Development of ABC/HR for Java, Split from "Closing listening-tests.info"
Sebastian Mares
post Dec 6 2009, 22:53
BTW, another problem is that schnofler apparently stopped development of ABC/HR for Java, coding something in Silverlight would require an expensive IIS server, and I don't know how to program in Air or Flash or even if those would be suitable for a testing application. ABC/HR has certain limitations and bugs that I don't know how to fix. Last time it didn't work correctly with JRE 1.6 and even with JRE 1.5 it had the problem that on some machines, a click was hearable when playing certain files (it always happened for the same files).
http://listening-tests.hydrogenaudio.org/sebastian/
stigc
post Jan 4 2010, 22:57
QUOTE (Sebastian Mares @ Dec 6 2009, 22:53) *
If you have the source, i could try fix the errors and missing features.
rpp3po
post Jan 27 2010, 23:58
Version 0.53a
  • Made the source changes for SwingWorker Java 1.5 compatible again by just fixing import directives and leaving the legacy code alone.
  • Included clicodecs.cfg in binary package.
This is only a very minor update. The "Loading Samples" dialog doesn't hang with this build on my machine. Verified with Java 1.6.0_17 on Mac OS X 10.6.2 and Java 1.6.0_18 on Windows XP and Alex B's config. Stigc's fix is also included.
Application binary (Java 6 compiled):
Attached File  abchr_java_0.53a_bin.zip ( 689.85K ) Number of downloads: 473
Application binary (Java 5 compiled):
Attached File  abchr_java_0.53a_bin_java5.zip ( 680.34K ) Number of downloads: 267
Full source package:
Attached File  abchr_java_0.53a_src.zip ( 611.36K ) Number of downloads: 347
Diff against 0.52b:
Attached File  abchr_java_0.52b_0.53a.diff.zip ( 1.86K ) Number of downloads: 138
The Java 5 build should also run fine on Java 6 machines. In both cases just double-click the jar to start.
This post has been edited by rpp3po: Jan 29 2010, 17:00
RSS Lo-Fi Version Time is now: 30th January 2015 - 18:20
