Fraunhofer has begun marketing HD-AAC, ISO MPEG-4 AAC-LC & SLS
rpp3po
post Jan 10 2010, 20:35
Fraunhofer IIS just presented HD-AAC at the Consumer Electronics Show in Las Vegas. It's a hybrid format which can be played back as conventional AAC on legacy devices. HD-AAC capable devices also read the SLS layer and get a lossless reconstruction of the original signal.
More details here.
MPEG-4 SLS is not really news, but Fraunhofer finally seems to be pushing this out to a broader public now. Decoders are supposed to be ready within 12 weeks for literally all current (mobile and stationary) hardware platforms.
Seems to be a great product, I hope Apple picks this up!
It's probably not necessarily better than other hybrid solutions. But it would be nice if it got enough momentum to be implemented into the top line of mobile players and their ecosystems. For example, if you would be able buy HD-AAC in the iTMS and then let it copy just the AAC-LC part to your iPod.
This post has been edited by rpp3po: Jan 10 2010, 22:35
mixminus1
post Jan 10 2010, 20:55
QUOTE (rpp3po @ Jan 10 2010, 11:35) *
...or just buy ALAC files and then have iTunes encode to AAC on-the-fly when you sync your iPod (like it already can do with the shuffle).
This would seem to be the simpler solution as it utilizes an existing format, allows the end user to choose the AAC bitrate, and should also be more efficient from a downloading and storage standpoint (assuming the HD-AAC files would be larger than ALAC due to their hybrid nature).
C.R.Helmrich
post Jan 10 2010, 23:32
QUOTE (mixminus1 @ Jan 10 2010, 21:55) *
I heard/read somewhere that the compression performance of HD-AAC is supposed to be on par with FLAC and similar dedicated lossless coders.
Chris
Garf
post Jan 11 2010, 00:28
Server Admin
Group: Admin
QUOTE (C.R.Helmrich @ Jan 10 2010, 23:32) *
Chris
If we don't include speed into the comparison. But yes, compression ratio is OK. One can wonder what the use of MPEG4 ALS is once you have SLS.
MPEG4 SLS (HD-AAC) will win if you need to transcode, because it only needs minimal processing to "slice" the stream to the bitrate you want, and the AAC or AAC+SLS layers are backwards compatible to LC-AAC.
C.R.Helmrich
post Jan 11 2010, 00:47
QUOTE (Garf @ Jan 11 2010, 01:28) *
The more I think of it: with HD-AAC gaining in popularity, I think LossyWAV will have a very powerful contender.
Chris
SebastianG
post Jan 11 2010, 15:16
QUOTE (C.R.Helmrich @ Jan 11 2010, 00:47) *
I dunno... It has pros and cons. LossyWAV-like formats are fairly easy to decode. On the other hand LossyWAV's "base layer" is currently not nearly as efficient as AAC (and it never will be). But I think it could perform much better with a simple, good and conservative psychoacoustic model + dynamic noise shaper (I can even offer code for designing and using frequency-warped all-pole lattice filters as noise shaper).
SG
- rpp3po   Fraunhofer has begun marketing HD-AAC   Jan 10 2010, 20:35
- - Brent   You know, if only for the ridiculous ease of use w...   Jan 10 2010, 20:48
- - mixminus1   QUOTE (rpp3po @ Jan 10 2010, 11:35) For e...   Jan 10 2010, 20:55
|- - /mnt   Hopefully this might work better then the HD Mp3 f...   Jan 10 2010, 21:18
|- - C.R.Helmrich   QUOTE (mixminus1 @ Jan 10 2010, 21:55) Th...   Jan 10 2010, 23:32
|- - Garf   QUOTE (C.R.Helmrich @ Jan 10 2010, 23:32)...   Jan 11 2010, 00:28
|- - C.R.Helmrich   QUOTE (Garf @ Jan 11 2010, 01:28) One can...   Jan 11 2010, 00:47
||- - SebastianG   QUOTE (C.R.Helmrich @ Jan 11 2010, 00:47)...   Jan 11 2010, 15:16
|- - odyssey   Garf: Will Nero release an encoder capable of util...   Jan 11 2010, 09:51
||- - Sebastian Mares   QUOTE (odyssey @ Jan 11 2010, 09:51) Garf...   Jan 11 2010, 12:24
||- - odyssey   QUOTE (Sebastian Mares @ Jan 11 2010, 12...   Jan 11 2010, 13:00
||- - Garf   QUOTE (odyssey @ Jan 11 2010, 13:00) Wasn...   Jan 11 2010, 14:59
||- - odyssey   QUOTE (Garf @ Jan 11 2010, 14:59) I quit ...   Jan 11 2010, 15:59
|- - KFal   QUOTE (Brent @ Jan 10 2010, 21:48) You kn...   Jan 11 2010, 13:10
|- - mixminus1   QUOTE (Garf @ Jan 10 2010, 15:28) MPEG4 S...   Jan 11 2010, 16:55
|- - rpp3po   Both the HD-AAC and the sliced LC-AAC file can be ...   Jan 11 2010, 17:21
|- - Garf   QUOTE (rpp3po @ Jan 11 2010, 17:21) Both ...   Jan 11 2010, 17:42
|- - mixminus1   Yep, got it, thanks!   Jan 11 2010, 19:17
|- - rpp3po   While everything you write is correct, I think we ...   Jan 11 2010, 19:28
|- - rpp3po   I think, if Fraunhofer wants this to be a success,...   Jan 11 2010, 20:34
|- - Garf   QUOTE (rpp3po @ Jan 11 2010, 20:34) I thi...   Jan 11 2010, 21:48
||- - benski   QUOTE (Garf @ Jan 11 2010, 15:48) QUOTE (...   Jan 11 2010, 21:50
||- - rpp3po   QUOTE (Garf @ Jan 11 2010, 21:48) I'm...   Jan 11 2010, 23:41
||- - Garf   QUOTE (rpp3po @ Jan 11 2010, 23:41) QUOTE...   Jan 11 2010, 23:52
|- - Mike Giacomelli   QUOTE (rpp3po @ Jan 11 2010, 14:34) Micro...   Jan 11 2010, 21:52
- - andy o   Will be interesting to see how this affects the au...   Jan 11 2010, 10:58
|- - odyssey   QUOTE (andy o @ Jan 11 2010, 10:58) Peopl...   Jan 11 2010, 13:03
- - Kvanto   Does anyone tried to compile reference mpeg4 sls e...   Feb 18 2010, 03:32
- - Larson   http://www.youtube.com/watch?v=JESMLDu_AyM...playe...   Mar 11 2010, 13:02
- - darkbyte   As i've read somewhere the next version of Win...   Nov 14 2011, 18:16
- - menno   Nero 11 includes HD-AAC encoding (in Recode).   Nov 14 2011, 19:21
- - darkbyte   QUOTE (menno @ Nov 14 2011, 20:21) Nero 1...   Nov 14 2011, 20:58
- - menno   All Nero 11 applications will be able to playback/...   Nov 14 2011, 21:23
- - darkbyte   QUOTE (menno @ Nov 14 2011, 22:23) All Ne...   Nov 14 2011, 22:20
- - Ljubo44   How to convert audio file with nero recode 11. The...   Nov 26 2011, 02:40
- - Sebastian Mares   Works only when encoding video files AFAIK.   Nov 26 2011, 09:06
- - darkbyte   I hope that the command line encoder gets updated ...   Nov 27 2011, 18:08
|- - benski   QUOTE (darkbyte @ Nov 27 2011, 13:08) I g...   Mar 14 2012, 18:58
- - lvqcl   QUOTE I haven't found any SLS encoded file yet...   Nov 27 2011, 19:31
|- - darkbyte   QUOTE (lvqcl @ Nov 27 2011, 20:31) QUOTE ...   Nov 27 2011, 20:21
- - Ljubo44   I have problem with: libtsp.lib , in mpeg4sls/impo...   Nov 29 2011, 04:16
- - darkbyte   Any success since then Ljubo44?   Dec 10 2011, 17:49
- - Ljubo44   This is hard for compiling, please heelp. any with...   Mar 14 2012, 02:18
|- - nu774   QUOTE (Ljubo44 @ Mar 14 2012, 10:18) This...   Mar 14 2012, 09:37
- - eahm   QUOTE (rpp3po @ Jan 11 2010, 11:28) Reque...   Mar 14 2012, 10:11
- - darkbyte   QUOTE (benski @ Mar 14 2012, 19:58) QUOTE...   Aug 5 2012, 23:24
- - infoleather   These generated files to LC-AAC playback on any de...   Aug 29 2012, 06:17
RSS Lo-Fi Version Time is now: 5th March 2015 - 21:56
