunhofer has begun marketing HD-AAC   Jan 10 2010, 20:35
- - Brent   You know, if only for the ridiculous ease of use w...   Jan 10 2010, 20:48
- - mixminus1   QUOTE (rpp3po @ Jan 10 2010, 11:35) For e...   Jan 10 2010, 20:55
|- - /mnt   Hopefully this might work better then the HD Mp3 f...   Jan 10 2010, 21:18
|- - C.R.Helmrich   QUOTE (mixminus1 @ Jan 10 2010, 21:55) Th...   Jan 10 2010, 23:32
|- - Garf   QUOTE (C.R.Helmrich @ Jan 10 2010, 23:32)...   Jan 11 2010, 00:28
|- - C.R.Helmrich   QUOTE (Garf @ Jan 11 2010, 01:28) One can...   Jan 11 2010, 00:47
||- - SebastianG   QUOTE (C.R.Helmrich @ Jan 11 2010, 00:47)...   Jan 11 2010, 15:16
|- - odyssey   Garf: Will Nero release an encoder capable of util...   Jan 11 2010, 09:51
||- - Sebastian Mares   QUOTE (odyssey @ Jan 11 2010, 09:51) Garf...   Jan 11 2010, 12:24
||- - odyssey   QUOTE (Sebastian Mares @ Jan 11 2010, 12...   Jan 11 2010, 13:00
||- - Garf   QUOTE (odyssey @ Jan 11 2010, 13:00) Wasn...   Jan 11 2010, 14:59
||- - odyssey   QUOTE (Garf @ Jan 11 2010, 14:59) I quit ...   Jan 11 2010, 15:59
|- - KFal   QUOTE (Brent @ Jan 10 2010, 21:48) You kn...   Jan 11 2010, 13:10
|- - mixminus1   QUOTE (Garf @ Jan 10 2010, 15:28) MPEG4 S...   Jan 11 2010, 16:55
|- - rpp3po   Both the HD-AAC and the sliced LC-AAC file can be ...   Jan 11 2010, 17:21
|- - Garf   QUOTE (rpp3po @ Jan 11 2010, 17:21) Both ...   Jan 11 2010, 17:42
|- - mixminus1   Yep, got it, thanks!   Jan 11 2010, 19:17
|- - rpp3po   While everything you write is correct, I think we ...   Jan 11 2010, 19:28
|- - rpp3po   I think, if Fraunhofer wants this to be a success,...   Jan 11 2010, 20:34
|- - Garf   QUOTE (rpp3po @ Jan 11 2010, 20:34) I thi...   Jan 11 2010, 21:48
||- - benski   QUOTE (Garf @ Jan 11 2010, 15:48) QUOTE (...   Jan 11 2010, 21:50
||- - rpp3po   QUOTE (Garf @ Jan 11 2010, 21:48) I'm...   Jan 11 2010, 23:41
||- - Garf   QUOTE (rpp3po @ Jan 11 2010, 23:41) QUOTE...   Jan 11 2010, 23:52
|- - Mike Giacomelli   QUOTE (rpp3po @ Jan 11 2010, 14:34) Micro...   Jan 11 2010, 21:52
- - andy o   Will be interesting to see how this affects the au...   Jan 11 2010, 10:58
|- - odyssey   QUOTE (andy o @ Jan 11 2010, 10:58) Peopl...   Jan 11 2010, 13:03
- - Kvanto   Does anyone tried to compile reference mpeg4 sls e...   Feb 18 2010, 03:32
- - Larson   http://www.youtube.com/watch?v=JESMLDu_AyM...playe...   Mar 11 2010, 13:02
- - darkbyte   As i've read somewhere the next version of Win...   Nov 14 2011, 18:16
- - menno   Nero 11 includes HD-AAC encoding (in Recode).   Nov 14 2011, 19:21
- - darkbyte   QUOTE (menno @ Nov 14 2011, 20:21) Nero 1...   Nov 14 2011, 20:58
- - menno   All Nero 11 applications will be able to playback/...   Nov 14 2011, 21:23
- - darkbyte   QUOTE (menno @ Nov 14 2011, 22:23) All Ne...   Nov 14 2011, 22:20
- - Ljubo44   How to convert audio file with nero recode 11. The...   Nov 26 2011, 02:40
- - Sebastian Mares   Works only when encoding video files AFAIK.   Nov 26 2011, 09:06
- - darkbyte   I hope that the command line encoder gets updated ...   Nov 27 2011, 18:08
|- - benski   QUOTE (darkbyte @ Nov 27 2011, 13:08) I g...   Mar 14 2012, 18:58
- - lvqcl   QUOTE I haven't found any SLS encoded file yet...   Nov 27 2011, 19:31
|- - darkbyte   QUOTE (lvqcl @ Nov 27 2011, 20:31) QUOTE ...   Nov 27 2011, 20:21
- - Ljubo44   I have problem with: libtsp.lib , in mpeg4sls/impo...   Nov 29 2011, 04:16
- - darkbyte   Any success since then Ljubo44?   Dec 10 2011, 17:49
- - Ljubo44   This is hard for compiling, please heelp. any with...   Mar 14 2012, 02:18
|- - nu774   QUOTE (Ljubo44 @ Mar 14 2012, 10:18) This...   Mar 14 2012, 09:37
- - eahm   QUOTE (rpp3po @ Jan 11 2010, 11:28) Reque...   Mar 14 2012, 10:11
- - darkbyte   QUOTE (benski @ Mar 14 2012, 19:58) QUOTE...   Aug 5 2012, 23:24
- - infoleather   These generated files to LC-AAC playback on any de...   Aug 29 2012, 06:17
RSS Lo-Fi Version Time is now: 3rd June 2015 - 13:51
