Old flac version to last version
Yuna
post Jan 6 2010, 22:22
Again the search box never give me results but always give me the first page of subforums. dry.gif
Then i will ask my question here.
I use foobar2k v.9.6.9 as audio player (default)
My music library contains mostly flac files and some lossy files.
My flac files are mostly to latest version (libFLAC 1.2.1 20070917) because they are ripped of my own cds.
But some are in the oldest version such as (libFLAC 1.1.2 20050205) or (libFLAC 1.1.4 20070213).
I want them to last version. What is the procedure I do?
I tried of convert back in wav theses flac files but for each tracks i keep receive this message : "Corrupted flac stream" (with foobar2k). what that means ?
thx for help a novice.
foobar2000 v.1.3
FLAC -8 is the best!
Yuna
post Jan 7 2010, 04:13
QUOTE (Stereodude @ Jan 6 2010, 18:08) *
Can I ask why you want to convert from an old version of FLAC to a new version of FLAC? They're both lossless, so what's gained?
But if have none advantage to go of flac 1.1.2 to 1.2.1 then ... I'll think
QUOTE (Tony T @ Jan 6 2010, 16:40) *
on the old FLAC files, just "flac filename.flac --force"
http://flac.sourceforge.net/documentation_tools_flac.html
"flac abc.flac --force
This one's a little tricky: notice that flac is in encode mode by default (you have to specify -d to decode) so this command actually recompresses abc.flac back to abc.flac. --force is needed to make sure you really want to overwrite abc.flac with a new version. Why would you want to do this? It allows you to recompress an existing FLAC file with (usually) higher compression options or a newer version of FLAC and preserve all the metadata like tags too."
I nothing understood here. What is "flac filename.flac --force" and with what programs you do that?
Also i mentionned in my first post that when i convert back the flac files (v.1.1.2) in wav I keep get for each track the error message "Corrupted Flac Stream". it is because the decoder/encoder flac is v1.2.1 now ? The error is for corrupted metadata or ?
thx for our response
foobar2000 v.1.3
- Yuna   Old flac version to last version   Jan 6 2010, 22:22
- - Tony T   QUOTE (Yuna @ Jan 6 2010, 22:22) My flac ...   Jan 6 2010, 22:40
- - Rain   Sorry, how can I do this in WavPack as well? Check...   Jan 6 2010, 23:03
- - Stereodude   Can I ask why you want to convert from an old vers...   Jan 7 2010, 00:08
|- - Tony T   QUOTE (Stereodude @ Jan 7 2010, 01:08) Ca...   Jan 7 2010, 00:16
- - JunkieXL   By that he means they've added alot of new fea...   Jan 7 2010, 01:54
- - greynol   Of this metadata support, how much of this can...   Jan 7 2010, 02:14
- - Yuna   QUOTE (Stereodude @ Jan 6 2010, 18:08) Ca...   Jan 7 2010, 04:13
|- - Tony T   Are you using FLAC?   Jan 7 2010, 15:27
- - Yuna   QUOTE (Tony T @ Jan 7 2010, 09:27) Are yo...   Jan 8 2010, 00:36
|- - Tony T   What happens if you decode with FLAC from the comm...   Jan 8 2010, 02:13
- - Porcus   Seems to be a suitable thread to necromance, rathe...   Aug 7 2011, 17:00
- - Porcus   Testing libFLAC 1.2.1, it seems to transfer album ...   Aug 8 2011, 16:24
- - Phixion   I update all of my old FLAC files to the latest ve...   Oct 17 2011, 21:20
- - Heemlock   Hello! Should i re-encode a libFLAC 1.1.3 enco...   Oct 18 2011, 12:30
|- - mjb2006   I don't see anything of note in the changelog ...   Oct 18 2011, 13:05
- - Heemlock   Thank You! Well, only 6-7 albums are encoded ...   Oct 18 2011, 17:54
- - greynol   If there's a problem with your computer then y...   Oct 18 2011, 19:22
- - Heemlock   Thanks greynol! When i tried to re-encode one ...   Oct 19 2011, 23:09
|- - Porcus   QUOTE (Heemlock @ Oct 20 2011, 00:09) Whe...   Oct 20 2011, 13:14
- - Wombat   I only can think of one reason to worry about diff...   Oct 19 2011, 23:36
|- - Porcus   QUOTE (Wombat @ Oct 20 2011, 00:36) I onl...   Oct 20 2011, 14:34
- - Heemlock   QUOTE (Porcus @ Oct 20 2011, 14:14) I rec...   Oct 21 2011, 03:58
|- - Porcus   QUOTE (Heemlock @ Oct 21 2011, 04:58) hig...   Oct 22 2011, 11:53
- - SamDeRe81   What you need is called Traders Little Helper and ...   Oct 23 2011, 19:02
|- - Porcus   QUOTE (SamDeRe81 @ Oct 23 2011, 20:02) Tr...   Oct 23 2011, 20:47
|- - SamDeRe81   QUOTE (Porcus @ Oct 23 2011, 12:47) QUOTE...   Oct 23 2011, 22:46
- - Heemlock   Hi again! Finally i have time to convert my re...   Nov 6 2011, 21:46
|- - Porcus   QUOTE (Heemlock @ Nov 6 2011, 22:46) Is t...   Nov 6 2011, 22:59
- - db1989   Although metadata, of course, would not affect the...   Nov 6 2011, 23:22
- - Heemlock   Thanks Porcus and db1989 I'm finished the con...   Nov 9 2011, 19:55
- - db1989   QUOTE (Heemlock @ Nov 9 2011, 18:55) Bit-...   Nov 9 2011, 20:10
RSS Lo-Fi Version Time is now: 2nd June 2015 - 21:42
