Old flac version to last version
Yuna
post Jan 6 2010, 22:22
Again the search box never give me results but always give me the first page of subforums. dry.gif
Then i will ask my question here.
I use foobar2k v.9.6.9 as audio player (default)
My music library contains mostly flac files and some lossy files.
My flac files are mostly to latest version (libFLAC 1.2.1 20070917) because they are ripped of my own cds.
But some are in the oldest version such as (libFLAC 1.1.2 20050205) or (libFLAC 1.1.4 20070213).
I want them to last version. What is the procedure I do?
I tried of convert back in wav theses flac files but for each tracks i keep receive this message : "Corrupted flac stream" (with foobar2k). what that means ?
thx for help a novice.
foobar2000 v.1.3
FLAC -8 is the best!
Heemlock
post Oct 18 2011, 12:30
Hello!
Should i re-encode a libFLAC 1.1.3 encoded FLAC file to libFLAC 1.2.1 (the latest) with foobar2k?
Is there any benefit of doing this or should i leave it as it is?
mjb2006
post Oct 18 2011, 13:05
I don't see anything of note in the changelog between those versions. It's not like a lossy codec where the sound can change from version to version. The output is always the same, even if there are internal changes to the FLAC file's structure. There were improvements in the compression algorithms, but it's all backward compatible. And there was a security issue, but it only applies to decoding specially crafted FLACs. Nothing is wrong with the ones you created with 1.1.x. Recompressing would just be a waste of time.
This post has been edited by mjb2006: Oct 18 2011, 13:05
- Yuna   Old flac version to last version   Jan 6 2010, 22:22
- - Tony T   QUOTE (Yuna @ Jan 6 2010, 22:22) My flac ...   Jan 6 2010, 22:40
- - Rain   Sorry, how can I do this in WavPack as well? Check...   Jan 6 2010, 23:03
- - Stereodude   Can I ask why you want to convert from an old vers...   Jan 7 2010, 00:08
|- - Tony T   QUOTE (Stereodude @ Jan 7 2010, 01:08) Ca...   Jan 7 2010, 00:16
- - JunkieXL   By that he means they've added alot of new fea...   Jan 7 2010, 01:54
- - greynol   Of this metadata support, how much of this can...   Jan 7 2010, 02:14
- - Yuna   QUOTE (Stereodude @ Jan 6 2010, 18:08) Ca...   Jan 7 2010, 04:13
|- - Tony T   Are you using FLAC?   Jan 7 2010, 15:27
- - Yuna   QUOTE (Tony T @ Jan 7 2010, 09:27) Are yo...   Jan 8 2010, 00:36
|- - Tony T   What happens if you decode with FLAC from the comm...   Jan 8 2010, 02:13
- - Porcus   Seems to be a suitable thread to necromance, rathe...   Aug 7 2011, 17:00
- - Porcus   Testing libFLAC 1.2.1, it seems to transfer album ...   Aug 8 2011, 16:24
- - Phixion   I update all of my old FLAC files to the latest ve...   Oct 17 2011, 21:20
- - Heemlock   Hello! Should i re-encode a libFLAC 1.1.3 enco...   Oct 18 2011, 12:30
|- - mjb2006   I don't see anything of note in the changelog ...   Oct 18 2011, 13:05
- - Heemlock   Thank You! Well, only 6-7 albums are encoded ...   Oct 18 2011, 17:54
- - greynol   If there's a problem with your computer then y...   Oct 18 2011, 19:22
- - Heemlock   Thanks greynol! When i tried to re-encode one ...   Oct 19 2011, 23:09
|- - Porcus   QUOTE (Heemlock @ Oct 20 2011, 00:09) Whe...   Oct 20 2011, 13:14
- - Wombat   I only can think of one reason to worry about diff...   Oct 19 2011, 23:36
|- - Porcus   QUOTE (Wombat @ Oct 20 2011, 00:36) I onl...   Oct 20 2011, 14:34
- - Heemlock   QUOTE (Porcus @ Oct 20 2011, 14:14) I rec...   Oct 21 2011, 03:58
|- - Porcus   QUOTE (Heemlock @ Oct 21 2011, 04:58) hig...   Oct 22 2011, 11:53
- - SamDeRe81   What you need is called Traders Little Helper and ...   Oct 23 2011, 19:02
|- - Porcus   QUOTE (SamDeRe81 @ Oct 23 2011, 20:02) Tr...   Oct 23 2011, 20:47
|- - SamDeRe81   QUOTE (Porcus @ Oct 23 2011, 12:47) QUOTE...   Oct 23 2011, 22:46
- - Heemlock   Hi again! Finally i have time to convert my re...   Nov 6 2011, 21:46
|- - Porcus   QUOTE (Heemlock @ Nov 6 2011, 22:46) Is t...   Nov 6 2011, 22:59
- - db1989   Although metadata, of course, would not affect the...   Nov 6 2011, 23:22
- - Heemlock   Thanks Porcus and db1989 I'm finished the con...   Nov 9 2011, 19:55
- - db1989   QUOTE (Heemlock @ Nov 9 2011, 18:55) Bit-...   Nov 9 2011, 20:10
RSS Lo-Fi Version Time is now: 2nd September 2015 - 21:09
