8 Pages V  « < 6 7 8
Closed TopicStart new topic
foobar2000 v1.0: discussion
Yirkha
post Jan 18 2010, 01:51
Post #176
Group: FB2K Moderator
That behaviour depends on the notification area icon settings.
Fractal_Mortalit...
post Jan 18 2010, 02:16
Post #177
Oh, woops. I had no idea that had anything to do with it.
http://www.last.fm/user/magnumforce2006
Hamallainen
post Jan 18 2010, 02:24
Post #178
QUOTE (Fractal_Mortality @ Jan 18 2010, 00:45) *
Is there any way to recreate the old "View Now Playing" behavior? Currently, when that command is executed, a popup balloon appears over the foobar icon and displays the current playing track. The old behavior actually changed the focus of the selection to the track that was currently playing. This was very useful when a lot of playlists were open and you wanted to quickly go to the one that was playing.
I think what you are looking for is ACTIVATE NOW PLAYING which is no longer in 1.0 it seems. I don't know why. I also used it a lot
Yirkha
post Jan 18 2010, 02:32
Post #179
That has nothing to do with the core, though. If you don't see "Activate Now Playing" anymore, you forgot to (re)install Columns UI.
Hamallainen
post Jan 18 2010, 11:17
Post #180
QUOTE (Yirkha @ Jan 18 2010, 02:32) *
My bad, thanks for reminding me this.
Garson
post Jan 19 2010, 16:41
Post #181
Tell me please, why at equalizer activation there is an effect of normalisation of loudness?
I use version 1.0. Thanks
Yirkha
post Jan 20 2010, 00:20
Post #182
There is not.
Mastermnd
post Jan 20 2010, 19:36
Post #183
QUOTE (Garson @ Jan 19 2010, 17:41) *
QUOTE (Yirkha @ Jan 20 2010, 01:20) *
There is not.
Yes there is. I was just going to post about this, glad someone else noticed it.
Something was done to the peaks processing or something
I have completely disabled ReplayGain, and still get random frequent loudness changes when the EQ is on (no other DSPs active).
This is the sole reason i am considering switching back to the 0.9 series.
I can attach my equalizer preset if anyone needs it.
This post has been edited by Mastermnd: Jan 20 2010, 19:40
Case
post Jan 20 2010, 20:38
Post #184
Group: Developer (Donating)
EQ volume pump effect seems to be side effect of using float output on Vista/7 with DirectSound. Windows mixer seems to lower volume for samples that would clip. If you try WASAPI output you should get expected output.
Garson
post Jan 20 2010, 21:11
Post #185
QUOTE (Case @ Jan 20 2010, 22:38) *
WASAPI output
What is the WASAPI output? The primary sound driver?
shakey_snake
post Jan 21 2010, 01:08
Post #186
http://www.foobar2000.org/components/view/foo_out_wasapi
elevatorladylevitateme
Dandruff
post Jan 21 2010, 05:53
Post #187
QUOTE (Yirkha @ Jan 18 2010, 01:51) *
There's a bug with the notification area icon in foobar2000 1.0: http://www.hydrogenaudio.org/forums/index....showtopic=78027
Yirkha
post Jan 21 2010, 12:58
Post #188
Yes, that report has been read and the bug fixed.
No need to bump this poor thread with it.
Let's move back to the usual routine - start a new topic for each question or comment instead of piling up everything in one thread with generic title.
8 Pages V  « < 6 7 8
RSS Lo-Fi Version Time is now: 25th January 2015 - 15:47
